Author Topic: Continued experiments in homemade key caps...with interesting results.  (Read 72383 times)
So making homemade key caps is something that I've been wanting to try for a while.  I'm not what you would call a skilled artist, but I figured that if I can get the technique figured out, I might be able to get a friend who is to assist me.  I figured I'd share my results and my process so that anyone else who wanted to try to do the same could do it.
To begin, you'll need a volunteer key cap, masking tape, a razor blade, and some carving wax or some other carving medium (you could probably use some Crayons if you wanted).  For my key cap, I used one from the WASD sample kit.
16031-0
Set the cap on the masking tape.  Try to make it as flat as possible.  Then cut the tape flush with the key cap.
16033-1
16035-2
If you did it correctly, the base should look like this.
16037-3
Next, you need to melt the wax.  Use some sort of double boiler method to melt the wax.  I did mine by using a canning jar in a sauce pan.  Medium to medium high heat should do it.  You may need to use something to stir it to make sure it's properly melted.
16039-4
This was my first go at a wax mold. It's a wooden shim lined with saran wrap and taped together.  Just carefully place the key cap in face down.
Later I used a cardboard mold lined with saran wrap that was a little easier and seemed to work better.
16041-5
When the wax is melted, slowly pour it over the key cap.  Following that, let the wax sit for a little bit to cool down, but make sure not to wait too long.
16043-6
16045-7
Open up your mold and let it loose.  If you did it correctly, the wax should look something like this.
16047-8
16049-9
Next, you'll need to trim the wax to your carving size.  I highly recommend doing this while the wax is still warm and easily pliable.  You'll want to trim and even the base and get as close to the side wall as you can.  If you don't get close enough to the sides, your cap will be too wide for your keyboard, a problem I ran into with this first attempt.  To get the wax close enough to the side walls, you'll likely need to wait until it fully cools, but for the major trimming, it's best to do it while it's still warm.
16051-10
Here are the tools I used to then carve the key cap.
16053-11
Here's the finished product.  I'm not the most skilled artists, so I wanted to start with something a little easier to carve.
There are some problems with this cap that I didn't notice at first go.  First, it's way too tall and looks silly.  I had about 1/8" more room to carve down that I just didn't think about.  Second, I didn't follow my advice and left the sides a little too thick.  Third, I carved it sideways.  I forgot to check which side was the front of the cap and carved it 90 degrees off.  I corrected that last problem by rotating half the mold 90 degrees, but the other two weren't noticed until the mold was already made.
16055-12
For the molding supplies, I bought some Alumilite stuff from Hobby Lobby.  If you use their 40% off coupon they always have, it's not too expensive.  I think I bought the wrong molding silicon though and got a softer mold than I would like.
16057-13
Next you need to find some sort of form to put your mold in.  For mine, I used an old laundry detergent measuring cup.  You'll also want to put something in the bottom to lock the two halves of the mold together in the proper orientation.  For mine, I used some modeling clay.
16059-14
Mix your silicon with the reacting agent and pour it onto your keycap.  Wait overnight before pulling it out.  Since your mold is a two part mold, know that the mold making process is at least a two day job.
16061-15
To keep the two halves of the mold from bonding, you'll need some sort of mold release.  I used petroleum jelly for mine.  I just melted some in a spoon and applied it with a Q-tip.
I also cut the base off of the detergent cup so I could slide it over the first half of the mold instead of pushing it to the bottom.
Then just mix and pour the silicon like before and wait till the next day.
16063-16
When you're done, you should get a mold like this.
16065-17
For my first try at a key cap, I used some resin. You'll naturally have some resin that pours out the edges that you'll need to trim up.  When you pour the resin, you'll need to wait 48 hours before attempting to demold the cap.
I'm not really happy with how it turned out.  The top half turned out alright (the eyes are a little messed up)...but there are some issues once you flip it over.
16067-18
16069-19
As you can see, the stem didn't turn out quite right.  It still fits just fine and actually holds it to the Cherry stem, but it has some wobble and play.
16071-20
16073-21
For a first try, it wasn't horrible, but there certainly needs to be more experimentation with materials used to make it right.
In the future, I might try for lost-wax casting with a fine medium like plaster of paris so I can make a metal cap or see if I can find another fairly affordable medium to use that's better than resin, but not as costly as trying to make a homemade plastic injection mold (which would set me back at least $400).
« Last Edit: Tue, 21 January 2014, 21:38:24 by nubbinator »
Offline Dgsbllx
Re: My first attempt at homemade key caps...with interesting results.
« Reply #1 on: Mon, 18 March 2013, 16:17:40 »
Looks really good for a first attempt. Too much work at the moment but I'd love to have a go at creating my own as well. Your end result reminds me of a wine gum  :p
Offline blueasjim
« Reply #2 on: Mon, 18 March 2013, 16:19:06 »
I cannot see the stem pictures. Anyone else having this issue?
Great first run! Maybe a more square top would be easier than the circular face?
Either way, great job. :"D
Vortex KBT PURE [MX Red] | CM Storm [MX Blue] | CM Storm [MX Red]
Offline Tym
« Reply #3 on: Mon, 18 March 2013, 16:19:58 »
Photoshop level: 99
Offline blueasjim
« Reply #4 on: Mon, 18 March 2013, 16:27:19 »
Stem pics fixed and you have WAY more patience than I. :D
« Reply #5 on: Mon, 18 March 2013, 16:30:02 »
Haha, yeah, it is quite a bit of work, but once I get it figured out, it will be nice to have some completely unique keycaps to set my keyboards apart a little more.  If I can get some nice metal ones made at home, it will be even better.
I was thinking more of black licorice, but now that I looked up wine gum, I can definitely see that too.
The upload was borked, so I re-uploaded them and they appear to be there now.  Originally it said something about guests not being able to see the picture.
The circular face was actually pretty easy.  The main issues were just me not thinking things all the way through...like making a side too thick, not knowing exactly where the top of the donor cap was, and not double checking the key orientation before I started carving.
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #6 on: Tue, 19 March 2013, 07:28:28 »
an excellent first attempt! all i can think of when i see that is that it would make an excellent gummy snack :D
Offline jcrouse
Re: Re: My first attempt at homemade key caps...with interesting results.
« Reply #7 on: Tue, 19 March 2013, 07:39:02 »
I think of a Rolo.
Offline whiskerBox
« Reply #8 on: Tue, 19 March 2013, 07:39:27 »
Very cool nice work!
"I'm on a mission to bring down GH's anarchy of moderators" -RIPSTER jr.
Offline agodinhost
  • Soylent green is people ...
    • Dr Ian O Xaman
« Reply #9 on: Tue, 19 March 2013, 17:33:46 »
yup, gummy snack!  :D
Excellent first try, you didn't lost any finger right?
Try again, don't quit, you know that old adage don't you?
Patience is and virtue and bla bla bla ...
Offline eth0s
  • Peace & Love
« Reply #10 on: Tue, 19 March 2013, 17:42:55 »
So how much for that first nubbinator 'cap?  :p
[It could be worth something some day, you never know.]
Offline esoomenona
  • Gnillort?
« Reply #11 on: Tue, 19 March 2013, 17:45:07 »
Hmm, that thing looks familiar...
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #12 on: Tue, 19 March 2013, 18:03:44 »
Nice!  Can't wait to see G2.
Offline Turkishrambo
« Reply #13 on: Tue, 19 March 2013, 18:05:56 »
wasnt there a picture of this cap shopped with "Kill me" lol
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #14 on: Tue, 19 March 2013, 18:25:19 »
I think of a Rolo.
Keep on trying!
.... I thought of Michelangelo.
Not the artist, the teenaged mutant turtle ninja. Cowabunga! LOL!
Joking aside, thanks for posting this. Don't give up.
Quote from: Samuel Adams
Offline esoomenona
  • Gnillort?
« Reply #15 on: Tue, 19 March 2013, 18:27:50 »
There was, which is what made me want it the most. If I had been drinking something, I would've spit it up when I saw that picture.
« Reply #16 on: Tue, 19 March 2013, 18:33:54 »
It went for the price of shipping.  So if it goes for something someday, I expect 30% of sales.  I'm not a greedy man.
Yeah, I posted it to /r/mechanicalkeyboards a little while back.
Keep on trying!
Definitely not giving up.   I need to finish my RK-9000 Clear mod first, then I'll be back to experimenting some more.  I really need to try and find a better cap material.
Yes, yes there was.
Are you the person I ended up sending it to from Reddit?
« Last Edit: Tue, 19 March 2013, 18:37:24 by nubbinator »
Offline esoomenona
  • Gnillort?
« Reply #17 on: Tue, 19 March 2013, 19:58:07 »
^Yes sir, I am. <3 that picture
Offline Tarzan
  • formerly known as Greystoke
« Reply #18 on: Wed, 20 March 2013, 07:44:21 »
Nubbinator;
Your post inspired me to get way too much stuff at my local craft supply store yesterday, to try my hand at making a custom keycap.  Going to be the most expensive keycap around, by the time I actually produce one.
So far I'm at the mold-making stage, already managed to melt several stock keycaps (don't ask).  Wish me luck!
Offline ideus
  • Björkö.
« Reply #19 on: Wed, 20 March 2013, 07:51:41 »
Interesting work, keep the good work. The main difference with high pressure injection molding is the hardness of the final product. The hand made one depends on material density, :o and gravity.
« Reply #20 on: Wed, 20 March 2013, 12:29:11 »
Nubbinator;
What did you decide to use as the key cap material.  I used Alumilite resin, but I'm not sure I quite like it.
I have to ask since you said not to.  How did you melt several caps already?
I don't have the ability to do injection molding, but I was thinking about trying to adapt some bottle rocket launchers (you know the ones with 2 liter bottles and water) that I have around the home and turn them into pressure chambers for the mold.  Obviously it won't get a super high PSI, but it might help some.
« Reply #21 on: Wed, 20 March 2013, 12:30:29 »
I guess I somehow double posted.
« Last Edit: Wed, 20 March 2013, 13:38:49 by nubbinator »
Offline ideus
  • Björkö.
« Reply #22 on: Wed, 20 March 2013, 12:42:20 »
A bench press, or other mechanical manual press may be of help and it can apply a huge pressure if properly operated. For the size of a single cavity mold even a small one will fit.
Nubbinator;
Offline Tarzan
« Reply #23 on: Wed, 20 March 2013, 13:10:01 »
Nubbinator;
I was trying to make a mold from a stock cap, using Fimo (modeling clay).  This clay is oven-hardening, at 110 Celsius.  I left the key caps in the clay, as it's pretty soft, and found out the hard way that that temperature is plenty hot enough to warp stock Cherry keycaps.  Yeah, I'm a dumbass.  :-[
Interestingly, though, the PBT keycap kept it's shape just fine.
Now I'm letting the second mold harden without heat, see if that works.
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #24 on: Wed, 20 March 2013, 16:44:20 »
Maybe this could help?
feature=player_embedded
(ignore emo background music, LOL)
EDIT: Your keycap mold gets to experience SpaceCamp.
« Last Edit: Wed, 20 March 2013, 16:47:54 by Krogenar »
Offline Tarzan
« Reply #25 on: Wed, 20 March 2013, 17:01:36 »
That's pretty cool!  I've found a variety of mold-making resources online, including pressure (and/or vacuum) pots, but I had not seen anything about roto-molding! Might do something with a hollow key cap, filled with another color resin...  Hmm.
I did manage to extricate my sample key from the second mold I'd made.  I used a two-part rubber kind for stuff for the base, that's the yellow.  Once that was set, I sprayed it all down with mold release and poured a two-part epoxy casting over it, brand name is EasyCast.
16334-0
16336-1
16338-2
16340-3
Pretty happy with how it turned out, the details are nice and crisp for the key stem, which is what I was worried about.  Label says the product sets in 24 hours, but fully hardens in 72 hours, so I'm going to let it cure before trying to cast a key cap.
By the way, the epoxy product is clear, I tried my hand at tinting it a light blue.  I also noticed that the two Escape keys I had on hand were different profiles, one was shorter (OEM?) than the PBT unit.  I used the taller cap for the impression in  the rubber mold, and the shorter cap for the epoxy base casting, figuring this will give me an option to cast a thick-topped key, perhaps in a different color-way for the top part of the cap.  Not sure I'm explaining that very clearly, but I'll post samples once I have some.
« Reply #26 on: Wed, 20 March 2013, 17:08:29 »
That would give more consistently even coverage in the mold, but I'm not sure it would be great for keycaps since it's oriented toward hollow core resin casting.  It also would be suboptimal for the resin I have right now.  Not ruling it out just yet, but doesn't seem ideal.  I'd be more inclined to try and jerry rig something together with a large bore needle and constant pressure system (cheap homemade plunger?) to get a consistent full fill.  I need to switch to a harder silicone, clay, or other material mold for that though.
« Reply #27 on: Wed, 20 March 2013, 17:13:45 »
I've heard good things about that brand.  They were actually the one I was looking for, but they ended up costing a lot more than the Alumilite stuff I bought.  Since it was an early prototyping experiment, I decided to cheap a little.  It looks like that casting material has a higher fidelity, so that's nice to know.
Keep in mind that once you switch over to a two part mold for the top and bottom, it becomes a more difficult.  Doing something like that rotomold might help a little, but I wonder how it affects the strength of the cap.
I think I get you.  I've been trying to figure out a way to rig up a ghetto double shot mold and it sounds like that's what you're talking about.
Offline Tarzan
« Reply #28 on: Wed, 20 March 2013, 17:39:23 »
The local Michael's has the EasyCast kit with two small bottles - each about four (?) ounces.  I didn't want to get a lot of stuff to try at first, eventually I've got a larger project in mind.  I also picked up some resin+hardener of a different brand, which was absolutely horrible to use indoors.  The stuff stank up the whole house, I moved it all out to the garage and last I checked it still hasn't cured.
I'm a bit worried about using epoxy as both the mold and the product, but I like the details on the mold so far.  Keeping my fingers crossed...
Offline F u r u y á
« Reply #29 on: Fri, 03 May 2013, 05:54:02 »
Dude just thinking about that meme makes me want to laugh :))
Poor keycap, it's smiling but deep inside it wants to die!
Filco 91 | Filco 87* | Filco 105 | PLU 87 | PLU 87 | Cherry 120 | Cherry 120
Offline esoomenona
  • Gnillort?
« Reply #30 on: Fri, 03 May 2013, 06:20:58 »
« Last Edit: Tue, 27 October 2015, 08:42:28 by esoomenona »
Offline F u r u y á
« Reply #31 on: Fri, 03 May 2013, 07:19:32 »
I hope he's really happy and doesn't want to die anymore!
PS:
lmao
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #32 on: Fri, 03 May 2013, 09:38:57 »
Bro, no. All he needed was a place he could call his own, where he is loved for who he is.
This keycap absolutely slays me. The Sloth Keycap.
Just don't sing 'When the Bough Breaks' and we're good.
Offline Thechemist
« Reply #33 on: Fri, 03 May 2013, 10:17:43 »
Hey you guys.. hahahaha
Offline cdemasy
« Reply #34 on: Sat, 08 June 2013, 16:51:42 »
Have you made another? Would be awesome to see how it turned out!
Offline mkawa
« Reply #35 on: Sat, 08 June 2013, 20:44:28 »
nubbin's made all kinds of cool crap. we're supposed to go checkout hacker spaces together, but he's busy like "getting a job" and junk like that. i mean, seriously. COME ON
« Reply #36 on: Sat, 08 June 2013, 21:01:59 »
I did but didn't photograph it.  My molds were then butchered for another project.  Before I go back to resin casting, I need to try and figure out a couple of things.  First, I need to figure out how to make a cheap, yet safe, pressure chamber for resin casting.  Hopefully that will help me with some of the issues I've had with some of the direct pour casting.  Second, I need to find a better resin.  I've been checking out some and I think I found one that would work better, but it's $50+ and I don't really have the spare cash for it right now.  Third, I need some better silicon mold making material, again, a funds issue.  If some of my USB cables sell and some of my keycap pullers sell, I should get some more money to put back into experimenting.
I may have found a place where I can use their centrifugal caster, so I might be able to experiment some more with my metal caps I've been messing with.  I just need to find a place where I can buy a small amount of zinc at a reasonable price.
I just got back from Austin today for that very reason and have another interview for a different job coming up.  Once I get a steady source of income and a steady schedule, I'll definitely be able to delve more into my experiments and share my processes more.
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #37 on: Sat, 29 June 2013, 23:45:31 »
That "emo" background music is Radiohead you uncultured swine!  ;D
Offline Michael
  • Formerly Bro Caps
« Reply #38 on: Sat, 29 June 2013, 23:52:54 »
http://www.youtube.com/watch?v=Ok4fAqjKMoI&feature=player_embedded
  • Kitteh Overlord
  • Say WHAAT...
« Reply #39 on: Sun, 30 June 2013, 00:38:31 »
Don't you start with me!
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #40 on: Sun, 30 June 2013, 19:09:25 »
"Now is ze time on Sprockets vhen ve dance!"
Offline korrelate
  • iubeo stultum esse libenter
« Reply #41 on: Sun, 30 June 2013, 23:07:59 »
Very cool post! Yeah, it isn't MILSPEC or anything but I bet it was a lot of fun to do! Keep it up!!
Topre REALFORCE
« Reply #42 on: Mon, 02 December 2013, 13:10:52 »
I've been playing around with cap making some more of late.  TO be honest, I haven't really stopped since I've been playing with sand casting, wood, and other mediums.  About two months ago I decided to go back to resin though.  As such, Derp Cap v2 is alive.
I'm sitting here and can't stop laughing at the stupid thing.  For some reason I love it in spite of the flaws.
It's so derpy looking for two reasons.  First, the master got all messed up when I was drying it.  I did some slap dash repairs that, truthfully, didn't help much.  In spite of that, I went ahead and made a mold for it.  Thus comes in part two.  Instead of being a good mold and separating into two parts, it decided I had to cut it in half, messing it up more.  In spite of all the obvious defects (which were clearly present in the original), I love this guy.  I've got a cyclops I should be posting tomorrow or the day after that should look a lot better since there weren't glaring defects with the master.
Hopefully once I get a degassing chamber set up and a find an affordable pressure pot, I'll start to get better results.  I've already gotten good results with more refined models than this special guy, so I have hope.
« Last Edit: Mon, 02 December 2013, 13:13:12 by nubbinator »
« Reply #43 on: Mon, 02 December 2013, 13:13:34 »
I want some derp caps I will name them after some of my favorite people here.
Offline jiggityjane
« Reply #44 on: Mon, 02 December 2013, 13:17:21 »
I love how I can see your thumbprint in it :D
« Reply #45 on: Mon, 02 December 2013, 13:18:11 »
That's the little guys hair!! ;)
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #46 on: Mon, 02 December 2013, 13:45:06 »
Yeah, that makes it cooler. Awesome work nubbs.  :thumb:
« Reply #47 on: Mon, 02 December 2013, 15:30:56 »
Oh, believe me, I will share the derp.  The bottom turned out fantastic, just the top was all messed up.  I'm just playing around and experimenting more with different designs.  Sadly, one of my favorite ones I did got all messed up when I went to dry it out.  It was just this stupid grin on a cap with no eyes, nose, or any other part of a face.  Kind of like the don't panic face, but oh so much better.  I'm going to try and recreate it because it really was awesome.
That's not a thumb print, it's totally hair :shifty eyes:.
Thanks.  I'm hoping once I get the degasser set up for my silicone molds and figure out an affordable pressure pot, it will start to turn out much better.  I've already done some that turned out pretty awesome, but I'm not showing off that design yet.
« Reply #48 on: Mon, 02 December 2013, 16:10:03 »
And new color for the derp cap:
I'm having too much fun with these.
And for all of those aspiring cap makers out there, my word of advice is to try a bunch of different resins, experiment with different mold making techniques, and find what works best for you.
When it comes to coloring the caps, the only stuff I've had consistently good results with is the resin dyes like Alumilite makes and alcohol inks.  Alcohol inks actually seem to help harden up the resin faster and create an overall harder cap.  I want to try India ink, but it's a bit pricey.  And Jacquard Pearl-Ex doesn't work with the resins I've used, but it may work with some polyester resins based on what I've seen.
Offline domoaligato
« Reply #49 on: Mon, 02 December 2013, 16:33:41 »
I use bondo to fill and then resand again. Your imperfections can very easily be removed for a new master.
