Author Topic: [GB] TGR-Jane v2 CE (QC, Shipping) 99% completed  (Read 1498354 times)
Offline clasicks
  • Formerly KeyboardUser4
Re: [GB] TGR-Jane v2 CE (QC, Shipping)
« Reply #1800 on: Tue, 25 February 2020, 07:21:42 »
As someone that has pretool screw ins... Would it be worth it to try to find clip ins for the spacebar to use the gasket, or just roll top mount?
worth it - I haven't tried top mount yet cuz I am really digging the gasket.
ALSO - Install the gummy before you solder the PCB - I really liked having room to pull the PCB and Plate apart while wedging the o-ring in around the USB port on the PCB.
What switches did you use to use gummy before soldering? I have vints in a mock build and with the h88, the pcb moves around a bit to the point that I think doing it before soldering might be difficult.
By gummy, do you mean the gasket?  You can leave the gasket to the end. Just pinch it and stick it behind the USB port - that’s my technique.
you can do it before or after solder, I didn't like how tight it was in there and didn't want to slice the oring wedging it in
I think its best to start here, it likes to pinch the rubber here either way, then you can stretch it around the rest
note - ur oring is probably clear, ignore my red one
Offline rkarp
    • hypertext.dev
« Reply #1801 on: Tue, 25 February 2020, 09:24:09 »
Ah - cool. I see what you’re saying now.
Offline Auxo
  • Formerly CJD_Anthony
« Reply #1802 on: Tue, 25 February 2020, 11:42:22 »
Ran into that issue as well, I was cautious about the USB area as I didn't want to slice the O-ring with my spudging tool.
That said though, I did use GMK screw in stabs and didn't have any issues mounting it.
Offline Chimera
« Reply #1803 on: Wed, 26 February 2020, 10:07:22 »
So it does work fine with screw ins?
Offline Auxo
« Reply #1804 on: Wed, 26 February 2020, 10:51:53 »
Si senor. It is a little bit tight, but everything pushes in fine when you sandwich everything in. Maybe it just squishes the rubber gasket against the spacebar stabs but that doesn't seem to have caused any issues :shrug:
All said and done, I absolutely prefer the sound profile of gasket mount over top mounting (I tried both)
Offline rkarp
    • hypertext.dev
« Reply #1805 on: Wed, 26 February 2020, 11:25:55 »
Just to be on the safe side, you might want to disassemble the case after a few days and check to see how the rubber is holding up.  I had it in there with the Zeal screw-in stabs for 2 days.  When I opened the case, the part of the gasket that was pressing against the stabs was deformed with discoloration (different shade of white due to the compression) and it did leave lasting impression marks in the gasket.  I took this as a sign that it was under too much pressure, which prompted me to desolder and order/install some clip ins for the space bar.  Your mileage may vary and you might be alright, but it couldn't hurt to double check after a few days.
I did a complete desolder job with pump and wick - last time I'm doing that btw - and am waiting for an H88 and FR4 plate to arrive later this week to reinstall my zealios.  I'm hoping the sound profile of the FR4 isn't too different from the CF, as I really liked it.   I'm not having any luck on r/mm for some vints, and don't know enough about older boards to take a chance on eBay.  I might hit up the local thrift shops this weekend to see if I can't find anything to harvest from.
Offline pr0ximity
« Reply #1806 on: Wed, 26 February 2020, 21:43:47 »
For what it's worth, I think most o-ring gasket mount boards will damage their gaskets over time. It's just how it works when you have soft rubber compressed against sharp-edged aluminum for years. But even with that (I basically have chunks taken out of my mini's gasket) it should still hold together. And once sourced, they're not very expensive to replace.
Offline Velvet_Crowe
« Reply #1807 on: Wed, 26 February 2020, 21:53:46 »
If you're using zeal/durock stabs, you can file the spacebar stab housings a bit to relieve some stress on the gasket
Current daily: OTD 356mini v1 (Red) | OTD 356CL (Gunmetal) | TGR Jane V2 CE (Black) | zekk.works Ogre (Dark Grey) | Noxary Vulcan Pro (Silver/Red) | 488 Pista Spider (Red)
Offline Auxo
« Reply #1808 on: Thu, 27 February 2020, 12:43:46 »
Thanks for the info guys, is there a particular part number associated to these o-rings? I'd need to buy some extras anyway for spare builds :eyes:
Offline tomu
  • hi
« Reply #1809 on: Thu, 27 February 2020, 17:08:22 »
Size 271 should work, IDK what duro Sam used though
Sent from my SM-G965U using Tapatalk
G80-3700 | HHKB Pro 2
Offline Chimera
« Reply #1810 on: Thu, 27 February 2020, 23:47:17 »
Yeah, I'd be interested in specs to order a few replacements.
Offline rkarp
    • hypertext.dev
« Reply #1811 on: Fri, 28 February 2020, 18:32:00 »
Yuktsi posted the specs a few posts up. 3.5mm thick and 240mm diameter I believe.
Offline DukeEsquire
« Reply #1812 on: Sat, 29 February 2020, 16:28:01 »
I know that part of the novelty of TGR is the wait, but is there any indication of estimated shipping for the remaining orders?
Offline rkarp
    • hypertext.dev
« Reply #1813 on: Sat, 29 February 2020, 17:39:05 »
Rebuild went great.  Ended up getting a H88 from Daily Clack, and picked up a FR4 plate from Hiney's store.  Tealios fit well.  Clip in space bar stabs worked well too - the gasket sits properly now and everything is flush.  Very, very happy with how things turned out.
Here is are two quick picks.  I put DSA Galaxy Class on just because.
https://imgur.com/a/qSjec3r
Offline Fortnite
« Reply #1814 on: Sun, 01 March 2020, 02:08:49 »
Hey guys,
I finally got my CE all done up and built.
Sam absolutely nailed this board and it's--by far--my favorite board I have yet to own or use.
Switches and build done by R3msky.
Excuse the crap photos, but I was too excited to resist sharing.
https://imgur.com/a/QHUxvwC
Peace
Offline rkarp
    • hypertext.dev
« Reply #1815 on: Sun, 01 March 2020, 04:26:22 »
Hey guys,
Peace
Omg that’s amazing!!!  How is that even possible?
Offline Fortnite
« Reply #1816 on: Sun, 01 March 2020, 04:46:50 »
Months of planning and a friend who was willing to experiment with me--Shout out to Stephen of Caustic Customs.
Offline tentboy
« Reply #1817 on: Sun, 01 March 2020, 09:25:38 »
Hey guys,
Peace
wtf thats nuts.  Nice stuff man
Offline Emir
  • icon mods
  • Bandit
    • Discord
« Reply #1818 on: Sun, 01 March 2020, 09:40:21 »
Hey guys,
Peace
Ok wow, that is insane
Offline funderburker
« Reply #1819 on: Sun, 01 March 2020, 10:02:19 »
Hey guys,
Peace
It's okay...  :rolleyes:
Keyboard design by Skepur
Offline badboy731
« Reply #1820 on: Sun, 01 March 2020, 11:16:46 »
Hey guys,
Peace
Really wanna see metaverse on it or perhaps even sanctuary . Nice stuff either way!
E7-V1 | TGR Jane v2 CE | HBCP | GSKT-00 | Raine | AOS
Offline jortzii
« Reply #1821 on: Sun, 01 March 2020, 13:38:37 »
Second this. Have yet to receive shipping invoice or other communication. I know that it takes longer this time of year with LNY and all, but haven't heard anything yet. So excited for this board!
Volcano660 | Satisfaction75 | Think6.5 | TGR Jane V2 CE | Preonic | IC Kira | Drop ALT
Offline Nigolski
« Reply #1822 on: Mon, 02 March 2020, 10:23:43 »
ne shipping avail  :'(
Offline ejewell89
  • 4ever Smol
« Reply #1823 on: Tue, 03 March 2020, 09:42:16 »
****ing kyle.
Offline adxlk
« Reply #1824 on: Tue, 03 March 2020, 12:55:11 »
Offline Hadi
  • Formerly eqtri
« Reply #1825 on: Tue, 03 March 2020, 14:16:22 »
Same here. Given how late my PayPal invoice was, I suspect I'll be one of the last to receive the board. More time to get switches ready I guess.
Offline marono
« Reply #1826 on: Tue, 03 March 2020, 16:32:16 »
Is there anyone who paid the shipping invoice early January and have not received the tracking number/ board yet?
Offline kconfire
« Reply #1827 on: Tue, 03 March 2020, 17:54:43 »
Lucky.. I haven't even received a shipping invoice  :'(
[Collection] Monokei Kei SE, Realforce R2 TKL, Leopold FC660C
[Soon TM] Monokei Tomo SE, GSKT-00
Offline DukeEsquire
« Reply #1828 on: Tue, 03 March 2020, 18:28:46 »
No invoice for me either. :(
Offline 1Raku
« Reply #1829 on: Tue, 03 March 2020, 18:32:37 »
Same :(
Sent from my GM1917 using Tapatalk
tgr jane v2 ce | duck unicorn x legend | duck jetfire | HHKB pro 2 | pc singa | tgr alice | iu tkl | kohaku | pc volcano 660 | matrix 8xv 3.0 | matrix 2.0 add | ryujin tkl | dndd | noodle.zip | matrix falcon | noxary evija | tgr 910 me
Offline pr0ximity
« Reply #1830 on: Tue, 03 March 2020, 20:40:33 »
Sounds super muted in comparison to mine, not sure how aside from tons of lube or a low-pass filter or something.
Offline tentboy
« Reply #1831 on: Tue, 03 March 2020, 21:09:26 »
Same :(
Im starting to think there are more of us waiting for the invoice then there are that received it
Offline Retrospects
« Reply #1832 on: Tue, 03 March 2020, 21:28:45 »
Still waiting on an invoice gang checking in. Stay strong friends.
Offline Mousy
  • I <3 tootall
    • IG
« Reply #1833 on: Wed, 04 March 2020, 10:12:45 »
We have strength in numbers!
- White Kira 60 | Black Kira 60 | TGR Jane v2? -
Offline Chimera
« Reply #1834 on: Thu, 05 March 2020, 01:46:51 »
I did a mock up of mine with inks and it sounded pretty muted like this video. I ended up actually building it with vints blacks but it's still quite muted sounding with the gasket. I'll eventually get around to doing a typing test with it.
Offline BAS1C
« Reply #1835 on: Thu, 05 March 2020, 15:11:33 »
Holy **** that sounds incredible. Would Gat Inks sound at all like this do you think?
Offline mellen
« Reply #1836 on: Thu, 05 March 2020, 19:50:57 »
just got tracking, paid jan 7
Offline Chimera
« Reply #1837 on: Thu, 05 March 2020, 23:02:50 »
As someone that sort of built both cherry and inks they didn't sound quite as good IMO. They are quite muted, but they just don't sound quite as good as cherry. Normally I feel like inks sound more muted, but in this case for some reason I just think cherry sounds better. Don't get me wrong, they're both great but the vints I have are almost silent but in a good way, where as the inks were muted but had a bit more thock to them. I think it ultimately comes down to preference.
Offline beamingrobot
  • もうけい
    • monokei
« Reply #1838 on: Fri, 06 March 2020, 03:54:17 »
I have inks on my v2 and vints on my CE v2. Inks are still higher pitch so I definitely prefer the vints (both are on poly half plates). I do enjoy having inks though they've a very distinct sound signature to me that is pleasant.
http://monokei.co
Jane v2 | Jane v2 CE | Police | EXENT | KFE | KFE CE | Singa R1 | Jaguar | HHKB | Custom G80-3000 | Dalco 959mini | Haus | Kei | Hiro | Hidari | Tomo | Neko | Prophet | MXSS | TKL One | RS
« Reply #1839 on: Sat, 07 March 2020, 01:59:49 »
You kids and your silly switches.
Offline tentboy
« Reply #1840 on: Mon, 09 March 2020, 11:02:57 »
ya boi got a shipping invoice
Offline rainb1ood
  • so pretty so plastic
« Reply #1841 on: Mon, 09 March 2020, 12:58:38 »
same!
Offline Emir
  • icon mods
  • Bandit
    • Discord
« Reply #1842 on: Mon, 09 March 2020, 13:10:25 »
Yall just pretending to be part of last batch bois. pfft
Offline newbatthis
« Reply #1843 on: Mon, 09 March 2020, 13:30:03 »
shipping invoice when
Offline JFKroflcopter
« Reply #1844 on: Mon, 09 March 2020, 22:20:42 »
Received and paid shipping invoice on January 6th, haven't received any tracking information yet. Don't worry, I'm sure it'll come soon  :thumb:
Offline ejewell89
  • 4ever Smol
« Reply #1845 on: Tue, 10 March 2020, 12:32:36 »
hey sam can you send me a link to buy some diodes for the compromised one on my PCB
1N4148 Series SOD-123 Diodes was what you sent me but on the following page below there are three options, which one do I grab for replacement diodes?
https://www.mouser.com/Semiconductors/Discrete-Semiconductors/Diodes-Rectifiers/Diodes-General-Purpose-Power-Switching/1N4148-Series/_/N-ax1mp?P=1z0yr4vZ1yxk9r0&gclid=EAIaIQobChMIoLnotreQ6AIVF4iGCh2mygWvEAAYAiAAEgI50fD_BwE
I'd be interested in another PCB, too, if you're not too busy and have any extras  :thumb:
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #1846 on: Tue, 10 March 2020, 12:39:04 »
They're all 1N4148s, which all pretty much work in the same way despite small differences between manufacturers. You can pick up the first one and should be fine.
Offline ejewell89
  • 4ever Smol
« Reply #1847 on: Tue, 10 March 2020, 12:46:28 »
but in all seriousness thanks. now can you help me with a spare TGR jane pcb also?  :p
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #1848 on: Tue, 10 March 2020, 12:50:20 »
Lel, so I'm still pending on a blue-grey part, v2 PCB + brass plate, and a v2 CE PCB + alu plate from Yuktsi too, so . . .
Offline regionfree
Re: Re: [GB] TGR-Jane v2 CE (QC, Shipping)
« Reply #1849 on: Wed, 11 March 2020, 20:50:40 »
just got tracking for my WKL. i need to change my pants now.
