Author Topic: Help soldering a GH60 Rev c. from Scratch  (Read 5268 times)
Offline atlantapuzzler
« on: Sun, 16 June 2019, 12:44:09 »
Hello Geekhack members,
Given my background in electronics and having access to components and other tools, I went ahead and printed several GH60 PCB's using the gerber files available on GitHub. The new boards look amazing. I populated 3 PCB's so far with a brand new ATMega32U4 along with all the Crystal, SMD Caps and Resistors. I also installed the reset button and it's pull up resistor. Per schematics, I installed a 6 pin headers on P1-P6. I am able to use AVRDude to flash the chip various hex files without any issues. I even experimented with flashing the bootloader with the Caterna boot loader used by the Pro Micro with the Arduino IDE. Flashing is always successful. However, when I plug the keyboard to the PC, it does not get detected by the computer and it never shows up on any COM port. I used the ATMega32U4 in many projects in the past, it is pretty easy to get it going. I am not sure what am I doing wrong.
Using an ISP, here is the avrdude output:
avrdude -C<path to conf>avrdude.conf -v -patmega32u4 -carduino -PCOM3 -b19200 -Uflash:w:<path to hex file>gh60_default.hex:i -Ulock:w:0x2F:m
avrdude: Version 6.3-20171130
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "<path to conf>avrdude.conf"
         Using Port                    : COM3
         Using Programmer              : arduino
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega32U4
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  9000  9000 0x00 0x00
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e9587 (probably m32u4)
avrdude: safemode: lfuse reads as FF
avrdude: safemode: hfuse reads as D8
avrdude: safemode: efuse reads as CB
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
         To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "<path to hex>\gh60_default.hex"
avrdude: writing flash (16978 bytes):
Writing | ################################################## | 100% 19.99s
avrdude: 16978 bytes of flash written
avrdude: verifying flash memory against <path to hex>\gh60_default.hex:
avrdude: load data flash data from input file <path to hex>\gh60_default.hex:
avrdude: input file <path to hex>\gh60_default.hex contains 16978 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 11.74s
avrdude: verifying ...
avrdude: 16978 bytes of flash verified
avrdude: reading input file "0x2F"
avrdude: writing lock (1 bytes):
Writing | ################################################## | 100% 0.04s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x2F:
avrdude: load data lock data from input file 0x2F:
avrdude: input file 0x2F contains 1 bytes
avrdude: reading on-chip lock data:
avrdude: 1 bytes of lock verified
avrdude: safemode: Fuses OK (E:CB, H:D8, L:FF)
avrdude done.  Thank you.
Offline hasu
  • @tmk
Re: Help soldering a GH60 Rev c. from Scratch
« Reply #1 on: Sun, 16 June 2019, 23:27:45 »
If you got proper variant of the ATMega32U4 it should has bootloader(from Atmel) from the begining. You don't have to program with ISP programmer and avrdude.
The Atmel bootloader should appear as like this on Windows.
https://github.com/tmk/tmk_keyboard/wiki/Driver-install-on-Windows#device-name
Or you will see it on log like below under Linux. No device file for the Atmel bootloader is not created in general.
Code: [Select]
Jun 17 13:23:28 desk kernel: [2003193.461697] usb 3-3.2: USB disconnect, device number 34
Jun 17 13:23:29 desk kernel: [2003193.942872] usb 3-3.2: new full-speed USB device number 35 using xhci_hcd
Jun 17 13:23:29 desk kernel: [2003194.092542] usb 3-3.2: New USB device found, idVendor=03eb, idProduct=2ff4
Jun 17 13:23:29 desk kernel: [2003194.092546] usb 3-3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jun 17 13:23:29 desk kernel: [2003194.092549] usb 3-3.2: Product: ATm32U4DFU
Jun 17 13:23:29 desk kernel: [2003194.092552] usb 3-3.2: Manufacturer: ATMEL
Jun 17 13:23:29 desk kernel: [2003194.092554] usb 3-3.2: SerialNumber: 1.0.0
Offline hasu
  • @tmk
« Reply #2 on: Sun, 16 June 2019, 23:33:43 »
And You should consult with your xtal's datasheet for load capacitance and make sure you are using proper capacitor value for the xtal. Xtal won't oscillate with imporper capacitors.
