Author Topic: [IC] SA SNES  (Read 435142 times)
Offline voodoo6k
  • Formerly voodoo5
[IC] SA SNES
« on: Fri, 14 June 2019, 10:05:55 »
★★★ SUPER MT3 SA KEYCAP SYSTEM ★★★
Info
This project has been put on hold. There is no ETA.
Why? Because MT3 production is different from traditional doubleshot technology (eg. Cherry, SP). There isn't as much flexibility when it comes to colours, legends and kit design.
The following kits are outdated and left for reference purposes.
Profile
MT3
SP SA (for comparison)
Kits
Renders
« Last Edit: Tue, 02 February 2021, 15:58:02 by voodoo6k »
Offline KingOfMemes
Re: [IC] SA SNES
« Reply #1 on: Fri, 14 June 2019, 10:09:56 »
Colemak plz thx  :-*
Offline Asbrodeus
Re: [IC] SA SNES
« Reply #2 on: Fri, 14 June 2019, 10:10:21 »
Sculpted or riot
Offline vosechu
Re: [IC] SA SNES
« Reply #3 on: Fri, 14 June 2019, 10:15:14 »
Can SP do legends in the upper left like this for similar cost? Normally they’re centered.
Also, I’m a big fan of r3 profile because it supports various ortho/ergo layouts. But if you decide not to offer those sculpted is probably preferred.
Offline Kokaloo
  • 🤘(• ω •)🤙
Re: [IC] SA SNES
« Reply #4 on: Fri, 14 June 2019, 10:17:42 »
YES PLEASEE ever since GMK SNES has died there's been a hole in my heart for a set like this. A few things thooo~
A optional mod colored F-Row would be pleasing. ;D
Also, would you consider having a separate kit to get these colored "WASZ" and "[;'/" keys? Obviously in the SNES colors that you already have.
EDIT: Meant SNES
« Last Edit: Fri, 14 June 2019, 10:28:03 by Kokaloo »
Offline vosechu
Re: [IC] SA SNES
« Reply #5 on: Fri, 14 June 2019, 10:18:24 »
Also, would you consider having a separate kit to get these colored "WASZ" and "[;'/" keys? Either in the SNES colors or the Super Famicon, or maybe even booooth?
This is such a great freaking idea!
Offline voodoo6k
  • Formerly voodoo5
Re: [IC] SA SNES
« Reply #6 on: Fri, 14 June 2019, 10:19:23 »
Yes, the Filco caps pictured are actually made by SP. Those are stock legends with no extra cost (confirmed with SP).
Offline vosechu
Re: [IC] SA SNES
« Reply #7 on: Fri, 14 June 2019, 10:20:14 »
Sweet! Thanks!
Offline iaman
Re: [IC] SA SNES
« Reply #8 on: Fri, 14 June 2019, 10:20:30 »
It's probably a little too fiddly to work, but a novelty with a simplified single-color version of the controller illustration from the Super Famicom box could be neat:
Offline Rensuya
  • Blue is my spirit animal
    • Link to the discord!
Re: [IC] SA SNES
« Reply #9 on: Fri, 14 June 2019, 10:22:13 »
+1 to R3
I like the colors and theme but would like to see more renders, and starting point for kits. Gl!
Offline rowie
Re: [IC] SA SNES
« Reply #10 on: Fri, 14 June 2019, 10:23:04 »
Yes please. Skipped the previous run hoping for an SA version.  Sculpted is my favorite but I can go either way. Please add support for WKL, Tsangan and hhkb layouts with stepped capslock, split shift and split back space.
Offline voodoo6k
  • Formerly voodoo5
Re: [IC] SA SNES
« Reply #11 on: Fri, 14 June 2019, 10:25:06 »
Also, would you consider having a separate kit to get these colored "WASZ" and "[;'/" keys? Obviously in the Super Famicon colors that you already have.
The Famicon colours are probably not gonna make it... because they would have to be custom colours. Extra things like this are the reason why GMK SNES was so expensive and never hit MOQ.
I personally prefer WASD over WASZ, but I'm not closed on any idea.
Offline mta
Re: [IC] SA SNES
« Reply #12 on: Fri, 14 June 2019, 10:26:12 »
Love the idea, but I would have preferred to see a revival of GMK SNES (with extra add-on famicom color mods as Kokaloo mentioned) as opposed to SA SNES, as it would make a nice companion set to GMK DMG. I suspect the growth of the community would make it more viable this time around.
Offline lewisflude
  • Hand Engineering
    • Hand Engineering
Re: [IC] SA SNES
« Reply #13 on: Fri, 14 June 2019, 10:26:56 »
Looks nice! Would be in if there's UK ISO support.
Offline voodoo6k
  • Formerly voodoo5
Re: [IC] SA SNES
« Reply #14 on: Fri, 14 June 2019, 10:27:28 »
+1 to R3
A barrage of renders is coming...
Offline Kokaloo
  • 🤘(• ω •)🤙
Re: [IC] SA SNES
« Reply #15 on: Fri, 14 June 2019, 10:27:36 »
Oops I got them mixed up, still waking up on my end. I meant the SNES colors since I read in the OP you didn't want to do custom colors.
Preferably WASZ since that's the controller layout! :p
Offline Rensuya
Re: [IC] SA SNES
« Reply #16 on: Fri, 14 June 2019, 10:35:44 »
+1 to R3
Awesome, I'm looking forward to them!  :thumb:
Offline Peripheral Prophet
  • Lets change the game
Re: [IC] SA SNES
« Reply #17 on: Fri, 14 June 2019, 10:36:34 »
I want this set in my life, yesterday..
Check out my live build streams on twitch and join my discord! https://discord.gg/QzeSQj2  https://www.twitch.tv/peripheral_installer
Offline voodoo6k
  • Formerly voodoo5
Re: [IC] SA SNES
« Reply #18 on: Fri, 14 June 2019, 10:37:30 »
That's on @intelli78. I contacted intelli before launching this IC, but didn't get a response yet.
To be clear: there is absolutely no plan of taking over GMK SNES.
I wanted to do something considerably different-- given that GMK SNES pretty much outlined the most sensible colourway for this theme.
Offline Acereconkeys
  • Happiness = life - expectations
Re: [IC] SA SNES
« Reply #19 on: Fri, 14 June 2019, 11:16:49 »
Oh boy oh boy. This is nice.
TMO50 | Jane V2 CE Incoming | Realforce 87u 55g | Aergo
Aergo design and build log: https://geekhack.org/index.php?topic=103681.msg2840918#msg2840918
Offline enrique.aliaga
Re: [IC] SA SNES
« Reply #20 on: Fri, 14 June 2019, 11:19:57 »
Why did GMK SNES die, though? Looks to me that lots of people are into the colorway.
Offline dk4one
Re: [IC] SA SNES
« Reply #21 on: Fri, 14 June 2019, 11:20:45 »
+1 Fully sculpted SA. No more GMK. Too much GMK. I love GMK, but at this point, I'm getting sick of seeing GMK.
Offline Nigolski
Re: [IC] SA SNES
« Reply #22 on: Fri, 14 June 2019, 11:21:56 »
i'm in
Offline Gondolindrim
    • My GitHub
Re: [IC] SA SNES
« Reply #23 on: Fri, 14 June 2019, 12:20:54 »
Second. GMK is nice, quality stuff, but there are lots of profiles we need more of, MT3, SA, DSA and XDA stuff.
A pessimist will tell you the cup is half empty. An optimist will tell you the cup is half full. An engineer will tell you it's exactly twice the size it needs to be.
Offline Warrenified
Re: [IC] SA SNES
« Reply #24 on: Fri, 14 June 2019, 12:26:44 »
Yes! Count me in :D
Offline thearctican
Re: [IC] SA SNES
« Reply #25 on: Fri, 14 June 2019, 12:54:39 »
Yes. The Filco SA caps are made by signature plastics. I have a set and they look great!
Offline pixelpusher
Re: [IC] SA SNES
« Reply #26 on: Fri, 14 June 2019, 13:23:08 »
Love it.  Let's make it happen. I also have the brown filco SP caps, and I like them a lot.  Great idea!
Offline kconfire
Re: [IC] SA SNES
« Reply #27 on: Fri, 14 June 2019, 13:53:58 »
EDIT: Meant SNES
I like this the best.
My super famicom had that colorful buttons.
[Collection] Monokei Kei SE, Realforce R2 TKL, Leopold FC660C
[Soon TM] Monokei Tomo SE, GSKT-00
Offline Armory
Re: [IC] SA SNES
« Reply #28 on: Fri, 14 June 2019, 14:04:03 »
Need  :thumb:
Offline Asbrodeus
Re: [IC] SA SNES
« Reply #29 on: Fri, 14 June 2019, 14:59:31 »
Minimum order quantity for custom colors was much higher back when this ran and it ran at a bad time during other popular group buys/the holidays.
Offline xondat
  • i'm not a star
Re: [IC] SA SNES
« Reply #30 on: Fri, 14 June 2019, 15:04:17 »
And then a vendor picked the project up to put it in the dungeon :'(
Offline tskiller
Re: [IC] SA SNES
« Reply #31 on: Fri, 14 June 2019, 15:27:07 »
Nice, def in for SA.
Offline vicissitude
Re: [IC] SA SNES
« Reply #32 on: Fri, 14 June 2019, 19:08:29 »
Love snes.
Nice project.
Offline despairsray
Re: [IC] SA SNES
« Reply #33 on: Fri, 14 June 2019, 23:11:50 »
This looks great. These might be my first SAs.
Offline voodoo6k
  • Formerly voodoo5
Re: [IC] SA SNES
« Reply #34 on: Fri, 14 June 2019, 23:16:03 »
Seems to work...
Great idea. Thanks!
Offline BlindAssassin111
  • I design keyboards and stuff.
    • Viktus
Re: [IC] SA SNES
« Reply #35 on: Fri, 14 June 2019, 23:22:25 »
Seems to work...
Great idea. Thanks!
...Damn that looks nice.
Offline club_sauce
  • Formerly jmstephens4
Re: [IC] SA SNES
« Reply #36 on: Fri, 14 June 2019, 23:34:04 »
I’m in—brings back some awesome memories.  Sculpted gets my vote. Great work.
Offline Hackerpilot
Re: [IC] SA SNES
« Reply #37 on: Fri, 14 June 2019, 23:38:02 »
223333 gives you the chance to run a very simple Colemak/Dvorak/Workman kit.
Offline kennardsmith
Re: [IC] SA SNES
« Reply #38 on: Sat, 15 June 2019, 00:22:08 »
yes please
[Control] is just left side of [A]. It comes from Sun Type3 key layout.
Offline iaman
Re: [IC] SA SNES
« Reply #39 on: Sat, 15 June 2019, 07:55:16 »
Seems to work...
[img width=640 height=360]https://i.imgur.com/tROvpgA.jpg[/img
Great idea. Thanks!
Yesssssss
Offline BalticSubmarine
Re: [IC] SA SNES
« Reply #40 on: Sat, 15 June 2019, 09:59:08 »
Now that's some good looking SA!!
Offline FatOldGuy
  • SA4Lyfe
Re: [IC] SA SNES
« Reply #41 on: Sat, 15 June 2019, 10:04:39 »
112343 all day! r333333333333333333333 kills the SA profile imo
Offline voodoo6k
  • Formerly voodoo5
Re: [IC] SA SNES
« Reply #42 on: Sat, 15 June 2019, 10:19:59 »
Let's stop messing around, poll:
Which SA profile do you prefer?
https://forms.gle/xUqSiwx5Q1zLGvPp9
« Last Edit: Sat, 15 June 2019, 10:32:58 by voodoo6k »
Offline voodoo6k
  • Formerly voodoo5
Re: [IC] SA SNES
« Reply #43 on: Sun, 16 June 2019, 20:19:58 »
Looks like sculpted is in the lead.
Let's keep it going, make sure you have your say!
Offline FatOldGuy
  • SA4Lyfe
Re: [IC] SA SNES
« Reply #44 on: Sun, 16 June 2019, 21:06:54 »
Yeah my brothers from other mothers! Sculpted gang gang  :cool:
Offline voodoo6k
  • Formerly voodoo5
Re: [IC] SA SNES
« Reply #45 on: Mon, 17 June 2019, 16:56:31 »
Unboxing!
Fun times ahead. ;)
Will be ordering colour chips.
Offline coffeeshopcoder
Re: [IC] SA SNES
« Reply #46 on: Mon, 17 June 2019, 23:47:27 »
Sculpted or bust !!
Love this...
Please consider an accent kit ?
Offline cari66ean
Re: [IC] SA SNES
« Reply #47 on: Tue, 18 June 2019, 10:32:56 »
Love this one!
I'd love sculpted but a Colemak (and Colemak Mod DH) support is more important to me. So I vote either uniform R3 or sculpted with ColemakDH compatibility kit.
Offline zfightingman
Re: [IC] SA SNES
« Reply #48 on: Tue, 18 June 2019, 16:40:20 »
MT3 or MDA SNES would be among my dream keysets.  I'm down for SA though as a more realistic option.  (It is a shame that MDA is only on like two sets ever - it's a very pleasing profile to type on.)
Re: [IC] SA SNES
« Reply #49 on: Tue, 18 June 2019, 19:52:57 »
If this goes well would you consider doing one for SA NES?
