Author Topic: Brownfox, alu + acrylic custom keyboard  (Read 27401 times)
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« on: Tue, 25 June 2013, 09:08:27 »
After the steelbeauty it's time for the brownfox :)
This time instead of 100% steel I used alu top/bottom and acrylic sides. I just received the plate, the keys are not wired yet, I just placed the switches to see how the keyboard feels.
I totally love it so far, now a long wiring session awaits me.
I'll post the step by step in the coming days, in the meantime to wet your appetite:
« Last Edit: Thu, 27 June 2013, 13:23:01 by Matt3o »
Offline Jocelyn
  • 조셀린
Re: Brownfox, alu + acrylic custom keyboard
« Reply #1 on: Tue, 25 June 2013, 09:10:22 »
Ummm awesome! I thought this was in the f/s section when I clicked the thread :p
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #2 on: Tue, 25 June 2013, 09:12:53 »
do you want one? :) it won't be cheap :P
« Reply #3 on: Tue, 25 June 2013, 09:15:03 »
Matt3o this is both amazing and beautiful! Brown is whats up!
« Reply #4 on: Tue, 25 June 2013, 09:16:59 »
Matt30! How many projects do you have running?? I was all excited this was the secret Alps board you were building and instead I saw your Model M cutdown and this custom beauty!
Offline The_Beast
  • I like wood ಠ_๏
« Reply #5 on: Tue, 25 June 2013, 09:17:36 »
If Matt3o doesn't mind, I could cut cases like the steelbeauty and not have international shipping. You'd have to source everything else tho
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #6 on: Tue, 25 June 2013, 09:25:28 »
not only I don't mind, but I could give you the DXF files if you want/need
way too many! the next one is the Whitefox (same as above but with ALPS!)
« Last Edit: Tue, 25 June 2013, 09:27:46 by Matt3o »
Offline The_Beast
  • I like wood ಠ_๏
« Reply #7 on: Tue, 25 June 2013, 09:27:55 »
Cool, if there's interest, I'd have no problem running a small GB for these. I wasn't in love with the layout at first, but I think it could grow on me :D
« Reply #8 on: Tue, 25 June 2013, 09:32:32 »
Man....all these sexy 75% projects coming out lately. Wonder if we could slightly modify the Steelbeauty case to fit the Epsilon.
In regards to both of these statements, you're my hero :D
Offline HannibalChew
  • Formerly PixelScript
    • gaffworks
« Reply #9 on: Tue, 25 June 2013, 09:50:43 »
Very cool! More pictures please!!
« Last Edit: Tue, 25 June 2013, 10:41:44 by PixelScript »
Offline Rendom
« Reply #10 on: Tue, 25 June 2013, 10:40:56 »
Basically what GON did? Nice idea!
QFR - MX Blue
« Reply #11 on: Tue, 25 June 2013, 11:03:31 »
GON was not the first.  GON stylized the design and made his rendition ultra-thin.
Offline agodinhost
  • Soylent green is people ...
    • Dr Ian O Xaman
« Reply #12 on: Tue, 25 June 2013, 12:41:36 »
Awesome!
Please, post a few more pictures (bottom, side, etc)
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #13 on: Tue, 25 June 2013, 13:10:48 »
will do! hopefully even some making of video :)
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #14 on: Wed, 26 June 2013, 13:06:46 »
Here's the step by step with lots of pictures. Not finished yet, tomorrow I'll post the final steps.
Step 1: place the switches
The aluminum plate is 1.5mm thick, but I have the feeling that I could have done it 2mm for better stability. Next time I might try that. I had a similar keyboard done in steel and keys stick better on 1.5mm steel than they do on 1.5mm alu. Steel is too stiff though and typing is a bit tiring.
All switches are MX Blue plate mounted (but you can use pcb mounted as well) with few exceptions. Arrows are MX Red, spacebar is MX Green.
Step 2: diodes!
We need one diode per switch. I connect them to the top left pin of each switch with the diode black strip on the outside (in this case poiting down).
First of all melt a drop of soldering wire onto the pin.
Then bend the diodes wires in chunk of 10-20. Bending them together makes your matrix more symmetrical.
Approach the upper diode wire to the drop of lead and heat with your iron (I keep it a 310°C). It should take just 1 second to melt the lead, release the soldering iron and blow over the diode. I find this technique the fastest and most secure.
When all diodes are soldered to the switches you can start soldering them together.
This is a detail:
This is an overview (as you see the spacebar needs some extensions)
It is important to leave enough real estate on the left of the spacebar switch as we are using that space for the controller.
Step 3: connect the columns!
Now that we have the rows ready we can do the columns. I haven't found an ideal way of wiring them, so far the best thing I came up with is to prepare the wires like this in advance:
Since the case is very thin wires are going to touch each others so it's a good idea to have the columns insulated as much as possible to prevent shorts with the rows.
When I have all the wires ready I use them to connect the top right pins. This is the end result
I usually put the columns under the rows, this helps keeping the layout compact.
Step 4: preparing the case!
The sides are made of acrylic in the effort of saving some bucks and also to have a strip of color in the middle of the case. I must say that I like the final result.
The case is reduced to the minimum so to reinforce the three 3mm layers of acrylic I glue them together.
To prevent shorts with the aluminum I also placed a sheet of plastic in the inside part of the case bottom.
Now all it is left to do is to connect the controller a burn the firmware!
« Last Edit: Wed, 26 June 2013, 13:16:56 by Matt3o »
« Reply #15 on: Wed, 26 June 2013, 13:11:37 »
^^ This is just awesome! Thank you for walking us through this project!!
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #16 on: Thu, 27 June 2013, 13:22:13 »
Step 5: wire the controller
The case is very small and there's no room for connectors/headers so I have to wire directly on the controller.
I have 16 columns and 5 rows, so I need 21 pins. No LEDs because LED is for keyboards what neon is for cars. Looking at the picture I use 10 pins on the left and 11 pins on the right. Remember to skip VCC, GRN and pin D6. Refer to this page for complete Teensy pinout.
Before positioning the controller I put some insulation under the teensy.
Step 6: wire rows and cols
Rows first.
I use pins F0, F1, F4, F5, F6 for the rows.
Then it's time for the columns.
Pins from F7 to B0 clockwise.
I placed the wires under the matrix to keep the layout nice and compact.
Here's an overview
Step 7: USB extension
Nothing interesting to see here. I just built a small extention cable that goes from the teensy to the case top. I then glued the the female USB mini to the case with superglue first and epoxy glue then.
Step 8: burn the firmware
I use hasu's code, of course modified for my matrix. I always start from the GH60 code as a base and build over that.
The files to modify are in /keyboard/gh60 directory. You need to customize: config.h, keymap_plain.h (I use the plain file because it's the cleanest), keymap.c, led.c, matrix.c and Makefile.lufa.
I'll cover this step deeply in a dedicated thread. Once ready and compiled the firmware is ready to be burned. The easiest way to do that is with the Teensy Loader that you can find on the JRC website.
And now the BrownFox in all its glory...
Step 9: satisfaction
Please note that I still miss the feet, but the keyboard is already 100% working (fox-typing right now!)
*Cable courtesy of Paranoid
« Last Edit: Thu, 27 June 2013, 13:28:30 by Matt3o »
« Reply #17 on: Thu, 27 June 2013, 13:36:20 »
Thank you so much for posting the Build Log Matt3o. The pictures were lovely and now I really want to build my own matrix-wired board.
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #18 on: Thu, 27 June 2013, 13:52:13 »
w o w . . .
I am in awe of your skills Matt3o. Completely blown away.
BTW, what stabilizers are you using on that board?
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #19 on: Thu, 27 June 2013, 14:20:39 »
I want to do this bad!!! How hard would it be to add a numpad?
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #20 on: Thu, 27 June 2013, 14:31:38 »
w o w . . .
thanks!
stabs are costar. easier to handle for custom keyboards
just longer to wire, not any harder to build.
Offline mashby
    • Mashby
« Reply #21 on: Thu, 27 June 2013, 14:45:01 »
Interesting, the clips in my plate are black. I didn't know they came in white.
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #22 on: Fri, 28 June 2013, 04:02:33 »
i just noticed you made this into a a full walk-through Matt3o. So cool. I think i should grab some teensys
Offline domoaligato
« Reply #23 on: Fri, 28 June 2013, 04:29:55 »
Awesome job! I have followed all of the threads for these 2 keyboards and it is amazing work.
I am still working on my development alps board (sidetracked with the groupbuy).
but I would not have started that project if I had not seen what you had done.
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #24 on: Fri, 28 June 2013, 05:14:23 »
Brilliant walk through Matt3o, I've seen matrix build logs before but never this comprehensive. I'm building a similar board myself but I think the cherry switch template I have for CAD is wrong, would you mind sharing your design or switch template?
Offline WhiteFireDragon
    • youtube
« Reply #25 on: Fri, 28 June 2013, 05:28:18 »
Awesome worklog! I love seeing custom work like this.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #26 on: Fri, 28 June 2013, 06:07:12 »
Source files attached. They are in mm not inches. Also please note that I use 19mm between keys instead of the suggested 19.05, because it absolutely makes no difference.
IMPORTANT! I used a 6u spacebar with custom stems position! if you are going to use my DXF you probably need to review that!
« Last Edit: Sat, 29 June 2013, 01:22:59 by Matt3o »
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #27 on: Fri, 28 June 2013, 06:11:58 »
Thanks for the detailed build-log!
Offline bueller
  • MX baller
« Reply #28 on: Fri, 28 June 2013, 06:33:46 »
Champion, this will give me a massive leg up!
Tried to do some searching around but I came up dry, can anyone tell me where I would buy Costar stabs for this?
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #29 on: Fri, 28 June 2013, 06:59:58 »
http://www.wasdkeyboards.com/index.php/products/keyboard-parts-1.html
Offline tgujay
« Reply #30 on: Fri, 28 June 2013, 10:45:01 »
This is so awesome thank you so much, I'm going to do this to make my old WYSE usable.
Gotta collect them all
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #31 on: Sat, 29 June 2013, 01:22:42 »
« Reply #32 on: Thu, 04 July 2013, 10:24:08 »
Where did you source the spacebar from then?
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #33 on: Thu, 04 July 2013, 12:04:18 »
It's a 6u spacebar from DSA Retro GB with glued stems
Offline TheFlyingRaccoon
  • HHKB Pro
  • Cable maker and future engineer
« Reply #34 on: Thu, 04 July 2013, 13:00:39 »
What gauge is the multi-colored cable you used to connect the teensy to the matrix? Thanks so much for the writeup by the way. The board looks great!
HHKB Pro 2   SmallFry Keyboard
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
Offline domoaligato
« Reply #36 on: Thu, 04 July 2013, 22:16:59 »
i used a ide harddrive cable for my project.
  • HHKB Pro
« Reply #37 on: Fri, 05 July 2013, 00:34:28 »
I was thinking about doing this as I have a bunch of old IDE cables. How did that work for you?
Offline rDuck
« Reply #38 on: Fri, 05 July 2013, 00:58:04 »
so the bottom row is 1.25x, 1x, 1.25x, 6x, 1.5x ,1.5x,1x,1x,1x ?
Offline gnubag
« Reply #39 on: Fri, 05 July 2013, 01:06:26 »
it is 1.5 1 1.5 6 1.5 1.5 1 1 1
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #40 on: Fri, 05 July 2013, 01:19:22 »
they work but they are a little thin for my tastes.
this.
Next time I'll probably try
1.25, 1.25, 1.25 6 1 1 1 1 1 1
The following instead will be the Whitefox, my next custom (ALPS switches)
Offline bueller
  • MX baller
« Reply #41 on: Fri, 05 July 2013, 02:40:26 »
this.
HNNNNNGGGGGG. What board are they off?!?!?
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #42 on: Fri, 05 July 2013, 07:05:40 »
Focus FK-2001
Offline bueller
  • MX baller
« Reply #43 on: Fri, 05 July 2013, 07:28:40 »
Focus FK-2001
Cheers, I know what I'm keeping an eye out for!
« Reply #44 on: Fri, 05 July 2013, 07:36:04 »
Hehe, those Whitefox caps look familiar  ;)
Offline domoaligato
« Reply #45 on: Mon, 08 July 2013, 00:31:55 »
Well I finished my 60% alps custom.
I have attached a image.
I still need to cleanup the keycaps and I want to cover the plate with  3m carbon wrap.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #46 on: Mon, 08 July 2013, 03:02:18 »
is that LEGO? :) smart ass!
  • Kitteh Overlord
  • Say WHAAT...
« Reply #47 on: Mon, 08 July 2013, 04:43:51 »
Looks good!
« Reply #48 on: Mon, 08 July 2013, 05:35:46 »
THAT'S HOT. What Alps switches did you use and are those caps from a Focus FK-2001? And yes...are those Legos? You better not be covering that with carbon wrap if it is!
Offline bueller
  • MX baller
« Reply #49 on: Mon, 08 July 2013, 06:23:27 »
Okay so I'm just about ready to get this plate laser cut but I can't figure out how to do a standard 6.25 space bar with the correct spacing for stabilizers. I'll basically be using Matt's CAD file but will have [1.5] [1] [1.25] spacing on the left hand side to accommodate the standard space bar. Anyone help?
« Last Edit: Mon, 08 July 2013, 06:53:15 by bueller »
