Author Topic: Make a 2 key keyboard?  (Read 41158 times)
Offline WangZi
« on: Thu, 09 January 2014, 13:07:45 »
Just wondering if it's possible to make a mechanical keyboard with only 2 keys, or something as low as 2 keys. Why? We'll I plan to make one for a game called osuu which only requires 2 keys.
Offline lcs
  • Lover of Grape Drank
  • はやく
Re: Make a 2 key keyboard?
« Reply #1 on: Thu, 09 January 2014, 13:08:18 »
Yes. You can see the teckkeys business card. It has 3.
http://techkeys.us/collections/accessories/products/techkeys-keyboard-business-card
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2 on: Thu, 09 January 2014, 13:28:36 »
For sure that is a great suggestion... just get the techkeys card and only put 2 switch on it. Reprogram it. Done.
Offline WangZi
« Reply #3 on: Thu, 09 January 2014, 13:34:09 »
Not great computer programmer, do you know if it will be complicated to reprogram the keys?
« Reply #4 on: Thu, 09 January 2014, 14:18:38 »
I suspect some firmwares will appear for it soon enough on here that will make it easy to assign whatever you like. It was only made available a few days ago I think.
Offline regack
« Reply #5 on: Thu, 09 January 2014, 19:45:46 »
I am so totally going to make this just for laughs...
50373-0
« Reply #6 on: Thu, 09 January 2014, 19:46:17 »
^ I'll take one
Put 1, and A on them.
Offline fourzeropooh
« Reply #7 on: Thu, 09 January 2014, 19:47:34 »
Group buy?
Also can someone do the SMD soldering for me if this becomes a thing?
« Reply #8 on: Thu, 09 January 2014, 19:52:53 »
If this becomes a groupbuy, we should get some really baller 0 and 1 doubleshots to go with it.
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #9 on: Thu, 09 January 2014, 19:53:56 »
Holy **** this is a good idea
Offline bcg
« Reply #10 on: Thu, 09 January 2014, 20:01:31 »
I'm sure it would be easy to load hasu's firmware on there.  The switches are each wired directly to a pin on the 16U2 you just have to read the value from the pin to know if the key is pressed I presume
You can probably just modify the onekey keyboard example, just add some keys to keymap.c and then change the functions at the bottom of matrix.c:
https://github.com/tmk/tmk_keyboard/blob/master/keyboard/onekey/matrix.c#L144
:wq!
« Reply #11 on: Thu, 09 January 2014, 20:02:05 »
Group buy?
If this was really small and really cheap, there would be all kinds of uses for it.
What is a much smaller equivalent of an Altoids tin?
"The Trump campaign announced in a letter that Republican candidates and committees are now expected to pay “a minimum of 5% of all fundraising solicitations to Trump National Committee JFC” for using his “name, image, and likeness in fundraising solicitations.”
“Any split that is higher than 5%,” the letter states, “will be seen favorably by the RNC and President Trump's campaign and is routinely reported to the highest levels of leadership within both organizations.”"
Offline regack
« Reply #12 on: Thu, 09 January 2014, 20:10:01 »
Group buy?
Well... as a one-off it's going to come in ~$9 each... but that included me pricing out (2) $1.20 switches from mouser (not that anyone would buy them there at that price, but I just wanted some kind of price estimate).
Offline bcg
« Reply #13 on: Thu, 09 January 2014, 20:20:23 »
What is IC1?
:wq!
Offline regack
« Reply #14 on: Thu, 09 January 2014, 20:29:56 »
What is IC1?
ATTINY85
« Reply #15 on: Thu, 09 January 2014, 20:32:27 »
I'm sure we could get at least a few dozen of these PCB if doing a groupbuy. If really low numbers... doubleshots probably not but getting some neat dyesubs done with imsto wouldn't be a problem.
« Reply #16 on: Thu, 09 January 2014, 20:41:11 »
I'd be down for one.
Just add at least one mounting hole to the PCB: it'll make it a HECK of a lot easier to put in some sort of case.
« Reply #17 on: Thu, 09 January 2014, 20:42:11 »
A keyboard with only 2 keys would be pretty much limited to entering binary data.
A keyboard with 1 key anyone?  Morse code data entry? ;)
« Reply #18 on: Thu, 09 January 2014, 20:47:14 »
As far as case goes... perhaps something 3D printed? For something so small I can't imagine doing something kind of like a miniature Poker tray would be too difficult or terrible expensive? I think if you put a hole in the PCB at two diagonal corner it would be enough?
« Last Edit: Thu, 09 January 2014, 20:49:44 by IvanIvanovich »
« Reply #19 on: Thu, 09 January 2014, 20:55:33 »
Will this be a kit?
Some people have distinct ideas about switches and key caps.
I would love a bag of parts and some instructions.
Offline regack
« Reply #20 on: Thu, 09 January 2014, 21:00:55 »
Yup, I fit a 3.5mm hole in the middle of the PCB, but it will require some kind of standoff.
Offline bcg
« Reply #21 on: Thu, 09 January 2014, 22:27:39 »
What is IC1?
ATTINY85
Totally awesome.  If you get these made up I'm totally in for a few, even if its just the PCB and not a kit.
Adafruit has a Arduino library targetting ATTINY85 to make a USB keyboard, although I didn't really look if this arduino specific but even if its not would be easy enough to do from scratch:
http://learn.adafruit.com/trinket-usb-keyboard/code
:wq!
« Reply #22 on: Thu, 09 January 2014, 22:55:43 »
I don't know why, but I would also be interested in some sort of GB for regack's little 2-switch PCB.  Mostly just because it'd be so fun.
What would you other people use something like that for?
Offline nuclearsandwich
« Reply #23 on: Thu, 09 January 2014, 22:56:25 »
^ I'll take one
The new Sifo Elite Protoss Custom™
Offline bcg
« Reply #24 on: Thu, 09 January 2014, 23:38:27 »
One think that I can think of right off the top of my head is for a volume control to attach to my laptop docking station at work
Also I was thinking of making a sort of password manager that I could store passwords on and have them typed out for me when I
Also I'm iterested in it just as a breakout dev board for the ATTINY85 - it might be nice if it was a bit more breadboard friendly but it looks fun to hack around on regardless
:wq!
Offline Oobly
« Reply #25 on: Fri, 10 January 2014, 05:55:04 »
I am in for a few PCB's if this comes together! Just the PCB's, I can find my own switches and components easily enough.
Finally a REAL programmer's keyboard!
Buying more keycaps,
it really hacks my wallet,
but I must have them.
« Reply #26 on: Fri, 10 January 2014, 11:49:16 »
^ I'll take one
Pretty much
Offline WangZi
« Reply #27 on: Fri, 10 January 2014, 12:03:51 »
Ill definitely take one. I'm not a great engineer so could you actually make one for me with keys and everything? I'm willing to pay. BTW, if you can, i should be able to advertise it on OSU and try to get more buyers involved.
Offline Defying
  • (suffer on)
« Reply #28 on: Fri, 10 January 2014, 12:43:24 »
this + tablet = perfect osu! combo
« Reply #29 on: Fri, 10 January 2014, 14:14:40 »
I think a kit would be great. If we could get a PCB with all the smd stuff done + a little plastic 3D printed tray or something + 2 keycap. Then make switch and led optional for extra perhaps with a limited selection.
I would be willing to take the helm on a groupbuy. I'm pretty seasoned and even if it happened to get quite huge it wouldn't phase me.
« Reply #30 on: Fri, 10 January 2014, 14:20:52 »
Let's do it! I'm in for a few. Especially with a couple GMK caps on there. :)
« Reply #31 on: Fri, 10 January 2014, 14:22:11 »
On/Off switches  ;D
    • Gray Designs
« Reply #32 on: Fri, 10 January 2014, 14:24:48 »
F5 and FN :p
I'm down
« Reply #33 on: Fri, 10 January 2014, 14:29:04 »
Is there anyone that can design a tray? Once that is done we would need some pricing from 3D printer or whatever.
Need pricing for PCB fab with pick and place for any SMD parts... I don't know where is good.
Once I know those things I could start up buy thread since I know where to get switch/led/keycap and how much those should cost.
Offline kmiller8
  •  Post Reporting Timeout
  • Who is that kmiller8 guy?
« Reply #34 on: Fri, 10 January 2014, 14:31:11 »
« Reply #35 on: Fri, 10 January 2014, 15:11:07 »
Try PCBcart.com. You will need the Gerber files from regack. :)
Offline i3oilermaker
  • techkeys.us
    • TechKeys
« Reply #36 on: Fri, 10 January 2014, 15:11:45 »
Offline kmiller8
« Reply #37 on: Fri, 10 January 2014, 15:13:12 »
« Reply #38 on: Fri, 10 January 2014, 15:15:36 »
The branding.
Offline kmiller8
« Reply #39 on: Fri, 10 January 2014, 15:16:29 »
Offline regack
« Reply #40 on: Fri, 10 January 2014, 15:24:49 »
Ok, let me just throw another thought out there for everyone to chew on: The attiny will need to be programmed by ISP (at least the first time, I guess? I'm not really good with firmware) - I've got the ISP pins brought out to pads on the edge of the board, and I suppose throwing together a jig to hand-jam a bunch of boards would work, but would be tiresome in bulk... anyone have any ideas how to handle this?
Especially with all of the different layouts people will want :D ...
(seriously, I'm not really good with firmware)
BTW, I ordered some prototypes yesterday, because I've never actually played with the ATTINY before so... probably need at least SOME testing first.
But hey, at least with only two switches and optional don't-solder-in-the-resistors-or-LEDs-if-you-don't-want-it backlighting it shouldn't be really hard to make sure it's working ok.
« Reply #41 on: Fri, 10 January 2014, 15:25:50 »
Can't wait ...
« Reply #42 on: Fri, 10 January 2014, 15:32:54 »
I would prefer the bare module or a kit with instructions.
« Reply #43 on: Fri, 10 January 2014, 15:43:09 »
I have no idea how plausible this idea is... but would it be possible to have it programmed at the fab? It could be 0 and 1 by default so it would do something 'out of the box'. Would it be at all possible to have it on the fly programmable? Surely almost no one would be using this as primary keyboard. Maybe could have like a 2pin header jumper like for clear cmos placed to enable program mode? Something like a press key... press key(s) on keyboard, press key again to save kind of deal? Even if you have to remove keycap to get to it... at least something like that would be super user friendly instead of making people do compile and flash deal with a tricky interface.
Offline Oobly
« Reply #44 on: Fri, 10 January 2014, 16:15:53 »
If we can somehow get this flashed to a bunch of chips it would make life easier: https://github.com/micronucleus/micronucleus
Apparently Digi-Key can flash them :D
"This part can be programmed by Digi-Key; for details please contact our custom department at 1-800-344-4539 x5725 or custom.orders@digikey.com"
http://www.digikey.com/product-detail/en/ATTINY85-20SH/ATTINY85-20SH-ND/2238295
I wonder if they are happy to do it for bulk orders?
Offline Defying
  • (suffer on)
« Reply #45 on: Fri, 10 January 2014, 16:22:18 »
wouldn't a 3d printed case make the thing too light? i mean it's just 2 switches (probably without a plate), so i can see this thing not being too secure on a desk or something
Offline McWilloughby
« Reply #46 on: Fri, 10 January 2014, 16:27:05 »
Really like this idea.
Definitely need some brass weights as well right?
« Reply #47 on: Fri, 10 January 2014, 16:31:00 »
Could always design it in such a way that can place some weight in the bottom under the PCB or something like this in miniature.
There is always things doublesided tape too... :))
Offline WangZi
« Reply #48 on: Fri, 10 January 2014, 16:48:50 »
+1 on double sided tape. To be honest i really don't think it will slide around that much if you are only tapping on it. However i could be wrong and this just destroys my table.
Also what switches are you planning to place on the keyboard?
Offline agodinhost
  • Soylent green is people ...
    • Dr Ian O Xaman
« Reply #49 on: Fri, 10 January 2014, 17:00:09 »
V-USB provides some sample code ready to be used into this mini keyboard.
We just need someone to review the pins assignments
HID Keys
EasyLogger
Why not more keys too?
 :D
BTW: I'm in for a group buy.
« Last Edit: Fri, 10 January 2014, 17:05:48 by agodinhost »
