Author Topic: Windows 10 Driver Installation Question  (Read 10398 times)
Offline Stupidface
  • Lifelong edge use case
« on: Fri, 30 August 2019, 17:26:22 »
When Windows 10 detects a new device, (e.g. a trackball) and determines that it needs to install a new driver in order for the device to work, will it always display a modal dialogue box (i.e. one that must be clicked through before the user can do anything else)?
or
Can Windows 10 automatically install a driver without ever notifying the user?
What I am trying to get at here is: is it at all possible (even remotely) for Windows 10 to install a driver without the user ever knowing?
Offline Leslieann
Re: Windows 10 Driver Installation Question
« Reply #1 on: Sat, 31 August 2019, 01:21:03 »
Sounds like a setting got ticked somewhere, I connect new mice to systems all the time and it just does it.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline Stupidface
« Reply #2 on: Sat, 31 August 2019, 02:47:21 »
Thank you for the reply.  So the default setting on Windows 10 is to install drivers automatically without any sort of user notification, is that right?
Offline Leslieann
« Reply #3 on: Sun, 01 September 2019, 01:25:57 »
Correct.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline Stupidface
« Reply #4 on: Sun, 01 September 2019, 04:29:41 »
Correct.
Okay, I think I understand this now.  I am much obliged for your taking the time to respond to my queries. *Tips hat*
