Author Topic: [IC] KAT Milkshake (Group Buy from 09/02 to 09/30)  (Read 228287 times)
Offline bobgr8
Re: [IC] KAT Milkshake (Group Buy from 09/02 to 09/30)
« Reply #300 on: Fri, 30 August 2019, 11:03:20 »
could you confirm, that there is no conflict with any north facing switches? Thanks!
Offline norb
« Reply #301 on: Fri, 30 August 2019, 11:25:23 »
prices are neat :thumb:
but one question, of course that's not up to you but maybe you have an idea why there's an MOQ for the blanks? i mean, they're literally the base for all the kits since it's dyesub and are less production steps, so from my perspective there shouldn't be an MOQ^^
Offline Adelscott
« Reply #302 on: Fri, 30 August 2019, 12:59:13 »
Forgive me for the question I'm going to ask, I'm new to this field. If I order X kits but only Y reach the MOQ, what happens? My order is abandoned ? I receive Y kits ? And if in missing kits there is one indispensable for me ?
Please think about ISO users, add a split left shift to your "alice style" keyboards
Offline Tequila_Heineken
« Reply #303 on: Fri, 30 August 2019, 14:06:41 »
You should ask the vendor you buy from that question, but usually they will ask you if you want to stick with your order or cancel it I think.
Offline tanya22f
« Reply #304 on: Fri, 30 August 2019, 18:15:43 »
Is it possible for the kits to sell out before the end of the group buy? what i mean is, is better to buy what i want as soon as it up for sale or i can take my time (up until the 30 of september that is)
thank you
Offline foxlive
  • The quick brown fox jumps over the lazy dog
« Reply #305 on: Fri, 30 August 2019, 21:56:25 »
Hum, it miss some render with katakanas. I don’t know if I only go with alpha, or if I also add katakanas or weirdos ! Definitely first world problem here!
Offline alanskiii
« Reply #306 on: Sat, 31 August 2019, 01:59:33 »
Lol same! They all look soo good!
Offline eskimojo
    • KeycapLendar
« Reply #307 on: Sat, 31 August 2019, 02:15:28 »
thank you
You can take your time, kits won't sell out. The only limit on buying is the group buy period.
Offline biip
    • @biipmk
« Reply #308 on: Sat, 31 August 2019, 04:26:04 »
Can confirm that there will be no conflict with north facing switches.
The walls of the keycaps will not hit the switch ;)
Offline koshi
« Reply #309 on: Sat, 31 August 2019, 06:32:18 »
Not sure about KAT, but in other profiles, PBT has always been rougher.
PBT can be smooth or even shiny. KAT is quite smooth and matte, with a slight chalky texture.
Thats great to hear. I wasn't aware of that, so texture of keycaps is part of the profile?
Offline Surefoot
« Reply #310 on: Sat, 31 August 2019, 06:44:58 »
Yes it is. The mold determines which kind of texture you get. For instance KAM profile is very smooth and shiny. DSA is quite grainy... XDA is in-between, while XDAS and KAT are matte smooth.
Offline The_Royal
  • That's what I call, a Sunday.
« Reply #311 on: Sat, 31 August 2019, 07:23:17 »
I still have yet to find the reason for this but does anyone know why KAT and KAM have Different textures and finishes even though KAM is just Uniform Row-3 KAT.
Do they use different factories?
Offline Surefoot
« Reply #312 on: Sat, 31 August 2019, 09:44:05 »
They just use different molds.
Offline bobgr8
« Reply #313 on: Sat, 31 August 2019, 17:53:16 »
Thank you! definitely in!
Offline Rise
  • Trying to Give back to Community
« Reply #314 on: Sat, 31 August 2019, 19:18:40 »
Just another sexy set from Biip in a new profile, what else is new?
Offline KevinSanToast
« Reply #315 on: Sat, 31 August 2019, 19:47:47 »
So are any of the rows the same sculpt, or are they all unique? Like for sculpted SA, R2 and R4 are essentially the same sculpt except flipped. Is that the case with any rows for KAT?
Offline PocketAces
« Reply #316 on: Sat, 31 August 2019, 23:36:00 »
Have you thought about turning the deskmat graphics into something that could be used as a desktop wallpaper?
Ideally, it would be a design with the same cues as the mats you already have, but is still something unique enough to stand alone on someone's monitor.
Also, someone may have already mentioned this, but is there the possibility of getting some custom cables to fit the design too?
I'm definitely in on this set and mousemats though! Looks incredible!
Offline Surefoot
« Reply #317 on: Sun, 01 September 2019, 04:15:09 »
I think two of the rows (r3 & r5) are the same flipped over:
Now looking at it closely, it's not the case, the side wall profile is different.
« Last Edit: Sun, 01 September 2019, 04:17:04 by Surefoot »
Offline bobgr8
« Reply #318 on: Sun, 01 September 2019, 06:15:16 »
his epbt 2048 has started shipping, so that's new
« Reply #319 on: Sun, 01 September 2019, 07:41:41 »
Ah yeah. But R2 and R4 look the same. Good to know, thanks!
Offline Surefoot
« Reply #320 on: Sun, 01 September 2019, 08:20:47 »
Thought the same at first, but look closely, the front wall is more sharply curved than the back wall. So while the key top is symmetric, the side walls are not.
« Reply #321 on: Sun, 01 September 2019, 11:29:16 »
Good eye! You are absolutely right.
Offline clarisssssaa
« Reply #322 on: Sun, 01 September 2019, 13:46:47 »
Not sure if I just missed it, but do you have the pricing for the deskmats? And I also agree it would be nice to have matching cables ;D
Offline MdotMaxson
« Reply #323 on: Sun, 01 September 2019, 14:18:43 »
I have been dying to know this too
Offline tanega
« Reply #324 on: Sun, 01 September 2019, 15:18:19 »
Are the 2u in ortho kit convex ?
Offline mgsickler
« Reply #325 on: Sun, 01 September 2019, 15:46:12 »
Deskpads will be $14/deskpad on my site plus shipping.
But we won’t have these up until we receive samples from the manu.
Offline Frosttenchi
« Reply #326 on: Sun, 01 September 2019, 22:52:30 »
Probably a silly question:
Does the M6-C come with keycaps? Cable? It looks like other versions do from Rama, but most aren’t “e” coated.
Offline Adelscott
« Reply #327 on: Mon, 02 September 2019, 01:47:51 »
Live on novelkeys but no proxy at the moment. I hope nothing bad happened !
Offline Hell-es
« Reply #328 on: Mon, 02 September 2019, 02:16:30 »
also already waiting for the listing on candykeys...
... David - wake up  :cool:
Offline biip
    • @biipmk
« Reply #329 on: Mon, 02 September 2019, 02:24:17 »
It's coming!
Offline foxlive
« Reply #330 on: Mon, 02 September 2019, 03:34:58 »
It's coming!
The hype is high! Can't wait to see this on candykeys !
Offline bobgr8
« Reply #331 on: Mon, 02 September 2019, 03:51:48 »
pricing live on Zfrontier, but no desk mats yet
Offline biip
    • @biipmk
« Reply #332 on: Mon, 02 September 2019, 03:52:41 »
Deskmats will be available later!
Offline tanega
« Reply #333 on: Mon, 02 September 2019, 04:19:09 »
The struggle between: Weirdo Vs. Alphas + Colemak is kiling me  :-\
Offline biip
    • @biipmk
« Reply #334 on: Mon, 02 September 2019, 04:20:19 »
Get all of em :>
Offline foxlive
« Reply #335 on: Mon, 02 September 2019, 04:27:57 »
Get all of em :>
Make it rain!  :cool:
Offline lush_bunny
« Reply #336 on: Mon, 02 September 2019, 04:31:18 »
GB live on zFrontier for the Asian market let’s ******* goooo.
Offline Adelscott
« Reply #337 on: Mon, 02 September 2019, 04:34:16 »
Hurry candykeys ! Brexit is coming
Offline biip
    • @biipmk
« Reply #338 on: Mon, 02 September 2019, 04:38:44 »
Candykeys will be live at 5pm CEST
Proxies
I'll update the url very soon™.
Novelkeys US:
DailyClack Oceania:
Candykeys EU:
zFrontier EN Asia:
zFrontier CN Asia:
Offline tanega
« Reply #339 on: Mon, 02 September 2019, 05:16:26 »
I think you'll be good as you will pay the intracom VAT before Brexit.
Offline foxlive
« Reply #340 on: Mon, 02 September 2019, 05:24:11 »
Brexit  :))
Offline BuildSteady
« Reply #341 on: Mon, 02 September 2019, 06:50:37 »
When are deskmats going up
Offline biip
    • @biipmk
« Reply #342 on: Mon, 02 September 2019, 07:04:10 »
Later. I want to receive the prototypes first before running the GB.
Offline guzzi
« Reply #343 on: Mon, 02 September 2019, 09:38:38 »
Live. Sorta.
« Last Edit: Mon, 02 September 2019, 09:40:33 by guzzi »
Offline Cyrille0815
« Reply #344 on: Mon, 02 September 2019, 10:35:50 »
Live. Sorta.
Ergo, Intl and others still not online at Candykeys...
Hope it will come...
Offline mrpetrov
« Reply #345 on: Mon, 02 September 2019, 10:40:51 »
In! I went for alphas, mods, specialty, fruit and dots. Thanks for making this happen biip.
Offline biip
    • @biipmk
« Reply #346 on: Mon, 02 September 2019, 10:45:05 »
Live. Sorta.
He's working on it!
Sorry :thumb:
Offline norb
« Reply #347 on: Mon, 02 September 2019, 11:42:22 »
blanks bois unite! get to ze 50 MOQ :thumb:
is there an estimated shipping date already? more like GMK or SP lead time?
Offline Adelscott
« Reply #348 on: Mon, 02 September 2019, 12:51:25 »
Live. Sorta.
He's working on it!
Sorry :thumb:
Candykeys devs seem to be struggling, group buy page is still missing.  :D
It's not easy to deliver in production while a horde of thousands baguette guys is waiting in line. (I hope I'm not wrong about the numbers  ;D)
« Reply #349 on: Mon, 02 September 2019, 12:59:22 »
Can this be added on to our order after or do we have to pay for the shipping again or should we just wait to order everything together??
