Author Topic: SteelBeauty: Laser Cut, StainlessSteel, 65%  (Read 31591 times)
Offline agodinhost
  • Soylent green is people ...
    • Dr Ian O Xaman
Re: SteelBeauty: Laser Cut, StainlessSteel, 65%
« Reply #50 on: Tue, 23 April 2013, 22:30:07 »
Geeeeeeeeeeeeee, so many wires!
Awesome work man!
I'm kinda paranoiac with exposed wires and short circuits though ...
you took too much time to design the PCB :) I had to be creative :P
Easy, I think I'll finish it up to this sunday ...
And sorry for your lost (the teensy)
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #51 on: Thu, 25 April 2013, 09:27:07 »
FINISHED! And 100% working!
My gratitude goes to Hasu and his exceptional work with the keyboard firmwares!
Offline Broadmonkey
« Reply #52 on: Thu, 25 April 2013, 09:55:39 »
I honestly would rather buy this than most standardized keyboard. It's looking really good, just change the phillips screws ;)
Offline Tarzan
  • formerly known as Greystoke
« Reply #53 on: Thu, 25 April 2013, 10:01:18 »
I've been considering using something like these for a keyboard project:
Bought some custom cap-head stainless steel screws for a motorcycle restoration project, those were neat but the tops were too tall.
Edit: Source is http://www.trfastenings.com/pages/Metric+Socket+Countersunk+Head+Screws
« Last Edit: Thu, 25 April 2013, 10:02:54 by Greystoke »
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #54 on: Thu, 25 April 2013, 10:10:48 »
I tried many screws but at the end the phillips are those that give me the most perestroika feeling :)
The ones suggested by broadmonkey are a bit problematic on my case because I don't have enough clearance to completely inset them into the case top (which is also the plate).
also consider it's 100% stainless steel... a hell to work with (I broke 3 threading bits)
« Last Edit: Thu, 25 April 2013, 10:12:36 by Matt3o »
« Reply #55 on: Thu, 25 April 2013, 10:15:23 »
Threading bits? Y U NO USE NUTS?? :P
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #56 on: Thu, 25 April 2013, 10:18:29 »
yes, next time I'll use nuts for sure!
Offline hasu
  • @tmk
« Reply #57 on: Thu, 25 April 2013, 10:30:32 »
Congrats! Great job. It looks lovely.
Offline Broadmonkey
« Reply #58 on: Thu, 25 April 2013, 13:45:24 »
I was thinking more about something like this
Offline TheSoulhunter
  • Thorpelicious!
« Reply #59 on: Thu, 25 April 2013, 14:10:10 »
You could use something like this...
19898-0
It has a thread inside to insert a screw from the back
- No thread tapping, just drilling
- Flat and minimalistic at the faceplate
- Screw head hidden on the underside
Offline Tarzan
« Reply #60 on: Thu, 25 April 2013, 14:43:18 »
There are a variety of fastening options, some more difficult to source than others.  I have a lot of respect for anyone tackling a project like this, I'm just hoping I can borrow (copy shamelessly) some of the ideas when I finally muster up the nerve to start a similar project!
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #61 on: Thu, 25 April 2013, 16:24:36 »
this is a nice idea! I'll use these for my next project (alps 60%)
Offline agodinhost
    • Dr Ian O Xaman
« Reply #62 on: Sun, 28 April 2013, 22:16:03 »
For those wiling to build one keyboard like this one posted by Matt3o here comes my 5 cents:
Complete PCB:
https://github.com/agodinhost/KiCad/tree/master/Matt3o
The same PCB with a Teensy board attached:
https://github.com/agodinhost/KiCad/tree/master/Matt3o-Teensy2
There is no USB connector in these boards - only the 2.54mm header to connect and plug the USB wherever you like.
Right now Matt3o Matt3o is trying to find a way to attach the USB connector into his case. Any idea is welcome ...
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #63 on: Mon, 29 April 2013, 01:27:38 »
Thanks agodinhost for working and posting this! You did and exceptional work.
I don't think there's enough interest for the SMD version but the teensy is tempting if we find a way to fit the usb cable.
Offline agodinhost
    • Dr Ian O Xaman
« Reply #64 on: Mon, 29 April 2013, 06:41:54 »
Okay, let me know.
It would be sad to trash it away so soon ...
I'm working on a 60% board based on this same idea (Cherry and Alps into the same board). Any interest, please, note me or open one new topic.
Offline domoaligato
« Reply #65 on: Thu, 02 May 2013, 10:56:20 »
I know somewhere I saw a link to the wiki page you created based on your work with hard wiring but I can not seem to find it now?
I want to create a alps gh60 hard wired but I am basically stuck planning and understanding the wiring matrices and how this all ties to the teensy controller.
would someone mind giving a brief explanation of how the wiring connects together?
« Reply #66 on: Thu, 02 May 2013, 11:13:05 »
Check this out: http://geekhack.org/index.php?topic=20898.0
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #67 on: Thu, 02 May 2013, 12:20:30 »
I think I'll soon start a "group build" (not "buy") for a 60% alps keyboard (hard wire+teensy) code named whitefox :) stay tuned.
Offline domoaligato
« Reply #68 on: Thu, 02 May 2013, 12:23:16 »
I have looked at that thread and this one a lot in the last few weeks.
the switches I am harvesting are yellow omron alps and are all mounted upside down in the existing board.
which side +/- do the diodes attach to and how do I tell which side is positive and which is negative?
once I get the board to a point when I have it laid out like lowpoly does how do I determine which wires connect to which pins on the teensy to be compatible with the default gh60 poker layout firmware?
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #69 on: Thu, 02 May 2013, 12:32:37 »
Awesome job on the MX one. Very interested to see how the "whitefox" goes.
Offline domoaligato
« Reply #70 on: Thu, 02 May 2013, 12:43:03 »
Thanks! I look forward to seeing your progress. I am getting married in a little over 2 weeks and I have to pay for the gh60 GB so it may be some time before I can get started.
Offline agodinhost
    • Dr Ian O Xaman
« Reply #71 on: Thu, 02 May 2013, 13:18:11 »
Seems that the PCB I designed for you is going to be trashed away ...
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #72 on: Thu, 02 May 2013, 13:57:41 »
hope not. these things just take some time. don't be negative!
Offline agodinhost
    • Dr Ian O Xaman
« Reply #73 on: Thu, 02 May 2013, 15:30:54 »
Sorry, 8-)
Anyway I'm using that same board as base to create another PCB for one 60% keyboard design (same idea, cherry and alps into the same board).
« Last Edit: Fri, 03 May 2013, 07:49:05 by agodinhost »
« Reply #74 on: Thu, 02 May 2013, 15:38:11 »
If you have a PCB use it for goodness sake!  The one and only reason to direct wire is to avoid having to fab a board
Offline domoaligato
« Reply #75 on: Sat, 04 May 2013, 12:49:10 »
I am doing it to get good at soldering again because I haven't done it in 10 years.
Offline Paranoid
« Reply #76 on: Wed, 31 July 2013, 04:30:23 »
Any idea what the official name for this part is in English? If I translate it I get bolt bus assuming that the name I have for it is even correct, but that just gives me an actual bus as result :D I'm prototyping my own Dell AT102W case and this could come in handy to replace the nut I have at the bottom :)
*Found it! In English it's called a blind nut. The only downside is that the outside diameter is ~5mm so those are some big holes ^^
You can have them very short: http://www.hobbyking.com/hobbyking/store/__8227__blind_nut_m3_10pcs_.html
Or longer: http://www.ebay.com/itm/25PC-M3-METRIC-NUT-RIVET-BLIND-NUTS-INSERTS-ALUMINUM-/280707253169
Btw, hobbyking has really cool screws, bolts and nuts in nylon and different colors of metal.
« Last Edit: Wed, 31 July 2013, 05:09:38 by Paranoid »
Offline yasuo
  • spanengan puyeng newbie
« Reply #77 on: Wed, 31 July 2013, 05:25:36 »
nice :p
« Last Edit: Wed, 31 July 2013, 05:29:53 by yasuo »
Logitech MK220 Colemak DH
Offline yasuo
« Reply #78 on: Wed, 31 July 2013, 05:37:55 »
Whether it is inside the copper (black cable)?
« Last Edit: Wed, 31 July 2013, 05:41:16 by yasuo »
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #79 on: Wed, 31 July 2013, 05:39:44 »
in the second link they are just rivet inserts, they are not threaded.
Offline Paranoid
« Reply #80 on: Wed, 31 July 2013, 06:38:43 »
Ah good that you noticed :) Gotta be more thorough next search ^^
Offline alaricljs
  • I be WOT'ing all day...
« Reply #81 on: Wed, 31 July 2013, 08:36:10 »
Not true, they are rivet style nut inserts w/ M3 threads.  The are attached just like rivets with a special rivet nut insert tool that squashes them down, but there are some threads in there.
Filco w/ Imsto thick PBT
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #82 on: Wed, 31 July 2013, 10:18:38 »
you sure they are threaded? I can't see threads from the pics.
Offline alaricljs
« Reply #83 on: Wed, 31 July 2013, 10:20:06 »
"minimum 6 turns"  so very few of them, and they don't show the end where they are, they show the end that gets squished.  ed:  ok they do show them, but the fidelity is absolute crap.
  • Thorpelicious!
« Reply #84 on: Wed, 31 July 2013, 16:44:02 »
Wasn't thinking of blind-rivet-nuts as these usually don't have a "head" and are meant to expand...
What I meant is "Innengewindehülse mit Linsenkopf/Flachkopf" which translates to "Inside threaded bushing/bolt with pan-head/flat-head":
30036-0
« Last Edit: Wed, 31 July 2013, 16:47:22 by TheSoulhunter »
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #85 on: Thu, 01 August 2013, 01:31:59 »
where the hell do you get those?! :D
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #86 on: Thu, 01 August 2013, 02:11:30 »
I've been looking at getting something like that for my build but I'm a little bit worried that if overtightened you'd never get the screw out again.
« Reply #87 on: Thu, 01 August 2013, 09:23:51 »
Kailet, who made my 2TU, had used clear polycarb for the center of his "vicki" style case, and it's had some great aesthetic applications like case LEDs.
Offline Tarzan
« Reply #88 on: Thu, 01 August 2013, 09:32:38 »
They look similar to the blind fasteners I ordered from McMaster-Carr:
Nice domed surface on the blank side, though!  I don't have pics of the ones I ordered, they're still on the way.
Offline yasuo
« Reply #89 on: Mon, 05 August 2013, 10:51:28 »
any recomen controller besides TEENSY 2.0 beacuse  in my country no one sells TEENSY :confused: if buy at pjrc will be time consuming and expensive that shipping :(
but i see on my country any seller Arduino Fio ATmega328P Microcontroller what recomended? qute big >:D
or other suggestions
This shop
Which good controller
http://kam-kits.blogspot.com/search/label/Arduino%20Mikrokontrollerhttp://kedairobot.com/
Thanks :thumb:
« Last Edit: Mon, 05 August 2013, 11:03:15 by yasuo »
Offline alaricljs
« Reply #90 on: Mon, 05 August 2013, 10:53:08 »
Just ebay search atmega32u4 and pick something that works for you.
Offline yasuo
« Reply #91 on: Mon, 05 August 2013, 10:56:45 »
shipping to my country sure expensive and time consuming :-\
Offline bueller
  • MX baller
« Reply #92 on: Mon, 05 August 2013, 11:03:48 »
This shop
Which good
Thanks :thumb:
Avoid the Arduino micro-controllers, the bootloader is incompatible with a lot of the firmware's people are using. You can get around it by reloading another bootloader but you need an ISP box and that's just more money down the tube. I'm using a board from MattairTech with the same AVR chip, fair bit larger than the Teensy but it also has a lot more pinout's for things like external USB connectors. Very configurable as well, they will load it with whichever bootloader you request and will add headers if requested too.
Offline alaricljs
« Reply #93 on: Mon, 05 August 2013, 11:08:46 »
I use a teensy as an ISP, typically cheaper than an actual ISP.  Any other similar MCU board can do the same.  http://dorkbotpdx.org/wiki/teensy_2_0_as_avr_isp_programmer
yasuo:  We don't know what country you're in if you don't tell us... we also can't fix the realities of prices/shipping.
Offline Neebio
  • Dance Master
« Reply #94 on: Thu, 05 September 2013, 14:55:52 »
Here: http://www.jakob.ch/1279/metagroup=G39192
Smallest is 6mm head diameter, 4mm barrel diameter, 6.5mm barrel length, that takes a 3m bolt.
« Last Edit: Thu, 05 September 2013, 14:57:45 by Neebio »
RK9000RE w/ Raindrop & DDR arrow keys
Cherry G80-11900LUMEU-2 w/ Red/Black SA keys
Offline RabRhee
« Reply #95 on: Thu, 05 September 2013, 14:59:51 »
Really superb looking keyboard.
With a full stainless steel body, could this be the Delorean of keyboards? What happens when it hits 88 wpm?
-Life is good-          Crafting: |  KeychainsMore.   .Keychains | Crowdsource Key | Budget Keycap Board |
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #96 on: Thu, 05 September 2013, 17:52:22 »
LOL... dunno... let me try... LOL... dunno... let me try... LOL dunno... let me try...
GREAT SCOTT! It works!
Offline Pacifist
  • on hiatus
« Reply #97 on: Mon, 24 February 2014, 00:40:55 »
Sorry, 8-)
I'd love to see that, in this "65%" design
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #98 on: Mon, 24 February 2014, 01:20:37 »
Sorry, 8-)
I gotta say Matt3o, that is one sexy beast.  What can I say though I am a sucker for raw stainless.
