Author Topic: QMK Flashing Help  (Read 3725 times)
Offline rxc92
QMK Flashing Help
« on: Fri, 19 July 2019, 09:45:13 »
So I just got my Tina C in the mail and have tried setting it up; however, the Fn layer doesn't appear to be functioning. Does anyone know how to flash a new layout so that the Fn layer works using QMK, or is there a better solution? I was hoping to flash it to a standard HHKB layout, as I've used it before.
Offline clasicks
  • Formerly KeyboardUser4
Re: QMK Flashing Help
« Reply #1 on: Fri, 19 July 2019, 10:16:32 »
Hello - Tina C is a case style - they can house many different PCBs as it has a universal 60% tray mount setup.
Do you have any more information on what PCB is in it?
Did you buy it prebuilt from KBDfans, did you build it, did you buy from someone who built it?
Offline rxc92
« Reply #2 on: Fri, 19 July 2019, 10:21:17 »
Is that so.. I bought it prebuilt from KBDfans, so using their own PCB I assume... in the meanwhile I attempted to flash it to a different layout using QMK toolbox and it seems to have been rendered unusable. Is there any way to fix that?
Offline clasicks
« Reply #3 on: Fri, 19 July 2019, 10:27:21 »
I am not up to date with what they put in them for a PCB - maybe a DZ60 or KBD6X?
Here are some instructions provided by KBD fans https://kbdfans.com/pages/qmk-instructions (http://qmkeyboard.cn/)
You may be able to find the correct hex and try to flash it again - I am not certain what you did when you "flashed" it with whatever you did.
You can take out the PCB and there will be a name on it somewhere
Offline rxc92
« Reply #4 on: Fri, 19 July 2019, 11:02:55 »
I've got it disassembled and it's a DZ60 Rev 3 PCB from comparison; however, without a physical reset switch. If what I'm reading is correct, I should connect the two pinholes labeled 'reset' using a clip or tweezers while plugged in?
Offline rxc92
« Reply #5 on: Fri, 19 July 2019, 11:09:01 »
Update: Completely fixed it, I just connected the reset and was able to reflash it to the desired layout successfully via GMK toolbox. First time taking apart a keyboard, was damn scared it was going to break!
Offline clasicks
« Reply #6 on: Fri, 19 July 2019, 11:15:09 »
fantastic - sorry I missed your last post - glad you were able to work it out!
you learn to LOVE this kind of troubleshooting, every board seems to have its unique quirks...
Offline rxc92
« Reply #7 on: Fri, 19 July 2019, 14:57:51 »
Honestly, you're right! Outside of the fear of having completely crapped my brand-new keyboard, the whole disassembly, learning something about the PCB design, figuring out drivers and QMK let me understand my keyboard a lot better. And after spending ten minutes fiddling with screwing back in the internal screws, it made me respect how well put together it is compared to most commercial stuff. Thanks for the encouragement!
