Author Topic: [IC] HB60 - Honeyboard60 - GB is live!  (Read 28898 times)
Offline VictorMTB
  • MTBkeys
  • Designer at SilverTrunk Designs
« on: Thu, 15 August 2019, 21:57:09 »
HB60 - HONEYBOARD60 BY MTBKEYS
We are proud to announce our very first 60% case design! It features a pretty simplistic, elegant glossy design with a honeycomb design in the inside which gives it a unique sound profile.
You will be able to choose from two tops. Standard or HHKB 7U for the same price.
Manufacturing will be done in-house in our shop here in Richmond, BC. Canada.
SPECIFICATIONS
Case Angle: 4 Degrees.
Material : 6061 Aluminum Base, Plate, and High profile Standard or HHKB Top.
Plate Layout: ANSI/ISO Univeral
Price: $290.00 + Shipping for Basic colors - $310.00 + Shipping for premium colors.
Shipping: $25.00 US and Canada, $55.00 International.
Timeline: We have already had a successful GB run on reddit. We hope to run a Geekhack GB as soon as we reach 2 month account age (Oct 13) or we hear back from GH mods about vendor approval.
Basic Base + lid colors (Anodized):
  • Black
  • Blue
  • Red
Premium Base + Lid colors (Anodized):
  • Rose Gold
  • Gold/Brass
  • Orange
  • Purple
Plate Colors (Anodized):
  • Black
  • Blue
  • Red
  • Gold/Brass
  • Rose Gold
  • Purple
PICTURES
RENDERS
Renders By Macsurfy!
Sound Test & Build Stream
Thanks to Top Clack for their build stream and sound tests of the HB60 which you can watch here:
Also shoutout to Tennstrong for clipping the sound tests and putting them in a neat list for us!
https://docs.google.com/spreadsheets/d/1Z3iSSUCJnulUpBDmoPh0aLuhQ0Di3pYHa8BWCeZLGZ8/edit#gid=1742896824
PLATE DXF & DIMENSIONS
DXF file for the Honeyboard60 blank plate: https://drive.google.com/file/d/1M70YirzLkwg3G3OPbGXvljIZYdzvEDUK/view?usp=sharing
PDF File of Drawing with plate dimensions: https://drive.google.com/file/d/1KlcCiEtDqch-0oMlmy_F03tDGzcXnObg/view?usp=sharing
« Last Edit: Tue, 08 October 2019, 17:50:33 by VictorMTB »
Offline VictorMTB
  • MTBkeys
Offline TokyoExpress
  • bambino screech
Re: [IC] Honeyboard 60% Aluminum case Prototype
« Reply #2 on: Thu, 15 August 2019, 22:07:19 »
I'd suggest a deep crimson if you're going with anodized aluminum - it'll look totally sick! Love the renders
Offline LostInInaka
« Reply #3 on: Thu, 15 August 2019, 23:05:50 »
Love that silver blue....wanted a canoe with that color way (or silver pink)
If colors can come out like the renders, this will indeed be an awesome board.
Any idea of price range and/or pcb compatibility?
« Last Edit: Fri, 16 August 2019, 00:04:17 by LostInInaka »
Offline Pluto19
  • All who break the taboo will be eliminated.
« Reply #4 on: Thu, 15 August 2019, 23:25:30 »
Interesting board you've designed.
How much extra time did it take for milling the honeycombs in the base? Would you also be adding o-rings to the bottom case in regards to the extra spacing you've milled out on the screw holes? Also, is there any significance to the asymmetrical registration marks for the plate and bottom case?
Offline EMC Labs
« Reply #5 on: Fri, 16 August 2019, 00:10:49 »
Looks good! Interested to see the price.
Offline VictorMTB
  • MTBkeys
« Reply #6 on: Fri, 16 August 2019, 23:39:36 »
Updated with more pictures of finished prototype!
« Last Edit: Fri, 16 August 2019, 23:42:02 by VictorMTB »
Offline ecbob
« Reply #7 on: Sat, 17 August 2019, 03:02:24 »
Wait BC? If this is cheaper than the Polaris I'm definitely buying this over Polaris. Color suggestion is white case and red secondary!
Offline rondg
« Reply #8 on: Sat, 17 August 2019, 05:40:26 »
That's a lot of screws for that form factor...
Offline YellowHalo
  • See You Starside
« Reply #9 on: Sat, 17 August 2019, 06:58:34 »
I agree. Four or six should be enough, top and bottom. You can also just lose the side screws and do with just eight like the kyuu. Since it will be sandwiched, maybe one of halves can have alignment tabs to secure the plate in place, like the aegis, jane v2, and kyuu.
Edit: I saw that you do have some sort of alignment tabs. If you have them where some of the screw holes are, again like the three examples, it would look much cleaner.
« Last Edit: Sat, 17 August 2019, 07:13:31 by YellowHalo »
Offline VictorMTB
  • MTBkeys
« Reply #10 on: Sat, 17 August 2019, 10:12:13 »
You're right we can definitely look into lowering the number of screw holes.
Offline VictorMTB
  • MTBkeys
« Reply #11 on: Sat, 17 August 2019, 10:14:59 »
Thank you! We're working on calculating material and machining + tooling costs today - we're hoping to keep this under $400 USD.
Offline beekey
« Reply #12 on: Sat, 17 August 2019, 14:01:23 »
Better some more screws than having a gap somewhere, due to uneven pressure.
Offline Mcnos
    • GMK Fuyu
« Reply #13 on: Sat, 17 August 2019, 19:02:39 »
I'm not a fan of the board but boy, your enthusiasm about it makes me want to support you!
I hope this project of yours goes well man.
Offline quinnx
« Reply #14 on: Sat, 17 August 2019, 20:20:53 »
I am all hand support! love a mirror finish with nature color of aluminum. more than that I'm happy that I can finally have a board made in Canada
Offline VictorMTB
  • MTBkeys
« Reply #15 on: Mon, 19 August 2019, 16:44:15 »
We appreciate the support! If you're near Richmond feel free to come check out our shop and the prototype :]
Offline JohnsonMG
Re: [IC] HB60 - Honeyboard 60% aluminum CNC case with plate. (Made in Canada)
« Reply #16 on: Mon, 19 August 2019, 18:35:39 »
Looks good! I'm personally not a fan of low profile cases, so I'd be very interested in a high profile version.
Keep it up! I will be monitoring this closely. Great to see manufacturing being done in Canada!
« Last Edit: Mon, 19 August 2019, 18:38:42 by JohnsonMG »
Offline VictorMTB
  • MTBkeys
« Reply #17 on: Mon, 19 August 2019, 18:41:58 »
Thank you! we have gotten rid of the gap on both sides by popular demand LOL!  I will look into high profile cases, although I'm mostly looking into making a compatible hhkb plate and top for this case. :thumb:
Offline rpiguy9907
« Reply #18 on: Mon, 19 August 2019, 19:29:07 »
I really like this design!
Might I suggest a 3mm acrylic/polycarbonate plate option? This would let light out from underglow which would also be reflected quite nicely off of the buffed interior honeycomb! I am assuming the seem in the side of your case is the plate...
Offline VictorMTB
  • MTBkeys
« Reply #19 on: Mon, 19 August 2019, 20:23:13 »
Great suggestion! our shop landlord is in the acrylic business I will ask him for a piece tomorrow. it would have to be clear/transparent i assume?
Offline rpiguy9907
« Reply #20 on: Mon, 19 August 2019, 21:50:25 »
Clear or frosted/milky acrylic would work. Some people prefer frosted because it diffuses the light better.
Offline VictorMTB
  • MTBkeys
« Reply #21 on: Mon, 19 August 2019, 23:15:44 »
Im hoping he has frosted but for sure he has clear.. I will update tomorrow.
Offline hammerbrotha
« Reply #22 on: Tue, 20 August 2019, 06:54:51 »
Great to see a Canadian board maker!!! My only feedback was related to getting rid of the gap but sounds like you've already addressed this.
60% is not a form factor I use, but I love that this is made in BC, full support just for that!
Offline rpiguy9907
« Reply #23 on: Tue, 20 August 2019, 13:28:09 »
Great! So I have a couple warnings for you...
It looks like you intend to run the Group Buy directly from PayPal. If you send out 25 invoices in one day and suddenly your account goes up to $10,000+ in a couple of days PayPal will freeze the funds until you ship the product! Basically if this is not normal for your PayPal account to have this much money coming in it sets off their auto-fraud detection. This has happened to countless group buy runners on GeekHack.
So be sure you can afford the raw materials because the money might get tied up. If the money is tied up and you have no materials to make your product with to ship it, everyone gets shafted. The GB runner is stuck with money they can't access because they can't ship anything, the buyers angrily want their product shipped, and getting PayPal to release the funds can take months...
The second warning is that it looks like your IC form is actually the Group buy form, meaning if I put my PayPal in the interest check then I will be invoiced. This is not an interest check. Usually payment is separate from collecting the list of potential buyers. This might scare off people who otherwise would complete your interest check.
« Last Edit: Tue, 20 August 2019, 13:30:21 by rpiguy9907 »
Offline VictorMTB
  • MTBkeys
« Reply #24 on: Tue, 20 August 2019, 13:52:00 »
Hey thanks for the warnings! in any case money should be frozen due to paypal issues we will still be able to buy material and manufacture as per order!
I edited my Reddit post to be more specific!
Offline MMKB
« Reply #25 on: Tue, 20 August 2019, 18:17:47 »
First I thought it's made by Hiney. The honeycomb bottom looks so sick man!
Offline nathanchere
« Reply #26 on: Wed, 21 August 2019, 01:40:01 »
If it's anything like the quality of your other work it will be killer. I imagine you don't want to complicate things focus on getting it right but is there any chance of a HHKB top in future if this first run is well received?
Offline VictorMTB
  • MTBkeys
« Reply #27 on: Wed, 21 August 2019, 05:27:37 »
Yes! I commented earlier how I will mostly focus on hhkb compatible plate and top if first run goes well.. but i'd also start working on a 75% design which will probably be high profile :)
Offline beekey
« Reply #28 on: Wed, 21 August 2019, 06:10:41 »
Looks nice and as long as the split space support stays I'm very interested.
How hard is it to polish the "Natural Aluminum" variant? Or will it come polished?
Offline VictorMTB
  • MTBkeys
« Reply #29 on: Wed, 21 August 2019, 06:19:44 »
We buff and wax each one with red rouge. The natural aluminum will be pretty easy to scratch, and also prone to fingerprint marks which is why we'll include a shammy towel with it.  :))
Offline Frystie
« Reply #30 on: Wed, 21 August 2019, 10:52:23 »
Count me in! (really though)
Offline Capsmiths
    • Capsmiths
« Reply #31 on: Wed, 21 August 2019, 17:36:59 »
Honeycomb bottom is an interesting idea. Too bad you can't really show it off. Is it for extra support?
Offline VictorMTB
  • MTBkeys
« Reply #32 on: Wed, 21 August 2019, 17:46:47 »
Original idea was to use as weight pockets but ended up being pockets to make case lighter. Top clack guys wondered if it would make any acoustic difference - so I'm pretty curious.
It will definitely reflect rgb lighting nicely though! so we're planning to machine a 3mm frosted acrylic plate to see how it looks.
Offline VictorMTB
  • MTBkeys
« Reply #33 on: Wed, 21 August 2019, 17:47:12 »
Sounds good!  :thumb:
Offline equalunique
« Reply #34 on: Fri, 23 August 2019, 08:58:59 »
I want to cut my own custom plate for a Boardwalk PCB. Could you share an SVG or DXF of the plate?
Sent from my Ono-Sendai Cyberspace 7 using Tapatalk
« Last Edit: Sat, 24 August 2019, 08:12:54 by equalunique »
Offline VictorMTB
  • MTBkeys
« Reply #35 on: Mon, 26 August 2019, 16:58:59 »
Sure I can!
Offline FredBananaz
« Reply #36 on: Mon, 26 August 2019, 17:34:36 »
Consider me interested!
Offline VictorMTB
  • MTBkeys
« Reply #37 on: Tue, 27 August 2019, 14:25:02 »
8/27/2019 UPDATE:
new pictures of high profile top.
new renders of honeycomb on outside.
new renders of high profile top.
Gap has been brought in.
Let us know if we should lower or raise the top!
Offline azulyf
« Reply #38 on: Wed, 28 August 2019, 16:24:38 »
Have asked this on reddit but didn't got reply. Wonder could you share some detail pics of the usb cutout and o-ring mounting structure? Thx.
Offline VictorMTB
  • MTBkeys
« Reply #39 on: Fri, 30 August 2019, 09:42:05 »
Sorry we havent responded! - we have been pretty busy with work.. I will be getting you some pictures with dimensions asap!
Offline Benitone
« Reply #40 on: Fri, 30 August 2019, 09:46:19 »
Nice. I hope that you'll do a tkl in the future.
Offline VictorMTB
  • MTBkeys
Re: [IC] HB60 - Honeyboard 60% . (Made in Canada) Updated Pictures + Price!
« Reply #41 on: Tue, 10 September 2019, 15:49:49 »
UPDATE 9/10/2019
New pictures of our anodized cases and plates!
We have run our first decently successful group buy off of Reddit and we have anodized our first batch of cases to ship out!
« Last Edit: Tue, 10 September 2019, 17:36:39 by VictorMTB »
Offline beekey
« Reply #42 on: Wed, 11 September 2019, 00:46:00 »
The moment you have a HHKB top ready, I'm in. :)
Offline growler
« Reply #43 on: Wed, 11 September 2019, 14:02:34 »
HHKB for the win.
6u spacebar obvs.
growler
Don't just stare at it ...
Offline VictorMTB
  • MTBkeys
« Reply #44 on: Wed, 11 September 2019, 14:34:06 »
HHKB for the win.
6u spacebar obvs.
growler
I just finished modeling a top for a 7u and a seperate 6.25u HHKB top.
My understanding is that 6u spacebars and stabs arent very common?
Offline growler
« Reply #45 on: Wed, 11 September 2019, 15:25:41 »
HHKB for the win.
6u spacebar obvs.
growler
Spacebars are easy enough, stabs, yeah, not so much, but they do exist!
growler
Offline VictorMTB
  • MTBkeys
« Reply #46 on: Mon, 23 September 2019, 20:43:00 »
9/23/2019 UPDATE
Added Build stream and sound test by Top Clack.
Added Sound test comparison list by Tennstrong.
Offline VictorMTB
  • MTBkeys
Re: [IC] HB60 - Honeyboard 60% . Blank plate dxf + Sound test
« Reply #47 on: Tue, 24 September 2019, 14:44:30 »
Update 9/24/2019
Added Blank Plate DXF and PDF with plate dimensions.
Offline MacSurfy
  • Designer & 3D artist
Re: [IC] HB60 - Honeyboard60 - New colors added.
« Reply #48 on: Wed, 25 September 2019, 15:30:26 »
A purple one with HHKB 6.25  .. I'm so down.
Offline VictorMTB
  • MTBkeys
Re: [IC] HB60 - Honeyboard60 - 7U HHKB Confirmed!
« Reply #49 on: Fri, 27 September 2019, 17:40:58 »
UPDATE 9/27/2019
Added HHKB 7U Top.
