Author Topic: Guide to removing and cleaning mechanical switches?  (Read 2578 times)
Offline LrgDietCoke
« on: Sat, 23 March 2019, 13:29:32 »
Hey everyone. I was wondering if anyone had a guide on how to open up and clean old mechanical switches. I will be harvesting vintage cherry blacks from an old board and wanted to give them a good cleaning and lube them before using them on a new board. Any suggestions/tips would be greatly appreciated! Thanks.
Offline frydaja
  • "It's my last keyboard, I swear"
Re: Guide to removing and cleaning mechanical switches?
« Reply #1 on: Sat, 23 March 2019, 13:48:03 »
Depends on the keyboard. If the switches are plate-mounted, you need to desolder them. You don't need to desolder the switch if the switch is PCB mounted.
That said, I'm not sure if lubing vintage blacks is worth it.
Anne Pro 2 w/ Kailh Box Browns | CM Storm Quickfire TK Stealth w/ MX Browns | Unknown Chinese keyboard w/ Outemu Reds | Compaq-branded NMB RT101 | Gigabyte Force K81 w/Kailh Reds
