Author Topic: [IC] TGR 910 PCBs and Plates  (Read 60519 times)
Offline futurecrime
  • Get Zooted
Re: [IC] TGR 910 PCBs and Plates
« Reply #100 on: Fri, 10 January 2020, 08:12:35 »
Going to be finalizing plate files and checking things over this week.
GB most likely next week or the week after.
Hype. Can't wait for a poly plate and extra PCB.
Same same. It's about time my 910s got some fresh guts.
Offline reconsiderit
  • I'm actually not left handed www.switchplate.co
« Reply #101 on: Wed, 15 January 2020, 03:40:26 »
Going to proto before running the GB. Got the files today and sending them to JLC tonight. Should get them soonish to confirm everything works
Southpaw 65 || Southpaw Full Size || Trinity XT TKL || TGR Jane V2 || TGR 910 RE || Duck Jetfire || Matrix Lab 1.2 OG || Jubi || Lunar || Lunar II || g80-1800 HEU
switchplate.co
« Reply #102 on: Fri, 17 January 2020, 00:28:43 »
« Reply #103 on: Fri, 31 January 2020, 21:07:25 »
Small delay on the proto. CNY Extended a week as many of you guys know. Proto should be in my hands about mid February
switchplate.co
Offline Solotov
« Reply #104 on: Fri, 31 January 2020, 22:07:17 »
Will you provide half plate as well?
Flex is love, flex is life.
« Reply #105 on: Sat, 01 February 2020, 21:29:55 »
From the responses I've gathered from both the forms, I'll most likely be doing a poly full plate and a coated full brass plate.
switchplate.co
« Reply #106 on: Mon, 24 February 2020, 19:29:41 »
PCBs are finally headed to me. Should be able to test them and get the GB set up by the end of next week.
Edit: I'll also have 4 extras from the proto run available immediately (if they work) if anyone is in dire need of one of these.
switchplate.co
Offline lamenthe
« Reply #107 on: Fri, 03 April 2020, 01:17:00 »
If it's not too late I'd love to grab one of those proto boards. My current 910 has been out of commission for a few months due to a dead board. Let me know if there's one available! I'm still in for the group buy either way.
Offline oldcat
  • 65% is Life
« Reply #108 on: Fri, 10 April 2020, 15:00:38 »
great
« Reply #109 on: Tue, 23 June 2020, 21:28:45 »
any updates?
TGR Jane V2 | TGR Alice | TGR Police | TGR 910 RE (Polycarbonate) | OTD Mini | Matrix 2.0 OG Pink | Lin Dolinger RE (Polycarbonate) | Lin Dolphin |
« Reply #110 on: Wed, 01 July 2020, 19:56:26 »
Redid the plate this morning. Will be submitting for a quote tonight and should have the GB started soon. GB will be a month long.
Plate materials will be 1.5mm black anodized alu and 1.5mm polycarbonate. I may add brass but have to look at prices and MOQ from the factory. These will be cut with a 0.5mm radius so your fingers won't hurt once you've finished putting the board together.
Edit:
Realized that I never posted a pic of the PCB. I'm putting it together this week and throwing it into my 910 to make sure it fits.
« Last Edit: Wed, 01 July 2020, 20:02:41 by reconsiderit »
switchplate.co
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #111 on: Wed, 01 July 2020, 20:18:20 »
Yes please.
Offline zekkin
  • my entire life was unlimited zekk works
« Reply #112 on: Wed, 01 July 2020, 20:26:37 »
Please and thank you!!!
Offline lamenthe
« Reply #113 on: Wed, 01 July 2020, 23:46:41 »
Thank you!
Offline vegs
« Reply #114 on: Thu, 02 July 2020, 03:50:09 »
No hope for iso support?
hhkb 4 life
buy less
Offline finalarcadia
« Reply #115 on: Sun, 05 July 2020, 22:14:15 »
Is it just me, or is that left shift stab on the PCB north facing? Should be south no?
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #116 on: Sun, 05 July 2020, 22:35:23 »
Good observation - that seems like a mistake - it should be
- south-facing left shift and backspace
- north-facing enter
« Reply #117 on: Tue, 07 July 2020, 02:59:16 »
Nice catch. I was just putting it together and realized at the last moment that something wasn't quite right. Good thing that was caught. Back into fusion the plate goes.
« Last Edit: Tue, 07 July 2020, 03:01:31 by reconsiderit »
switchplate.co
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #118 on: Tue, 21 July 2020, 00:10:59 »
Ne updates or did Fusion crash?
« Reply #119 on: Wed, 22 July 2020, 17:09:14 »
Heh, fusion crashed while tryna push the stab cutouts forward and backwards to make room
Just finished setting up shopify for this and got quotes back from a few places for the plates. Should be ready to launch very soon.
switchplate.co
« Reply #120 on: Wed, 22 July 2020, 21:50:39 »
Just got a 910 so really looking forward to buying a couple pcbs or more :thumb: Hope you'll fix the stab on the PCB as well, not just plate
« Reply #121 on: Sun, 26 July 2020, 02:09:48 »
Stab issue was just an issue with the plate. The PCB is fine.
PCB is getting requoted since it's been ages. GB should be ready very soon.
switchplate.co
« Reply #122 on: Sun, 26 July 2020, 03:12:50 »
It all depends on the plate of course. Just saying that if left shift remains north facing in the PCB, it won't work with original plates which are all south facing.
Sent from my Pixel 3 using Tapatalk
Offline Yeoh
« Reply #123 on: Sun, 09 August 2020, 16:31:44 »
Really looking forward to this!
« Reply #124 on: Mon, 10 August 2020, 06:00:30 »
PCB will be fixed to south facing left shift
switchplate.co
Offline fleeceman
« Reply #125 on: Mon, 10 August 2020, 15:39:27 »
Interested
« Reply #126 on: Wed, 12 August 2020, 00:21:13 »
Starting the GB this weekend or on Monday of next week. Gonna run for 3 or 4 weeks. Need to work out the exact numbers but PCBs will be 45ish. Plates will be offered in the universal layout; similar to the stock 910 plates, but without split space compat and without iso compat. Will have PC, black anodized aluminum, and coated brass plates available.
switchplate.co
« Reply #127 on: Wed, 12 August 2020, 01:03:49 »
Whoot!
« Reply #128 on: Mon, 17 August 2020, 22:47:20 »
we ready to go!?!?
« Reply #129 on: Tue, 25 August 2020, 00:05:28 »
and we're live
https://switchplate.co/collections/910-plates-pcbs
Will close this thread and move it into GB shortly.
switchplate.co
Offline fleeceman
« Reply #130 on: Wed, 26 August 2020, 11:39:47 »
$51 to ship a PCB and plate to the UK? That's far too much. I've shipped 2kg keyboards from across the world for cheaper than that.
Sent from my Pixel 3a XL using Tapatalk
« Reply #131 on: Wed, 26 August 2020, 15:46:51 »
It should show DHL as the only option right now. Pricing for DHL starts at 40-45 dollars or so due to covid. 51 does sound a tad high. I'll see if I can get product dimensions put into the system to maybe bring it down a little.
I've gotten a few emails regarding USPS. I'll make it an option, but please know that these are untracked and I've had packages go missing on me. USPS First Class should put you around the $15-20 mark for a plate and PCB. Should be available tomorrow or Friday once I've sorted a couple things out.
switchplate.co
« Reply #132 on: Thu, 27 August 2020, 03:31:20 »
Updated shipping for international customers. Manually calculated and played around with prices so they're a little lower now. Also added USPS first class.
switchplate.co
Offline fleeceman
« Reply #133 on: Thu, 27 August 2020, 04:27:53 »
Thank you for this, just placed an order for a PCB and plate!
« Reply #134 on: Thu, 27 August 2020, 17:41:59 »
@reconsiderit - Are you shipping these out from CA, or is it being shipped directly from the factory to us?
« Reply #135 on: Fri, 28 August 2020, 19:00:57 »
I'm shipping these out from CA. I'm not sure why it's giving a couple people sky high shipping prices.
I'm not able to input package sizes into shopify so it goes off of weight. I've weighed the PCBs and plates prior to putting them into the website and they're fairly light. If you're getting high shipping prices, please shoot me an email at mill@switchplate.co and I'll see what I can do to sort it out.
switchplate.co
« Reply #136 on: Fri, 28 August 2020, 19:10:41 »
Edit -  I've just done the same thing for domestic rates. USPS seems to max out at 11.50 for the most expensive shipping option so that what I've used. Both rates, calculated and fixed should show up upon checkout. Please use the lower rate.
switchplate.co
Offline fleeceman
« Reply #137 on: Thu, 28 January 2021, 17:50:46 »
Any update on these?
« Reply #138 on: Mon, 08 March 2021, 04:29:10 »
There's a GB thread for it, but PCBs are done and shipped if your order did not contain plates. If it did, I made a mistake and they're being made again and should be done this month or next.
switchplate.co
Offline sup3r170va
« Reply #139 on: Mon, 08 March 2021, 06:01:07 »
Hi. Do u have any extra USB type C PCBs? If so, where can I get them? Thanks!
« Reply #140 on: Mon, 22 March 2021, 07:28:58 »
These are mini only. No type C as it doesn't fit on the 910.
switchplate.co
Offline Randalljai
« Reply #141 on: Mon, 30 January 2023, 00:37:03 »
Chance of another run?
