Author Topic: [IC] SA Crystal  (Read 12938 times)
Offline Dazon
[IC] SA Crystal
« on: Fri, 31 May 2019, 18:08:23 »
220247-0
Hi!
SA Crystal is inspired by the colors of Rose Quartz and Amethyst.
Please comment suggestions for novelties and anything else. I am working on other kits right now, and rows are going to be finalized soon, so the renders might not be accurate.
Speaking of renders:
220267-1
220269-2
220273-3
« Last Edit: Sat, 01 June 2019, 13:53:06 by Dazon »
Offline OtherAndrew
Re: [IC] SA Crystal
« Reply #1 on: Fri, 31 May 2019, 18:13:39 »
why is it a different color in every picture
and not sa
Offline Techno Trousers
  • ʘ_ಠ
Re: [IC] SA Crystal
« Reply #2 on: Fri, 31 May 2019, 18:23:00 »
That hand drawn logo tho. Is this going to run with GMK FEELING CUTE?
Offline Dazon
Re: [IC] SA Crystal
« Reply #3 on: Fri, 31 May 2019, 18:24:57 »
and not sa
that is the lighting i was playing with. I will use white light for any future renders.
Offline Dazon
Re: [IC] SA Crystal
« Reply #4 on: Fri, 31 May 2019, 18:26:24 »
The logo isn't hand drawn haha, the font is called D-ickie (this should work, the - isnt really there)
« Last Edit: Fri, 31 May 2019, 18:29:13 by Dazon »
Offline Dazon
Re: [IC] SA Crystal
« Reply #5 on: Fri, 31 May 2019, 18:39:18 »
Also here is what I have now for the base kit:
220257-0
this render has all of the actual colors, with no colored lighting.
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
Re: [IC] SA Crystal
« Reply #6 on: Fri, 31 May 2019, 19:13:07 »
Those aren't SA caps.
Also, you can see even in the render there is not enough contrast on the mods on the right side. They will look blank in real life.
Offline Dazon
Re: [IC] SA Crystal
« Reply #7 on: Fri, 31 May 2019, 19:52:21 »
I know they aren't SA, I am currently working out the row profiles, so new renders will be out when they are SA.
as for the contrast, what should I do to fix it?
Sent from my SM-G973U using Tapatalk
Offline fireworm
Re: [IC] SA Crystal
« Reply #8 on: Fri, 31 May 2019, 20:02:00 »
Personally, I'd fork over $10 and pay for one: https://kbrenders.com/.
Re: [IC] SA Crystal
« Reply #9 on: Fri, 31 May 2019, 20:11:18 »
GMK FEELING CUTE was much better.
Offline Dazon
Re: [IC] SA Crystal
« Reply #10 on: Fri, 31 May 2019, 20:16:37 »
honestly nothing can top GNK FEELING CUTE
Offline AaronR
Re: [IC] SA Crystal
« Reply #11 on: Fri, 31 May 2019, 22:27:45 »
Maybe you could do the set like grand Budapest but with the mod legend colour the same as the alpha background colour.
Offline coffeeshopcoder
Re: [IC] SA Crystal
« Reply #12 on: Fri, 31 May 2019, 23:06:33 »
I'd buy if you did !
Offline Henriii
Re: [IC] SA Crystal
« Reply #13 on: Sat, 01 June 2019, 00:46:02 »
Doesnt look like SA pro to me :/
Offline Dazon
Re: [IC] SA Crystal
« Reply #14 on: Sat, 01 June 2019, 12:54:45 »
Alright, i have made a new full render! It is now SA, with finalized row profiles. I also made the mods more visible.
220260-0
Edit: I realized I didn't say the profiles;
R1
R1
R2
R3
R4
R4
« Last Edit: Sat, 01 June 2019, 13:17:58 by Dazon »
Offline luan7749
Re: [IC] SA Crystal
« Reply #15 on: Sat, 01 June 2019, 12:58:17 »
Sorry, I don't like this keyset :(
Offline Dazon
Re: [IC] SA Crystal
« Reply #16 on: Sat, 01 June 2019, 13:57:23 »
Alright, I hope that is what you mean.
Offline AaronR
Re: [IC] SA Crystal
« Reply #17 on: Sat, 01 June 2019, 17:55:43 »
Sorry had the purple as mods with pink for the legends and pink as alphas with purple legends in mind.
Offline vicissitude
Re: [IC] SA Crystal
« Reply #18 on: Sat, 01 June 2019, 20:43:06 »
Lovely color combination.
Offline lewisflude
  • Hand Engineering
    • Hand Engineering
Re: [IC] SA Crystal
« Reply #19 on: Mon, 03 June 2019, 05:42:53 »
Would be good with UK ISO support!
Offline Oblotzky
  • Backspace is for people that make mistakes.
Re: [IC] SA Crystal
« Reply #20 on: Mon, 03 June 2019, 05:46:13 »
SA Arcane sold 3 ISO-UK kits in Europe, I'm not sure if a ISO kit makes much sense.
Re: [IC] SA Crystal
« Reply #21 on: Mon, 03 June 2019, 07:27:47 »
This ^^^^
Also - can you post your target pantone or RAL codes for the colors ? Pinks are generally hit or miss, Budapest did it great with their nice creamy light pink... darker pinks can be very overpowering.
Offline lewisflude
  • Hand Engineering
    • Hand Engineering
Re: [IC] SA Crystal
« Reply #22 on: Mon, 03 June 2019, 08:35:10 »
Yeah, it's not viable if it's only gonna be a few kits sold. Best keep this stripped back then, unless interest is off the charts.
Offline Dazon
Re: [IC] SA Crystal
« Reply #23 on: Mon, 03 June 2019, 14:57:34 »
i plan on having ISO in the base kit
This ^^^^
the purple is RDA and the pink is RCS
