Author Topic: [IC]Go-fit60, A 60% Bluetooth 5.0 Barebones Kit, GB is in progress  (Read 65669 times)
Offline M0nk3yG0d
Re: [IC] GG60 60% Bluetooth Travel Keyboard Kit (Update on 9th Apr 2020)
« Reply #100 on: Tue, 14 April 2020, 08:37:46 »
Great! Thanks for the amazing communication. Will be placing my order when this GB is listed(already filled out the form). Any estimate on when this will drop?
Offline entergogo
    • entergogo | Typing Matters
« Reply #101 on: Tue, 14 April 2020, 20:41:29 »
We are planning to launch the GB in May, hopefully, everything can go smoothly.
www.entergogo.com
Discord link: https://discord.gg/ECErFWB
Discord name: entergogo#2512
Reddit: u/entergogo
Offline lush_bunny
« Reply #102 on: Tue, 14 April 2020, 22:18:35 »
Glad to see so much interest in this board.
Offline entergogo
« Reply #103 on: Tue, 14 April 2020, 22:26:15 »
Sorry to let you wait so long, we are hurrying up...
www.entergogo.com
Reddit: u/entergogo
Offline lush_bunny
Re: [IC] GG60 60% Bluetooth Travel Keyboard Kit (Update on April 20)
« Reply #104 on: Mon, 20 April 2020, 04:40:29 »
Just saw the update. Sad that black isn’t available anymore, but I can still make grey work. Also thanks for the switch to south-facing switches!
Offline entergogo
« Reply #105 on: Mon, 20 April 2020, 04:52:09 »
Lol, sorry for the misunderstanding, what I mean is besides black and red, maybe add one more color option.
www.entergogo.com
Reddit: u/entergogo
Offline lush_bunny
« Reply #106 on: Mon, 20 April 2020, 05:26:21 »
Okay that is much clearer thanks!
Offline Ehhrrrick
« Reply #107 on: Mon, 20 April 2020, 23:37:30 »
The PCB will still be hot swappable, correct? ;D
Offline entergogo
« Reply #108 on: Tue, 21 April 2020, 02:36:16 »
Yes, for sure, always hot-swap.
www.entergogo.com
Reddit: u/entergogo
Offline microCuts
« Reply #109 on: Mon, 04 May 2020, 21:52:52 »
Is polycarbonate case under consideration? Thanks!
Offline entergogo
« Reply #110 on: Tue, 05 May 2020, 01:28:25 »
I'm sorry, no.
www.entergogo.com
Reddit: u/entergogo
Offline Blue_Ninja0
« Reply #111 on: Wed, 06 May 2020, 10:27:41 »
I'm sorry if I've already asked any of these questions on the Discord server, but I'll post them here so that anyone can read them.
These questions are for the 2nd round group buy because I have to wait for ISO support:
1) Will there be a grey case?
2) Will there be the possibility for a high profile case?
3) Can the PCB become compatible with standard 60% cases like most PCBs do?
4) Have you decided if you're using Bluetooth 4.0 or 5.0? What are the benefits of 5.0?
EDIT:
5) Will we be able to request the keyboard with Cherry MX Silent Red switches?
« Last Edit: Wed, 06 May 2020, 10:58:49 by Blue_Ninja0 »
Offline entergogo
« Reply #112 on: Wed, 06 May 2020, 19:48:46 »
EDIT:
Yeah, I'm very glad to meet you here again. Here is the answer.
1) Will there be a grey case?  Very probably
2) Will there be the possibility for a high profile case? I don't think so:(
3) Can the PCB become compatible with standard 60% cases like most PCBs do? No one knows, maybe will compatible with GH60
4) Have you decided if you're using Bluetooth 4.0 or 5.0? What are the benefits of 5.0? I think it's 5.0, faster and greater range.
EDIT:
5) Will we be able to request the keyboard with Cherry MX Silent Red switches? Yeah, for sure
www.entergogo.com
Reddit: u/entergogo
Offline kidviddy
    • 駄日記
« Reply #113 on: Wed, 06 May 2020, 20:14:42 »
I mentioned this on the form, but when you get to the second round group buy, please consider the following on top of ISO support if you don't already have them:
1) Support for a split backspace (relatively common on 60% boards)
2) Support for a split right-shift key with the 1U on the left.  GH60, DZ60, and various other boards support this.
3) Support for a "minila" style split space key. On the original minila this is split in three with sizes 1.25, 3, 1.25.  Support for this is very rare; the only PCB I'm aware of that has it is the GH60 (the DZ60 doesn't  :()
This would be enough to offer full support for JIS layouts with keys either side of the space bar for switching between English and Japanese, which would be just awesome in a bluetooth keyboard -- I am not aware of another bluetooth PCB that offers this.  Those keys can also be useful as function keys even if you don't use JIS; see the ANSI Filco Minila for an example of them in use.
I know this may be out of scope for what you are considering but I just wanted to point it out as if you were going to add these things doing it at the same time as ISO would make a lot of sense.  We JIS users are starved of usable PCBs :(
Offline entergogo
« Reply #114 on: Wed, 06 May 2020, 21:23:34 »
Very good point, we didn't get any requirements from Japan before, we will definitely consider this.
www.entergogo.com
Reddit: u/entergogo
Offline kidviddy
    • 駄日記
« Reply #115 on: Wed, 06 May 2020, 23:05:06 »
Thanks! Even if you don’t offer it as an option for your fully-built keyboards, just having support for it in the PCB would be really helpful!
Offline entergogo
« Reply #116 on: Thu, 07 May 2020, 01:03:17 »
Yes, that makes sense, lots of thanks
www.entergogo.com
Reddit: u/entergogo
Offline IBMweMissU
« Reply #117 on: Wed, 22 July 2020, 05:30:58 »
I am SO in if this supports split backspace, split Rshift, split spacebars and stepped caps.
And definitely BLE5 !
Offline entergogo
« Reply #118 on: Wed, 22 July 2020, 21:16:18 »
Hey, thank you for reaching.
We are appreciate your advice, but the PCB is almost done, so far it's not support the layout as you mentioned.
We will consider to upgrade the PCB in future, but all depends on if the community like it or not.
www.entergogo.com
Reddit: u/entergogo
Offline entergogo
« Reply #119 on: Thu, 30 July 2020, 22:45:57 »
UPDATE coming
www.entergogo.com
Reddit: u/entergogo
Offline entergogo
Re: [IC] GG60 60% Bluetooth5.0 Travel Keyboard Kit (Update on Sep 25, 2020)
« Reply #120 on: Fri, 25 September 2020, 03:57:20 »
NEW UPDATE ON SEP 25 2020
www.entergogo.com
Reddit: u/entergogo
Offline entergogo
Heyyyy guys, we know it's been a longggg time since the last update on this discussion page. Fortunately, we are now re-starting this project right after finished up the Go-popper. Here's the update on it.
Let us know any thoughts, comments, and questions about our Go-fit60 barebones kit!
entergogo
April 2021
www.entergogo.com
Reddit: u/entergogo
Offline entergogo
entergogo
April 2021
www.entergogo.com
Reddit: u/entergogo
Offline CPU_Cartel
Do you have a list of cases the pcb supports?
Offline entergogo
Hey, as we designed our own case, so far our PCB doesn't support other cases on the market.
www.entergogo.com
Reddit: u/entergogo
Offline entergogo
This video will give you a quick walk-through on go-fit60's sound with two kinds of switches: TTC red switch and Gateron blue switch.
https://youtu.be/u-EdkMk_3IM
« Last Edit: Tue, 17 August 2021, 00:20:12 by entergogo »
www.entergogo.com
Reddit: u/entergogo
Offline entergogo
Re: [IC]Go-fit60, A 60% Bluetooth 5.0 Barebones Kit, GB is in progress
« Reply #126 on: Sun, 22 August 2021, 20:45:21 »
Hey, just notify everyone that fit60's GB is now online.
Basically, you can see all the popular features from its compact body, it has a simple design and we have tried to keep the price as low as possible. Please check the link for more details if you have an interest.
https://geekhack.org/index.php?topic=114214.0
www.entergogo.com
Reddit: u/entergogo
