Author Topic: [GB] Cases and Plates for Shark 40 PCB  (Read 14224 times)
Offline Wood_Cables
    • Wood/Cables
« on: Fri, 26 April 2019, 23:08:52 »
Now that the PCB group buy has ended, it is time for us to focus on the cases. These became available a couple weeks after the PCB, so that would explain the delay.
This GB will run until the end of June.
To those who have already purchased, thank you.
REAL WORLD PICTURES
Switch Plates:
  • Designed to be used with either "The Short One" or "The Tall One" aluminum cases.
    6061 Aluminum, CNC smooth surface, anodized in Gray, Black, Purple or Cyan.
    Short One plate will fit other 19mm 40% ortho cases not sold by Shark.
The Short One Aluminum Case:
  • Attractive design that allows the switch plate to sit flush with the top surface of the case. Unique mounting design that utilizes all holes of the PCB/switch plate(10). This adds a great deal of rigidity.
    Will come with M2 screws(10).
The Tall One Aluminum Case:
  • Weighs about 2 pounds.
    Switch plate recessed into the case.
    Same mounting system as The Short One case.
    Available in Gray, Black, Purple and Cyan.
Cost:
  • The Short One Aluminum Case - $60
    The Tall One Aluminum Case - $100
    Aluminum Switch Plate - $15 (Tall and Short Plates)
    Shipping is based on weight and will increase when multiple products ordered.
ORDER HERE
« Last Edit: Sun, 26 May 2019, 10:29:08 by Wood_Cables »
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
Re: [GB] Shark PCB is LIVE!
« Reply #1 on: Tue, 30 April 2019, 18:21:15 »
Approved
Offline Abec13
« Reply #2 on: Tue, 30 April 2019, 19:39:52 »
I didn't buy the Kotai case because the planck PCB line was too long.
Let's do this.
45-ATS | Adelie | Gentoo | Volcano 660 | Think 6.5 v2 | SKOG | 7V | Hello M0110
[/url]
Offline factoryofidols
« Reply #3 on: Tue, 30 April 2019, 20:47:33 »
ordered, been waiting for something to replace my contra that I can put in a nicer case now that I know I like ortho.
Offline Wood_Cables
    • Wood/Cables
« Reply #4 on: Wed, 01 May 2019, 08:03:22 »
Thanks for your order!
We will be offering two aluminum case options in the near future, both subject to a similar 100 minimum order GB. The first one we're calling our Short case, which will have the switch plate mounted flush with the top of the case.
Follow me in IG for renders of that, the other case and general updates.
IG - woodcables
Offline Wood_Cables
    • Wood/Cables
« Reply #5 on: Wed, 01 May 2019, 08:03:50 »
Let's do this.
No crazy queue here. Thanks!
Offline TuCZnak
« Reply #6 on: Wed, 01 May 2019, 12:21:51 »
Are standoffs and screws included in the basic kit, or do we have to source them ourselves?
Offline Wood_Cables
    • Wood/Cables
« Reply #7 on: Wed, 01 May 2019, 15:35:08 »
They are included, I'll make that clear in the OP. Thanks!
Offline Wood_Cables
    • Wood/Cables
« Reply #8 on: Sat, 04 May 2019, 09:31:32 »
An aluminum case that we designed is in prototyping stages right now. I will have real world pictures to post in about a week. Will be aluminum dark gray.
Offline Wood_Cables
    • Wood/Cables
« Reply #9 on: Mon, 06 May 2019, 12:19:18 »
We're about to offer an aluminum case. Check the IC Thread for more information.
Offline Wood_Cables
    • Wood/Cables
« Reply #10 on: Tue, 07 May 2019, 10:24:23 »
Added aluminum case and new switch plate options.
Offline Wood_Cables
    • Wood/Cables
« Reply #11 on: Sat, 11 May 2019, 19:27:14 »
Bump.
Check www.woodcables.com for new products and a status update.
Offline OkKarma
« Reply #12 on: Sun, 12 May 2019, 12:51:07 »
Ordered the case + pcb. :thumb:
Offline Wood_Cables
    • Wood/Cables
« Reply #13 on: Mon, 13 May 2019, 07:34:11 »
Appreciate it!
Offline Wood_Cables
    • Wood/Cables
Re: [GB] Shark 40% PCB & Kit...Halfway There
« Reply #14 on: Wed, 15 May 2019, 09:18:25 »
Status update in OP.
Offline Wood_Cables
    • Wood/Cables
« Reply #15 on: Tue, 21 May 2019, 08:35:48 »
The prototype of The Tall Case and Switch Plate are in!
https://imgur.com/a/D13cbPq
