Author Topic: [IC] Chimera65 - 65% Gasket mounted Keyboard from CannonKeys [GB Final Info!]  (Read 91085 times)
Offline HouseOfKeebs
How does the e-coating compare to anodizing and cerakoting in terms of feel?
Offline Nevermore012
hey @upas, could i have a question, what different between isolation gasket mount and isolation sandswich mount? thanks
To me, isolation sandwich mount is a more specific description for isolation gasket mount.
Basically, the gasket provides the isolation. Sandwich describes how its implemented.
For example, someone could make the case that burger mount, which uses O rings to isolate a top-mounted plate is a form of isolation gasket mount.
got cha, count me in the GB
Offline bsands
Love this, I am ready for the GB cus that Lilac is fire.
Offline upas
Re: [IC] Chimera65 - 65% Gasket mounted Keyboard from CannonKeys [GB Details!]
« Reply #103 on: Sat, 09 November 2019, 17:36:17 »
Hey guys, some final updates!
All units will go live for GB on November 23rd at 10AM Eastern Time.
The Group Buy will be open for 2.5 weeks. It will end on Wednesday, December 11th at midnight.
Standard Unit
$475 - 120 Total Units
Aluminum Top, Bottom - Main Color
Aluminum Back Accent, Bottom Crest, Badge - Accent Color
Sandblasted Raw Brass Weight and Plate
Colors:  (Main/Accent)
Black/Burgundy
Grey/Lilac
Navy/Silver
E-white Edition
$495 - 30 Total Units
Aluminum Top, Bottom, Bottom Crest - E White
Sandblasted Raw Brass Weight, Back Accent, Badge, and Plate
Special Edition:
$725
10 Total Units (5 Black, 5 Gold)
Note: I really tried to drive this price down, but PVD is expensive, and doesn't scale well with volume either.
"Angelic"
Gold PVD Brass Weight, Back Accent, and Badge
Raw Brass Sandblasted Plate
"Demonic"
Aluminum Top, Bottom, Bottom Crest - Black
Black PVD Brass Weight, Back Accent, and Badge
Black Carbon Fiber Plate
Extras:
Alu Badge   $12
Alu Crest $20
Alu Back   $37
Brass Badge   $12
Brass Back   $50
PCB w/ Cable + Daughterboard   $60
CF Plate   $40
FR4 Plate   $25
The extra accent pieces (Back, Badge, Crest) will be available in the following colors:
Black
Lilac
Silver
Navy
Grey
Burgundy
Every unit comes with the following 7 pieces:
Top, Bottom, Weight, Crest, Back Accent, Badge, Brass Plate
Along with:
Poron Gaskets
PCB w/ JST Cable and ai03 Unified Daughterboard
Hex Head Hardware
Bumpons
Each case will also ship in a custom fitted CannonKeys hard foam carrying case, as well as a microfiber cloth.
Plates will be available in 6.25U and 7U
Extras will go live at Nov 23rd 12 AM EST (00:00), 10 hours before the group buy goes live, so that they can be added to cart ahead of time.
Remember, the group buy goes live at Nov 23rd 10 AM EST
 A google form will be sent after purchase to select options.
Estimated Delivery: May 2020
Photos:
Black/Burgundy (Photo)
Crest Detail (Photo)
Renders:
Navy/Silver:
Dark Grey/Lilac:
Black/Burgundy:
E-White/Raw Brass:
Demonic:
Angelic:
« Last Edit: Sat, 09 November 2019, 22:24:38 by upas »
Offline MeloDet
I'm assuming plate files we available like with your past projects? Definitely looking forward to this :)
Offline upas
Yes they will!
Offline GPrix
Re: [IC] Chimera65 - 65% Gasket mounted Keyboard from CannonKeys [GB Final Info!]
« Reply #106 on: Sun, 10 November 2019, 06:58:02 »
So, upas, I’ll have to be pretty fast to check out both special editions at the same time, huh? 😅
Offline persocom
« Reply #107 on: Sun, 10 November 2019, 10:45:25 »
Got an alert set up for this now! hoping to catch an e-white
Offline upas
« Reply #108 on: Mon, 11 November 2019, 15:34:25 »
After some discussion in my discord, I am considering moving the SE FCFS sale 30 min - 1 hour before the rest of the sale.
The reason is it could allow for people to try for an SE unit, and then try for an E-white unit later if they miss out on the SE unit.
I'll continue to consider this - I can't really see any downsides but please let me know!
« Reply #109 on: Mon, 11 November 2019, 21:56:55 »
that's fair Upas, but I think raffle is also a option, you can open the form with limit time, and raffle before open the GB.
Offline j135
« Reply #110 on: Tue, 12 November 2019, 17:14:40 »
Will there be any more photos? Still deciding to buy or not :/
Offline Ld1993
« Reply #111 on: Tue, 12 November 2019, 19:52:51 »
Could you possibly create a render with which board you believe would look best with Olivia, given that it is re-releasing soon?
Offline j135
« Reply #112 on: Tue, 12 November 2019, 21:21:38 »
I think the Olivia looks pretty similar to gmk Cafe which is in the white and brass render. I think the white and brass boards would look really good with cafe and Olivia
« Last Edit: Tue, 12 November 2019, 21:25:51 by j135 »
Offline Ld1993
« Reply #113 on: Tue, 12 November 2019, 21:32:05 »
Good point. I looked at the renders again and they look phenomenal!
Offline upas
« Reply #114 on: Fri, 15 November 2019, 08:20:50 »
I tried to come up with a better way to run the Special Edition - unfortunately I won't have time to finish the system, so it's official:
The SPECIAL EDITION FCFS sale will start at 9am EST on Nov 23rd.
E WHITE and NORMAL Edition FCFS sale starts at 10am EST on Nov 23rd.
Offline vidoardes
« Reply #115 on: Sun, 17 November 2019, 12:49:43 »
That white and gold is beautiful! Hopefully I get lucky on the sale
Sent from my Pixel 3 XL using Tapatalk
« Reply #116 on: Thu, 21 November 2019, 14:06:57 »
Do the prices above include shipping?
Offline DukeEsquire
« Reply #117 on: Thu, 21 November 2019, 15:05:19 »
I can't imagine why they would since people live all around the world.
Offline upas
« Reply #118 on: Thu, 21 November 2019, 16:15:41 »
They do not
Offline octix
« Reply #119 on: Thu, 21 November 2019, 23:44:32 »
Cannot wait!
Discord: octix#0478
Offline upas
« Reply #120 on: Sat, 23 November 2019, 06:44:57 »
Group buy topic is live, so I'm locking this one!
https://geekhack.org/index.php?topic=103528.0
