Author Topic: [CLOSED][GB] Evil 82 Mechanical keyboard Kit  (Read 30289 times)
Offline KPrepublic
  • * Moderator
    • KPrepublic
« on: Mon, 29 April 2019, 00:45:00 »
Evil-82 Mechanical Keyboard
GB Ended:2nd of May (EST TIME)
Manufacture:EVE Studio
Producing Duration:60 days after GB closed
Estimated Delivery: October
[Standard]:
Aluminium alloy case,
aluminium alloy weight,
PCB x 1,
aviation connector x 1 set
[Option]:
Add another bronze weight x 1 set
Add another alu weight x 1 set
Add another PCB x 1
Add another PC plate x 1
Add another Alu-alloy plate x 1
[Case Colour]:
Green
Blue - close toTiffany Blue
Pink
Grey
Black
Elctrophoretic white
Slop:7 degrees
Fixed:upper case fixed
Layout:Support wk、wkl
PCB support QMK program
ATTENTION: NO complete USB cables with the keyboard. You need to make the cable with the Aviation connector by yourself.
JOIN NOW
« Last Edit: Mon, 06 May 2019, 02:06:35 by KPrepublic »
Offline KPrepublic
  • * Moderator
    • KPrepublic
Re: [GB] Evil 82 Mechanical keyboard Kit
« Reply #1 on: Mon, 29 April 2019, 00:45:53 »
more pic
Offline Sshimosawa
« Reply #2 on: Mon, 29 April 2019, 01:44:26 »
Def in for this. Whats “bronze” weight set. Is there an option for brass or bronze or alu weights?
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #3 on: Mon, 29 April 2019, 08:40:47 »
I like everything about this board except the lack of space between the arrows and the letters. So I won't be joining.
It's top mount, right?
Offline p_blaze
« Reply #4 on: Wed, 01 May 2019, 22:06:47 »
was about to ask if we can have different color parts, but it looks like its sold out lol
