Author Topic: [IC] X-mas abs and poly set  (Read 5078 times)
Offline Badwrench
  • ummmm.....I forgot
« on: Fri, 15 November 2013, 02:02:53 »
Ever since I saw the poly color ring come out from SP, I have been intrigued with the idea of doing a backlit set (very similar to the orange and white cherry legend currently in GB).
My proposed set would be this:  green poly on white alphas and clear poly on green mods.  Tree would be white on poly red.  Not sure if it is feasible to have 3 different custom keys, but wanted to get some feedback from the community.   Profile is undecided.
44130-0
I know that this is similar to ccng, but still wanted to see if it was doable.
Rough mock up of green poly mods on red
44144-1
« Last Edit: Fri, 15 November 2013, 04:44:37 by Badwrench »
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
Re: [IC] X-mas abs and poly set
« Reply #1 on: Fri, 15 November 2013, 03:03:39 »
Timing is your problem, you won't be able to get it in time for Chritmas. Otherwise, it looks really good and interesting idea.
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #2 on: Fri, 15 November 2013, 03:10:36 »
How about red polycarb on green mods?
Offline Badwrench
« Reply #3 on: Fri, 15 November 2013, 04:30:22 »
Yeah, I know, but at least it would be purchased around the holidays.
I was playing with how that would look, I will add it to the op.  The more feedback the better.
« Reply #4 on: Fri, 15 November 2013, 07:25:42 »
Could be done for NEXT Christmas :P
Offline aggiejy
« Reply #5 on: Fri, 15 November 2013, 08:49:32 »
I think the green text on red may be a problem for visibility.  We've seen similar problems in things like the Miami contrast, and this would likely be much worse.  Poly or not, I think it would still be an issue to consider.
Offline LechnerDE
« Reply #6 on: Fri, 15 November 2013, 10:43:32 »
Yeah, especially since some people have bad eyes and can't distinguish between red and green.
Besides that I don't think this is the right time for a new GB with poly keys. Even the orange and white Cherry font GB is kinda struggling, because either people spend all their keyboard budget of the year already or are simply not the biggest fan of translucent sets.
Maybe you should aim at doing this GB next June so it would be ready for christmas?
Offline Badwrench
« Reply #7 on: Fri, 15 November 2013, 17:20:11 »
Yeah, the green on red would def be a problem for contrast.  So would the clear on green i believe.  As far as timing, I know I am way off, but just wanted to get some feedback for the future.
Offline AKmalamute
  • HHKB Scrub
« Reply #8 on: Fri, 15 November 2013, 17:29:58 »
Red legend on green keys would probably be okay, but for my money I'm quite certain that green legends on red keys would be horrendous.
Also, not really that bad of a time for an IC ... for Christmas 2014.
Be sure to make some sub-sets, like a lang-dvorak kit, and a tk addition to the tk set, and maybe a wk/wkl set of options, and ....
HHKB-lite2, Dvorak user
Offline Badwrench
« Reply #9 on: Sat, 16 November 2013, 00:51:26 »
I was thinking of a setup similar to the Toxic set where the Tsangan is incorporated into the base price.  If there was enough interest, those other sets could easily be added as well as ergodox or any other setups people wanted (31 key pad?)
Offline bianco
« Reply #10 on: Sat, 16 November 2013, 02:06:46 »
interested in this set.
but not a fan of green or red
how about yellow on red?
otherwise, white on red (to match the red esc xmas tree).
Offline stoic-lemon
« Reply #11 on: Sat, 16 November 2013, 03:00:39 »
Have there never been any Christmas novelty cap GB here? I mean single keys.
Offline leesofi
  • super lurking
« Reply #12 on: Sun, 17 November 2013, 06:32:18 »
i need only x-mas tree.
Offline Paranoid
« Reply #13 on: Sun, 17 November 2013, 07:17:01 »
haha I misread the title for a sec. I wouldn't mind getting some abs for Christmas :D
