Author Topic: [IC] MT3 Serika | IS LIVE! ORDERS CLOSE ON 08/30/19 11:59 PDT  (Read 406223 times)
Offline Zambumon
  • discord.zambumon.com
    • Keyset projects
Re: [IC] MT3 Serika
« Reply #150 on: Thu, 02 May 2019, 05:29:03 »
Just ordered some Gateron Inks and Silent Inks today.
Bought a new KB kit a couple of days ago.
Got in on Kuro Shiro just before the GB ended about a week ago.
I will not spend any more money.
Sees this IC.
Loves MDA.
Am typing this on MDA.
I will spend more money.
This is MT3, not MDA. Those profiles are fairly different.
Offline Zambumon
    • Keyset projects
Re: [IC] MT3 Serika
« Reply #151 on: Thu, 02 May 2019, 05:31:16 »
Not a big fan of the text mod for the ergo kit as there is no standard layout.
It's nice but blanks would have been cheaper as you could also drop all the duplicate keys.
I wish a kit has double 2u spacebar for Boardwalk pcb.
This is dyesub. Printing the legends is cheap and it won't make much of a difference.
Offline hailbreno
Re: [IC] MT3 Serika
« Reply #152 on: Thu, 02 May 2019, 05:54:10 »
Is it possible to have a Typist Katakana set?
Offline JoeriW
Re: [IC] MT3 Serika
« Reply #153 on: Thu, 02 May 2019, 06:02:03 »
Well I bought a yellow keyboard specifically for this set based on a rumour I heard. Guess you can count me in.
Offline malde
Re: [IC] MT3 Serika
« Reply #154 on: Thu, 02 May 2019, 06:18:05 »
I take it that Katakana support for the international kit is off the table, since it'll almost double the number of keys?
Offline thelaughingman
  • Simultaneously the most starry-eyed idealist and t
Re: [IC] MT3 Serika
« Reply #155 on: Thu, 02 May 2019, 07:19:10 »
MY MAN!!!  :thumb: :thumb: :thumb:
Offline mimalik
Re: [IC] MT3 Serika
« Reply #156 on: Thu, 02 May 2019, 07:50:12 »
Will there be a SA version to this at some point in future??
Offline lendflat
Re: [IC] MT3 Serika
« Reply #157 on: Thu, 02 May 2019, 07:52:03 »
Hopefully the fixed their font alignment issues?
Offline KingOfMemes
Re: [IC] MT3 Serika
« Reply #158 on: Thu, 02 May 2019, 08:26:14 »
Woooo Colemak bois eatin on this one!
Offline kakiharaOne
Re: [IC] MT3 Serika
« Reply #159 on: Thu, 02 May 2019, 08:38:53 »
Any chance of an R1 1.5u backspace in the extensions kit or 40s and an R2 1u pipe in the symmetry kit? This set would look lovely on my M0110 when it’s done.
I'll think about it, but I haven't seen many boards with a R1 1.5 Backspace.
Thanks for considering!
At least it’s in one kit so I can’t really complain. I don’t use ergo and it would be hard to sell the rest of the set with one missing key. As it stands, I would need 5 kits to cover one board. It would be nice to only have to buy 4 kits
Offline Techno Trousers
  • ʘ_ಠ
Re: [IC] MT3 Serika
« Reply #160 on: Thu, 02 May 2019, 08:42:15 »
I've been using /dev/tty with the R5 bottom row as my daily driver at work since I got round 1. I don't think I can go back to an angled space bar.
The colorway and legends are great, though.
Offline Zambumon
    • Keyset projects
Re: [IC] MT3 Serika
« Reply #161 on: Thu, 02 May 2019, 08:43:26 »
SA, no.
Offline Zambumon
    • Keyset projects
Re: [IC] MT3 Serika
« Reply #162 on: Thu, 02 May 2019, 08:46:27 »
Dev TTY R2 was OK on that aspect. We'll see how this goes with Godspeed.
Offline Zambumon
    • Keyset projects
Re: [IC] MT3 Serika
« Reply #163 on: Thu, 02 May 2019, 08:51:25 »
That's correct.
I don't have plans to add that one.
In other news, I found out how to multiquote with tapatalk. Yay.
Offline jagger27
  • ne 1.5U supers???
Re: [IC] MT3 Serika
« Reply #164 on: Thu, 02 May 2019, 09:03:47 »
Yesssssssssssssssssss my body is ready
Offline smurkcity12
Re: [IC] MT3 Serika
« Reply #165 on: Thu, 02 May 2019, 09:15:17 »
Disheartening to see the ergodox modifiers are function-specific instead of being generic keys - like with the Oblotzky's assembly kits.
I don't like those ones. There are plenty of non-specfic keys that you should be able to fill most of the layouts with them.
I'm mostly okay with the keys you've chosen. But I find R3 tab to be an odd choice over an R3 control.
However, seeing that there are very few "standard" ergodox layouts that people use (as many users prefer to make their own layouts to suit their own needs) - something along the lines of the novelty legends might make more sense, and reduce the amount of keycaps required for the kit.
A cost reduction and general compatibility increase while keeping the aesthetic is a win/win/win in that regard.
I wholeheartedly agree with more generic legends. Like un_related said, it's a win/win/win.
I know it's a long shot, but would there be any chance to have some R4 1.25u keys added? My unigo66 has 4 1.25u keys and it'd help if I didn't have to buy a 40s kit to obtain them. I understand this is unlikely, but I had to at least ask  ;D
Offline baoduy23
Re: [IC] MT3 Serika
« Reply #166 on: Thu, 02 May 2019, 09:25:17 »
Waiting for SA cap :( dyesub is not my choice
  • ʘ_ಠ
Re: [IC] MT3 Serika
« Reply #167 on: Thu, 02 May 2019, 09:30:52 »
I don't know why my eye skipped over it, but I see there's a 6.25u spacebar kit. Would it be possible to add R5 space bars to that?
Offline Zambumon
    • Keyset projects
Re: [IC] MT3 Serika
« Reply #168 on: Thu, 02 May 2019, 09:34:47 »
SA version of Serika is very unlikely to happen.
Unlikely. The kit is pretty much specific to Ergodox. I am aware that there are lot of split ergo boards out there, and I'm not keen on making a super huge Ergo kit.
Offline Gati
Re: [IC] MT3 Serika
« Reply #169 on: Thu, 02 May 2019, 09:44:23 »
I know that you already said no, but can we get a neutral-colored mod kit? Yellow doesn’t match with anything on my desk (but grey def will)
Offline Mousy
  • I <3 tootall
    • IG
Re: [IC] MT3 Serika
« Reply #170 on: Thu, 02 May 2019, 09:45:23 »
Though not my desired profile I am glad to see more PBT sets coming out that are a little more colourful than what is currently available! Bets of luck with the buy!
- White Kira 60 | Black Kira 60 | TGR Jane v2? -
Offline fractl
Re: [IC] MT3 Serika
« Reply #171 on: Thu, 02 May 2019, 10:00:28 »
Sees this IC.
Loves MDA.
Oops.  Still comparatively new to this.  The similarity between MT3 /dev/tty and MDA Big Bone with the multi-colored modifiers kits made me associate MT3 and MDA.  Which has no effect on my wanting this set.  Definitly in.   :thumb:
Offline Zambumon
    • Keyset projects
Re: [IC] MT3 Serika
« Reply #172 on: Thu, 02 May 2019, 10:10:27 »
Yellow plays a major role on this set. Sorry, but without yellow modifiers it wouldn't be Serika.
Offline Oblotzky
  • Backspace is for people that make mistakes.
Re: [IC] MT3 Serika
« Reply #173 on: Thu, 02 May 2019, 10:12:55 »
Yellow Katakana kit or no balls
Offline equalunique
Re: [IC] MT3 Serika
« Reply #174 on: Thu, 02 May 2019, 10:15:49 »
>Colemak, Dvorak, Norman, Workman, Carpalx
Sent from my LG-H918 using Tapatalk
Offline nulltorious
Re: [IC] MT3 Serika
« Reply #175 on: Thu, 02 May 2019, 10:17:40 »
Can someone explain the super homing kit to me? Are the keys extra deep dish?
Offline equalunique
Re: [IC] MT3 Serika
« Reply #176 on: Thu, 02 May 2019, 10:19:43 »
This is GeekHack, where we buy whole desk setups to match our keyboards - not the other way around.
Offline equalunique
Re: [IC] MT3 Serika
« Reply #177 on: Thu, 02 May 2019, 10:21:01 »
On the home row, all eight of your fingers get their own homing key - assuming you get the plain Latin alpha kit.
Offline Zambumon
    • Keyset projects
Re: [IC] MT3 Serika
« Reply #178 on: Thu, 02 May 2019, 10:22:14 »
No balls.
Fixed:
ATTENTION ALL ERGODOX AND BOARDWALK USERS
Complain here
Offline Zambumon
    • Keyset projects
Re: [IC] MT3 Serika
« Reply #179 on: Thu, 02 May 2019, 10:23:51 »
Instead of having just 2 homing keys (F and J) you have 8.
Offline thearctican
Re: [IC] MT3 Serika
« Reply #180 on: Thu, 02 May 2019, 11:00:02 »
I'll take 2 to use one and keep one sealed like I did with GMK. It's just my favorite colorway.
Offline ReDsNoTDeAd
    • RNDKBD
Re: [IC] MT3 Serika
« Reply #181 on: Thu, 02 May 2019, 11:03:40 »
Are you going to be getting samples sometime down the line, or are we just limited to these dirty rendies and chicken tendies.
Offline thearctican
Re: [IC] MT3 Serika
« Reply #182 on: Thu, 02 May 2019, 11:05:00 »
Did I miss the free tendies? It's about lunchtime.
Offline 8six753o9
Re: [IC] MT3 Serika
« Reply #183 on: Thu, 02 May 2019, 11:08:28 »
Can you include the Symmetry kit with the Alphas?  I really don't want spend $15 for 3 of the 6 keys in that set.  Looking at how MT3 Godspeed and XDA Canvas did on the Sym Kit, they didn't hit MOQ which means MassDrop would have to buy extra and just sit in their inventory to hoping that people will buy them for $25 during Re-Cap.
Offline Petch
Re: [IC] MT3 Serika
« Reply #184 on: Thu, 02 May 2019, 11:27:52 »
Would be nice to have the option of some less colourful mods
I was part of the original GB with all the wonky ass legends and never got my replacements, so I've been wanting something similar but with nice legends for a long while now (I missed the 2nd round somehow ;D )
Offline laserbeamspewpew
Re: [IC] MT3 Serika
« Reply #185 on: Thu, 02 May 2019, 11:32:20 »
I agree that symmetries could be distributed into the other kits. Tilde could go into extensions and the 1.5u pipe key could go into alphas/modifiers, for example.
Also, no more square geometry novelty? I really liked that one.
Offline wangledorf
  • Formerly pewing
Re: [IC] MT3 Serika
« Reply #186 on: Thu, 02 May 2019, 11:54:05 »
Just noticed one thing that I would suggest; would you consider adding a yellow " key to either the Forties or symmetry kit? It's on the default Planck layout so I would guess that more folks getting the Forties kit would prefer it in yellow than white.
« Last Edit: Thu, 02 May 2019, 12:08:02 by pewing »
Offline megaforce
Re: [IC] MT3 Serika
« Reply #187 on: Thu, 02 May 2019, 12:14:27 »
yes i would like to order a cheeseburger without the cheese
Corsair K63 Wireless | Razer Huntsman Elite
Hokusai | Ogre| Yohane | Mc65 | Kaze | RBB
Former: LZ MX | LZ FE | LZ CLS TKL Silver |LZ CLS TKL Gray| LZ St | V.EA | Blackbird | LSV3 | OctagonV2 | Norbatouch | X60 | TX84 | Kyuu | SSK | 268.1| Jane CE | Corsair K95 | X60R | HHKB JP x JS HiPro | 910 CE |Nunu |Nunu FE | Jane V2 CE|Jane V2| RS (TKL)
Offline Zambumon
    • Keyset projects
Re: [IC] MT3 Serika
« Reply #188 on: Thu, 02 May 2019, 13:30:52 »
Oblotzky also has complained about it. Will think about it.
All those keys would go to their respective Core kit (so either Alphas or Katakana)
Drop (formely Massdrop) has some samples at their office that they were supposed to be shipped to me this week.
They have also told me that they have Holy Pandas production samples  :eek:
Offline Zambumon
    • Keyset projects
Re: [IC] MT3 Serika
« Reply #189 on: Thu, 02 May 2019, 13:32:34 »
Alternate modifiers kit with a different colorway are not going to happen, otherwise it wouldn't be Serika.
Offline Bhk1004
Re: [IC] MT3 Serika
« Reply #190 on: Thu, 02 May 2019, 13:37:46 »
any shot at a render with the grey spacebar and grey arrow keys?
Offline Zambumon
    • Keyset projects
Re: [IC] MT3 Serika
« Reply #191 on: Thu, 02 May 2019, 13:44:04 »
With the next major update I'll add some keyboards to the gallery.
Offline Zambumon
    • Keyset projects
Re: [IC] MT3 Serika
« Reply #192 on: Thu, 02 May 2019, 16:08:40 »
Colemak DH and DHm support added. The kit currently supports: Colemak, Colemak DH, Colemak DHm, Dvorak, Workman, Norman, and Carpalx QGMLWY.
Offline Oblotzky
Re: [IC] MT3 Serika
« Reply #193 on: Thu, 02 May 2019, 16:14:53 »
ne neo support avail? https://neo-layout.org/
Offline nasp
Re: [IC] MT3 Serika
« Reply #194 on: Thu, 02 May 2019, 16:53:55 »
Complain here
What do you mean by Novelty legends? Is it similar to what a lot of GMK Ergo/Assembly kits offer for legends?
Offline snelltrail
Re: [IC] MT3 Serika
« Reply #195 on: Thu, 02 May 2019, 17:04:01 »
This is awesome! I've dabbled in Colemak DH and was super happy to see that support for it has seemingly become standard in MT3 sets (Susuwatari, Godspeed). Glad to see Serika is continuing this trend!
Offline Zambumon
    • Keyset projects
Re: [IC] MT3 Serika
« Reply #196 on: Thu, 02 May 2019, 17:10:07 »
Complain here
Hyper, Meta, Mod, Sub, System, Code, Make, Run...
Offline Zambumon
    • Keyset projects
Re: [IC] MT3 Serika
« Reply #197 on: Thu, 02 May 2019, 17:11:00 »
Oh come on, give me a break.
Offline euphxenos
Re: [IC] MT3 Serika
« Reply #198 on: Thu, 02 May 2019, 19:14:11 »
How about an R3 1.75U Fn or Function, probably in Extension?
Offline RominRonin
Re: [IC] MT3 Serika
« Reply #199 on: Thu, 02 May 2019, 22:52:48 »
Your alternative layouts kit doesn't include various for colemak mod dh - the original mt3 set does.
Can you please add it?
Sent from my Moto G (5) Plus using Tapatalk
That kit covers Coleman, Dvorak, Workman, and Norman. If it's a modified version of Coleman, I think we would be going a little bit too far with that kit.
May I ask how Workman and Norman were chosen? It seems arbitrary to me, especially considering that mt3 had support for mod dh from the start, so you must have actively taken it away.
Or is it purely a matter of cost?
Edit - ignore me, I replied before seeing that you already added support.
« Last Edit: Thu, 02 May 2019, 23:01:00 by RominRonin »
