Author Topic: [IC] Karat WKL with ALF studio (🔓💎🔓)  (Read 17805 times)
Offline amaddo
« on: Tue, 02 April 2019, 04:33:45 »
Travelers who continue to seek END GAME,
welcome to the IC thread of "Karat WKL".
This project is designed by Amaddo and manufactured by ALF. I will not forget the gratitude to ALF.
If you are attracted to this gem, leave a message here. That will bring this project one step closer to success.
support layout
color rendar
black
gray
silver
white
burgundy
navy blue
cyan
green
purple
brown
pink
polycarbonate
wood
The color obtained in the questionnaire survey render
orange
red
dark green
yellow
full brass/gold
full brass/rose gold
weight rendar
Details
 WKL
 High Profile
 Top Mount
 9 Degree Angle
 Case Material: Aluminium, PC, (Wood, brass)
 Weight Material: Brass
 Plate Material: Brass, PC
 Brass Finish: PVD
 Supports most PCBs
 2kg
Include
 Aluminim Case
 Brass weight and plate
 Screws
 Rubber Foot
Case Color
 I have not decided yet, but I will try to offer you many colors.
Price
 Although I can not say for sure yet, according to ALF's factory, the price of the prototype is $ 200 ~ 230.
 When actually doing GB, it can be lower than the price of the prototype depending on the number of products manufactured.
 (The PC version is expected to be 1.2 to 1.3 times higher than aluminum.)
Schedule
 Ordering prototypes this week.
 It will be manufactured in around 20 days and will be transported internationally.
 It has not been decided until the scheduled GB date, but after the GB of "Uncertainty60" is finished.
Q&A from Google form, Reddit etc...
Q: Proxy?
A: I'm planning to set up a proxy, but please wait as I haven't talked yet.
Q: HHKB Top too please?
A: Sorry, This project is only WKL.
Q: Do you offer a PC model? (Another similar question.)
A: Yes, You can get PC model.
Q: Leave out a PCB to keep costs down.
A: Yes, I have no plans to provide PCBs for this project. Because it is compatible with many 60% PCBs.
Q: I'd like to see some renders with keycaps!
A: Wait, wait.... :'(
Q: I want to put a boardwalk PCB inside. The PCB is GH60-compatible & supports WKL cases. I'll just laser cut my own plates & adapts to this case. A DXF file for cutting plates would be useful.
A: When GB is over, publish using Github etc. (The corner rounding is set to 0.5 mm)
Q: Please list estimated price and date of GB!
Q: Would it be a possibility for a version num/macropad edit
A: There is no design plan for the moment.
If there are many such requests, I consider.
Q: How big is the clearance between the case and the switch hole? Because it looks really tight.
A: The distance from the bottom of the plate to the bottom of the case is approximately 8.8 mm. I think there is probably no interference.
↓↓reference image
Update
IC Form
https://goo.gl/forms/mMW0aIjiyHIeACGD3
I am also working on Twitter, Instagram and so on.
Twitter
→https://twitter.com/amaddo_type_A
Instagram
→https://www.instagram.com/amaddo_type_a/
« Last Edit: Sun, 13 October 2019, 04:35:19 by amaddo »
Offline vicissitude
Re: [IC] Karat WKL with ALF studio
« Reply #1 on: Tue, 02 April 2019, 05:55:23 »
Like the shining pvd brass weight and plate.
Offline amaddo
« Reply #2 on: Tue, 02 April 2019, 08:19:46 »
I just asked an ALF representative if the PC version could be manufactured.
I want to provide it, because the demand for the PC version is increasing.
Offline Chewwy
« Reply #3 on: Tue, 02 April 2019, 08:22:42 »
I missed out on the Leaf 60 WKL and want a better WKL board. Very excited to see this board make it to GB.
Sent from my SM-N960U using Tapatalk
Offline amaddo
« Reply #4 on: Tue, 02 April 2019, 08:41:03 »
I just received a reply.
The PC version can be provided.
However, it is expected to be 1.2 to 1.3 times higher than aluminum plate.
Offline equalunique
« Reply #5 on: Tue, 02 April 2019, 09:14:08 »
Looks good to me. Hoping I can cut a custom plate for it & put in a boardwalk PCB.
Sent from my LG-H918 using Tapatalk
Offline amaddo
« Reply #6 on: Tue, 02 April 2019, 09:55:43 »
In ALF's Discord, I realized that the split space bar is important. Fix the plate.
Also, plate data will be released after the end of GB.
Offline equalunique
« Reply #7 on: Tue, 02 April 2019, 10:05:15 »
 Fantastic, thank you!!
Offline eskimojo
    • KeycapLendar
« Reply #8 on: Tue, 02 April 2019, 11:15:12 »
out of curiosity, how is space normally split on a WKL?
Offline azulyf
« Reply #9 on: Tue, 02 April 2019, 12:32:15 »
Like the board,but want a standard layout.
Offline bball2
« Reply #10 on: Tue, 02 April 2019, 12:41:05 »
Red case, blue plate, and the Superman logo engraved on the brass weight  :thumb:
« Reply #11 on: Tue, 02 April 2019, 13:14:35 »
> alf studio
i'm out
Offline maximize
« Reply #12 on: Tue, 02 April 2019, 14:19:44 »
Offline pixelpusher
« Reply #13 on: Tue, 02 April 2019, 14:24:09 »
> alf studio
i'm out
Damnit, man.  I can no longer decipher truthiness in your posts.  Serious or no?  Did I miss something?  Plus, again... you're out of funds.  We KNOW you're out.
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #14 on: Tue, 02 April 2019, 15:31:07 »
The Brutal60 chamfer and the angled back are a weird but interesting combo in my opinion.
Also for an "endgame" keyboard, you expect to see features like a shaped USB cutout and extra attention to detail on the plate, like relief cuts or asymmetric mount points. Obviously nothing wrong with omitting them, but given the current state of keyboard design I don't think you can call it "endgame" unless you're planning to go above and beyond what's come to be standard.
That said, I'm sure the quality will be high and whoever buys it will enjoy it.
Offline amaddo
« Reply #15 on: Tue, 02 April 2019, 20:57:53 »
I devise every detail to give you a satisfying keyboard.
Offline amaddo
« Reply #16 on: Tue, 02 April 2019, 21:03:24 »
I discussed the space bar on ALF's Discord server.
As a result, I thought that such a layout was the best.
Offline amaddo
« Reply #17 on: Tue, 02 April 2019, 22:45:37 »
I made some changes to the USB part.
It is Klippe of MKANISK which made reference
« Last Edit: Tue, 02 April 2019, 23:38:38 by amaddo »
« Reply #18 on: Tue, 02 April 2019, 23:12:40 »
> alf studio
i'm out
ALF GBs are riddled with delays and quality issues, too many boards not enough factory
Offline dimo
« Reply #19 on: Wed, 03 April 2019, 00:28:36 »
Another uneffortful 60% ic. Complete lack of design.
Gigantic weight could have been incorporated in the back in a myriad of different ways but its just flat and boring.
+ alf
Offline amaddo
« Reply #20 on: Wed, 03 April 2019, 01:17:45 »
What do you think if a PCB with a USB hub function like HHKB exists as an option?
(It is still a fictional)
Offline equalunique
« Reply #21 on: Wed, 03 April 2019, 08:04:11 »
Sounds interesting but can that be a configuration option users can choose vs. a normal GH60-compatible PCB like with the ALF x Scott G60?
Offline amaddo
« Reply #22 on: Thu, 04 April 2019, 06:52:02 »
That is a difficult place.
Therefore, we also consider providing two types of models.
1: A model corresponding to a generally popular PCB (GH60, GK64, etc.) without drilling a hole for USB in the case. However, PCB is sold separately
2: A model in which the case is made with a hole for USB and the corresponding PCB is attached to the kit
Offline amaddo
« Reply #23 on: Thu, 04 April 2019, 23:25:27 »
Fix the plate
Offline amaddo
« Reply #24 on: Sun, 07 April 2019, 01:03:14 »
Currently, ALF staff works hard to meet my hopes.
If he could do that, I might be able to offer you a more attractive keyboard.
Offline kabel1337
« Reply #25 on: Thu, 11 April 2019, 15:10:25 »
I'm very interested in the board but I feel like a lot of people would appreciate a gasket mounted plate and maybe a more interesting weight design because it does look really bland and without any depth to it right now.
Offline amaddo
« Reply #26 on: Fri, 12 April 2019, 02:11:33 »
I now want to provide wood models in addition to aluminum models and PC versions. I think trees are beautiful, but many high-end keyboards do not have models using trees.
At the time of Carat WKL's design, it was planned to provide a case using wood, but the ALF plant could not be manufactured with wood. However, ALF's Sirusu is looking for this keyboard factory.
Offline pixelpusher
« Reply #27 on: Fri, 12 April 2019, 16:30:16 »
I did not know the Sirius was going to have a wood option.  I knew about the POM version.  interesting
Offline amaddo
Re: [IC] Karat WKL with ALF studio add new color rendar
« Reply #28 on: Sun, 14 April 2019, 01:59:33 »
add new rendar.
Offline hyppialonso
Re: [IC] Karat WKL with ALF studio (add new color rendar)
« Reply #29 on: Sun, 14 April 2019, 06:18:46 »
looking good, really interested
Offline roguesystem087
« Reply #30 on: Sun, 14 April 2019, 12:20:52 »
omg... I think this will finally be my first GB keyboard kit.... omg pls make
Offline bukowski
« Reply #31 on: Mon, 15 April 2019, 07:54:55 »
I would buy the full brass-version in an instant.
Offline amaddo
« Reply #32 on: Mon, 15 April 2019, 09:20:19 »
I answered questions from Google forms and Reddit. Questions that have similar content are answered collectively.
Also, thank you to those who appreciate this keyboard, those who support me, and those who give me an opinion!! ;D
Offline snurrebassen
  • mechanical keyboard designer and enthusiast
    • Linktree
« Reply #33 on: Mon, 15 April 2019, 10:02:07 »
Just as I was looking for cases to use my extra DZ60 for, this one popped up at a perfect time!!  :D
Big fan of ALF and WKL!
Take your time, so that I can save up some money!
Offline amaddo
« Reply #34 on: Wed, 17 April 2019, 09:57:56 »
I will issue a request to manufacture prototypes in the near future.
Also, as we have important announcements about the wood model, we will make corrections to the main thread shortly.
« Last Edit: Wed, 17 April 2019, 09:59:30 by amaddo »
Offline amaddo
Re: [IC] Karat WKL with ALF studio (Preparation for prototype production)
« Reply #35 on: Thu, 18 April 2019, 07:48:36 »
The prototype data was submitted to ALF.
Soon production will begin.
Offline KyleUK
« Reply #36 on: Mon, 29 April 2019, 05:57:39 »
Chipping in 2 cents after being part of the x1.1 group buy.
I would absolutely stay away from this until Alf and team have resolved the outstanding issues with the current group buys.
The quality control was shocking, my PCB still plays up, and they sent the wrong colour.
These issues have either not been acknowledged at all, or for the scratched brass which they committed to replace the timescales keep slipping and slipping.
To run another group buy is absolutely madness.
I'm happy to update my opinion if the issues are addressed, but right now I will not entertain anything more from this manufacturer.
