Author Topic: [GB] KAT Milkshake + M6-C Milkshake edition  (Read 194316 times)
Offline biip
    • @biipmk
Re: [GB] KAT Milkshake + M6-C Milkshake edition
« Reply #300 on: Mon, 17 August 2020, 10:02:28 »
Set came early last week, and I am very happy!
KAT is a major contender; for me best of sound and king of texture along with SA. Profile is amazing as well.
Milkshake is such a nice concept, each board likely looks unique because there are so many possibilities. Thanks, biip! <3
Anyone else have issues with the ISO Enter key cap?
Using a stock Ducky One 2 TKL: white Enter works ok, but not perfect perfect (very slight binding). Green Enter has enough binding to make it unusable (on that board). This is the only issue I have with the set.
Thanks for your kind comment.
I really hope  all the customers will be happy in the end after the replacment keys phase.
Offline bobgr8
« Reply #301 on: Mon, 17 August 2020, 12:52:57 »
Cheers man! You da best
Offline andtar2
« Reply #302 on: Mon, 17 August 2020, 13:49:43 »
Having some pretty major issues with the keycaps I received. They have this dark outline on all of the legends. It makes them look fuzzy at a distance.
https://ibb.co/hF02RBS
This picture shows it even worse. It shows the difference between a key that looks ok (the pipe key) and the others than are so blurry and have this weird dark shadowing effect
https://ibb.co/XFHsDZ8
Is there a way to report these issues and get replacements?
You should send these images to your vendor and ask for replacement.
I really do not think this is how it supposed to be.
Offline saesh
« Reply #303 on: Mon, 17 August 2020, 14:22:00 »
Anyone else have issues with the ISO Enter key cap? Both (white and green), when put on stabs, get stuck and do not come up again. My theory is that the stems where the stabs are connected to are bent slightly outwards and create too much friction within the stab. I tried different brands of stabs with the same result. The ANSI Enter does not seem to have this issue. I will test further but this is a serious issue for me right now.
Edit: tried on a different board with the same result. When I place the cap on a table I can spin it effortlessly like humming-top and it spins on the middle stem.
@biip anything I can do?
Small update: Tested with a ISO Enter from GMK 9009 R3 and everything is fine with that key. I am in contact with CandyKeys to find a solution.
Offline hkhawk
« Reply #304 on: Tue, 25 August 2020, 12:42:53 »
I am having an issue using this keyset with Durock stabilizers. I have two keyboards both with T1 switches but one has Cherry stabs and the other has Durocks. All my other keysets (GMK etc...) work perfectly on both keyboards but when I put KAT Milkshake on my keyboard with Durock stabilizers, the stabilized keys get stuck and don't return properly. Is this a known issue? Can someone please assist?
EDIT: I have no issues with KAT Milkshake with the Cherry stabs
Offline maxdrehzahl
« Reply #305 on: Wed, 26 August 2020, 03:12:31 »
I have exactly the same issue with both ISO Enters, and also contacted Candykeys. Just got a reply, they're aware of the situation and will fix it.
Offline hkhawk
« Reply #306 on: Wed, 26 August 2020, 19:55:37 »
As I said above, I'm having the same issue with my ANSI enter
Offline the_marsbar
« Reply #307 on: Tue, 01 September 2020, 13:57:06 »
Any news on a second round? Candykeys' website was bombarded (impossible to access) when it was announced that there would be extras...
So they will do a raffle instead it seems. I'm probably not going to join that.
So, a second round would seem to make sense, no?
Offline marshskitow
« Reply #308 on: Wed, 02 September 2020, 05:08:29 »
I only guess it was 2000 people f5ing the page at the same page for few extra so yes i agree with you, a second batch would be better.
Envoyé de mon iPhone en utilisant Tapatalk
Offline ssdt
« Reply #309 on: Wed, 02 September 2020, 05:28:08 »
Second batch! Second batch! Maybe start an IC? (Pretty, please?)
Poker II         HHKB Pro 2
“We are what we repeatedly do. Excellence, therefore, is not an act, but a habit.” - Aristotle
Offline ssdt
« Reply #310 on: Wed, 02 September 2020, 05:28:08 »
Poker II         HHKB Pro 2
Offline tngpq
« Reply #311 on: Wed, 02 September 2020, 09:17:09 »
Having similar issue with green ANSI enter on durock stabs. White enter is fine. I haven't tried any other stabs as all my stabs are durock.
Offline gbenz
« Reply #312 on: Wed, 02 September 2020, 12:20:34 »
Yes a second round please!
Offline Mearaz
« Reply #313 on: Wed, 02 September 2020, 21:55:24 »
Just open up my kits to see that the legends are smudged. WTF? Anyone else got this problem?
Offline biip
    • @biipmk
« Reply #314 on: Fri, 04 September 2020, 06:23:08 »
That's not normal.
Please contact your vendor to get replacement keys :thumb:
Offline Mearaz
« Reply #315 on: Fri, 04 September 2020, 06:35:11 »
That's not normal.
Thanks, I got the same advice on discord group as well. Already contacted them.
« Reply #316 on: Wed, 02 December 2020, 10:13:19 »
Some of my keycaps were also smudged. Should I report to the vendor?
Offline nnkb
« Reply #317 on: Sun, 31 January 2021, 09:42:06 »
My wearing KAT Milkshake
Offline nnkb
« Reply #318 on: Sun, 31 January 2021, 09:44:50 »
Me too.
Where did you contacted?
Offline Anorexus
  • Designer
    • Anorexus Web
« Reply #319 on: Sun, 28 February 2021, 22:09:26 »
Are we having round 2?
Offline biip
    • @biipmk
« Reply #320 on: Mon, 01 March 2021, 12:16:45 »
That's not planned yet.
Offline bansheetango
« Reply #321 on: Mon, 01 March 2021, 15:44:55 »
Any chance for a standalone Cherry profile run? It looked really nice on the NK65, too small a board though. :(
Offline ytc7776
« Reply #322 on: Tue, 02 March 2021, 22:21:59 »
+1 GMK Milkshake Please.
Offline biip
    • @biipmk
« Reply #323 on: Fri, 12 March 2021, 04:52:05 »
That's something I could consider.
Offline Rafa_n
  • stuffforrectangles.etsy.com
« Reply #324 on: Fri, 12 March 2021, 07:21:51 »
MT3 Milkshake would also look really nice imo
Offline Hell-es
« Reply #325 on: Fri, 12 March 2021, 14:24:50 »
Epbt  :thumb:
Offline Anorexus
  • Designer
    • Anorexus Web
« Reply #326 on: Sat, 13 March 2021, 04:08:17 »
+1 for cherry profile!
« Last Edit: Tue, 23 March 2021, 06:41:31 by Anorexious »
Offline saesh
« Reply #327 on: Tue, 23 March 2021, 02:50:01 »
Any updates on the replacement of the warped ISO Enter keys?
Offline foxlive
  • The quick brown fox jumps over the lazy dog
« Reply #328 on: Tue, 23 March 2021, 09:53:35 »
If someone is interested, I'm selling a complete set (Alphas + Katakanas + Modifiers + Specialties + Space + Fruits), brand new, never used :) ! You can check it in Classifieds  :)
Don't hesitate to pm me
Offline Gondolindrim
    • My GitHub
« Reply #329 on: Tue, 23 March 2021, 10:15:02 »
PM
A pessimist will tell you the cup is half empty. An optimist will tell you the cup is half full. An engineer will tell you it's exactly twice the size it needs to be.
Offline Surnia
« Reply #330 on: Thu, 22 April 2021, 23:49:00 »
+1! Would love to see weirdos on MT3. Might even reconsider the ergo build to go standard mx again just for the weirdos on the lovely MT3 sculpt.
Noppoo Choc Mini with MX Black | Filco 104 MJ2 Ninja with MX Black
Offline bobgr8
« Reply #331 on: Fri, 23 April 2021, 04:11:28 »
I don't think there are any replacements : (
Offline saesh
« Reply #332 on: Mon, 26 April 2021, 06:26:56 »
I hope this is not true. I spent >200€ on this set and without an Enter key this is basically unusable.  :(
Offline aterix
« Reply #333 on: Wed, 05 May 2021, 14:36:57 »
Anyone willing to sell their KAT Milkshake keycaps? I'm bummed that I missed the second GB.
If not, is there a way to stay notified next time it goes up for GB?
Offline convoliution
« Reply #334 on: Wed, 05 May 2021, 16:51:22 »
You might have better luck finding sellers in the Classifieds subforum or in the MechMarket subreddit (with all the usual disclaimers for community purchases, I bear no responsibility for this recommendation!).
As for staying notified, note that re-runs of keysets in this hobby are not guaranteed, but you might want to join biip's Discord server, which you can find a link for near the bottom of the post for the GMK Parcel group buy.
« Last Edit: Wed, 05 May 2021, 16:53:58 by convoliution »
Offline FSund
« Reply #335 on: Fri, 31 December 2021, 07:26:58 »
I just received 2x ISO enters (white and green) out of nowhere. I originally ordered from CandyKeys, but these came directly from China. I never contacted anyone regarding replacements. Perhaps CandyKeys replaced all ISO enter orders?
Join the Mechanical Keyboards Norway Discord server
Offline bliss
« Reply #336 on: Sat, 01 January 2022, 15:31:01 »
Same for me, got them out of the blue on Christmas Eve from CK  :cool: - very happy about that, since the original pair gives me mild problems; see above. Thanks CandyKeys  :thumb:
Offline saesh
« Reply #337 on: Fri, 07 January 2022, 02:07:32 »
Oh! I hope I get ISO Enter replacements as well. Mine are unusable.  :(
Offline depressedkeebs
    • Depressed Keebs
« Reply #338 on: Mon, 10 January 2022, 13:22:26 »
you would have to try it, no response would be accurate for how you would feel
