Author Topic: My new favorite tactile  (Read 28297 times)
Offline Lyd
« on: Wed, 17 April 2019, 22:02:09 »
Over the last few months I've managed to get a hold of some KBDfans T1 switches, as well some zealio V2s, Mint Pandas, and of course,  some massdrop halos for stem swaps.  I've tested a few combinations of each in an attempt to rig a new frankenswitch (and to test other well known switches like the Holy Pandas)  My results are in, and are as follows
Zealio V2 (67g) - These did not work well with any of the other switches.  I opted to keep them stock in the end (may be swapping out some springs in the future or lubing them).  I liked these, they are certainly tactile.  The bump was at the top of the key press.  They mind me of a sort of tactile box clicky switch; both feel similar with the tactile event coming in at the top.  To differentiate them from the KBDFans T1, they have a much faster return (possibly due to a heavier spring although both are measured at 67g).  They're a good deal snappier post tactile event, and they feel smoother when compared to KBDFans Stock.
KBDfans T1 - Originally made to replicate "Holy Pandas" these felt very good, more tactile than the Zealio V2s, but only ever so slightly.  There was a slight delay on the return - nothing at all to worry about when typing, but in a single switch to switch comparison the spring did seem to require me to lead off a bit more before it even started moving after being depressed.  I had never tried a holy panda before trying these and I so I thought that this would be a good way to segway into the Holy panda - that and a cheaper panda-clone is never a bad thing given how expensive / rare they've gotten.  Hopefully things change with the recent recreation of the holy pandas.
"Holy Pandas" (Halo stem / Panda Housing) - Before going into this I just want to state that my goal in getting to build these franken-switches was to potentially find the most tactile switch possible.  The Holy Pandas have been touted as very tactile since their introduction.  I have a few other tactile boards ala topre, but having to choose between MX style keycaps (no I'm not using sliders) and tactility I'll he hard pressed If I'll give up my MT3 and Sculpted SA profiles.  I made my holy pandas with some 67g gold cherry springs, Mint Pandas from Novelkeys, and Halo stems from massdrop.  They were awful.  I tried lubing them, I tried using different springs, I tried a few different rounds to make sure that they were correctly put together.  They were the least tactile out of the bunch here.  Now, I'm not saying they're a bad switch (I mean everyone has their preferences), but the tactility was beated by 3 other switches in this franker-stein experiment.  I could feel the long drawn out bump, but there was little to no tactile event.  I guess these were not for me.
"Wei-los" "KBD Pandas" "???" (Halo stem / KBDfans T1 housing) - I am surprised.  These were extremely crisp and the most tactile switch I've ever used.  It reminded me of BKE Lights / Heavies.  The tactile bump was at the top and there's a feeling of the switch "inverting" as you press down on it.  Once you press through the tactile event, It almost feels as if the switch "jumps down".  They feel lovely and are the best thing to come out of this.  To make things better, I found that the slight delay in return in the KBDfans T1 is caused by the spring and not the contacts, so for good measure I swapped in a spring from my zealio v2 and although they have the same actuation force, the Zealio spring returns faster.  What I created is an incredibly crisp switch with a lightning return.  PERFECT for my little typing fingers.  HOWEVER there was 1 downside to this combination.  Due to the stem being so long it smacks into the bottom of the housing, now normally this wouldn't be a problem (I believe all variations of the holy panda do this) BUT in the batch (R1 clear & smokey) that I have, there's a tiny plastic dimple at the bottom of the shaft.  If you depress the key and give it a stern little wiggle, you can feel the stem "popping" to the left and the right of that dimple.  I remedied this by sanding it a bit so that it no longer made contact.  The switch no longer "popped down" completely when depressed, but there was no effect on tactility (I mean... why would there be?).
To conclude the KBD Pandas are going into my next board, but I was wondering if I could ask for some help now regarding 2 things
1. Would sanding the bottoms of multiple Halo stems lead to discrepancies in the key feel of the switches?  (I can't always sand away the "perfect" amount of material)
2. Where does Zeal get his springs?  And where can I get some?  I've heard that you can get some high grade springs from SPiRIT, but I've also heard that they're weighted differently than other springs.
3. What is the closest weighting (and if not exact does it require more or less force) if a SPiRIT spring to a 67g Zealio Spring?
These were really the only 4 worth talking about.  The rest of the frankenswitches weren't bad, but these are the 3 highest ranking in tactility (and a Holy Panda for good measure)
Thank you!
Offline audax989
  • NOM NOM NOM
    • Guam Mechanical Keyboards
Re: My new favorite tactile
« Reply #1 on: Wed, 17 April 2019, 22:23:28 »
Great writeup man!
What can you say about the sound compared to the t1 housings compared to the mint housings?
I’ve been rocking my r2 t1s stock for about a week now. Just waiting on some films and lube. Do you notice how after the bump there’s a bit more resistance to bottom it out completely?
Completely different from the sharp drop off from the royals after the bump.
Offline Lyd
« Reply #2 on: Wed, 17 April 2019, 22:40:03 »
Great writeup man!
The t1 housings are definitely higher pitched than the mint pandas.  I thought the mint pandas were fairly soft sounding, but once you put a halo stem in them, the plastic on plastic produces a fairly loud "thock" just from bottoming out hard enough.
Stock T1s have a very lightly pronounced "dead zone" similar to the halos.  Once you clear the tactile event there's a small area with little to no resistance, but you can depress the switch further after and that gives a bit more resistance.
Replacing the T1 stem with a halo nearly removes the dead zone.  The halo stem smacks into the bottom of the shaft and stops so no dead zone otherwise, if you shorten it the tactile event brings you to almost the bottom of the switch (leaving something like 5% of your press left feeling a tiny bit of resistance)
Offline Telstar
« Reply #3 on: Thu, 18 April 2019, 02:21:18 »
Very interesting writeup.
Whoever told you that HP were more tactile than zealio v2 was wrong, as it has been pointed out in zealio reviews. it's the kind of bump that is what some people love.
I do not have a HP (and not even sure I'll like it), but I have a few t1 (r2), halos and zealios that I could try the "KBD panda".
If possible, I would like you to try a vanilla halo with a 72g sprit spring (not gold plated) or similar, and compare, because I'm liking it very very much.
Zealios springs could be korean made.
Offline Telstar
« Reply #4 on: Thu, 18 April 2019, 02:23:38 »
Once you put a weaker spring in the halos this dead zone disappears IME.
Offline Lyd
« Reply #5 on: Thu, 18 April 2019, 02:36:50 »
I was thinking of getting some korean springs and trying those out in my kbd pandas.
Everywhere I looked people were hailing the holy pandas for having "serious tactility" I find that extremely odd given that the t1's feel nothing like holy pandas.  I thought that I had done something wrong, but it's nice to know that I'm not an outlier.  I might have missed where the Zealio V2s were straight up said to be more tactile than HPs, but even so I'm so surprised that the tactility is a world's apart.  The HPs to me feel like linears with progressive springs.  Weird stuff.
Offline Telstar
« Reply #6 on: Thu, 18 April 2019, 02:44:32 »
IME the most tactile switches I have under test are the following 4, and they are my favourite, and I cannot choose yet:
Zealio v2 67g and 62g (not the 65g)
NK Box Royal
Halo Clear with 72g sprit spring
Halo Clears and Trues stock are also super tactile but too heavy for my liking and so was the zealio 78g.
Among clickies, obviously jades and navies are even beyond this but noisy :)
Stock T1 r2 are noisy and I was probably unlucky with my batch as 2 of 10 were wobbling like crazy (didnt test all 10 in the gmmk).
Offline Lyd
« Reply #7 on: Thu, 18 April 2019, 02:52:51 »
I would have to say that in terms of tactile events the Box Thick Clicks are pretty much my #1 too.  Unfortunately the feedback is a little too sharp for my tastes.  I'm typing on a Box Navy board right now  :D it's great for single actions, but typing for extended periods can be a bit fatiguing.  I wholeheartedly recommend navies for things like macro pads.
Offline Telstar
« Reply #8 on: Thu, 18 April 2019, 03:17:35 »
Yeah, I will make a keeb with the jades too. Navies are way too heavy for my fingers.
Offline Peripheral Prophet
  • Lets change the game
« Reply #9 on: Thu, 18 April 2019, 03:50:19 »
Its odd you found the yok pandas to be the least tactile.. what exactly did you lube them with??  I think at most, in order to not kill the tactility, that I wouldnt lube with anything more than say, 103 or even 203..
Can you tell me what lube you used?  I sold my yok pandas but it wasnt because they werent tactile, I found them to be dramatically tactile tbh.. Some even describe the tactility as 'violent'... Not sure i would go that far but they were pretty nice..
Check out my live build streams on twitch and join my discord! https://discord.gg/QzeSQj2  https://www.twitch.tv/peripheral_installer
Offline ctrlshiftbryan
« Reply #10 on: Thu, 18 April 2019, 14:13:36 »
Holy Smokes! (hope you got the smoke T1 housing)
« Reply #11 on: Thu, 18 April 2019, 14:17:10 »
I did this too but I found I prefer the fit of the actual holy panda better. The YOK housing just fits the halo stem tighter and the overall feel is more solid.
Offline Lyd
« Reply #12 on: Fri, 19 April 2019, 01:08:02 »
I didn't lube them, but I bought some tribosys 3203 so I'll be able to more accurately make a comparison.  The tactility wasn't nothing, but by comparison the T1s and the Zeal V2s were much more tactile.  You can feel the tactility a bit in the HP, but they feel more like progressive linears to type on because my fingers go right to the tactile events to press down.
I bought some of the pandas from massdrop when they opened so I'll have more to say about it once I get them in.  I'm still wondering if I just did something wrong but idk  it might be an issue with just the mint pandas, or YOKs in general?
« Reply #13 on: Sat, 20 April 2019, 10:47:03 »
Are you sure you have pandas???  I have all of Zeals v2's in front of me, and the tactility is no where near as dramatic as the yoks.. When you say 'tactile' how do you define that??  Zeals are a bit more rounded , but I guess I dont understand how you say a yok panda is less than a t1 or zeals v2's... I mean, i guess everyones opinion is their own, but you dont really hear people saying the yok pandas are less tactile than zeals or kbdfans.. Just weird to hear that.. I have them all in front of me as we speak and I dont understand how you came to that conclusion.. Not trying to invalidate your experience so much as trying figure out why myself and essentially everyone Ive spoken with are having the opposite experience you are having..
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #14 on: Sat, 20 April 2019, 11:03:00 »
I have heard some grumblings that the Mint YOKs do not end up as tactile as the Red YOKs & GSUS Pandas with Halo stems. I personally have not tried any of the Mint YOKs yet, but I do have Red Yoks with Halo stems in my Redscarf & IMO they compare very well to OG Holy Pandas. That said I do find V2 Zealios to be more tactile & step up from any HP variants I have tried. OG HPs are very tactile, but they are also fairly scratchy IME. This goes for Red YOK HPs & GSUS HPs too. I have yet to try the T1s so I can't comment on them yet.
Offline Lyd
« Reply #15 on: Sun, 21 April 2019, 01:47:53 »
This may be the case then.  That's severely disappointing if true, but I'll have some OG hps once the massdrop lands.  At least I'll be able to properly compare once I have both in hand, still how odd for 2 different YOK switches to be so different.  I have to say that currently,. my favorite switch without doing stem swaps is the t1 I would very much recommend it!  Going to be experimenting with some springs and lube when I get them in.  At the time of writing, I'd prefer them over Zeal v2s in all aspects other than the slight return delay.  But I've tried swapping zeal springs into them and that fixed that problem.  So hopefully some lube and better springs will fix the problem.  No way I'm going to cannibalize v2s just for their springs.
« Reply #16 on: Sun, 21 April 2019, 17:49:41 »
This is VERY interesting..
Offline 2ndRoad805
« Reply #17 on: Mon, 22 April 2019, 22:04:56 »
How does your new KBDfans frankenswitch compare to the box royal? I've ordered some 67g zealios v2 and t1 r2 switches but I won't be able to have them in the arsenal to know for myself until the end of July. I'm asking about the box royal because I actually prefer these over the 3203 lubed Holy Pandas/GSUS. I like lighter switches, but the tactility of the Holy switches seem muted to me. Looking forward to one day also trying a 55g uniform topre, bke heavy redux dome, and these new beamsprings coming out. The search continues!
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #18 on: Mon, 22 April 2019, 22:53:37 »
Don't sand your Halo stems. Clip them with flush cutters.
Offline Lyd
« Reply #19 on: Tue, 23 April 2019, 01:41:09 »
I hear you there, I'm eagerly waiting those cool new beamspring switches!  Box royals feel like they have a sharp tactile bump, but then immediately just bottom out, I'm a med-heavy typist so the force I would press with to get through the bump would push the key all the way down, by comparison immediately after the bump ends with holy t1's the switch stops.  The halo stem shortens the travel distance on the down-stroke.  Imagine a zealio v2 with a sharper bump, except immediately after the bump ends at the top of the keypress, the halo stem slams into the housing and stops you from depressing the key any further.  They remind me of bke heavies/lights.  There's a sharp tactile event and then you immediately bottom out (imho similar to how a bke dome "inverts" as you press down on it)
Lol, I don't know why I didn't think of this.
Offline Telstar
« Reply #20 on: Tue, 23 April 2019, 08:04:38 »
The box royal is definitely heavier.
Offline aleck
  • im so full of topre yum
« Reply #21 on: Tue, 23 April 2019, 08:29:24 »
Wei-los... That name... Unique name, I like it.
HHKB Pro 2 Type-S (2016)
« Reply #22 on: Tue, 23 April 2019, 09:22:36 »
What about cherry MX clears. While not super tactile, how do they compare to other switches? What's the lightest spring you can use on those?
I like to have some pretravel before the bump
« Last Edit: Tue, 23 April 2019, 09:27:23 by cherrymxsilent@gmail.com »
Offline Lyd
« Reply #23 on: Tue, 23 April 2019, 20:33:17 »
To me mx clears have a pretty defined bump, but the bump is very short and in the middle of the keypress.  I've also never thought they felt that great, extremely scratchy and had an odd issue where the bump was a bit too strong for the spring to clear, so having it return would cause significant delays in comparison with the other tactile switches I've tried.  They were usable but they just felt awful to me.  Then again, I haven't tried any cherry switches outside of blacks since they retooled their switch molds.  Pretravel or not, there are better switches for mid-press tactility.
tbho, I'm really not a fan of any cherry switches outside of their retooled blacks.  You'd be better off getting things from other, more innovative manufacturers if you're building your own board.
Offline ArchDill
« Reply #24 on: Tue, 23 April 2019, 21:11:46 »
I just ordered some R2 T1's. I hope they do not suck. haha
« Reply #25 on: Tue, 23 April 2019, 22:44:02 »
55 grams in cherry MX clears seems fine, no delays in returning. Do you have suggestions about better switches?
Offline Telstar
« Reply #26 on: Wed, 24 April 2019, 08:19:09 »
IDK, they didn't pass the first selection on the switch tester. I found the MX white much better in tactility and overall feel.
Didn't care to mod them, but felt immediately that they are overrated.
Offline Telstar
« Reply #27 on: Wed, 24 April 2019, 08:20:36 »
Most of those in this thread: zealios, t1, box royal, even halo clear (with spring swap).
Offline audax989
  • NOM NOM NOM
« Reply #28 on: Wed, 24 April 2019, 08:21:29 »
Let me know how you like em when they come in man.
Offline lightsout714
« Reply #29 on: Wed, 24 April 2019, 15:08:25 »
I also have a X8 coming monday with T1's installed. Looking forward to trying them out. Although I only have experience with Cherry switches and ergo clears. None of these new fangled switches that appear to be everywhere.
