Author Topic: [IC] Wireless 60% Custom MK with Hot-swap and QMK | "WE NEED YOUR AWESOME IDEAS"  (Read 6819 times)
Offline entergogo
    • entergogo | Typing Matters
Check new UPDATES here https://geekhack.org/index.php?topic=101589.0
Design for MK Enthusiast
Greetings! This is Chao. Entergogo is a new startup brand that focuses on providing cool mechanical keyboards. As I usually working mobile with surface or iPad, a custom 60% wireless keyboard with QMK and hot-swap is my dream. So I'm trying to make it happen. Please check the design prototype https://imgur.com/a/OLBqnv3
Main Features:
  • Hot-swappable
  • Fully programmable via QMK
  • CHERRY MX switch, KAILH Box Switch or other switches
  • Wireless via Bluetooth
  • Hefty CNC Aluminum case
  • PBT Keycaps
  • Standard ANSI and ISO layout
We would like to hear more ideas from the community, please check the link if you have an interest. https://forms.gle/k5vH7xjbqYUuQ48dA
« Last Edit: Mon, 30 March 2020, 02:34:48 by entergogo »
www.entergogo.com
Discord link: https://discord.gg/ECErFWB
Discord name: entergogo#2512
Reddit: u/entergogo
Offline EMC Labs
Re: [IC]60% Customizable MK with Hot-swappable socket/QMK/Wireless
« Reply #1 on: Wed, 26 June 2019, 20:37:27 »
Nice!
Offline equalunique
« Reply #2 on: Wed, 26 June 2019, 22:31:11 »
Cool! I have some questions:
In addition to the USB port, are those two other ports on the side? What are they for?
Are the three indicator lights on the side programmable RGB?
Are the LEDs for the switches also hot swappable, like how KPRepublic has done with their XD75re LED sockets? They are sold seperately from the PCB itself: https://kprepublic.com/products/xd75re-gold-plated-hot-swap-socket-for-3mm-leds-234-leds-custom-mechanical-keyboard-75-keys-gh60-kle-planck-hot-swappable
Sent from my LG-H918 using Tapatalk
Offline entergogo
« Reply #3 on: Wed, 26 June 2019, 22:57:45 »
Hey, thanks for your attention.
1. Yes, besides the USB-C port, there are two other switches on the side, one for Bluetooth connection, another one is the battery on/off. (1000mAh lithium battery inside)
2. No, they are not programmable RGB. Is it necessary for you?
3. This one was designed without LED backlit, after serious discussion, we decided to sacrifice the led backlit which make the keyboard battery can last more than 30 or 40 days.
Btw, here invite you to join our survey for the GG60-Pro, appreciate your feedback. https://forms.gle/k5vH7xjbqYUuQ48dA
www.entergogo.com
Reddit: u/entergogo
Offline piit79
« Reply #4 on: Thu, 27 June 2019, 02:10:23 »
Looks nice! Although you say battery life should be 30-40 days which is great, I'd go for a bigger battery, 2000 mAh if it can fit.
Also please correct your description slightly where you say "Kailh Choc Box switches" - you meant to say "Kailh Box switches". "Kailh Choc switches" are low profile switches with incompatible pinout (it is possible to make universal PCB, but not including hotswap).
Offline entergogo
« Reply #5 on: Thu, 27 June 2019, 02:16:28 »
Thank you for your comments.
We will consider using a 2000mAh battery, will update here about the end of July.
Sure, I will change the description soon.
www.entergogo.com
Reddit: u/entergogo
