Author Topic: [IC] GMK ASCII - Available November 1st 2019 - GB LIVE  (Read 67826 times)
Offline konstantin
  • Formerly constexpr
Re: [IC] GMK ASCII - Available November 2019
« Reply #50 on: Thu, 08 August 2019, 09:08:02 »
ne NUL avai—
Oh. Uh, could you add the few control code sublegends that are missing? I find that I use ^[ and ^@ more than most of the ones on alphas (other than ^C, ^D, ^Z). I don't think it'll detract from the aesthetics either; in fact, I kind of like it better with the complete set of control codes present.
(missing sublegends highlighted in yellow)
Also, I see you went with HT instead of TAB for tab. Good choice, that's one that most ASCII table sites get wrong.
Edit: Forgot to add DEL.
« Last Edit: Thu, 08 August 2019, 09:30:33 by constexpr »
Offline konstantin
« Reply #51 on: Thu, 08 August 2019, 09:39:13 »
A few more things: +1 for using Return, +2 for 1.75u Function, and would you consider using Scroll↲Lock instead of Lock so it matches the rest of lock key legends and Page↲Up, Page↲Down?
Offline Oblotzky
  • Backspace is for people that make mistakes.
« Reply #52 on: Thu, 08 August 2019, 10:11:38 »
ne NUL avai—
That's actually a pretty good idea to add the remaining sublegends with a 64 offset. I didn't want to add them as single keys like a novelty kit, I'll look into this approach instead!
I really dislike the asymmetry of Scroll Lock when placed between Print and Pause (making those also two-liners is even worse). I'll have to say no for now, but I understand the request.
Offline neutralstate
« Reply #53 on: Thu, 08 August 2019, 10:39:23 »
Looks like we gonna need a GMK Gray Cadet as well...
Offline konstantin
« Reply #54 on: Thu, 08 August 2019, 11:45:30 »
Sweet!
Usually I'd agree 100% (I prefer one-line legends on everything), but in this particular case it's a bit different since you have Page Up and Page Down as two-liners, and the set is going for a retro vibe, with the Shift Lock and everything. Would you at least consider using Scroll instead of Lock?
Offline 0Name
« Reply #55 on: Thu, 08 August 2019, 11:49:19 »
Can I buy an Oblotzky season pass or will I have to order every set separately?
"10/10 would bankrupt again." - Chyrosan22.
Offline MacSurfy
  • Designer & 3D artist
« Reply #56 on: Thu, 08 August 2019, 12:39:42 »
Haha spot on! +1
Offline rondg
« Reply #57 on: Thu, 08 August 2019, 21:57:44 »
Would you consider a stepped Function key?
Offline depletedvespene
    • Keyboard-related resources.
« Reply #58 on: Fri, 09 August 2019, 05:56:08 »
Extremely interesting set. My only (small) caveat would be the "Shift Lock" legend — all(*) other mods have "modern" legends, so going "back" only for the Caps Lock key strikes me as odd.
I look forward to seeing this in action.
(*) Yes, there's "Return" instead of "Enter" on both alpha-block Enter keys, but that one key has had this "dual identity" for ages, so it's not an issue. And yes, there's "Lock" instead of "Scroll Lock", but that's a different, modern defficiency (YMMV) in current sets.
« Reply #59 on: Fri, 09 August 2019, 07:12:48 »
Yeah, but... Pause/Break are two different commands (and Break is supposed to be front-printed, with what that entails), and "Print Screen" is a single legend (conveniently forgetting SysRq here).
Come to think of it, why are we still calling the Print Screen key, "Print Screen"? Although this WAS its original function, few people nowadays remember it, and it's been completely taken over by the screenshot/windowshot functionality. I wonder if a new legend like "Screen Capture" (or some shorter version) would be well received.
« Reply #60 on: Fri, 09 August 2019, 08:56:52 »
I'm not exactly sure why Micro Switch's keyboard does not feature ASCII sublegends on all alphas, I did complete it using the standard ASCII table
The sublegends on letter-keys (not all alphas) correspond to the ASCII codes that could be obtained with the Ctrl key: Ctrl-G produced an audible bell, etcetera. The few letter keys without a sublegend are those whose corresponding ASCII code already had a dedicated key and thus the Ctrl-_ combination was unnecessary to implement (namely: Ctrl-H: Backspace ⇒ Del Key; Ctrl-J: LF ⇒ LF key; Ctrl-M: CR ⇒ CR key; had a dedicated Tab key existed, the I keycap would have also lacked the ASCII "HT" sublegend).
The above said, I think your decision of adding the "missing" sublegends is for the best in this kit.
Offline The_Royal
  • That's what I call, a Sunday.
« Reply #61 on: Fri, 09 August 2019, 09:43:25 »
*Cough, Cough
Uegrrrrr...Basic...Ortho *cough* Compat. urrrghhh *cough, cough*
Hurrggghaa HUGE Potential... *cough*
Offline vicissitude
« Reply #62 on: Fri, 09 August 2019, 10:26:03 »
Interesting alpha.
Gonna grab one for sure.
Offline thelaughingman
  • Simultaneously the most starry-eyed idealist and t
« Reply #63 on: Fri, 09 August 2019, 11:23:22 »
Definitely in for 1, R0+R5+tons of sublegends - that's my kind of set  :thumb: :thumb: :thumb:
Offline yaya
« Reply #64 on: Fri, 09 August 2019, 12:24:01 »
Finally a full grey monochrome set.  Thank you.
Not a fan of R0 personally.  How about an addon kit of 2B relegendables?
« Last Edit: Fri, 09 August 2019, 20:11:10 by yaya »
Offline abkumar
« Reply #65 on: Fri, 09 August 2019, 14:13:54 »
This is a neutral colored set. Does it make sense to split out numpad/iso into it's own kit to get cheaper base kit pricing like Minimal or 9009?
Offline Oblotzky
« Reply #66 on: Fri, 09 August 2019, 14:40:26 »
See signature.
Offline IOVERCALLHISTIOCYTES
« Reply #67 on: Fri, 09 August 2019, 15:16:25 »
I'd buy those. I'm guessing I should see the signature too tho. At least I got 100 of em from skiidata
Offline pcire
« Reply #68 on: Sun, 11 August 2019, 01:00:29 »
Thoughts on adding a FACK kit à la Salty kit?
I know it won’t run on drop, but maybe there’s enough interest?
Offline RETURNISO
  • I do get excited about keyboard stuff..
« Reply #69 on: Sun, 11 August 2019, 05:55:24 »
Damn, this is HOT Oblotzky  :thumb:
+1 for a Intl. kit. It should still be possible with the ASCII sub legends ( i think )
+1 For a EOT ISO enter / ESC novelty :p
Offline konstantin
« Reply #70 on: Sun, 11 August 2019, 18:40:06 »
Not sure if I love it or hate it, but I think you're on to something here.
« Last Edit: Sun, 11 August 2019, 18:41:43 by constexpr »
Offline jonowarren94
« Reply #71 on: Mon, 12 August 2019, 04:40:49 »
Another for ISO support, looks like a really interesting set!
EDIT: NORDEUK support...
« Last Edit: Mon, 19 August 2019, 03:15:18 by jonowarren94 »
Offline BanglesOtter
« Reply #72 on: Tue, 13 August 2019, 16:33:02 »
I really like this one. I'd be down for it!
Bangles Otter
Don't have a build yet. Soon (tm)
Offline nasp
« Reply #73 on: Tue, 13 August 2019, 16:50:14 »
Are the sublegend molds already available or will they have to be created?
Offline dc_in_sf
  • Old Bastard
« Reply #74 on: Tue, 13 August 2019, 16:52:41 »
I really wish this was an SA set, those ASCII printed sub legends really remind me of the old school serial terminals I used in college, which all had SA style keys (at least in my memory)
That said, getting SA sets to production seems to be a bit challenging so totally understand the choice, and will likely join in.
Offline geewiz
« Reply #75 on: Wed, 14 August 2019, 03:11:06 »
Wow, that's an amazing set that would fit my data centre G80-11900 perfectly if there was also a 2u Shift key. Any chance of one getting added?
Offline equalunique
« Reply #76 on: Sat, 17 August 2019, 01:55:48 »
No ortho kit?
Sent from my Ono-Sendai Cyberspace 7 using Tapatalk
Offline lovetree
« Reply #77 on: Sat, 17 August 2019, 23:12:23 »
R5, R5? Yes.
Offline jimboytacos
« Reply #78 on: Sat, 17 August 2019, 23:53:05 »
Can I just say that this keyset is full of shift?  :)) :))
Offline Oblotzky
« Reply #80 on: Thu, 22 August 2019, 02:42:53 »
Updated Kits, added Icon Modifier Kit, added Alice renders.
I am aiming for MOQ 500 on the Base Kit due to sublegend creation cost. It should roughly cost the same as GMK Crimson Cadet Base at 250 units then.
Kits
Renders
« Last Edit: Thu, 22 August 2019, 03:23:03 by Oblotzky »
Offline Rayndalf
Re: [IC] GMK ASCII - Available November 2019 - Kits and Renders updated
« Reply #81 on: Thu, 22 August 2019, 03:32:57 »
Any chance for barebones ortho or ergodox support? Even just a few blanks/novelty legends (like GMK Voyager) would be wonderful.
« Reply #82 on: Thu, 22 August 2019, 04:14:00 »
I'll ask out of abject, complete ignorance (and deal with the flack later).
Given that the bottom row is fully R5... do R5 molds for the split space bar keys already exist, or do those need to be created as well?
Offline Oblotzky
« Reply #83 on: Thu, 22 August 2019, 04:30:43 »
Spacekeys are Spacebar shaped (Convex). There is no 'R5' Spacebar.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #84 on: Thu, 22 August 2019, 06:43:04 »
Indeed. Also applies for the long keys (6, 6.25, 7).
Bless up for icon mods though it'll cost me another $20-30 or so.
Offline Emir
  • icon mods
  • Bandit
    • Discord
« Reply #85 on: Thu, 22 August 2019, 07:15:48 »
MA BOI BRINGIN THE ICONS
let's get it lads
Offline packman86
  • Morning Coffee
« Reply #86 on: Thu, 22 August 2019, 09:19:20 »
Looking great!
Keyboard Collection:
TGR Jane V2 | TGR Jane V2 CE | TGR Alice | TGR Dolice | TGR 910 | TGR x Singa UNIKORN 60 | Matrix 8XV 2.0 Korea Version | Matrix 8XV 2.0add | LZ CLS s h x | Duck Jetfire | TX-CP | QXP | Noxary X65 | RAMA M60-A | Model F62 "Kishsaver" | Daji OC 2XL FnF Black
Offline fn
« Reply #87 on: Thu, 22 August 2019, 14:21:45 »
This is a really cool set, great work. Any consideration for a ortho kit? even a minimal one!
Offline jimboytacos
« Reply #88 on: Thu, 22 August 2019, 15:23:08 »
Is the gray color in this kit the same as Oblivion's alphas? Or Space Cadet Alphas?
I'm trying to gauge what shade of gray it is.
Or is it a brand new shade of gray....
Offline yaya
« Reply #89 on: Thu, 22 August 2019, 16:20:29 »
Oblivion and Cadet are both matched to Signature Plastic's GQM  ASCII is using GMK's stock color 2B.  The grey in ASCII is a lighter grey than those two sets.
Offline rdg
« Reply #90 on: Thu, 22 August 2019, 19:00:44 »
So excited to see 1.25c in the space bars kit!!  ;D
Is this the first gmk set for that mold? I've not seen it in any GB/ICs.
Offline rpiguy9907
« Reply #91 on: Thu, 22 August 2019, 22:15:54 »
I suspect this is one of those sets that looks boring in the renders but when you see a real set you’re like “where have you been all my life.”
Offline mrpetrov
« Reply #92 on: Thu, 22 August 2019, 22:21:26 »
It'll be like WoB and Minimal. This set is fabulous and imo everyone who can should try to own one. This will be a classic.
Offline keebitup
« Reply #93 on: Tue, 27 August 2019, 01:38:52 »
+1 for basic ortho support (planck layout for me). Did anyone try 40% ortho with R5? Does it work?
Offline MdotMaxson
« Reply #94 on: Tue, 27 August 2019, 16:27:23 »
Ortho? Ergo?
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #95 on: Tue, 27 August 2019, 18:54:24 »
Ortho? Ergo?
Maybe no...
Topic: 【IC】 GMK Crimson Cadet - Available September 16th 2019 - Kits & Renders updated
Y no ergo kit? (instantly regrets buying expensive "crimson" Sol 2 plate)
Space cadet colevrak was beautiful too.
Ergo is really hard to push to MOQ. I don't want to have vendors buy out MOQ and then have those kits sit in their warehouse forever (I still have 5 kits of GMK Calm Depths Assembly and MyKeyboard.eu still has some stock left as well). I'm staying away from odd layouts for GB's outside of Drop for the time being, sorry.
Offline equalunique
« Reply #96 on: Tue, 27 August 2019, 20:48:00 »
That 1.25c mold was proposed for the GMK Blanks GB back in May & it didn't reach the MOQ, so it must be very, very new.
Offline The_Royal
« Reply #97 on: Tue, 27 August 2019, 22:03:44 »
With This being such a simple and clean Colorway set... I would bet a substantial amount of money that an ortho kit Like GMK Minimal's Would get to MOQ...or even be worth throwing into a child set.
The Ortho Community has grown so much in the past year!
I would buy 30 Ortho Kits structured like this to assist in the cause.
« Reply #98 on: Tue, 27 August 2019, 22:30:20 »
I bought that gmk minimal kit for the 2.75 and 2.25 spacebars without any intention of ever using the other keys, I'm probably not the only one.
Does the lack of 6U spacebars for minimal inconvenience more people than the lack of Ortho kits proposed here?
Offline break
« Reply #99 on: Wed, 28 August 2019, 20:56:40 »
Same, honestly. These caps are useful.
