Author Topic: [IC] KAT Milkshake (Group Buy from 09/02 to 09/30)  (Read 228280 times)
Offline msting
  • Don't Panic!
Re: [IC] KAT Milkshake
« Reply #100 on: Thu, 01 August 2019, 22:35:54 »
I'm so in!  :p
Colevrak, Ergo and Fruit, Oh My!
Offline m00t0nz
« Reply #101 on: Thu, 01 August 2019, 22:52:42 »
100% in on this. Don't like dsa profile, but this is something I can get behind. I'm really liking the number of kits offered too.
Offline spooknik
« Reply #102 on: Fri, 02 August 2019, 02:15:05 »
It's not DSA profile. It's KAT profile.
Offline lakeboredom
« Reply #103 on: Fri, 02 August 2019, 02:32:53 »
Are the legends blue or black? Every other renders look different to me.
Offline biip
    • @biipmk
« Reply #104 on: Fri, 02 August 2019, 04:47:37 »
Have you ever considered those in other colorways too?
Milkshake has to be white with colored accents. I thought about adding orange novelties and colored accent for caps lock etc. but the kits are massive enough imo.
I'm definitely in for this. After hearing how nice KAT profile sounds and feels, i've been waiting for a KAT set anxiously. This set looks great, can't wait, any idea when this will go into GB?
September :D
Like DSA Milkshake, blueish dark grey :thumb:
Quick fix on the nomad kit btw!
« Last Edit: Fri, 02 August 2019, 04:49:57 by biip »
Offline terrad
« Reply #105 on: Fri, 02 August 2019, 05:34:18 »
I'm so in for this! Would it be possible to add a colored tab key so that we can have all colored mods with standard/hhkb layout? That's the only key that doesn't have a colored variant in any of the kits. And maybe add a colored caps lock too but using a colored ctrl in its place is no big deal either.
Offline harlekein
« Reply #106 on: Fri, 02 August 2019, 06:43:31 »
I'd love a colored tab for ortho as well, but it's probably not part of the original vision.
Offline biip
    • @biipmk
« Reply #107 on: Fri, 02 August 2019, 09:35:54 »
Another update on the nomad kit. Huge thanks to the 40% Keebs Discord Community <3
Offline harlekein
« Reply #108 on: Fri, 02 August 2019, 10:05:05 »
For Preonic like keyboards you may want to add R1 ESC to Nomad.
But I really hope you will split ortho off in its own kit. Nomad is getting so huge I'm starting to fear the price. Please have a look at SA Laser for an example. It has a good separate ortho and 40s kit.
« Last Edit: Fri, 02 August 2019, 10:08:17 by harlekein »
Offline Vireca
« Reply #109 on: Fri, 02 August 2019, 12:49:47 »
Yes, maybe you have to separate 40s/5os and Ortho. For someone who want to buy base kit+ortho, having 2 6.25u space bars is really meh
Offline dibkib
« Reply #110 on: Fri, 02 August 2019, 17:07:33 »
Glad to see this come back, I am in!
Offline CandyKeys
  • Just doing EU things.
    • CandyKeys EU MK Store
« Reply #111 on: Fri, 02 August 2019, 19:36:17 »
Hate to poop on the parade, can we get a 1.5 R0/R1 ESC?
The CandyKeys Mechanical Keyboard Store
Offline biip
    • @biipmk
« Reply #112 on: Sat, 03 August 2019, 09:32:05 »
This mold also doesn’t exist. I will have to check that with Keyreative.
Offline kenkaneki
« Reply #113 on: Sat, 03 August 2019, 10:22:20 »
need this
Offline thelaughingman
  • Simultaneously the most starry-eyed idealist and t
« Reply #114 on: Sat, 03 August 2019, 13:57:04 »
I see KAT, I love it! I see Weirdo Alphas, I have to buy it!
Weirdo + Mod + Calc for me for sure  :thumb:
Offline Moshi0
« Reply #115 on: Sun, 04 August 2019, 17:54:25 »
Would it maybe be feasible to make separate flat KAT kits for ergo (or people that want flat profile)? Like flat versions of alphas/wierdo/fruits etc.
It would create duplicate kits to handle but maybe it would be cheaper than manufacturing the molds.
Or are the molds the only solution?
TBH i would buy every kit if they were flat, even if I would not use it. Makes it easy to switch to another keyboard in the future.
Offline xkhol
« Reply #116 on: Sun, 04 August 2019, 18:04:17 »
Wasn’t there a 1.5u backspace previously?
Offline eskimojo
    • KeycapLendar
« Reply #117 on: Sun, 04 August 2019, 18:04:53 »
KAT doesn't have any flat keys, the flat version is KAM (which is shiny)
Offline m00t0nz
« Reply #118 on: Sun, 04 August 2019, 18:47:27 »
I know... that's why I can get behind this set. The original milkshake was made in dsa profile
Offline Moshi0
« Reply #119 on: Sun, 04 August 2019, 19:09:07 »
Yes, KAM would be preferred but you could use KAT R3 it would be just slightly off center.
Doubt you could feel/see that it unless looking for it.
Offline biip
    • @biipmk
« Reply #120 on: Mon, 05 August 2019, 01:12:01 »
Then I would have to create duplicates alphas and other child kits with flat row disposition too then. I don't think that it's the best solution.
Offline Vireca
« Reply #121 on: Mon, 05 August 2019, 05:09:30 »
I thought KAT was also shiny, it isnt?
Offline eskimojo
    • KeycapLendar
« Reply #122 on: Mon, 05 August 2019, 05:10:57 »
Nope, KAT is matte.
Offline PacoVelobs
« Reply #123 on: Mon, 05 August 2019, 09:35:05 »
I'm in for the base and baguette!
Thanks @biip
Offline biip
    • @biipmk
« Reply #124 on: Tue, 06 August 2019, 03:33:30 »
Thanks @biip
Raise the 🥖
I should get the pricing of the kits soon btw :thumb:
Offline Bubblegum
« Reply #125 on: Tue, 06 August 2019, 04:20:16 »
No chance to have weirdo support for the international kit, right? I am in either way!
Offline harlekein
« Reply #126 on: Tue, 06 August 2019, 04:46:17 »
It's biip's call. I am wondering how many weirdo vs regular alphas DSA Milkshake sold. I am thinking maybe weirdo should be considered default and modifier kits branching off that instead of regular alphas.
At least that would be my preference. Any chance for a poll?
Offline biip
    • @biipmk
« Reply #127 on: Tue, 06 August 2019, 04:49:23 »
A solution would be to do a Mono-Legend kit as I did with DSA Milkshake.
Offline Ares2105
« Reply #128 on: Tue, 06 August 2019, 06:11:29 »
Since this is my first keyset gb, what do I need for a full-sized keyboard?
Is weirdo, modifiers, fruits (obviously!) and calc kit enough?
Offline biip
    • @biipmk
« Reply #129 on: Tue, 06 August 2019, 06:19:14 »
If you don't have an uncommon layout, yes
Offline cspirou
« Reply #130 on: Tue, 06 August 2019, 08:24:53 »
Very happy to see a Mac compatible AZERTY keycap set. This is going to be good
Offline harlekein
« Reply #131 on: Tue, 06 August 2019, 08:51:15 »
That would solve it for the international kit, but I was also thinking about Colevrak (and Baguette). Since Numpad was already extended, I am just wondering if most people are going for Weirdo or regular alphas. I said it before, but I think a great part of the identity of this kit are the Weirdo alphas.
Offline Tequila_Heineken
« Reply #132 on: Tue, 06 August 2019, 09:00:38 »
I don't like Weirdo personally and I think the identity of the set is its font.
Offline harlekein
« Reply #133 on: Tue, 06 August 2019, 09:21:11 »
The identy is colors, mod legends, font, etc.
So part of the identity is definitely the font.
The appeal of that part is subjective.
But do you intend to buy other layout kits besides mods and regular alphas? If not, it shouldn't really matter to you what the extended layout kits are based upon.
Offline tygr
« Reply #134 on: Tue, 06 August 2019, 10:15:51 »
down! hard choice between regular and weirdos though.
between olivia++ and milkshake, i just might be able to own the two keysets that brought me into this hobby!
Offline cowise
« Reply #135 on: Tue, 06 August 2019, 11:13:11 »
Excited for this! I skipped on DSA and have been envious of the sets my friend got. I'll definitely hop in on this to toss on my Tokyo60. Any chance of ergo mods?
Offline biip
    • @biipmk
« Reply #136 on: Wed, 07 August 2019, 02:23:22 »
I'm waiting to get the quote for ergo molds.
Offline Ramsus
« Reply #137 on: Wed, 07 August 2019, 04:11:20 »
Hi! I'm a long time lurker but I created this account to say that I'm pretty hyped for a KAT azerty keyset!
I just wanted to point out that the default character on the "8" key of the numrow on the azerty layout is an underscore (instead of the backslash). Not sure if this is intentional?
Anyways love the set and gl!
Offline harlekein
« Reply #138 on: Wed, 07 August 2019, 04:18:12 »
I just want to point out that Nomad now extensively covers 40%, but not common ortho.
For that R1 ESC is needed as well as two blank 1.5u keys.
Offline biip
    • @biipmk
« Reply #139 on: Wed, 07 August 2019, 04:56:40 »
and a R2 1u Tab then.
I won't add the 1.5u blanks tho I think, the kit is massive enough.
Offline Synergist
« Reply #140 on: Wed, 07 August 2019, 05:15:42 »
I would buy this set in a heartbeat if there was an option to make backspace and enter pink/purple/blue so I wouldn't have to use green/yellow.
Offline harlekein
« Reply #141 on: Wed, 07 August 2019, 05:39:36 »
I agree, which is why I think ortho should be separate.
Offline norb
« Reply #142 on: Wed, 07 August 2019, 12:13:06 »
i'm really interested in this, but just to confirm, the caps are be pretty white yeah? i've seen some pictures of dsa milkshake and some of them seem a bit beige, but that may be strongly depending on the lightning. i have a picture in my head and white caps play a big role in it.
this will also be my first KAT set, so even if the color may not fit a 100%, either way i'm in to try the profile :thumb:
Offline tiengalaxy
  • Life for art.
« Reply #143 on: Wed, 07 August 2019, 12:32:16 »
Awesome!
Offline JamesEdSmith
« Reply #144 on: Wed, 07 August 2019, 13:32:55 »
Would you ever consider doing a weirdo set that still had the additional symbols on the number keys and punctuation keys, etc?
Offline Tre3Cycl3S
« Reply #145 on: Wed, 07 August 2019, 15:10:26 »
Very interested!
QFR           HHKB Pro-2     JD45         VE.A                    XMIT 61-Key       JD40 Mk.II                    Realforce 87U     M65-A                 Custom:Annie      NightFox      Pearl                  E6-V2 R2                          Norbaforce
MX Blue     45g Topre        MX Blue     R5 67g Zealios     50g Hall Effect     Modded Gateron Red     55g Topre           R5 78g Zealios     62g Ergo Grey     Hako True     R9 62g Zilent     Lubed Holy Trash Panda     OG Sony BKE Domes
Offline biip
    • @biipmk
« Reply #146 on: Thu, 08 August 2019, 02:35:29 »
I'll work on that today :thumb:
Default (base) white.
Nope, Weirdos have to be mono-legends.
Offline harlekein
« Reply #147 on: Thu, 08 August 2019, 02:51:54 »
Awesome! Thanks for listening. That means I am 100% in for a couple of kits!
Offline biip
    • @biipmk
« Reply #148 on: Thu, 08 August 2019, 02:55:13 »
I check with the 40% community and decided to add even more keys, so it just makes sense to split it.
Offline biip
    • @biipmk
« Reply #149 on: Thu, 08 August 2019, 10:27:09 »
Update  :thumb: :thumb:
« Last Edit: Thu, 08 August 2019, 10:54:56 by biip »
