Author Topic: [IC] GMK Umbra - PRICING RELEASED! Nov. 1-30  (Read 163829 times)
Offline dvorcol
  • Discord: dvorcol_5071
Re: [IC] GMK Umbra - Theme Update, Final IC Form, Pricing Soon, Nov. 1-30
« Reply #100 on: Wed, 23 October 2019, 15:53:18 »
No bar 5 key for the numpad?
For that matter, what are the two sets of F & J in the Base kit?  They appear to be identical in the render.
Offline Pach
« Reply #101 on: Wed, 23 October 2019, 19:17:15 »
The other set has a bar, it's just a little hard to see in that render, sorry
Update: I'm fixing the kits a bit, I'll add the bar 5 key and a mod colored `¬ key that I didn't catch before :)
« Last Edit: Wed, 23 October 2019, 20:36:22 by Pachriksu »
Offline Oni74
« Reply #102 on: Thu, 24 October 2019, 09:06:06 »
Renders look great, but I've a feeling I liked it more before the most recent change. I couldn't find pics of the previous version so I can't say for certain. Unfortunately, the inclusion of the numpad in base kit makes me look elsewhere. I've heard arguments from other gb runners why they choose to include it, but i don't buy it and definitely don't want numpad kit.
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #103 on: Thu, 24 October 2019, 14:55:58 »
I really like the colors, but the cyan mod legends kind of clash with the white alpha legends on top of the background color contrast.
Offline nasp
« Reply #104 on: Thu, 24 October 2019, 19:05:35 »
In the previous kitting, numpad by itself was $65. It included shiny and OG mod colors. Keeping the numpad in base and dropping one of the mod colors is the right move unless you think price doesn't matter. Just the base and the numpad kits together would have been $195! I don't think this set would have reached MOQ at those prices, the numpad kit surely wouldn't have.
Offline phinix
« Reply #105 on: Tue, 29 October 2019, 07:28:58 »
Am I losing it, or I saw a different colors here?
I liked it with some orange colors... or was it different set?
Offline Pach
« Reply #106 on: Tue, 29 October 2019, 17:12:41 »
Theme color was changed to blue because of pricing and kit issues. Therefore, I will post an IC sometime in the future for orange as a kind of re-run.
Offline Tyson
« Reply #107 on: Wed, 30 October 2019, 00:54:19 »
GMK Umbra Origins
Offline infinitykw
  • Amazed by the beauty of industrial design
    • zFrontier Profile
« Reply #108 on: Wed, 30 October 2019, 02:52:10 »
The current colorway is a no for me.
Offline phinix
« Reply #109 on: Wed, 30 October 2019, 03:40:22 »
Ah, ok, I'll wait for that colors then:)
Offline Pach
Re: [IC] GMK Umbra - PRICING RELEASED! Nov. 1-30
« Reply #110 on: Wed, 30 October 2019, 07:04:04 »
Three updated!
Offline CodeMayhem
« Reply #111 on: Wed, 30 October 2019, 07:17:17 »
i know it's probably too late and not many ppl are going to need this anyways, but seeing as you added a 1u shift to the base kit for ortho support you just need to add a 2u shift for 60 percents with arrow clusters.
