Author Topic: Topre Clone Wobble Help  (Read 2773 times)
Offline Mr.Elli0t
« on: Tue, 16 July 2019, 08:26:55 »
So I just received the Archon RE:AL and absolutely love the keyboard, feel, and sound. But I noticed there's a lot of wobble on the keycap sliders and was wondering if there was anyway to limit it?
Offline swedishpiehole
Re: Topre Clone Wobble Help
« Reply #1 on: Tue, 16 July 2019, 12:30:03 »
Thick lube on the rails where the sliders touch the sides would definitely help. I did this on my HHKB which I found very rattly. I don't know if silencing rings can help with wobble, but you might want to throw some in there while you are lubing because they can really help with the sound of Topre switches.
Offline Mr.Elli0t
« Reply #2 on: Wed, 17 July 2019, 09:44:33 »
Thanks! I got some silencing rings just haven't put them on yet, and was hoping they would help with the wobble, as for the sound I love the way it sounds right now, but I may lube a few and try them out to see how the sound changes and how I like it. I'll probably do that when I get the 55g domes and make a day of modding out of it.
« Reply #3 on: Wed, 17 July 2019, 10:56:06 »
If you like the sound I suggest holding off on the silencing rings. It's a good idea to try lubing a few switches with one of the thicker lubes (make sure to search here and on r/mechanicalkeyboards to find recommendations for Topre-comptaible lubes) to see if that helps the wobble.
Offline Zuology
  • Why does this rabbit-hole have so many side-quests
« Reply #4 on: Wed, 17 July 2019, 14:03:12 »
The Nopre switches in the Archon are already silenced with "dental band" style rings. If you are talking about the topre-style thing foam disc rings, IDK about their compatibility with the Nopre sliders. If you are using tall key profiles like SA, wobble will be pronounced, with low profile keysets minimizing wobble.
75%: Scarlet Bandana (TBD) | Singa75 Polycarb (TBD) | SKB75 (TBD) | YMD75 (Box Navy) | XD84 (Outemu Ice) | Plum84 (BKE Redux Heavy)
TKL: ALF X1.1 SE (TBD) | LZ Iron White (TBD) | Fox Labs Orange (TBD) | Alu WASDv2 (Cherry Green) | MechkeyAlpha MA87 (Kailh Box Burnt Orange) | Archon RE:AL Superior EX (Nopre 65g)
Full+: Clueboard Double 1800 (Vint Clears) | IBM Model M | IBM Model F XT
