Author Topic: [IC] GMK Dots (GB live!)  (Read 173039 times)
Offline harvvvvv
Re: [IC] GMK Dots
« Reply #100 on: Sun, 26 May 2019, 08:42:02 »
Looks fantastic. I'm in.
Offline geekit
Re: [IC] GMK Dots
« Reply #101 on: Sun, 26 May 2019, 09:29:42 »
Highly suggest to make the dots smaller, and/or perhaps tone down the white alphas into grey or something. IMO they look like they're all screaming for attention.
Something like L9 or CP?
The problem is that when these white dots - large, bright and homogeneous colors - are clustered together, they look very strong & can be a bit distracting. You have nice colorful dots on the modifier, but the white alpha dots are simply too strong IMO.
Unfortunately I'm not really familiar with GMK color codes, but anything close to grey or light grey would do. And perhaps better make the dots smaller?
Offline geekit
Re: [IC] GMK Dots
« Reply #102 on: Sun, 26 May 2019, 09:52:27 »
There, a quick and dirty attempt to show my point about the difference between bright white vs something darker or greyish (I copied your existing grey color from the function keys). You can then put more colors on the backspace, tab, caps keys etc. Unfortunately I'm quite occupied thus unable to create the smaller dots example :p
My 2 cents :)
« Last Edit: Sun, 26 May 2019, 09:54:50 by geekit »
Offline dibkib
Re: [IC] GMK Dots
« Reply #103 on: Sun, 26 May 2019, 09:57:35 »
I love this! I’m in !
Offline depletedvespene
    • Keyboard-related resources.
Re: [IC] GMK Dots
« Reply #104 on: Sun, 26 May 2019, 10:22:55 »
My 2 cents :)
So a bright white dot should be perfect as the "accent" for the Esc key.  :thumb:
Offline Coreda
Re: [IC] GMK Dots
« Reply #105 on: Sun, 26 May 2019, 10:37:26 »
The most unique set I've seen in memory.
Offline geekit
Re: [IC] GMK Dots
« Reply #106 on: Sun, 26 May 2019, 10:45:01 »
Yup that's a possibility indeed.
Offline Lormania
Re: [IC] GMK Dots
« Reply #107 on: Sun, 26 May 2019, 11:30:10 »
Great kits! I will buy for sure.
Offline spyruf
Re: [IC] GMK Dots
« Reply #108 on: Sun, 26 May 2019, 11:50:01 »
+1 for Rama artisan.
Also please add a TKL render.
Offline VXQN
Re: [IC] GMK Dots
« Reply #109 on: Sun, 26 May 2019, 11:50:59 »
Absolutely love that is is going to be a real set!
I agree with others saying that the alpha dots could possibly do with being smaller or not quite such a bright white.
I also think that the custom dark navy colour is perfect, and that the solution you've chosen for the iso enter is perfect, anything else would look a little weird, in my opinion.
Offline Hell-es
Re: [IC] GMK Dots
« Reply #110 on: Sun, 26 May 2019, 12:38:29 »
If possible maybe some colorful 1x1 dots for R1 - for 108 full size kbd.
Would also prefer a differnt shape for iso enter
Offline dr_unconscionable
    • [sqeleton]
Re: [IC] GMK Dots
« Reply #111 on: Sun, 26 May 2019, 12:57:20 »
I'm so glad this is getting made! Definitely in for a set, but agree the dots could stand to be a little less contrasty.
Any chance of another R3 1.25u key in the Nomad kit? This would look great on a Dimple. Could just be an alternate colour option.
Offline IOVERCALLHISTIOCYTES
Re: [IC] GMK Dots
« Reply #112 on: Sun, 26 May 2019, 13:02:06 »
What would the MOQ be for an ortho or ergo set? 100? You might be there...
Offline xondat
  • i'm not a star
Re: [IC] GMK Dots
« Reply #113 on: Sun, 26 May 2019, 13:03:29 »
All child kits for GMK are 100, so yeah.  Wonder how many keys are needed for each.
Offline CaedanLavender
Re: [IC] GMK Dots
« Reply #114 on: Sun, 26 May 2019, 13:29:01 »
Haha, love it! I’m in
Offline travelsoff
Re: [IC] GMK Dots
« Reply #115 on: Sun, 26 May 2019, 16:06:13 »
Ima in! Love that ****!
Offline gok_nz
  • Enjoy your PBT
    • Website
Re: [IC] GMK Dots
« Reply #116 on: Sun, 26 May 2019, 16:11:31 »
Awesome as always biip! I'm not sure whether I'll be joining because I have enough trouble typing even with legends but this would provide a really funky F-row and could possibly work in conjunction with GMK Dracula.
Offline travelsoff
Re: [IC] GMK Dots
« Reply #117 on: Sun, 26 May 2019, 16:13:40 »
I'd be interested in a monochrome mod kit as well!
Offline harlekein
Re: [IC] GMK Dots
« Reply #118 on: Sun, 26 May 2019, 16:29:29 »
Would absolutely be in for assembly kit.
But please, with alphas, not as add-on.
« Last Edit: Sun, 26 May 2019, 16:32:29 by harlekein »
Offline vicissitude
Re: [IC] GMK Dots
« Reply #119 on: Sun, 26 May 2019, 19:49:51 »
Lovely design.
Easy but so cute.  :thumb:
Offline audax989
  • NOM NOM NOM
    • Guam Mechanical Keyboards
Re: [IC] GMK Dots
« Reply #120 on: Sun, 26 May 2019, 19:51:59 »
What layouts does the Nomad kit support? I’m just a little confused as base kit seems to cover almost everything.
Offline radam
Re: [IC] GMK Dots
« Reply #121 on: Sun, 26 May 2019, 20:34:25 »
It’s some extra keys for 40s and ortho I think.
Offline Acereconkeys
  • Happiness = life - expectations
Re: [IC] GMK Dots
« Reply #122 on: Sun, 26 May 2019, 20:44:13 »
I would love it if you added a 1.25u R3 key into the base kit. That's the only key needed for most 40s boards (especially when you have a set like this with no legends anyway).
TMO50 | Jane V2 CE Incoming | Realforce 87u 55g | Aergo
Aergo design and build log: https://geekhack.org/index.php?topic=103681.msg2840918#msg2840918
Re: [IC] GMK Dots
« Reply #123 on: Sun, 26 May 2019, 21:27:22 »
Perhaps the "single color kits" I suggested earlier in the thread would be ideal for this. Instead of only twelve 1U keys, they could also come with four 1.25U keys (one per row) and four 1.5U keys (ditto).
Re: [IC] GMK Dots
« Reply #124 on: Sun, 26 May 2019, 21:31:35 »
Would be cool, but this already has the key i'd be looking for in the nomad kit, just trying to push to get it added into the base kit.
Re: [IC] GMK Dots
« Reply #125 on: Sun, 26 May 2019, 21:36:37 »
The more I look at the nomad kit, the more I think it could be absorbed into the base kit by adding on to the latter the former's few non-1U key it has, then let the buyers complete what might be lacking with single color kits (YMMV; WDIKAA).
Re: [IC] GMK Dots
« Reply #126 on: Sun, 26 May 2019, 21:38:17 »
That's a pretty sweet idea. Makes a lot of sense in a set like this since it's not like the specific legends matter at all so you can expand the board compatibility a lot without much sacrifice.
Offline naudachu
Re: [IC] GMK Dots
« Reply #127 on: Mon, 27 May 2019, 00:10:47 »
wanna light theme! must-buy-set, btw
Offline AlcoholEnthusiast
Re: [IC] GMK Dots
« Reply #128 on: Mon, 27 May 2019, 02:03:53 »
After looking at the light grey side by side with the white I think I prefer the white dots. I would be interested in seeing what slightly smaller dots looked like though.
Offline biip
    • @biipmk
Re: [IC] GMK Dots
« Reply #129 on: Mon, 27 May 2019, 04:57:29 »
I think this design brief could be really interesting for a lot of keycap artisans. Any plans for collabs?
Not yet, but…  ;D
This might be unpopular, but I hope biip sticks as close to the custom color in the renders and doesn't just make it N9. I think it looks better as a slightly blueish gray.
What is the point of doing renders with inaccurate colors?
Any way to get the Ctrl + Alt +Shift to be Red + Blue + Green like the traditional RGB sets/Desko? Would make this a really great accent as well as standalone  :thumb:
Nope, I use the same color codes as for DSA Milkshake :thumb:
Another serious, if possibly unfeasible, idea:
Could there be optional six seven "color" kits with, say, 12 keys (4 R1, 2 R2, 2 R3, 4 R4) of the same color be made available, so anyone that might be unsatisfied with the base kit's offering could complete whatever he or she had in his or her mind regarding a particular keyboard layout?
This. Grey or some single colored mod kit. Vote on one color?
This will result in a more expensive kit (more keycaps + another custom color).
There is no cold colored black atm sadly that's why I went for custom colors.
deskmat idea maybe?
Love the idea! I made some mockups but haven't chosen anything yet.
Offline rbb
Re: [IC] GMK Dots
« Reply #130 on: Mon, 27 May 2019, 05:15:37 »
I'd also love to see lower contrast alphas and keep the bright white for accents. Looks perfect otherwise.
Offline pr0ximity
Re: [IC] GMK Dots
« Reply #131 on: Mon, 27 May 2019, 05:46:13 »
Sorry, I meant the order of them, not matching the specific shades. As in, make Ctrl red, Alt blue, and Shift green.
Offline kgorin
  • Formerly aka_gk
Re: [IC] GMK Dots
« Reply #132 on: Mon, 27 May 2019, 05:56:07 »
Given that kits IRL look a bit more muted than renders, I'd say keep bright white alphas as is. Also, duh, this set is very unusual and screams for attention
Offline biip
    • @biipmk
Re: [IC] GMK Dots
« Reply #133 on: Mon, 27 May 2019, 07:17:30 »
yes I understood. But I wanted to use the same color codes as for DSA Milkshake
Offline biip
    • @biipmk
Re: [IC] GMK Dots
« Reply #134 on: Mon, 27 May 2019, 07:49:10 »
Renders added
Pearl
Preonic
Jane 2
Offline Nebula97
Re: [IC] GMK Dots
« Reply #135 on: Mon, 27 May 2019, 08:37:25 »
Absolutely interested.
I agree with comments on the solid white maybe being a bit bright. Additionally, is there a black outline surrounding the dots or is it just my eyes? Would personally prefer without!
Offline biip
    • @biipmk
Re: [IC] GMK Dots
« Reply #136 on: Mon, 27 May 2019, 08:43:01 »
Yea I might go for a cold light grey. There is no outline :thumb:
Offline hyppialonso
Re: [IC] GMK Dots
« Reply #137 on: Mon, 27 May 2019, 10:17:12 »
A very interesting set!
Offline garbo
Re: [IC] GMK Dots
« Reply #138 on: Mon, 27 May 2019, 10:50:54 »
Strongly disagree with the idea of using much lower contrast alphas - really can't imagine it being a problem once the design's actually on plastic.
On a side note, based on that preonic render it really seems like putting this set into an ortho grid takes a lot of the fun out of things. I thought that could have looked cool.
Offline biip
    • @biipmk
Re: [IC] GMK Dots
« Reply #139 on: Mon, 27 May 2019, 10:55:14 »
Yeah, it definitely looks better on staggered layouts IMO
Re: [IC] GMK Dots
« Reply #140 on: Mon, 27 May 2019, 10:57:17 »
All whites, yes... and that screams for vertical and/or diagonal rows of a different color to make things visually interesing.
Offline geekit
Re: [IC] GMK Dots
« Reply #141 on: Mon, 27 May 2019, 11:19:24 »
Another example based on the 65% keyboard render, with white ESC dot & some colors on the |\, tab & caps :)
This, IIRC, is a slightly lighter grey compared to the previous example I posted earlier.
« Last Edit: Mon, 27 May 2019, 11:21:21 by geekit »
Offline TuCZnak
Re: [IC] GMK Dots
« Reply #142 on: Mon, 27 May 2019, 11:35:10 »
That looks totally rad and much easier on the eyes than the bright white IMO
Offline geekit
Re: [IC] GMK Dots
« Reply #143 on: Mon, 27 May 2019, 11:38:07 »
Anw those are just my 2c.
In the end it's all the same: RIP wallet.
Offline alveeno
Re: [IC] GMK Dots
« Reply #144 on: Mon, 27 May 2019, 12:16:56 »
White is definitely very bright. I'd also recommend a more gray color.
Offline packleadercho
Re: [IC] GMK Dots
« Reply #145 on: Mon, 27 May 2019, 12:18:24 »
The muted alpha dots don't look bad, but I personally prefer the stronger contrast that comes with the original white dot alphas.
Offline harlekein
Re: [IC] GMK Dots
« Reply #146 on: Mon, 27 May 2019, 12:23:10 »
Personally prefer the grey, but seems like it's really very subjective.
Ortho layouts look less exciting with this, could be solved by using colored dots throughout the alphas, but I mainly see a lack of those on R3.
Re: [IC] GMK Dots
« Reply #147 on: Mon, 27 May 2019, 13:18:57 »
Offline biip
    • @biipmk
Re: [IC] GMK Dots
« Reply #148 on: Mon, 27 May 2019, 13:35:02 »
I want the set to have contrast and distinctive alphas and modifiers. I could (and will probably in the end) go for a light grey tho.
Offline fombat
Re: [IC] GMK Dots
« Reply #149 on: Mon, 27 May 2019, 14:01:12 »
this is a slight stretch but is there a chance for a kit with just 1us in different rows with randomly colored dots
