Author Topic: [GB] Polaris - GB Complete  (Read 307110 times)
Offline ai03
  • I do not reply to PMs; contact me via website
    • Website
« on: Tue, 06 August 2019, 11:26:52 »
Polaris
by ai03 and Kevinplus
Gaskets. Seamless. 60%. $265 shipped, starting at $250.
Current status: GB complete. Thread being locked; please use Discord instead for extended support and discussion.
Discord for push notifications
Offering a quality typing experience without the high price tag, Polaris redefines the expectations from custom keyboards.
With proper gasket plate mounting, flex-slotted 1.2mm thin PCB, sleek seamless aesthetic, and accessible pricing, experience a top-tier 60% keyboard for a mid-range price.
Features
  • Refined seamless aesthetic that borrows from KBD8X MKII, with a rear-extended weight for a premium look
  • Plate held in place by a total of 18 gaskets. No metal-to-metal contact between the plate and case
  • 1.2mm thick, flex-slotted PCB that extends the gasket comfort further
  • Two foam filler sheets that remove open space within the keyboard while suppressing vibrations
Options
Tops:
  • Regular/Full
  • HHKB
  • WKL
Case colors:
  • Black
  • Space gray
  • Blue grey
  • Burgundy red
  • Forest green
  • Rose gold
  • Purple
  • E-White (Extra cost)
  • E-Yellow (Extra cost)
  • Polycarbonate (Extra cost)
Plate options:
  • Material: Brass, Polycarbonate, FR4
  • Layout: WKL or Universal
  • Style: Half or Full
Brass finish options:
  • Simple clear matte PVD
  • Matte black PVD
Timeline
GB will close in 1 month. Projected shipping time is around the end of the year.
This turned out very, very off from reality. GB completed August 26, nearly 9 months behind original ETA.
If you would like push notifications when there is progress, please join my Discord server and run the command ".iam Polaris" in the channel #bot-spam to receive direct updates whenever they happen.
Discord invite
« Last Edit: Sun, 11 April 2021, 03:35:32 by ai03 »
Re: [GB] Polaris
« Reply #1 on: Tue, 06 August 2019, 11:35:08 »
Approved!  :thumb:
Offline KingOfMemes
Re: [GB] Polaris
« Reply #2 on: Tue, 06 August 2019, 11:59:24 »
All aboard the hype train!
Offline valkyr1e
Re: [GB] Polaris
« Reply #3 on: Tue, 06 August 2019, 12:17:06 »
Could I get a clarification on the colour:
Is this the space gray? (Definitely not black, but looks darker than space gray on other KBDFans space gray)
Offline 1Weeb
  • ◕w◕
Re: [GB] Polaris
« Reply #4 on: Tue, 06 August 2019, 12:35:56 »
Is the polycarb case really that bad, any chance you could show samples of how "parts will not fit together perfectly" like the weight?
Offline nasp
Re: [GB] Polaris
« Reply #5 on: Tue, 06 August 2019, 12:38:48 »
At the time of the render the colors were not listed so it's neither
Offline Mekuno
Re: [GB] Polaris
« Reply #6 on: Tue, 06 August 2019, 12:45:19 »
I am assuming the color samples that are shown on the buy page are what they are aiming for.
Offline nasp
Re: [GB] Polaris
« Reply #7 on: Tue, 06 August 2019, 12:54:34 »
Yes. There are only a few physical color samples available. It would have been very expensive to make samples of all the colors.
Re: [GB] Polaris
« Reply #8 on: Tue, 06 August 2019, 12:58:26 »
In for E-White HHKB-layout with black matte PVD brass parts. Hope it will be shipped in December  :thumb:
Offline jonowarren94
Re: [GB] Polaris
« Reply #9 on: Tue, 06 August 2019, 13:10:17 »
So hyped to see this!
I know this might sound dumb but I would be correct in saying the base kit comes with a pcb and foam but not a plate right?
Offline Popopro
Re: [GB] Polaris
« Reply #10 on: Tue, 06 August 2019, 13:47:22 »
I believe that is the space grey as Ai03 said blue grey will be more blue than that.
Offline donkey
Re: [GB] Polaris
« Reply #11 on: Tue, 06 August 2019, 13:52:10 »
That to me looks like Black.
Re: [GB] Polaris
« Reply #12 on: Tue, 06 August 2019, 14:01:42 »
In for e yellow hhkb
Offline Vigrith
Re: [GB] Polaris
« Reply #13 on: Tue, 06 August 2019, 14:33:12 »
Offline hamilton
Re: [GB] Polaris
« Reply #14 on: Tue, 06 August 2019, 15:09:01 »
Rose gold, WKL, poly half plate :thumb:
Offline Emir
  • icon mods
  • Bandit
    • Discord
Re: [GB] Polaris
« Reply #15 on: Tue, 06 August 2019, 15:11:33 »
HHKB, Blue gray, half pc plate, black pvd - let's get it!
Offline Tekniqs
Re: [GB] Polaris
« Reply #16 on: Tue, 06 August 2019, 15:31:15 »
was fully in for a PC board but that warning is a little concerning
Offline valkyr1e
Re: [GB] Polaris
« Reply #17 on: Tue, 06 August 2019, 15:54:46 »
Once the colour sample is confirmed: Space gray WKL, full brass plate  :thumb:
Offline jooobe
Re: [GB] Polaris
« Reply #18 on: Tue, 06 August 2019, 16:00:32 »
@ai03 did you get the chance to build the out of spec red board
Sent from my SM-N960F using Tapatalk
Offline mongoose27
  • WKL FTW
Re: [GB] Polaris
« Reply #19 on: Tue, 06 August 2019, 16:07:48 »
In for a E-White, WKL  :thumb:
Can't wait to get it.
« Last Edit: Tue, 06 August 2019, 16:17:40 by mongoose27 »
Offline 112227
Re: [GB] Polaris
« Reply #20 on: Tue, 06 August 2019, 16:20:49 »
what color is the fr4 plate?
Offline kekstee
Re: [GB] Polaris
« Reply #21 on: Tue, 06 August 2019, 16:33:01 »
Any details on what exactly is the FR4 material option and what to expect from it?
Offline mongoose27
  • WKL FTW
Re: [GB] Polaris
« Reply #22 on: Tue, 06 August 2019, 16:46:10 »
From the KBD site:
Materials:
- Brass: A stiff metal with a deep sound. Firm bottom-out that pairs well with tactiles and some linears.
- FR4: A durable yet flexible fiberglass that is often used for PCBs. Medium firmness, slightly bouncy bottom-out that works for most switches.
- Poly: A flexible plastic that is more resistant to cracking than acrylic. Very soft bottom-out that works with linears.
Offline pr0ximity
Re: [GB] Polaris
« Reply #23 on: Tue, 06 August 2019, 18:04:42 »
 FYI all plate materials work for all MX-style switches 👍
Offline Mcnos
    • GMK Fuyu
Re: [GB] Polaris
« Reply #24 on: Tue, 06 August 2019, 18:33:38 »
Space Gray HHKB
Offline AcidBrain
Re: [GB] Polaris
« Reply #25 on: Tue, 06 August 2019, 19:08:30 »
Same, i was def in for PC also! I want to know if any other users that have had a PC board had an issue or have heard of this warning before....
Offline iammbox
Re: [GB] Polaris
« Reply #26 on: Tue, 06 August 2019, 20:03:41 »
My body is ready.  Buy now, think later!
Offline konradb
Re: [GB] Polaris
« Reply #27 on: Tue, 06 August 2019, 20:10:39 »
Will the burgundy be like KBDfans switch opener? Or will it be more bright red like on interest check photo?
This is a big difference for me and I don’t know if I should go safe with black, or trust that it will be dark burgundy.
Offline toanta
Re: [GB] Polaris
« Reply #28 on: Tue, 06 August 2019, 20:26:43 »
Any samples of the forest green?
Offline InvidiousIgnoramus
Re: [GB] Polaris
« Reply #29 on: Tue, 06 August 2019, 20:38:23 »
The one on the IC was stated as being the incorrect color.
I long for the day when I find a beamspring. (At a not insane price)
Re: [GB] Polaris
« Reply #30 on: Tue, 06 August 2019, 20:43:42 »
It's a warning that really should be put up for all boards available in polycarbonate. I purchased a Poly Singa75 used and was very surprised by the top/bottom alignment issues. visually you probably won't notice it, but it can be felt quite a lot. the main issue is that the Polaris, much like the Singa75, has fairly thin walls on the top half, and this can lead to a lot of side flex. It shouldn't be as bad once you've put it together though.
Oh, and I don't believe Ai03 has confirmed otherwise, so it's most likely the screws are threading directly into the polycarbonate, which means you need to be careful about over-tightening.
Offline f0leyme1ster
Re: [GB] Polaris
« Reply #31 on: Tue, 06 August 2019, 22:43:13 »
Will this keyboard have a second round of groupbuys in the future? Or can that not be confirmed? I'm new to groupbuys
Offline nguyenhimself
Re: [GB] Polaris
« Reply #32 on: Tue, 06 August 2019, 22:43:39 »
FYI if you don't mind a some misshapen arrow keys, Polaris actually allows an HHKB layout with arrow keys on the right side. This is a huge winning point for me.
Again, probably not for everyone. But for those who wish for HHKB-with-arrow-keys, this is awesome.
« Last Edit: Tue, 06 August 2019, 22:48:19 by nguyenhimself »
Re: [GB] Polaris
« Reply #33 on: Tue, 06 August 2019, 22:45:32 »
Usually no guarantee. There's a chance that KBDfans would stock up a number of units for post-GB purchase, but again, no idea.
Offline Solotov
Re: [GB] Polaris
« Reply #34 on: Tue, 06 August 2019, 22:58:18 »
E-Yellow for Serika  :thumb:
Flex is love, flex is life.
Offline KingOfMemes
Re: [GB] Polaris
« Reply #35 on: Tue, 06 August 2019, 23:18:35 »
This the move 100%
Offline sevenseacat
Re: [GB] Polaris
« Reply #36 on: Wed, 07 August 2019, 00:26:06 »
I really want to go purple but I don't trust KBDfans doing purple, their 5degree purple cases are just... off. All-black it is!
Offline Ivanddt
Re: [GB] Polaris
« Reply #37 on: Wed, 07 August 2019, 01:34:19 »
Has KBDfans done Rose Gold before? Can't seem to find anything on their site.
Offline raphaelf
Re: [GB] Polaris
« Reply #38 on: Wed, 07 August 2019, 01:42:04 »
I'm really interested to know that also. I love the red on the opener but the one in the proto didn't do much for me.
Offline jrs
Re: [GB] Polaris
« Reply #39 on: Wed, 07 August 2019, 03:25:48 »
What's the best feeling plate for linear switches?
Offline jooobe
Re: [GB] Polaris
« Reply #40 on: Wed, 07 August 2019, 05:31:55 »
To switch plate I will have to desolder all the switches?
Offline MK47
  • Don't talk to me
Re: [GB] Polaris
« Reply #41 on: Wed, 07 August 2019, 06:01:54 »
Is there a complete render of HHKB?
Offline kitty
Re: [GB] Polaris
« Reply #42 on: Wed, 07 August 2019, 06:16:51 »
would like to see a rose gold colour sample too :>
Offline ddnomad
Re: [GB] Polaris
« Reply #43 on: Wed, 07 August 2019, 07:15:27 »
Let me guess: with MT3 Serika, right?
Offline Bubblegum
Re: [GB] Polaris
« Reply #44 on: Wed, 07 August 2019, 07:23:03 »
Is Forest Green ano the same as KBDfans 5°/Tofu Dark Green?
Offline mr.squishy
  • I like beer and keebs
Re: [GB] Polaris
« Reply #45 on: Wed, 07 August 2019, 07:28:16 »
That's what I wanna know
Offline SpeakingSilence
Re: [GB] Polaris
« Reply #46 on: Wed, 07 August 2019, 07:37:02 »
In for Rose Gold for Bliss.
E White for Milkshake.
Offline LubedNReady
  • keep it kinky with Krytox
Re: [GB] Polaris
« Reply #47 on: Wed, 07 August 2019, 07:39:53 »
I feel this on so many levels.
All of you who have expressed interest in the polycarb plates - are you planning on buying an extra plate (either same or different material)?
i fap with 205g0
Offline Jonny_Lopez
Re: [GB] Polaris
« Reply #48 on: Wed, 07 August 2019, 07:55:10 »
Yee I ll buy 2 different plate and pcb
Offline nathanchere
Re: [GB] Polaris
« Reply #49 on: Wed, 07 August 2019, 08:31:05 »
https://brianlee.blog/2018/12/14/review-yuktsis-tgr-910re-polycarbonate/ sums it up nicely
