Author Topic: [IC] GMK Dracula — Group buy is live!  (Read 304270 times)
Offline Cyrille0815
Re: [IC] GMK Dracula — Coming out in Q4 2019!
« Reply #550 on: Mon, 09 September 2019, 10:59:36 »
Sorry for the lack of updates, I've been really busy with work and personal stuff. Rest assured, everything is on track.
Info about new/updated kits and other exciting things coming soon!
Render with a Polycarbonate board pls?  :D
this :D
I was already working on that actually :) Here's a render preview:
looks lovely!! I hope there will be an International / Norde KIT. if yes Im 100% on board :)
Yes please... Norde Kit.
[echo]
Until the hobby grows, German and Scandinavian users do need support. We're a small but not insignificant part of the mechanical keyboard community.
[/echo]  ;)
Offline CypherPls
« Reply #551 on: Mon, 09 September 2019, 18:19:14 »
ITS Q4 I CANNOT WAIT ANY LONGER  ;D
Probably the beginning of next month I bet. (October)
Any bets?
Uuuuuh Q4 is Oct-Dec. September is end of Q3.
I did say October, didn't I?  ;D
Offline zalmez
« Reply #552 on: Mon, 09 September 2019, 19:26:27 »
I would love to see the nordic with this :D
Offline CodeMayhem
« Reply #553 on: Tue, 10 September 2019, 19:55:03 »
just noticed that the f13 in the renders is not the same as in the kit. is it going to be mod colored or alpha colored bc i prefer the mod color personally. could both be available?
Offline AlcoholEnthusiast
« Reply #554 on: Wed, 11 September 2019, 00:42:22 »
Just noticed this as well. I too prefer mod colored fwiw
Offline pikku-allu
  • IG: @kinnalek
« Reply #555 on: Wed, 11 September 2019, 07:42:08 »
Yes, it's going to be mod colored, indeed looks much better that way. A new update including that change as well as new additions coming very soon. Stay tuned.
Offline juliandoucette
« Reply #556 on: Sat, 14 September 2019, 19:41:31 »
I'm starting to get nervous about the ergo module still being a "Todo". I really want ergo and colevrak kits for this set.
Offline pikku-allu
  • IG: @kinnalek
Re: [IC] GMK Dracula — Group buy launches October 4th!
« Reply #557 on: Mon, 16 September 2019, 18:20:53 »
$ gmk run update
> Starting 'update' ...
> Uploading: geekhack/interest_checks/gmk-dracula/update.tar.gz
> [=============================] 100% 0.0s
> Update in progress ...
> Group Buy date set to 'October 4th [2019-10-04]' ...
▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ GB_INFO.txt ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
├── GB_vendors/
│ └── proxy_list/
│     ├── NA - Dixie Mech
│     ├── EU - Mykeyboard.eu
│     ├── Oceania/Asia - Daily Clack
│     └── China/Asia - iLumkb*NEW
└── GB_date/
    └── Group Buy - October 4th [2019-10-04]
Update time—finally! The group buy for GMK Dracula is launching on October 4th on Dixie Mech, Mykeyboard.eu, Daily Clack Dracc Dracc Dracc!, and iLumkb!
All the existing kits have undergone some changes. The Core Module's wide compatibility has mostly remained the same, with some minor tweaks. The Nightmode Module reflects the same changes, as it should. The Highlight Module has received some extra color choices. With the addition of a new module, split keys have been moved from the spacebar kit, which now provides accent colors instead. The ERR! Module now has even more exciting new novelties to choose from! Unfortunately the white accented versions were dropped in order to keep the kit affordable.
Check them out (Also updated in the first post):
Without further ado... new kits!
$ gmk install -g @dracula/minify-module
$ gmk install -g @dracula/localization-module
$ gmk install -g @dracula/command-module
Minify [Module]*NEW
Here it is! The ultimate kit for 40%, ortholinear, and split layout keyboards. But wait, there's more! Even a second B key is included in case your dog eats the other one.
Localization [Module]*NEW
Language support for Nordic (Danish, Finnish, Swedish, Norwegian), German, and UK layouts.
Command [Module]*NEW
What did you think it was going to be called? Support for macOS specific keys. Starting at $999.
There are a few options that we need your help with. Please click the link below to vote on those:
New Google Feedback Form
« Last Edit: Sat, 21 September 2019, 12:25:19 by pikku-allu »
Offline nasp
Re: [IC] GMK Dracula — Group buy launches October 4th, new kits!
« Reply #558 on: Mon, 16 September 2019, 18:46:41 »
Would love to see a r3 1u Ctrl key in 40s or a r3 1u in novelty (Err) kit.
Offline DuellM
  • Keyboard Fatty
« Reply #559 on: Mon, 16 September 2019, 19:35:13 »
Yes!! Will definitely be picking this up at the beginning of the month :cool:
« Reply #560 on: Mon, 16 September 2019, 19:46:38 »
Sad to see the smaller spacebar + split bar + B kit removed. Was going to put on rukia but don't see buying an entire 40s kit just for split bars + B.
Would accent bars in the highlight kit not make more sense?
Either way, I'm in for quite a few of the kits, and still super excited for the set.
Offline forevermadrigal
« Reply #561 on: Mon, 16 September 2019, 20:40:17 »
Well, I was all in but instead I'm just gonna get about 420 mac kits and I'm out
But seriously, this update was fantastic and makes the set an all in. Thanks for sneaking that 1.5 fn key in there too <3
Offline sevenseacat
« Reply #562 on: Mon, 16 September 2019, 20:55:37 »
I'm still in for a base kit and maybe an accent/err kit, but I was so hoping for a Colemak kit >_< I'd buy one of everything if there was (except norde)
Offline Krakyn
« Reply #563 on: Mon, 16 September 2019, 21:46:12 »
Deskmat still a possibility?
Offline Mtalbert
« Reply #564 on: Mon, 16 September 2019, 21:47:52 »
Any proxy for Asia?
Big fan of Daeru
Offline kema
  • Designer
    • kevinmadesign
« Reply #565 on: Mon, 16 September 2019, 22:02:06 »
Super excited! Still hope to see a R4 1.25u Caps Lock if possible 🙏
Offline srxl
« Reply #566 on: Tue, 17 September 2019, 00:02:50 »
Any proxy for Asia?
Daily Clack should be covering Asia. IIRC they did it for SA Bliss, so they'll prob do it on this set too.
polaris hhkb | endash
waiting on: kepler fc65, tsukuyomi
Offline phatty
    • dailyclack.com
« Reply #567 on: Tue, 17 September 2019, 00:17:09 »
Any proxy for Asia?
Hey, that's correct, we'll be taking care of Australia and Asia. Just like our past Asia GBs, there'll be a discount code for free shipping or the option to upgrade to DHL. Also, I've got AliPay working now!
And, as usual, you can reach me here or on Discord @phatty#8888
Offline mwahlig
« Reply #568 on: Tue, 17 September 2019, 00:18:28 »
Glad to see the 40’s kit! Any chance at adding a 2u spacebar for planck/preonic users?
Offline Mtalbert
« Reply #569 on: Tue, 17 September 2019, 00:55:14 »
Any proxy for Asia?
Oh i see. Thx for replying
Big fan of Daeru
Offline gearson
« Reply #570 on: Tue, 17 September 2019, 01:32:27 »
This set looks amazing! Can't wait to have a set that matches my vs code theme!
Sorry, if this is a stuoid question, but I'm super new to mechanical keyboards. Would this set fit without issues on a Anne Pro 2 with Brown Cherry or Gateron switches?
Offline peterned
« Reply #571 on: Tue, 17 September 2019, 04:06:26 »
For a sec there I feared for the err module with all the changes, haha!
As a coder this is my endgame, thanks for making this a putting a stop to this wallet bermuda triangle hobby ;) (who am I kidding)
Offline Karni
« Reply #572 on: Tue, 17 September 2019, 04:10:53 »
So excited that there is now a 40's kit and I'm 100% in. If you could please include a 1.25 enter key for Dimple compatibility I would greatly appreciate it.
Offline OmniSzron
« Reply #573 on: Tue, 17 September 2019, 05:36:38 »
This set looks sick. Love the attention to detail. The highlight colors look fresh AF.
Fox Lab Key 65 split space
Offline VXQN
« Reply #574 on: Tue, 17 September 2019, 06:04:28 »
Absolutely pumped for this, love all the changes. I've held off on some other sets to go all-in on this and I'm glad I waited.
Offline CodeMayhem
« Reply #575 on: Tue, 17 September 2019, 06:44:44 »
Same feelsbadman. I think I'm just gonna see how Oblivion v2 alphas look on it with the nightmode kit.
Offline CodeMayhem
« Reply #576 on: Tue, 17 September 2019, 07:14:14 »
is the group buy going to last a month?
Offline srxl
« Reply #577 on: Tue, 17 September 2019, 08:26:36 »
It'll fit just fine. Switches are not a problem for keycap compatibility 95% of the time, most people use MX style switches. The layout of the Anne Pro 2 is pretty standard too, so you should be able to get away with just the base kit.
Offline hamilton
« Reply #578 on: Tue, 17 September 2019, 09:50:50 »
I think there is a 2u spacebar, it's just labeled incorrectly as the first 2.25u spacebar
Offline Dass
« Reply #579 on: Tue, 17 September 2019, 10:53:17 »
Looks amazing! Can't wait. Still any chance for a desk mat?
Offline pikku-allu
  • IG: @kinnalek
« Reply #580 on: Tue, 17 September 2019, 11:36:08 »
You're right, it was just a typo. A 2u spacebar is included. Fixed now:
Stay tuned! :)
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #581 on: Tue, 17 September 2019, 14:03:27 »
Any chance you will reconsider doing an R5 bottom-row?
Pretty please?
Offline mr scooty
« Reply #582 on: Tue, 17 September 2019, 14:12:47 »
god October is goin to be an expensive month.. Dracula, SA Yuri, Cafe.. next month is gonna hurt the wallet! ;D
Offline uood5
« Reply #583 on: Tue, 17 September 2019, 15:36:44 »
Gutted at the lack of ergo/colemak options, guess Oblivion will have to do for me. R2 when?
Sent from my SM-G970F using Tapatalk
Offline radam
« Reply #584 on: Tue, 17 September 2019, 16:22:12 »
really want, at least, a blank ergo set. with 2x2u spacebars for boardwalk compatibility
Offline pears
  • Sneezing is painful
    • Bad Produce
« Reply #585 on: Tue, 17 September 2019, 16:53:44 »
I like this :)
Getting punched in the face was the best thing that ever happened to me.
« Reply #586 on: Tue, 17 September 2019, 17:16:47 »
Ditto  :'(
Offline pikku-allu
  • IG: @kinnalek
« Reply #587 on: Tue, 17 September 2019, 18:33:45 »
> Updating proxies ...
> New proxy for Asia set to 'iLumkb' ...
├── GB_vendors/
│ └── proxy_list/
│     ├── Oceania - Daily Clack
│     └── Asia - iLumkb*NEW
└── GB_date/
    └── Group Buy in October 4th [2019-10-04]
Offline Rayndalf
« Reply #588 on: Tue, 17 September 2019, 18:40:02 »
Guess the dozen of us who need ergo keys will be waiting till Taro R2
Offline Randalljai
« Reply #589 on: Tue, 17 September 2019, 18:40:26 »
wow that yellow esc. love it
Offline rondg
« Reply #590 on: Tue, 17 September 2019, 18:42:15 »
├── GB_vendors/
│ └── proxy_list/
└── GB_date/
I really love how you do your IC. Makes everything interesting and it pops out so it's hard to miss!
Offline pr0ximity
« Reply #591 on: Tue, 17 September 2019, 18:50:13 »
Pretty please?
Please for the love of god.
A yes/no wouod be nice at least. But I can't see myself spending $100+ on any set without R5 at this point. Just feels so much better on a board with any angle of 8 degrees or more.
Offline pikku-allu
  • IG: @kinnalek
« Reply #592 on: Tue, 17 September 2019, 19:54:38 »
Pretty please?
R5 bottom-row is not really in line with the modern theme of the set. It would also complicate the already complicated kits. I have not personally tried R5 yet, so I can't comment on how it feels. Maybe with another set.
Offline nasp
« Reply #593 on: Tue, 17 September 2019, 21:32:10 »
I hope you will at least consider adding ergo blanks.
Thanks
Offline infinitykw
  • Amazed by the beauty of industrial design
    • zFrontier Profile
« Reply #594 on: Tue, 17 September 2019, 23:23:36 »
Any proxy for Asia?
Just saw Pikku's note that the new vendor for Asia changed to ilumkb and you will only take care of oceania region.  Can I still order on your site and get that free shipping to Beijing?  Thanks in advance!
Offline The_Royal
  • That's what I call, a Sunday.
« Reply #595 on: Wed, 18 September 2019, 01:53:07 »
Before we get this show on the road...
Can we just take a second to admire what a BEAUTIFUL and clear IC page this has become.
Its almost Like looking at another site page entirely.
Excited for this set as its grown on me a crazy amount these past few weeks.
Offline _rubik
« Reply #596 on: Wed, 18 September 2019, 11:11:31 »
Honestly the time and effort OP put into just branding the IC is astounding. Everything is on theme, and even flavor text is well done. Big set energy for sure
ai03 Meridian € Mech 27 € E8.5 € Brutal60 € SSK White Label € HHKB Pro JP € vAEK68 Alps Blues € RF87u
Offline hineybush
  • student of error
    • hineybush keyboards
« Reply #597 on: Wed, 18 September 2019, 14:16:54 »
the centered left and right arrows look weird without the centered down arrow
Offline BlindAssassin111
  • I design keyboards and stuff.
    • Viktus
« Reply #598 on: Wed, 18 September 2019, 14:25:23 »
Looks like both up and down aren't centered like left and right in the renders. I assume they should be and it is just a mistake maybe?
Offline MeloDet
« Reply #599 on: Wed, 18 September 2019, 15:03:36 »
That might just be standard? I'm looking at my GMK Chocolatier right now and it has the same arrow set up.
