Author Topic: [IC]Go-fit60, A 60% Bluetooth 5.0 Barebones Kit, GB is in progress  (Read 65673 times)
Offline stoffelduss
Re: [IC] GG60 60% Custom Travel Keyboard Kit (Update on Dec 25)
« Reply #50 on: Mon, 30 December 2019, 19:18:58 »
Hey, thank you for your interest!
1. Sorry, the plate design is already done, I don't think we can change the plate layout covering the bottom left and right cutouts.
2. Yes, we can add more colors for the case and plate, it all depends on how many interests for the new colors.
3. For GG60, it's a standard right shift key, we will consider making a split right shift for the next project.
Thanks for the reply :thumb: I just noticed that you mentioned the planned colors in the first post, didn't read properly, sorry!
« Last Edit: Mon, 30 December 2019, 19:22:17 by stoffelduss »
Offline entergogo
    • entergogo | Typing Matters
« Reply #51 on: Mon, 30 December 2019, 23:28:11 »
:D
www.entergogo.com
Discord link: https://discord.gg/ECErFWB
Discord name: entergogo#2512
Reddit: u/entergogo
Offline entergogo
Re: [IC] GG60 60% Custom Travel Keyboard Kit (Update on Dec 25 2019)
« Reply #52 on: Wed, 19 February 2020, 01:59:23 »
new update on 19th Feb 2020
www.entergogo.com
Reddit: u/entergogo
Offline lush_bunny
Re: [IC] GG60 60% Custom Travel Keyboard Kit (Update on 19th Feb 2020)
« Reply #53 on: Wed, 19 February 2020, 11:20:10 »
Filled!
Offline entergogo
Re: [IC] GG60 60% Custom Travel Keyboard Kit (Update on 9th Mar 2020)
« Reply #54 on: Mon, 09 March 2020, 05:20:07 »
NEW UPDATES :D
www.entergogo.com
Reddit: u/entergogo
Offline lush_bunny
« Reply #55 on: Mon, 09 March 2020, 13:59:59 »
Can’t open the new IC link for some reason.
Offline konstantin
  • Formerly constexpr
« Reply #56 on: Mon, 09 March 2020, 15:37:57 »
Which specific Bluetooth modules are you considering using?
Offline entergogo
« Reply #57 on: Mon, 09 March 2020, 20:31:05 »
Hi Mikko,
I just checked it, it still works for me, I'm not sure the exact reason.
But you don't need to fill out again, as it's the same form as before, never changed.
Thank you!
www.entergogo.com
Reddit: u/entergogo
Offline entergogo
« Reply #58 on: Mon, 09 March 2020, 20:38:12 »
Hey, good question, but I'm not sure the exact BT modules as I'm not total techno, I will ask my partners and then get back to you.
www.entergogo.com
Reddit: u/entergogo
Offline Sonickid15
« Reply #59 on: Thu, 19 March 2020, 01:13:39 »
Oh wow this looks great!! When will people who didn't participate in the group buy be able to buy it? If even possible.
Offline lush_bunny
« Reply #60 on: Thu, 19 March 2020, 01:19:43 »
No Group Buy yet. You can still join.
EDIT: There aren't really that many Bluetooth Customs out there, so I really hope this pushes through.
« Last Edit: Thu, 19 March 2020, 01:21:31 by lush_bunny »
Offline entergogo
« Reply #61 on: Thu, 19 March 2020, 05:05:50 »
The GB is still not open yet, you can join the IC form now, hopefully we can start the GB in April 2020, you will be notified.
www.entergogo.com
Reddit: u/entergogo
Offline lush_bunny
« Reply #62 on: Thu, 19 March 2020, 05:32:31 »
Fingers crossed!
Offline Jaltr
« Reply #63 on: Thu, 19 March 2020, 05:47:44 »
Bluetooth 5.0? Im down
Offline dommyy13
« Reply #64 on: Thu, 19 March 2020, 09:18:01 »
will ISO support be included in the initial GB?
Offline entergogo
« Reply #65 on: Thu, 19 March 2020, 20:03:04 »
Thank you for your answer:)
www.entergogo.com
Reddit: u/entergogo
Offline entergogo
« Reply #66 on: Thu, 19 March 2020, 20:04:23 »
Yes, we are testing Bluetooth 5.0, we are gonna use it.
www.entergogo.com
Reddit: u/entergogo
Offline entergogo
« Reply #67 on: Thu, 19 March 2020, 20:12:26 »
No, we will not launch the ISO layout in the initial GB.
We already know some people want ISO layout, but not as many as our expectations.
We're planning to launch the ISO layout in the second GB.
www.entergogo.com
Reddit: u/entergogo
Offline lush_bunny
« Reply #68 on: Fri, 20 March 2020, 02:39:37 »
If the first 60% ANSI run is a success, maybe you'd consider layouts too?  :)
Offline entergogo
« Reply #69 on: Fri, 20 March 2020, 02:52:47 »
Yes, for sure. ISO or HHKB, we will do a survey, then see how many votes for each one.
www.entergogo.com
Reddit: u/entergogo
Offline M0nk3yG0d
Re: [IC] GG60 60% Bluetooth Travel Keyboard Kit (Update on 9th Mar 2020)
« Reply #70 on: Tue, 07 April 2020, 15:19:18 »
If this is Bluetooth 5.0 , hotswap and USB-C, you guys can put me down for one right now.
Offline entergogo
« Reply #71 on: Wed, 08 April 2020, 03:17:21 »
Thank you for your comments, please fill out the IC form, you will be notified when the GB goes live, the GB time is still TBD.
www.entergogo.com
Reddit: u/entergogo
Offline Jaltr
« Reply #72 on: Wed, 08 April 2020, 07:00:40 »
Is there a limit to this GB?
Sent from my SM-J415G using Tapatalk
Offline caonv
« Reply #73 on: Wed, 08 April 2020, 07:44:40 »
There is no upper limit.
Offline yuki
  • sleep is for the weak
« Reply #74 on: Wed, 08 April 2020, 09:53:57 »
north facing,, oof, no thanks
Offline lush_bunny
« Reply #75 on: Wed, 08 April 2020, 10:38:15 »
Does north-facing matter if you're not gonna use LEDs anyway? Honest question.
Offline rockydbull
« Reply #76 on: Wed, 08 April 2020, 12:13:58 »
yes. its the switch housing that causes the issue on thick cherry keycaps, not the actual led (though a big one of those can also cause issues)
Offline yuki
« Reply #77 on: Wed, 08 April 2020, 18:57:59 »
Yeah, what he said, though there can still be issues with caps that are relatively thin, even 1,3mm caps can still have issues. I think the reason here for going with north facing is the large modules in the top edge of the pcb, but honestly a better layout or flipping just a few switches rather than ALL of them would've been a much better solution.
Might also be just because its meant as a lower end board and people might want to use it with shine through caps (?) but I dont think anybody would complain.
Offline rockydbull
« Reply #78 on: Wed, 08 April 2020, 21:22:51 »
I absolutely agree flipping a couple of switches is always a good compromise because usually it's just too row ones which have the least interference. I do think your theory about shine through is likely a major driving force in keeping it north.
Offline entergogo
« Reply #79 on: Wed, 08 April 2020, 22:33:28 »
Actually no limit.
www.entergogo.com
Reddit: u/entergogo
Offline entergogo
« Reply #80 on: Thu, 09 April 2020, 03:56:44 »
Thank you for your comments, we can do south-facing, let me know if you want a south-facing one.
www.entergogo.com
Reddit: u/entergogo
Offline entergogo
« Reply #81 on: Thu, 09 April 2020, 04:01:26 »
Hey, thank you for your comments. We still can do south-facing PCB boards now if really matters to you all. Please let me know.
www.entergogo.com
Reddit: u/entergogo
Offline entergogo
« Reply #82 on: Thu, 09 April 2020, 04:05:53 »
Thank you for your comments, as we are going to make the PCB board without LED light, so south-facing PCB seems a better choice if north-facing has the potential caps interference problem. Please let me know if you want it south-facing.
www.entergogo.com
Reddit: u/entergogo
Offline caonv
« Reply #83 on: Thu, 09 April 2020, 04:21:54 »
In my opinion, if you have test the issue mentioned in above comments and found no problem, you don't have to care about that issue.  :-\
Offline entergogo
« Reply #84 on: Thu, 09 April 2020, 04:34:21 »
Actually, we do have very small issues on the caps, we think it's acceptable, but the thing is we can't guarantee everyone has the same caps as us, so probably there are big issues on some thick keycaps.
www.entergogo.com
Reddit: u/entergogo
Offline rockydbull
« Reply #85 on: Thu, 09 April 2020, 07:01:33 »
South facing is always preferable because there are many people who use cherry profile keycaps. Just look at tall the south facing lcbs on the market.
Offline konstantin
Re: [IC] GG60 60% Bluetooth Travel Keyboard Kit (Update on 9th Apr 2020)
« Reply #86 on: Thu, 09 April 2020, 08:45:39 »
You should definitely switch to south-facing switches if you still have the option and the board doesn't use LEDs anyway.
Did you get a chance to ask your partners which Bluetooth module is being used?
Offline entergogo
« Reply #87 on: Thu, 09 April 2020, 22:04:44 »
Yeah, we'll make a decision if switch to south-facing on this weekend. Yes, but I haven't got an exact answer, I will keep track of this question.
www.entergogo.com
Reddit: u/entergogo
Offline lush_bunny
« Reply #88 on: Fri, 10 April 2020, 04:47:12 »
+1 for south-facing, if the issues caused by north-facing is apparent. I'm not a fan of LEDs anyway, this is gonna be part of my everyday carry.
Offline entergogo
« Reply #89 on: Sat, 11 April 2020, 01:49:08 »
No problem, we will do south-facing.
www.entergogo.com
Reddit: u/entergogo
Offline honoka
« Reply #90 on: Sat, 11 April 2020, 04:29:01 »
would this pcb fit a standard 60%? edit: just saw the cutouts in the bottom case. do you have any pictures of the modules?
« Last Edit: Sat, 11 April 2020, 04:31:11 by honoka »
Offline MdotMaxson
« Reply #91 on: Sat, 11 April 2020, 06:56:48 »
Did this already do group buy? Is this PCB able to fit into the standard 60% case? If not.... has anyone considered making a 60% PCB with Bluetooth that is a drop in to any standard 60% case?
Offline entergogo
« Reply #92 on: Sun, 12 April 2020, 22:35:42 »
GG60 case can be count a standard 60% one, but the charging port is at the left top, you can check the case photos in the post, I'm not sure if the PCB can fit your case.
www.entergogo.com
Reddit: u/entergogo
Offline entergogo
« Reply #93 on: Sun, 12 April 2020, 22:37:55 »
Not yet, the GB is still not open.
Please check the bottom case photos in the post, I'm not sure if the PCB can fit your case, please check the charging port position.
www.entergogo.com
Reddit: u/entergogo
Offline AffectionateData
« Reply #94 on: Mon, 13 April 2020, 13:06:20 »
Looking foward to it :D
Offline entergogo
« Reply #95 on: Mon, 13 April 2020, 20:28:51 »
www.entergogo.com
Reddit: u/entergogo
Offline KingOfMemes
« Reply #96 on: Mon, 13 April 2020, 21:33:38 »
Yeah I dig this. Perfect travel board
Offline M0nk3yG0d
« Reply #97 on: Tue, 14 April 2020, 01:01:19 »
Why are there 2 ports on the back of the case? Please tell me that we don’t have to charge using a separate cable.
Offline entergogo
« Reply #98 on: Tue, 14 April 2020, 01:32:24 »
One is charging(Type-C )port, you can use the keyboard like a wired when charging, another one is the power on/off.
www.entergogo.com
Reddit: u/entergogo
Offline entergogo
« Reply #99 on: Tue, 14 April 2020, 01:33:32 »
Thank you for supporting us.
www.entergogo.com
Reddit: u/entergogo
