Author Topic: [IC]Go-fit60, A 60% Bluetooth 5.0 Barebones Kit, GB is in progress  (Read 65661 times)
Offline entergogo
    • entergogo | Typing Matters
Updates on August 15, 2021
We just initiated the GB on Go-fit60! Check it out here: [GB] “Go-fit60,” A 60% Bluetooth 5.0 Barebones Mechanical Keyboard Kit, starts from US$89.00, GB starts on Aug 15, 2021 EST
Updates on August 10, 2021
We gathered some new pictures of the prototype:
More pictures at https://imgur.com/a/cAWXkPi
Here’s the video that will give you a quick walk-through on go-fit60's sound with two kinds of switches - TTC red switch and Gateron blue switch:
TIMELINE
GB starts on August 15, 2021, with a new GB post, but we will also update here.
PRICING
We made a slight adjustment to the pricing. The price will start from USD$89.00. Detail will be announced in GB.
entergogo
Updates on April 17, 2021
Hi from entergogo,
Hope you guys are staying safe and healthy. We know it’s been a longggg day since the latest update. Here’s a brief of what we have working on since the last update on this discussion page. We regrouped the team, designed and launched the first generation Go-popper, a 2-in-1 Aluminum Switch Opener (Interested in? You can find out more here)
More than that, we tried to break through the technical difficulty we identified during the past one-year exploration, studies, and development on Go-fit60, which is the new official name of the GG60 barebones kit. We’ve been receiving many cares and greetings during the past several months, so we think it’s time to go for the next chapter.
We notice that some of you also mentioned in the previous discussion if the purchase of the kit can be more flexible and whether the PCB was available for being purchased separately and inclusively. The answer to these questions is 100% a YES. Meanwhile, two types of PCB are available for the selection--with or without RGB lights.
The purchase on Go-fit60 kit has four options:
Option 1: The original kit includes 1 PCB (RGB enabled), 1 plate, and 1 aluminum case
Also contains 1 set of cherry stabilizers and 1 set screws
(switches and keycaps are not included in the kit)
Option 2: The original kit includes 1 PCB (no RGB), 1 plate, and 1 aluminum case
Option 3: 1 PCB with RGB
Option 4: 1 PCB does not have RGB
Go-fit60 e-white & black aluminum case and PCB overview (with keycaps and switches)
The black & e-white aluminum case
One significant adjustment was applied.
The initial ideal software design of PCB is Bluetooth 5.0 enabled plus the QMK setting. However, after almost one year of researching, engineering, adjusting, and prototyping, we found that this combination is currently not thoroughly well-developed and mature enough in the whole market. It is actually being identified as a very challenging technical barrier by most of the professionals we had lots of discussions with, and we are still on our way to solve it with a satisfying answer. However, at the moment, we have to regrettably announce that the PCB contained in the kit will not realize the combination of these two features.
As a result, we decided to keep the Bluetooth 5.0 and replace the QMK with a driver temporarily. Although this combination cannot be applied to the kit, we firmly believe that the demand for a full-case remapping is nonnegligible for the community. That’s why a driver is our alternative decision, which also provides the option of the full-keys customizable keyboard setting.
The PCB
Besides, during the prototyping and the previous IC collection, we realized that the battery capacity is another killing point for a Bluetooth-enabled mechanical keyboard, especially when the initial sample tested during the prototyping could only hold an 800mAh lithium battery, leading to some feedback we received regarding the duration of it. Therefore, we decided to upgrade the battery capacity to 3500mAh, which sustains a much longer working duration. Accordingly, the high frequency of charging the keyboard will not be a concern with Go-fit60 under a larger battery capacity.
Features of the kit
  • Bluetooth 5.0 (support up to 3 devices)
  • Hot-swap (Kailh socket)
  • Anodized Aluminum 6063 case
  • Type-C port
  • Charging indicator
Specs
  • An Aluminum 6063 plate, 1.5mm, Tray mount style
  • Low profile case, 7-degree angle
  • Layout: standard 61 keys, ANSI (6.25 u space bar)
  • Case and Plate color options: black, e-white, space grey
In the previous IC of Go-fit60, only black and red were provided as the case and plate color options. However, through the comments and feedback that we gathered from the IC, black, space grey, and e-white were the colors being wanted and loved the most. Therefore, we made a slight adjustment on the color selection by replacing the red variant with the space grey and e-white options.
More details on the Pre-soldered PCB
  • 3500mAh Lithium battery
  • Dual-mode, Wire/Wireless, charging when cable plugged
  • USB Type-C breakout
  • Black solder mask with gold surface finish
  • Low battery/charging indicators
  • Switch direction: South-facing (in case of keycaps interference issue)
  • ESD protection was added
  • Cherry stabilizers (pre factory lubed)
Go-fit60 with keycaps & switches
Go-fit60 type-c charging port and bluetooth button
TIMELINE
TBA
The form used to collect and gather IC will no longer receive responses as soon as we update this notice here. The new GB form will soon be posted if everything is on the right track.
PRICING
We put a lot of effort into this project since early 2019 before we initially started designing and producing Go-poppers. Many of you may recall that the first IC was posted one year ago, and after that, we faced some challenges over the past two years, including the unexpected COVID-19. The original idea of introducing Go-fit60 was to offering a barebone kit that is made with better raw materials, representing higher quality and durability, and therefore can be regarded as an alternative replacement of plastic-made case for intense typing workload. Keeping this in mind, we lower the pricing of the kit over the GB with our best effort over conversations and negotiations with the factory and warehouse.
Finally, we all agreed that during the GB, although the cost of the raw material of the e-white Go-popper is relatively higher than the others, it will have the same price as the kit of black and space grey Go-fit60. Also, we decided to waive the cost of the production on the PCB that is enabled with RGB, making it the exact pricing as the regular PCB with no RGB lights support.
The GB will be held for 20 days in total, and three different prices will be assigned to 1 kit and 1 PCB, respectively, for the first 3 days, the 4th to 10th day, and the last 10 days.
SHIPPING
All orders will be conducted and shipped by entergogo directly from the factory.
ANY QUESTIONS?
Any questions, thoughts, or concerns about this event or us, please post them here or reach out to us directly at hi@entergogo.com. Many thanks to everyone in the community for your unconditional support.
Be sure to check the discussion page for updates.
entergogo
Updates on Sep 25
As with the last update, we had a hard time with the QMK+ Bluetooth testing process, and after another period of time we were still unable to work out some of the bugs, and while it may disappoint some people, we have to be honest and say that we have decided that the GG60 does not support QMK, and we will still be using the Bluetooth 5.0 solution. We are already redesigning the PCB to speed up the product launch.
Here is the latest product details:
The GG60 kit came from an original idea to make a powerful and minimalist mechanical keyboard for working on the go.
Features
Spec.
  • Anodized aluminum 6063 case
  • Aluminum 6063 & brass plate, 1.5mm, Top-Mount style switch plate
  • Low profile case, 7 degree angle
  • Case and Plate color options: black, red
Pre-soldered PCB
  • 2000mAh Lithium battery (estimated 2 months duration)
  • Dual mode, Wire/Wireless, charging when cable plugged
Fill out IC form if you're new here;)
www.entergogo.com
Discord link: https://discord.gg/u63xJht
Discord name: entergogo#2512
Important updates on July 31
After some struggle and trade-offs, we decided to go with Bluetooth 4.0 + QMK instead of the originally planned Bluetooth 5.0 + QMK.We feel sorry about this, especially for who has an expectation on Bluetooth 5.0.
Either Bluetooth alone or QMK is very easy to implement, but Bluetooth + QMK is not.
After months of trial and talking to industry solution experts, we found that implementing Bluetooth 5.0+QMK was very difficult and beyond our team's current capabilities.
In fact, Bluetooth 4.0+QMK is a very good solution, at least for now, it is more stable and the user experience is almost the same as Bluetooth 5.0.
In short, we don't want to launch Bluetooth 5.0 + QMK when it's not fully ready.
Next, we need a little more time to finish the rest of the work and then officially launch the GG60 Kit. (GB coming soon...)
www.entergogo.com
Updates for the GG60 and initial GB
GG60 Kits include as follows. (switches and keycaps are not included in the kit)
  • 1x alu case
  • 1x plate
  • 1x PCB(soldered)
  • One set cherry stabilizers
  • One set screws
Features
QMK / Hotswap with Kailh socket / Bluetooth 5.0 / Alu Case / Type-C port / Charging indicator
Other information
  • There is no backlit for the initial GB, but the PCB supports SMD lights.
  • Besides black and red, maybe add one more color option for the case, probably grey. (We know many people want a white case, but due to the high defect rate, the price will be affected, we will release the white one in the future than now)
  • Only ANSI layout for the initial GB, ISO layout coming later(2nd round GB)
  • You can choose to buy a PCB separately
  • GB opens between May 20 to June 10, exact date TBD
  • We provide free assemble service if you need it.
Fill out IC form if you have an interest:)
www.entergogo.com
Update on 9th Apr 2020
Hey Guys,
Regarding switch direction, we can make a change on the PCB now, we made it north-facing before, but we heard from the community that will cause the issue of caps interference.
North-facing or south-facing, please let me know your ideas(comments). We appreciate.
Update on 9th Mar 2020
Hey Geekhackers!
I'm Chao! There are new updates, as we had a meeting with my partner and our supplier yesterday. We are testing BT4.2 and BT5.0 at the same time, we are planning to finish the testing work within March, then probably we can get the final PCB and other kits in April. Yeah, we are so excited to see the GG60 kit coming out in the near future as you guys.
Please fill out IC form if you have an interest:)
Update on 19th Feb 2020 Please fill out IC form if you have an interest:)
Hi everyone,
Since my team is based in Shenzhen China, due to the effects of coronavirus, we are not allowed to work in the office. Now we are not sure when the damn coronavirus is gone, as long as it finished, we will release the GG60 asap.
Update on Dec 25 2019 Please fill out IC form if you have an interest:)
Merry Christmas! Merry Christmas! Merry Christmas!
Actually there is nothing new to update about the product, we met some problems on the PCB earlier, we just to let you know that the project is still on the wheel, stay tuned!
Prototype Update on Oct 09 Please fill out IC form if you have an interest:)
Check More Photos
Keyboard total weight: 900g / 2 pounds
PCB Features
  • Hotswap (Kailh sockets)
  • QMK-all keys fully programmable
  • Bluetooth5.0, support up to 3 devices
  • Type-C connector
GB will be started around Nov, the exact date will be announced here!
New Updates on Sep 17, new PCB is on testing
Hi, sorry for updating late, the PCB is still on progress, as the previous test didn't meet our requirements, we are hurrying up to test the new PCB, hopefully, we can get the final keyboard kit sample before Sep 25, then we can start the GB around Sep 30. I will keep you all updated.
PCB includes:
  • Bluetooth dual mode
  • Type-C connector
Fill in this form if have an interest:)
Price updated on July 23, 2019
GG60-Pro is a minimalist mechanical keyboard kit, it is designed for the people who like portable and small keyboards, the wireless function quite fit for the people who like travel and work mobile, one charge can last over 2 months.
We hope more and more people can enjoy a premium custom mechanical keyboard. So we tried our best to make it an affordable custom keyboard kit, only $99 for the basic kit.
New Renders, Updated on July 19, 2019
More renders https://imgur.com/gallery/hRbvRTt
LAST POST: https://geekhack.org/index.php?topic=101368.0
Hi guys, we get the 3D print sample on July 5, we felt that both the right and left edge part could be narrower and it looked more concise and generous. As well, we adjusted the indicator light to the upper right corner of the keyboard and placed the charging port on the top left of the keyboard. Then we made several renders for reference.
Design
Minimalist Design for 60% MK Enthusiast.
Why the name: ‘GG’ from the brand name ‘entergogo’, 60 means 60%.
Features
  • Anodized Aluminum 6063 base case
  • 7-degree angle.
  • Aluminum 6063 & Brass plate
  • PCB
  • Bluetooth 5.0 with 2000mAh Lithium battery (estimated 2 months duration)
  • Hot-swap socket(soldered in)
  • QMK-Fully programming
  • Type-C terminal
  • Black PCB with Gold pads
Spec
  • Layout options. ANSI & ISO Layout (ANSI coming earlier, and ISO later)
  • Case color options. Black and Red
  • Aluminum Plate color options. Black and Red
  • 6.25 u space bar
  • Stab and necessary screw included
Pricing - USD (Free assemble)
  • Basic kit 1: $99 (including Anodized CNC Aluminum Case, PCB, Aluminum Plate, and necessary tools, screws, etc.)
  • Basic kit 2: $109 (including Anodized CNC Aluminum Case, PCB, and Brass Plate and necessary tools, screws etc.)
  • 65 pcs Cherry MX switch +$26
  • 65 pcs Kailh box +$15
  • 65 pcs Gateron +$12
  • Extra Case: +$50
  • Extra PCB: +$50
  • Extra aluminum plate: +$12
  • Extra brass plate: +20 USD
  • Shipping fee: TBD, DHL Express
  • Transaction fee included
Timeline
  • GB period: TBD
  • Estimated shipping date: TBD
MOQ: 50 kits
please check the link if you have an interest.  :p
« Last Edit: Sun, 22 August 2021, 20:42:38 by entergogo »
www.entergogo.com
Discord link: https://discord.gg/ECErFWB
Reddit: u/entergogo
Offline pixelpusher
Re: [IC] GG60-Pro 60% wireless custom kit - Updated July 14, 2019
« Reply #1 on: Mon, 15 July 2019, 20:25:19 »
Any photos of the PCB?  Are the switches facing with the logo upside down or right side up?  Can the case accommodate other GH60 compatible PCBs?
Offline entergogo
« Reply #2 on: Mon, 15 July 2019, 22:20:30 »
Hi, thank you for your questions.
1. Sorry, so far no PCB photos, we just finished the PCB design, our partner is making the PCB sample for us, hopefully, we can get the PCB sample July 31, will keep you updated.
2. The switches facing the logo is upside down, which one do you prefer?
3. Honestly, we haven't tested it on other PCBs, but I think the case is hardly compatible with other 60% PCBs unless the PCBs have the same functions with GG60-Pro.
www.entergogo.com
Reddit: u/entergogo
Offline pixelpusher
« Reply #3 on: Mon, 15 July 2019, 22:36:39 »
most people prefer the switches with the logo right-side up.  Upside down switches make contact with Cherry profile keycaps on a few rows.
Offline entergogo
« Reply #4 on: Mon, 15 July 2019, 23:09:20 »
I Got it, thank you very much! I will discuss it with my team.
www.entergogo.com
Reddit: u/entergogo
Offline evorus5
« Reply #5 on: Tue, 16 July 2019, 10:46:12 »
I agree on the keycaps being right side up.
Aside from that, it looks like a nice premium entry board and I'm totally in for this.
This could be my travel board  :)
Offline entergogo
« Reply #6 on: Tue, 16 July 2019, 10:59:28 »
Thank you for your comment!
Please fill in the form if you want to be kept updated. https://forms.gle/k5vH7xjbqYUuQ48dA
www.entergogo.com
Reddit: u/entergogo
Offline macinstein
Re: [IC] GG60-Pro 60% Wireless Custom Kit - Renders and Price Updated
« Reply #7 on: Sun, 04 August 2019, 00:32:38 »
Looking forward to the pcb design as well! I really hope that the pcb is compatible with hhkb layout. Also, will the pcb be hotswap? please be hhkb compatible with not hotswap lol
Offline entergogo
« Reply #8 on: Sun, 04 August 2019, 01:03:48 »
Thanks for your comment! The PCB will be released around Aug 15. Unfortunately it’s not compatible with hhkb layout. The pcb will be hotswap:)
« Last Edit: Sun, 28 March 2021, 09:53:43 by entergogo »
www.entergogo.com
Reddit: u/entergogo
Offline IvarLJ
« Reply #9 on: Sun, 04 August 2019, 02:52:21 »
This fills what I consider a big gap in the market: portable, wireless & hotswap mechs. QMK support is the cherry on the top. Good job!
Having said that, 2 (hopefully constructive) criticisms:
- Why settle for Bluetooth 3 which is at least 2-3 generations old? Newer versions have less energy consumption and better/more stable links. Is it a price based decision?
- Less consequential, but at least one more color option would be appreciated. It’s a matter of personal taste, but my vote would go for silver or grey.
Cheers
Offline entergogo
« Reply #10 on: Sun, 04 August 2019, 04:30:11 »
Cheers
Thank you for your comments! Constructive for sure!
We were told Bluetooth 3.0 is more stable, new version was reported lost connection sometimes, but we will test it on our own, will updated here.
Okay, will consider add one more color option if more people like silver or grey. We will discuss this with our cooperated factory.
Many thanks!
« Last Edit: Sun, 28 March 2021, 09:53:32 by entergogo »
www.entergogo.com
Reddit: u/entergogo
Offline ericrosenfield
« Reply #11 on: Sun, 04 August 2019, 15:08:09 »
Really looking forward to this keyboard. Right now the only 60% hotswap bluetooth board I know of is the GK61S, and it’s not that great. Having something with QMK would be a dream.
Any idea when the GB will begin?
Offline entergogo
« Reply #12 on: Sun, 04 August 2019, 17:40:40 »
We were planning to start the GB around Aug 20 to Sep 10. Will keep updated here when we have the final GB date.
Cheers,
Sean
从我的 iPhone 发送,使用 Tapatalk
www.entergogo.com
Reddit: u/entergogo
Offline vicissitude
« Reply #13 on: Sun, 04 August 2019, 17:55:07 »
The wireless kit is always welcome,especially on custom keebs.
Wish it stable and respond quickly.
Offline entergogo
« Reply #14 on: Sun, 04 August 2019, 18:19:16 »
Please fill in a form if you have an interest https://forms.gle/k5vH7xjbqYUuQ48dA. You will be keep updated.
« Last Edit: Sun, 28 March 2021, 09:52:25 by entergogo »
www.entergogo.com
Reddit: u/entergogo
Offline lush_bunny
« Reply #15 on: Sat, 10 August 2019, 02:28:39 »
Love everything about this. It’ll be absolutely perfect if I could order along some orange healios but that’s just nitpicking. Will be participating in the GB.
Offline entergogo
« Reply #16 on: Sat, 10 August 2019, 09:32:40 »
Thank you for liking the GG60-Pro, which encourage us to make the product perfect! Please make sure you have filled the form https://forms.gle/k5vH7xjbqYUuQ48dA, you will be kept updated:)
www.entergogo.com
Reddit: u/entergogo
Offline lush_bunny
« Reply #17 on: Thu, 15 August 2019, 13:20:47 »
Any updates on this bad boy? Target GB date perhaps? I’ve got the perfect keycaps for this.  :)
Offline entergogo
« Reply #18 on: Fri, 16 August 2019, 00:49:01 »
Hi, GB time is still TBD, maybe the end of Aug 2019, we are hurrying up making the PCB, hopefully, we can release the PCB on Aug 24, then if everything goes smooth after testing, we will start the GB. Thank you for your patient! You will be kept updated as long as we got any progress.
Could you share me your keycaps? exciting to see:) (my email: chao@entergogo.com)
www.entergogo.com
Reddit: u/entergogo
Offline lush_bunny
« Reply #19 on: Fri, 16 August 2019, 18:23:35 »
Thanks for the fast response! Emailed you my options for this board :)
Offline ilemondrop
« Reply #20 on: Fri, 16 August 2019, 20:30:37 »
wow this looks too good to be true, I find the prices of kits to vary greatly, how do you guys get the price so low compared to other kits?
Offline entergogo
« Reply #21 on: Fri, 16 August 2019, 23:28:35 »
Thank you for your comments. Very good question!
Basically, we want to make the GG60-Pro a premium custom travel keyboard, of course, we can make it very expensive with complicated design and all trended functions. But we want to make it affordable to all mechanical keyboard enthusiasts. Here are examples of how we control the cost and make it affordable.
We make it a low profile case which is cheaper than a high profile case.
It has no back-lighting(RGB), as we thought the long battery charging circle is more important to a travel keyboard.
Another reason is we hope the GG60-Pro idea can come true, apparently, the low price is more competitive.
www.entergogo.com
Reddit: u/entergogo
Offline entergogo
« Reply #22 on: Sat, 24 August 2019, 05:19:00 »
Hey! Got new updates, please check the post when you free:)
www.entergogo.com
Reddit: u/entergogo
Offline lush_bunny
« Reply #23 on: Sat, 24 August 2019, 20:06:42 »
Looking good! Excited for September 15 !
A few questions tho:
  • How much space is there between the bottom case and the PCB? I want to put some sort of dampening foam in between to eliminate some of the reverb.
  • Do you have a list of the Gateron and Cherry Switches you’ll be offering?
  • Do you have actual pics of the red case and plate? Interested in my options.
Offline entergogo
Re: [IC] GG60-Pro 60% Wireless Mech Keyboard Kit - PCB on progressing
« Reply #24 on: Sat, 24 August 2019, 22:47:27 »
1. I'm going to check it and let you know next week.
2. Yes, will offering
Cherry MX brown, red and blue switches.
Kailh box brown and blue switches
Gateron blue, yellow and brown switches,
3. So far don't have actual pics of the case, but already request them to make samples, will update later.
www.entergogo.com
Reddit: u/entergogo
Offline macinstein
Wow, the pcb looks promising, hopefully everything comes into fruition. Just wondering, judging form the pics will the pcb be using mill max hotswap sockets or kailh sockets or will just end up a solder pcb? really appreciate what you're doing here, a barebone bluetooth kit for $100USD is almost unbelievable
Offline entergogo
« Reply #26 on: Mon, 26 August 2019, 21:37:30 »
Hi Mikko, space is 3.5mm between the bottom case and the PCB. Anything else?
www.entergogo.com
Reddit: u/entergogo
Offline entergogo
Hi, thank you for your comments:)
We use Kailh sockets.
www.entergogo.com
Reddit: u/entergogo
Offline lush_bunny
« Reply #28 on: Mon, 26 August 2019, 23:23:05 »
Thanks! None that I can think of. Just waiting for September 15!
Offline entergogo
« Reply #29 on: Tue, 17 September 2019, 09:27:18 »
Hi Mikko, new PCB is on testing, keep you updated.
www.entergogo.com
Reddit: u/entergogo
Offline entergogo
« Reply #30 on: Wed, 02 October 2019, 06:58:01 »
Cheers
Hi there, we have updated the Bluetooth version to 5.0.
Thank you for your advice. GB time is still TBD, will keep you updated.
www.entergogo.com
Reddit: u/entergogo
Offline IvarLJ
Cheers
Great to hear!
Looking forward to the GB!
Offline entergogo
« Reply #32 on: Wed, 09 October 2019, 01:25:03 »
Hi Mikko, new updates of the product, actual pics have been uploaded. Please check.
www.entergogo.com
Reddit: u/entergogo
Offline caonv
 :D nice work!
I have seen photos of the prototype. The board is neat  :thumb: From the render photos, I saw 3 led indicators in the top right corner of the case. However, those leds disappeared in the prototype.  :o
With $99, I may be too greed to the feature of remembering multi devices and switch among them smoothly.  ::)
If you can provide a HHKB layout and multi-devices, I will 100% in even when the price increased to $150 ;D
Offline entergogo
:D nice work!
Hey, thanks for your comments:)
Yes, there are still have 3 led indicators in the top right corner, you can see the PCB board, there got 3 marks, as some reasons, this plate didn't have the led holes, will light it up later.
The Bluetooth will support up to 3 devices, and you can switch among them freely.
Regarding HHKB layout, we definiately will make one if we hear enough voice. As you know, there are MOQs if we want to start a new layout. Otherwise the cost will be very very high.
www.entergogo.com
Reddit: u/entergogo
Offline caonv
:D nice work!
3 devices are enough for me  :p
Anyone who wants the HHKB layout please rise your hand  ;D
Offline lush_bunny
I love that red color <3
Offline entergogo
Great:) thank you!
www.entergogo.com
Reddit: u/entergogo
Offline Caktuss
Any updates with this?
Offline entergogo
We are still working on the PCB, we have tested two versions, and fixed some bugs, we will test the 3rd version PCB next week, if everything works perfect, then the GB will be set.
As well, based on the IC form responses, we have decided the case/plate color options, keyboard layout and MOQ for the first round GB
www.entergogo.com
Reddit: u/entergogo
Offline lush_bunny
Are you considering color options other than black/red?
Offline entergogo
Hey Mikko, only black and red for the 1st round GB, we do want to offer more color options for all friends, but from the view of a project, the most important thing is to make it rolling smoothly, not get things too complicated, so that’s our decision.
« Last Edit: Sun, 28 March 2021, 09:52:43 by entergogo »
www.entergogo.com
Reddit: u/entergogo
Offline LeoZ
Does this PCB support kailh choc switches?
Offline entergogo
Hi friend, YES, the PCB support Kailh choc switch, but have to use a 0.8mm thick plate, so far we only have 1.5mm thick plate (aluminum & brass)
« Last Edit: Sun, 28 March 2021, 09:52:52 by entergogo »
www.entergogo.com
Reddit: u/entergogo
Offline Caktuss
Re: [IC] GG60 60% Custom Travel Keyboard Kit (Prototype Photo Update Oct 09)
« Reply #44 on: Tue, 19 November 2019, 15:42:38 »
any updates?
Offline entergogo
« Reply #45 on: Wed, 20 November 2019, 06:33:49 »
any updates?
We are still optimizing the PCB, my partners told me the PCB will be ok at the end of November, I will keep you all updated.
Everything is possible, but nothing is easy! We are trying our best to make it not delay too long.
www.entergogo.com
Reddit: u/entergogo
Offline caonv
« Reply #46 on: Fri, 20 December 2019, 04:55:12 »
It's a while from the last reply. Is there any update?  ;D
Offline entergogo
« Reply #47 on: Tue, 24 December 2019, 19:31:26 »
Hey, yes, it's been quite a while. Actually, we met problems on the PCB, one of our partners can't fix it as our request, then we have to source a new partner, luckily we have found one, and they are already on the work with the PCB, hopefully we can release it within weeks. I will keep you updated!
www.entergogo.com
Reddit: u/entergogo
Offline stoffelduss
Re: [IC] GG60 60% Custom Travel Keyboard Kit (Update on Dec 25)
« Reply #48 on: Mon, 30 December 2019, 04:37:55 »
A bluetooth QMK 60% seems useful, I would consider myself interested. Would it be possible to get a special plate layout covering the bottom left and right cutouts? Would it also be possible to get case and plate in different colors? (I'd take silver for the case and black for the plate)
Edit: Remembered that I wanted to mention that I would prefer a split right shift. You could put something useful like Delete there. (Some renders have Delete in the bottom row, I think that's a really bad spot for a "destructive" function)
« Last Edit: Mon, 30 December 2019, 11:11:51 by stoffelduss »
Offline entergogo
« Reply #49 on: Mon, 30 December 2019, 18:53:47 »
Hey, thank you for your interest!
1. Sorry, the plate design is already done, I don't think we can change the plate layout covering the bottom left and right cutouts.
2. Yes, we can add more colors for the case and plate, it all depends on how many interests for the new colors.
3. For GG60, it's a standard right shift key, we will consider making a split right shift for the next project.
www.entergogo.com
Reddit: u/entergogo
