Author Topic: [GB] Polaris - GB Complete  (Read 308468 times)
Offline valkyr1e
Re: [GB] Polaris
« Reply #100 on: Thu, 08 August 2019, 15:10:22 »
Some ano samples shared on Discord:
Is it possible to have the black pvd weight alongside these ano samples?
Offline jwilthethrill
Re: [GB] Polaris
« Reply #101 on: Thu, 08 August 2019, 18:55:00 »
in for an e-white with PC plate, can't wait!
Offline sevenseacat
Re: [GB] Polaris
« Reply #102 on: Thu, 08 August 2019, 18:56:04 »
Oh that purple is actually quite nice. Dang.
Offline Zombo
Re: [GB] Polaris
« Reply #103 on: Fri, 09 August 2019, 00:01:03 »
Any other renders of the purple case? I'm really interested in joining
Offline hyppialonso
Re: [GB] Polaris
« Reply #104 on: Fri, 09 August 2019, 05:24:49 »
is shipping included in the price $265 ?
Offline bengine
Re: [GB] Polaris
« Reply #105 on: Fri, 09 August 2019, 05:28:59 »
Yes
Offline hyppialonso
Re: [GB] Polaris
« Reply #106 on: Fri, 09 August 2019, 05:34:21 »
sorry to bother again but may I know what plate option should I go for If I want to order HHKB layout, universal or Tsangan/WKL?
Offline bengine
Re: [GB] Polaris
« Reply #107 on: Fri, 09 August 2019, 05:40:28 »
Both support HHKB layout, but best will be to use Tsangan/WKL plate, since it’ll has less cutouts.
Offline nathanchere
Re: [GB] Polaris
« Reply #108 on: Fri, 09 August 2019, 06:34:15 »
Offline ArmedPenguin
Re: [GB] Polaris
« Reply #109 on: Fri, 09 August 2019, 07:38:42 »
I suppose e-white is prone to yellowing over time? Anyone with experience on this?
Offline nathanchere
Re: [GB] Polaris
« Reply #110 on: Fri, 09 August 2019, 08:19:23 »
I would be more concerned with cracking from what I've heard about e-coating's susceptibility to UV light damage. If in doubt, maybe just stick to a standard finish.
Offline LubedNReady
  • keep it kinky with Krytox
Re: [GB] Polaris
« Reply #111 on: Fri, 09 August 2019, 08:48:46 »
some preliminary research tells me that yellowing generally occurs as a fault of the application/curing process. I don't think you're going to experience any yellowing under most circumstances.
i fap with 205g0
Re: [GB] Polaris
« Reply #112 on: Fri, 09 August 2019, 09:15:01 »
What do people think of polycarb plate with tactile switches? To me this seems like it would give the most pleasant typing experience and dampened/deeper sound?
Offline ian13
Re: [GB] Polaris
« Reply #113 on: Fri, 09 August 2019, 09:19:26 »
That purple though. I hope it is really that dark and not pale or lacking in saturation for the final unit
Offline LubedNReady
Re: [GB] Polaris
« Reply #114 on: Fri, 09 August 2019, 10:00:08 »
I hope you're not talking about the render. Did you see the images of the sample? It's pretty vibrant, at least in that lighting.
i fap with 205g0
Offline ramblinrose
Re: [GB] Polaris
« Reply #115 on: Fri, 09 August 2019, 11:50:28 »
Still no green....
this :(
If the green is anything like kbd67 - it will be very nice. It's a great forest green shade.
Offline johuu
Re: [GB] Polaris
« Reply #116 on: Fri, 09 August 2019, 11:57:35 »
Which firmware is supported?
Offline KingOfMemes
Re: [GB] Polaris
« Reply #117 on: Fri, 09 August 2019, 12:00:23 »
ai03 confirmed in the IC that it will support QMK
Offline krisst
Re: [GB] Polaris
« Reply #118 on: Fri, 09 August 2019, 13:44:40 »
Poly plate will give most flex, compare to fr4 and brass. It's all about preference. I got the brass plate, most likely going for holy yoks, will consider linears too. Too many good linear switches though, will have to do more reading.
Re: [GB] Polaris
« Reply #119 on: Fri, 09 August 2019, 15:47:59 »
Yeah I am thinking Zilent v2.
Offline KingOfMemes
Re: [GB] Polaris
« Reply #120 on: Fri, 09 August 2019, 18:48:40 »
300 sold, baby! Where da hype at?!
Offline dubious
  • 쏘쿨
Re: [GB] Polaris
« Reply #121 on: Fri, 09 August 2019, 18:53:15 »
in for PC, wish me luck yall   ;)
Offline jooobe
Re: [GB] Polaris
« Reply #122 on: Fri, 09 August 2019, 19:05:53 »
I still haven’t placed mine yet
Sent from my iPad using Tapatalk
Offline pr0ximity
Re: [GB] Polaris
« Reply #123 on: Fri, 09 August 2019, 19:27:33 »
it's pretty good, that's my plan anyways.
Offline bball2
Re: [GB] Polaris
« Reply #124 on: Fri, 09 August 2019, 19:52:09 »
Offline jooobe
Re: [GB] Polaris
« Reply #125 on: Fri, 09 August 2019, 21:48:08 »
So the pcb has underglow?
Sent from my SM-N960F using Tapatalk
« Last Edit: Sat, 10 August 2019, 08:45:36 by jooobe »
Offline donkey
Re: [GB] Polaris
« Reply #126 on: Sat, 10 August 2019, 00:18:34 »
So the pcb had underflow?
You must mean underglow. I don't think so. No room to glow while sandwiched between foams.
Offline krisst
Re: [GB] Polaris
« Reply #127 on: Sat, 10 August 2019, 07:05:13 »
The pcb have smd rgb leds on the underside. Bottom foam pad have cutouts too. Though if you are not getting poly case, the rgb will be of no use.
Offline jooobe
Re: [GB] Polaris
« Reply #128 on: Sat, 10 August 2019, 08:46:20 »
Kbdfans staff says it does, I don't see it mentioned any where tho
Offline jooobe
Re: [GB] Polaris
« Reply #129 on: Sat, 10 August 2019, 08:46:43 »
Ahhh thx
Offline Kingk22
    • Naptime
Re: [GB] Polaris
« Reply #130 on: Sat, 10 August 2019, 10:12:04 »
Great looking board at a great price, so tempted  :)
Offline nathanchere
Re: [GB] Polaris
« Reply #131 on: Sun, 11 August 2019, 10:39:01 »
Who do we have to poke to get a better indication what "forest green" will look like?
Offline valkyr1e
Re: [GB] Polaris
« Reply #132 on: Sun, 11 August 2019, 16:49:25 »
Probably close to this:
Offline Etherealsound
Re: [GB] Polaris
« Reply #133 on: Sun, 11 August 2019, 19:54:02 »
Don't know if it's allowed but can I post the color samples from discord here for people by chance?
Offline jooobe
Re: [GB] Polaris
« Reply #134 on: Sun, 11 August 2019, 20:06:00 »
Yes
Offline ilemondrop
Re: [GB] Polaris
« Reply #135 on: Sun, 11 August 2019, 20:25:44 »
Hey, new to the community, is a value case like this rare? I'm debating on buying a second one if it's not frequent to get a clean aesthetic like this case at a solid price.
Re: [GB] Polaris
« Reply #136 on: Sun, 11 August 2019, 20:37:09 »
no but the odds of it being run again are unclear
buying 2 now is a lot easier than trying to find a second one in the exact spec you want later
Offline jooobe
Re: [GB] Polaris
« Reply #137 on: Sun, 11 August 2019, 20:41:59 »
This a like a two for one deal
Offline valkyr1e
Re: [GB] Polaris
« Reply #138 on: Mon, 12 August 2019, 08:10:08 »
For those who are wondering:
A picture of the KBD8x mkii space gray (should be very similar to the Polaris space gray) with the Polaris black pvd weight.
Credit to AI03. It was posted on the Polaris discord server.
Offline KingOfMemes
Re: [GB] Polaris
« Reply #139 on: Mon, 12 August 2019, 08:34:57 »
Is there any way to get a better pic? That looks brown with the lighting
Offline LubedNReady
Re: [GB] Polaris
« Reply #140 on: Mon, 12 August 2019, 09:07:37 »
I would absolutely not assume or hope that's what it looks like. I know he's called it "forest green" but based on 100% of the evidence presented, it will be saturated green-green. Not forest green. The "burgundy red" is almost fire red / slightly orange. the renders look nothing like the anodized samples.
My guess is that he came up with the names and gave those to whoever was doing the renders - then he made a color swatch and gave that to the manu. We've wound up with two drastically different ideas of what the boards will look like, but all with the same (wrong) color names.
Just my two sense: the entire first two weeks of this GB has been people asking for COHESIVE color samples. people aren't asking for white balanced/extremely color accurate samples, they're just asking for all of the colors to be as close to final and all laid out next to each other. I don't think it's an unreasonable request - I do think that ai03 has put in a bunch of hard work and is frustrated with what seems like "a small issue". Conversely, people are frustrated because they think something as simple as color samples should be a priority for any group buy.
i fap with 205g0
Offline rockydbull
Re: [GB] Polaris
« Reply #141 on: Mon, 12 August 2019, 10:23:21 »
Considering this is being run through KBDfans I don't think its unreasonable that they can achieve "forest green" to the extent they have in other boards like the tofu. Kbdfans has run two distinct greens before. The darker green and a bright green. I don't see how either could be confused with each other and the bright green is far off from the swatch they are trying to match to on the website. I do agree the renders do not match the swatches well, but IMO the swatches match reality better. Just look at the swatch for "burgandy red." It looks exactly like you described of an orange red.
Offline sevenseacat
Re: [GB] Polaris
« Reply #142 on: Mon, 12 August 2019, 10:41:53 »
Hence why black will probably be the most popular colour, people have been burnt too many times with mismatching colours...
Offline rockydbull
Re: [GB] Polaris
« Reply #143 on: Mon, 12 August 2019, 10:49:48 »
Or that its a basic color that matches tons of keycap sets (way better than grey imo)... No way a large portion of buyers are as caught up in the shades of the colors like yall are.
Offline mr.squishy
  • I like beer and keebs
Re: [GB] Polaris
« Reply #144 on: Mon, 12 August 2019, 11:01:30 »
It's a decent chunk of change. I'm not going to be getting one unless a color sample for the green is released, this is absurd. So, count me out I guess.
Offline KingOfMemes
Re: [GB] Polaris
« Reply #145 on: Mon, 12 August 2019, 11:32:44 »
Heaven forbid people dropping $265 on a product want to be as informed as they possibly can about the product they are purchasing lol
Offline nasp
Re: [GB] Polaris
« Reply #146 on: Mon, 12 August 2019, 12:28:24 »
Since the Fusion60 ran through KBDFans, it'd be nice if they could confirm that colors from that board will be similar to the Polaris' colors. But I suppose this is one of the pitfalls of going with a medium tier manufacturer, not a high end one.
Offline rockydbull
Re: [GB] Polaris
« Reply #147 on: Mon, 12 August 2019, 12:40:34 »
I was responding to the contention that black will be the highest sold color because people are spooked of the other colors and not because its always a popular color choice.
Offline LubedNReady
Re: [GB] Polaris
« Reply #148 on: Mon, 12 August 2019, 12:44:11 »
LOL I can see you're not a Discord user. I've spent the last week in discord watching people ask about colors. If you think this isn't the biggest point of contention for most people, I'd have to disagree.
And that's my biggest point: for something that doesn't actually have anything to do with the performance or value offered here, why is it such a pain in the ass? why is something "so simple and not important" so hard to nail down? if it's "not a big deal" then the board should not have been offered in multiple colors OR the GB should not have gone live until they were finalized. I agree, color isn't important. But you don't offer a bunch of color options and let people just figure it out when they get the product.
i fap with 205g0
Offline KingOfMemes
Re: [GB] Polaris
« Reply #149 on: Mon, 12 August 2019, 13:06:15 »
That's why you just buy Poly, White, black, or silver unless you are willing to gamble getting screwed on less obvious colorways
