Author Topic: [IC] GMK ASCII - Available November 1st 2019 - GB LIVE  (Read 66946 times)
Offline AlbinoJellyfish
Re: [IC] GMK ASCII - Available November 1st 2019 - Kits finalized
« Reply #150 on: Tue, 29 October 2019, 20:55:03 »
I was wondering what the color code for the grey used was. I haven’t seen it asked about or mentioned
Offline Ensaum
« Reply #151 on: Tue, 29 October 2019, 23:33:50 »
Colors?
Stock colors, 2M on 2B.
In the original post
« Reply #152 on: Wed, 30 October 2019, 02:57:22 »
Colors?
Thanks! Missed that.
Offline CrazyNun
« Reply #153 on: Wed, 30 October 2019, 07:17:46 »
Nice, may be interested.  Shame there aren't any international legends though
Offline spakecdk
  • Browns are best
« Reply #154 on: Wed, 30 October 2019, 19:33:10 »
You did mention you are a fan of correct legends, so I'd kindly request having the correct icons on the numpad ("/" and "*"), since those are the characters that are displayed on screen when pressing those.
Offline GraffitiDecos
« Reply #155 on: Wed, 30 October 2019, 22:17:50 »
^ this
Offline Oblotzky
  • Backspace is for people that make mistakes.
« Reply #156 on: Thu, 31 October 2019, 05:42:14 »
^ this
Yesn't. I used to agree with that, but I changed my mind. If you went by what keys display on the screen when you are in notepad and you press on them, then yes those should be * and /. However that would also qualify them as alphas, in which case on dual-tone sets like Oblivion or Space Cadet, those would need to be alpha colored, and we don't do that. They are not alphas, for example if you have calc.exe opened and you press those keys, they send an action to the program, which is behavior more in line with modifiers.
I also have both Return and Enter in my keysets now because one key is for when writing text and wanting to move to the beginning of next line (return carriage) while the other (on the numpad) enters an equation for processing, even though both do the same when you have notepad open.
Offline spakecdk
  • Browns are best
« Reply #157 on: Thu, 31 October 2019, 19:09:37 »
Appreciate the answer, but I think it's wrong. The keycode that is sent is / and *. By your logic nothing is an alpha since it can be interpreted by software differently. For instance, pressing the [ key on my keyboard displays Š.
Even ignoring that, having / and * is more "old school" and in line with the theme of the set.
« Last Edit: Thu, 31 October 2019, 19:12:50 by spakecdk »
Offline funderburker
« Reply #158 on: Fri, 01 November 2019, 04:29:34 »
Woosh man, stop pressuring the designer with your agenda. He gave you his reasoning.
Keyboard design by Skepur
Offline mrpetrov
« Reply #159 on: Fri, 01 November 2019, 10:14:39 »
let's go man it's my wife's birthday today and i'm more excited by ascii dropping. i am such a bad guy.+
Offline noodleman
« Reply #160 on: Fri, 01 November 2019, 11:15:47 »
today's the day!
Offline jimboytacos
« Reply #161 on: Fri, 01 November 2019, 14:23:11 »
Has it dropped it? Can't find anything on konos store....
Offline IOVERCALLHISTIOCYTES
« Reply #162 on: Fri, 01 November 2019, 14:33:35 »
https://kono.store/products/gmk-ascii?variant=31080989884499
It's up now.
Oblotsky/Kono: A+ job on the pricing. Others have base kits at this price without new key design.
Offline spakecdk
  • Browns are best
« Reply #163 on: Fri, 01 November 2019, 19:21:42 »
Did you hear negative tone with my comment? I was just replying with my opinion. That's better than not contributing to the discussion by being sour and seeing conflict everywhere.
On a more positive note, holy hell the pricing. How? With 35 new moulds... wow.
« Last Edit: Fri, 01 November 2019, 19:32:34 by spakecdk »
Offline atectatifern
« Reply #164 on: Sat, 02 November 2019, 09:31:28 »
Here to say great pricing also - just joined. Thanks!
Offline Oblotzky
« Reply #165 on: Sat, 02 November 2019, 09:48:12 »
GB Thread: https://geekhack.org/index.php?topic=103218.0
