Author Topic: [IC] GMK Dots (GB live!)  (Read 173043 times)
Offline OkKarma
Re: [IC] GMK Dots (ergo kit added)
« Reply #250 on: Tue, 11 June 2019, 08:37:41 »
If the ergo kit is as specified, and you want to support boards like the Boardwalk, we need 1.25U x 2 on R4. Personally, as a Boardwalk and Planck user, I'd kinda prefer it if there were base alphas + separate kits, but I can appreciate why you haven't done that.
At least if I get a base kit + an ergo kit in this setup I would have enough to cover both the Boardwalk and a Planck, haha.
Offline Hell-es
« Reply #251 on: Tue, 11 June 2019, 12:09:58 »
Any ideas for a rama cap ? Maybe a shine through dot ?
Would be so hot with Think 6.5 s. 4RGB ESC key
Offline biip
    • @biipmk
« Reply #252 on: Tue, 11 June 2019, 15:56:17 »
Update :)
Offline robbieheart
« Reply #253 on: Tue, 11 June 2019, 16:25:44 »
Im in!
The base kit and Nomad kit cover a XD75 perfectly!
+1 for a translucent key OR a Rama enamel fill of the Dots logo would also be a great idea!
Tofu XD75  PC KBD67 MKII
Offline nasp
« Reply #254 on: Tue, 11 June 2019, 16:40:18 »
Ergo kit looks much better! Thanks 😊
Offline WilySouser
  • I would RTFM, but I can't find the FM
« Reply #255 on: Tue, 11 June 2019, 18:47:19 »
This is so stupid... I love it.  Not sure if I'm able to vote with my wallet but I support the sh!t out of this set
Offline biip
    • @biipmk
« Reply #256 on: Wed, 12 June 2019, 03:41:31 »
About the transparent dot keycap, the centered dot sits right above the stem which is the worst position for backlighting.
After discussing with GMK, we will pass this option.
Offline Hell-es
« Reply #257 on: Wed, 12 June 2019, 12:17:31 »
didn‘t think about that - but makes  sense  :))
Thanks for clarification ... would‘ve been too nice
Offline Acereconkeys
  • Happiness = life - expectations
« Reply #258 on: Thu, 13 June 2019, 12:25:46 »
Love love this set. Just another +1 for monotone. While I don't hate the colored mods on this set, i think just gray would look better.
Imo the fact it's all dots instead of legends is crazy enough a reserved simple gray and white color scheme would be awesome.
TMO50 | Jane V2 CE Incoming | Realforce 87u 55g | Aergo
Aergo design and build log: https://geekhack.org/index.php?topic=103681.msg2840918#msg2840918
Offline jiatlormee
« Reply #259 on: Sat, 15 June 2019, 21:48:04 »
Yassssss I'm in!
So psyched for them dots
Offline biip
    • @biipmk
Re: [IC] GMK Dots
« Reply #260 on: Mon, 17 June 2019, 08:49:36 »
Is the background color N9? Because it could be. This is lit.
nope, custom.  :thumb:
Also, quick update:
E-White Aluminium with white gloss enamel fill keycap
Hand mirror polished PVD Brass keycap
Offline IOVERCALLHISTIOCYTES
Re: [IC] GMK Dots (Rama keycaps 👀)
« Reply #261 on: Mon, 17 June 2019, 08:57:02 »
awesome
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
Re: [IC] GMK Dots
« Reply #262 on: Mon, 17 June 2019, 09:04:12 »
Also, quick update:
Masterpiece. Work of art, belongs in a museum.
Just my thoughts
Offline Sintpinty
    • My Roblox Profile
« Reply #263 on: Mon, 17 June 2019, 09:05:16 »
If you type on dvorak and have this keyset on , your co workers won't want to type on your keyboard. Ever.
Good way to make people stay away from my keyboards.
Just my thoughts
Offline rondg
Re: [IC] GMK Dots
« Reply #264 on: Mon, 17 June 2019, 09:35:31 »
Also, quick update:
Yes.
« Reply #265 on: Mon, 17 June 2019, 09:46:54 »
can we get nipple homing keys
Offline harlekein
« Reply #266 on: Mon, 17 June 2019, 10:13:06 »
 Didn't realize anyone would actually like that.
« Reply #267 on: Mon, 17 June 2019, 10:22:44 »
i don't think anyone likes them i just think it'd be funny with the dots
Offline harlekein
« Reply #268 on: Mon, 17 June 2019, 10:54:41 »
That just seems like a waste then.
Offline wilksMJP
Re: [IC] GMK Dots
« Reply #269 on: Mon, 17 June 2019, 16:00:04 »
Also, quick update:
How much will the white Rama Works keycap be?
Re: [IC] GMK Dots
« Reply #270 on: Mon, 17 June 2019, 22:11:14 »
Also, quick update:
hold on i nearly have bingo
Offline dav1k
« Reply #271 on: Tue, 18 June 2019, 00:56:32 »
Wow!
I really appreciate the updates to the Ergo kit! Thanks!
WoW! That PVD, polished Rama keycap is beautiful!
Does the Ergo kit have an estimated price? Similar to the base kit pricing I'm sure, but I'd like to make a note of it.
Keep up the great work !!  :thumb:
Offline biip
    • @biipmk
« Reply #272 on: Tue, 18 June 2019, 02:20:10 »
I should receive the quote from GMK soon™ :thumb:
Thanks for your kind words :3
Offline konstantin
  • Formerly constexpr
Re: [IC] GMK Dots (Rama keycaps )
« Reply #273 on: Wed, 19 June 2019, 03:47:29 »
I'll be all over this when it drops! I knew you'd make this set a reality :D
Have you considered making the spacekeys a separate kit? Also, I've seen a few people suggest that Delete should have a red dot. I guess that makes sense.
« Last Edit: Wed, 19 June 2019, 03:49:35 by constexpr »
Offline equalunique
Re: [IC] GMK Dots (Rama keycaps [emoji102])
« Reply #274 on: Wed, 19 June 2019, 14:22:57 »
Space keys are important to me too. The ergo kit only has 1x2u R4C key. I'm looking for 4x1u R4C keys, so will probably have to buy a couple nomad kits with the way things are currently structured.
If this was N9, then I would be able to use the massive amount of N9 1u R4C keys I purchased via scud80's recent GMK blanks GB... :)
Sent from my LG-H918 using Tapatalk
Offline biip
    • @biipmk
Re: [IC] GMK Dots (Pricing)
« Reply #275 on: Mon, 24 June 2019, 09:59:49 »
Pricing:
Base kit$135
Ergo kit$110
Nomad kit$35
I will update it and add vendors soon™
« Reply #276 on: Mon, 24 June 2019, 10:59:48 »
Great prices.
It may never take off, but I appreciate the split bars in the base kit
Offline Magnificent Bureaucrat
  • Sooooo much red tape
« Reply #277 on: Mon, 24 June 2019, 19:50:44 »
Such a cool set. I'm almost tempted but the thought of having no legends suddenly makes me doubt my ability to touch type.
Offline harlekein
« Reply #278 on: Tue, 25 June 2019, 03:59:02 »
It's a good opportunity to learn.
Offline tacahiroy
« Reply #279 on: Tue, 25 June 2019, 08:18:28 »
Update :)
Definitely in for the Ergo kit!!
Offline biip
    • @biipmk
« Reply #280 on: Tue, 25 June 2019, 08:23:57 »
this
Offline vicissitude
« Reply #281 on: Tue, 25 June 2019, 09:59:15 »
nice price.
ready to join GB.
Offline Chumbo
Re: [IC] GMK Dots GB July 1st)
« Reply #282 on: Sat, 29 June 2019, 11:34:20 »
Are those extra R3 keys scooped?
Offline iaman
« Reply #283 on: Sun, 30 June 2019, 21:57:40 »
Put in my order 👏
Offline scoopbb
« Reply #284 on: Sun, 30 June 2019, 22:36:43 »
will there be any price breaks on moqs?
Offline dantambok
« Reply #285 on: Mon, 01 July 2019, 00:44:55 »
Waiting for the set to go up on Zf! :)
Stuff  I have
2x TGR Alice / TGR 910 RE / TGR 910 CE / TGR 910 VKC / 2x TGR Jane V2 / 2x Matrix 2.0 / Matrix 2.2 / Matrix 1.2OG / Lyn Whale v2 / Lyn EM7 v3 / DK Saver / Keycult No. 1/60 /  Quantrik Hachi /  Quantrik  Kyuu / Duck Orion V2 / TGRxSinga Unikorn R1 / 2x Unikorn 2.2 / Quantrik QXP /  JER80 / TMO50 / 2x 86u / ION i69 / LZ MP / 2x FMJ80 / TGR Jane V2 CE / Matrix Project F / IDB60 / is0  / MXSS / Atom TKL / HBCP / Noxary 280  / FLX Virgo / Modern M0110 / Matrix 2.0 ADD / TGR Police / Noxary XRF / Noxary Vulcan Pro / 35g0 Mimi / Matrix 2.0CP / Kira80 / Exent 65% / FMJ60 / Haus 65 / Kikuichimonji / Cake 60 / 2x AU Unikorn  Commission/ LZ XE / Paraluman 60 / AI03 Andromeda / Dalco 959 Mini GT /  Finder Works Hyphen / Linworks EM8 / GAFxTGR 910 / TGRxKLC Dolice / TGR 910v2 ME / Noxary Valhalla / Hiney Ibis / LZ REs / PerryWorks MC65 / Hiney Poly TKL One / RS60 / Zekk RBB / Keycult No 2 TKL
100+ GMK sets
Offline nephlock
« Reply #286 on: Mon, 01 July 2019, 00:47:18 »
I’m in! Can’t wait. Excellent job dude
Offline gutsack
« Reply #287 on: Mon, 01 July 2019, 00:55:52 »
Joined via NovelKeys!
Offline sevenseacat
« Reply #288 on: Mon, 01 July 2019, 01:30:52 »
Joined via DailyClack 👍
Offline biip
    • @biipmk
« Reply #289 on: Mon, 01 July 2019, 02:04:04 »
Group Buy is live!
I'll post the GB thread soon.
Offline dav1k
Re: [IC] GMK Dots (GB live!)
« Reply #290 on: Mon, 01 July 2019, 02:13:17 »
Really excited to pick up this kit.
Got a quick question, Nomad kit. Can someone do me a huge favor and clue me into what layouts this facilitates? I'm almost planning to order just to make sure, but the knowledge would be extremely useful.
Thanks! Great work Biip!
Offline dantambok
« Reply #291 on: Mon, 01 July 2019, 02:14:33 »
Joined!
Stuff  I have
100+ GMK sets
Offline biip
    • @biipmk
« Reply #292 on: Mon, 01 July 2019, 02:17:03 »
Nomad kit is basically for all the weird layout below 60% :thumb:
The kit is needed if you have a 40% staggered keyboard.
Offline ndom91
    • ndo.dev
« Reply #293 on: Mon, 01 July 2019, 09:20:49 »
Any news on candykeys GB?
Offline biip
    • @biipmk
« Reply #294 on: Mon, 01 July 2019, 09:31:42 »
will be live at 7pm (EU time)
GB thread is waiting for approval!
Offline KingOfMemes
« Reply #295 on: Mon, 01 July 2019, 10:43:02 »
Copped. Hype
Offline tobiasvl
  • ISO 9995
« Reply #296 on: Mon, 01 July 2019, 13:07:09 »
What is EU time? GMT? So in an hour then?
I still think the ISO Enter should have had a vertical bar, but other than that this looks amazing!
Offline ndom91
    • ndo.dev
« Reply #297 on: Mon, 01 July 2019, 13:12:05 »
Yeah so it looks like I was just impatient haha.
They went live on candykeys around 19:00 CET (GMT+2:00) and I got my base kit :)
EDIT: Is there any sort of general timeline on the group buy? When it'll be over, how long manufacturing should take, and finally when we can expect to begin seeing shipments go out? Just asking about like general months, not specific days.
« Last Edit: Mon, 01 July 2019, 13:17:18 by ndom91 »
Offline Hell-es
« Reply #298 on: Mon, 01 July 2019, 13:20:40 »
When is this Group-Buy going to ship?
   GMK Dots is scheduled to ship late November 2019
Think its running until end of july
Offline tobiasvl
  • ISO 9995
« Reply #299 on: Mon, 01 July 2019, 13:25:39 »
Nice, Candykeys changed their website's logo
