Author Topic: [GB] Custom/Switch Stickers [Shipping]  (Read 105739 times)
Offline elton5354
Re: [GB] Custom/Switch Stickers - ONLY $1 for 128 stickers - Ordering till 15-Oct
« Reply #50 on: Mon, 23 September 2013, 17:46:24 »
I just saw this, how?
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #51 on: Mon, 23 September 2013, 17:55:05 »
I don't know. This GB should be stickered on the homepage since it is so awesome. No?
Offline elton5354
« Reply #52 on: Mon, 23 September 2013, 18:10:16 »
Will you share the order results?
Offline MOZ
  • Busy making stuff
« Reply #53 on: Mon, 23 September 2013, 19:23:54 »
I will, there is just so much to process.
Like my current GB's I'll try to keep it as transparent as possible, with complete order details (Except ofcourse personal details)
Offline MOZ
  • Busy making stuff
« Reply #54 on: Mon, 23 September 2013, 20:41:32 »
Add order status for fixed stickers ordered thus far to OP.
Offline Latin00032
« Reply #55 on: Wed, 25 September 2013, 05:43:31 »
Do you think there is a way to make some custom stickers to use on the side of key caps like the poker has.
You can use them on key caps that don't already come with the side print.
Offline MOZ
  • Busy making stuff
« Reply #56 on: Wed, 25 September 2013, 06:38:58 »
Why not?
« Reply #57 on: Wed, 25 September 2013, 06:46:52 »
Why not?
They'd just have to be really small!! But if that is no issue this could be interesting.
Offline MOZ
  • Busy making stuff
« Reply #58 on: Fri, 27 September 2013, 03:40:37 »
Order! Order! Order! Why you slowdown people?
« Reply #59 on: Fri, 27 September 2013, 15:29:15 »
I'll order a sheet or 2 when I get money!
QFR | MJ2 TKL | "Bulgogiboard" (Keycon 104) | ctrl.alt x GON 60% | TGR Alice | Mira SE #29 | Mira SE #34 | Revo One | z | Keycult No. 1 | AIS65 | First CW87 prototype | Mech27v1 | Camp C225 | Duck Orion V1 | LZ CLS sxh | Geon Frog TKL | Hiney TKL One | Geon Glare TKL
Offline saturnotaku
« Reply #60 on: Fri, 27 September 2013, 15:50:28 »
Ordered 10 2' X 2' sheets. Exactly the kind of stuff I was looking for.  :thumb:
Offline ssdt
« Reply #61 on: Sat, 28 September 2013, 05:03:09 »
My order is not in the sheet. Do you want me to order again or did you just miss it?
Poker II         HHKB Pro 2
“We are what we repeatedly do. Excellence, therefore, is not an act, but a habit.” - Aristotle
Offline saturnotaku
« Reply #62 on: Sat, 28 September 2013, 05:28:47 »
MOZ probably hasn't gotten around to updating it yet.
Offline MOZ
  • Busy making stuff
« Reply #63 on: Sat, 28 September 2013, 07:29:43 »
I will check and get back, the sheet was suppose to auto-update, but you never know with these things.
Offline goobus
  • HHKB Elite
« Reply #64 on: Sun, 29 September 2013, 05:06:53 »
Thanks moz for yet another great value gb!
I have a dumb question: how do I modify my order?
Offline MOZ
  • Busy making stuff
« Reply #65 on: Sun, 29 September 2013, 07:49:19 »
There was a link given at the end of thr form submission, otherwise just PM me.
Offline raphdu57
« Reply #66 on: Sun, 29 September 2013, 14:02:23 »
Any updates on the MOQ of custom stickers ?
QFR with MX brown
Offline MOZ
  • Busy making stuff
« Reply #67 on: Sun, 29 September 2013, 14:03:43 »
I'll post them later tomorrow as that is a bit more work as I have to manually tally the results.
Offline MOZ
  • Busy making stuff
« Reply #68 on: Sun, 29 September 2013, 14:04:24 »
We'll reach MOQ, if we don't I probably chip in, they are so damn cheap.
Offline MOZ
  • Busy making stuff
« Reply #69 on: Sun, 29 September 2013, 14:11:10 »
Your order didn't go through, please submit it again.
Offline saturnotaku
« Reply #70 on: Mon, 30 September 2013, 07:48:30 »
My name appears on the order sheet but at a quantity of zero. I only ordered plain vinyl sheets (no stickers), though. Has that been noted somewhere?
Offline MOZ
  • Busy making stuff
« Reply #71 on: Mon, 30 September 2013, 07:53:08 »
Don't worry I have your order, I just haven't had time to update the custom stickers, vinyls and tiered pricing yet, since it has to be done manually.
Offline SigLogical
  • 5 prototypes built
« Reply #72 on: Mon, 30 September 2013, 10:22:17 »
Ordered  ;) i hope it shows up with no problem
HHKB Pro Hybrid Type-S
Offline Reomero
  • Manual breather
« Reply #73 on: Mon, 30 September 2013, 10:51:00 »
Order submitted. :)
Offline JonasDK
  • Let me poo on you
« Reply #74 on: Mon, 30 September 2013, 15:53:35 »
When is this GB going to end ^^?
Offline MOZ
  • Busy making stuff
« Reply #75 on: Mon, 30 September 2013, 16:05:08 »
It says in the title, 15th Oct!
Offline JonasDK
  • Let me poo on you
« Reply #76 on: Mon, 30 September 2013, 16:07:02 »
 :-[ I was a bit too quick there. Sorry.
Offline MOZ
  • Busy making stuff
« Reply #77 on: Mon, 30 September 2013, 16:46:37 »
Don't worry, ti is the excitement!
Ordered way more colors of stickers than I actually need. Guess I'll find a use for them eventually :p
I'm excited.
Offline ssdt
Alright, thanks for the information! I'll order again right now!
edit: done!
« Last Edit: Wed, 02 October 2013, 17:41:33 by ssdt »
Poker II         HHKB Pro 2
Offline nickwalt
Just submitted order, but think I've missed a step or two.
Completed 2 stages, for fixed and tiered price switch stickers.
It didn't push me to a 3rd stage.
I was expecting somewhere to enter custom/plain orders.
Were those intended to just go in the comments?
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
Nice!
Offline HesterDW
You don't have to desolder the switches to remove the top half on a plate mounted board right?
Offline MOZ
  • Busy making stuff
Depends on the plate. If it has cutouts for the switch that allow you to, then you den't need to, otherwise, you will have to.
The custom stickers order was part of the first form, let me check your order and get back to you.
Offline MKULTRA
  • telling it how it is
Just submitted my order.  Got a bunch of stuff.  Who knows how much it will cost.  Thanks MOZ!
Offline LechnerDE
Placed my order for 13 different stickers sheets.
I have no idea what to do with all of them, but at these prices I just felt I had to stock up :D
^^ that is the proper geekhack attitude ;)
Offline Paranoid
Ordered 6 sticker sheets and 5 custom zelda stickers :) Looking forward to it!
My avatar is a less than 300 px square, but it should be easily recognizable nontheless. If not, I can reupload one in a larger size.
A larger size would be appreciated
here's the original, resized to 300*300
http://i.imm.io/1hP4P.png
Do you want me to upload it elsewhere, or edit my order?
Offline MOZ
  • Busy making stuff
It's fine sir.
Offline Flamingchook
  • There are no dumb questions, only forbidden ones.
Ordered earlier and just sent you a pm about custom stickers MOZ.  :thumb:
MX: Filco Majestouch Metalic Blue 104-key w/ MX Brown, JD40 w/ MX Green, ErgoDox w/ MX Blue, GHPad w/ MX Blue. Topre: Realforce 87U 45g. BS: IBM Model M 52G9700 29-OCT-93
Soon™: GH60 w/ 62g MX Clear, [CTRL]ALT 60 w/ MX Green
Offline BliTzKiN
Submitted!
Offline yicaoyimu
Just put in an order.
EDIT:
Have to put in another order to grab some stickers for my friend. MOZ, could you help combine those two orders? Big thanks.
« Last Edit: Mon, 14 October 2013, 00:34:27 by yicaoyimu »
Finally got in on this.  That's one hell of a google doc.   :p
Offline MOZ
  • Busy making stuff
EDIT:
Submit another order and just add in the comments your username and that i need to combine it with your order.
Imagine the pain making the form :p
Last two days people, although I might allow you to pay until I receive payments.
Offline Vintage
The orders will go until what time tomorrow?
Gotta pick up a moneypak at target after work tomorrow :D
CM QFR w/ MX Reds  | Logitech G900
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
I'll place my order in about 8 hours while at work tomorrow. Thought this one was running later for some reason.
Offline MOZ
  • Busy making stuff
Ordering would be allowed till end of this month.  I'm just going to start invoicing tonight and freeze the prices.
Offline MOZ
  • Busy making stuff
I've segregated the older orders for the sake of organization, and will begin tallying the orders and then begin invoicing.
I'll post final prices for the tiered pricing.
Orders are STILL OPEN until I am invoicing and receiving payments, which hopefully we can conclude by end of this month.
Offline MOZ
  • Busy making stuff
OK, this is going to be a royal PITA, I should have just used opencart/magento and opened an online store to automate payments.
I've sent out 4 invoices and messed one.
So, I'm not going to send out detailed invoices. Just totals and it might take me a day or two to sort all the things first.
