Author Topic: Huge Stock of Non-Mechanical Keyboards. Worth Salvaging?  (Read 6832 times)
Offline Dima210
« on: Thu, 27 June 2019, 22:05:40 »
I have been slowly amassing a huge number of non-mechanical keyboards from a dumpster which keeps on giving.
Is there any use in these keyboards to the members of this forum?
Currently I'm sitting on over 40 keyboards, some with only a couple of missing keycaps.
I also have a huge number of laptop keyboards as well.
Is there something which you may find useful in them?
Do any of the members of this forum have any ideas for keeping them?
Let me know.
Offline fpazos
Re: Huge Stock of Non-Mechanical Keyboards. Worth Salvaging?
« Reply #1 on: Fri, 28 June 2019, 00:03:41 »
Yes!!!
Enviado desde mi Redmi Note 7 mediante Tapatalk
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #2 on: Fri, 28 June 2019, 01:43:33 »
Yes!!!
Joder, muy bien.
Offline fpazos
« Reply #3 on: Fri, 28 June 2019, 02:18:33 »
Joder, muy bien.
Hahahahahaha
« Reply #4 on: Fri, 28 June 2019, 08:43:30 »
artful uses
- Franklin Roosevelt 1933
« Reply #5 on: Fri, 28 June 2019, 10:31:44 »
That depends on the model. Not all rubber domes are equal. What do you have?
Key Tronic ErgoForce, BTC dome with slider, older Unix workstation keyboards,
and ergonomically shaped keyboards are some of the more interesting ones.
Some keyboards from the '80s and '90s have high-quality keycaps that are compatible with mechanical switches, so those are in demand for that reason. But don't expect to get any large sums for them.
Notebook keyboards would be interested mostly as spare parts. I believe they tend for wear out faster than desktop keyboards, and they are often more difficult to clean properly.
On the other hand, different collectors are different, and what is hyped up tends to shift with time.
As always with (things that could be) collectibles, it is often a question of finding the right buyer at the right time.
« Last Edit: Fri, 28 June 2019, 10:35:04 by Findecanor »
