Author Topic: [IC] ØBLIVIATE • FRL TKL O-Ring Mounted Keyboard  (Read 29772 times)
Offline Anorexus
  • Designer
    • Anorexus Web
« on: Tue, 31 October 2023, 18:57:36 »
ØBLIVIATE
Monoblock Case FRL TKL O-Ring Mounted Keyboard
0. Status
Prototype #2 currently being tested, as we eager to lower unit price, another round of prototype will be needed to test overall design and colors.
1. Intro
Hello everyone! I'm excited to introduce Øbliviate, a FRL TKL keyboard layout featuring an o-ring mount within a single monoblock design. The concept behind Øbliviate is to deliver a 60% O-ring keyboard experience by dividing the alphanumeric cluster and navigation cluster into separate sections. The hypothesis behind this design is that by having separate sections between each cluster, the inner wall will create a friction fit with the PCB and plate, impacting both sound and typing feel.
Interest check is now open.
2. Index
0. STATUS
1. INTRO
2. INDEX
3. DESIGN
4. SPECIFICATIONS
5. CONSTRUCTIONS
6. LAYOUT
7. PRICING
8. MEDIA
9. MANUFACTURER
10. FAQ
11. KEEP IN LOOP
3. Design
Prototype photos
Prototype #1
*The design is based on the earlier version, the next prototype will implement the new appearance as the latest render
4. Specifications
Øbliviate Specifications:
- Layout: FRL TKL
- Mounting system: O-ring mount
- Typing Angle: 6.5°
- Effective keyboard height: 22.672 mm
- Materials: Aluminum 6063 or Polycarbonate Accent, Brass Weight, Brass Accent
- Plate: 1.5mm Aluminium, Polycarbonate, POM, Carbon Fiber, FR4 (1.6mm)
- PCB: In-house design PCB obliviateFRLTKL 1.6mm thickness solder or hotswap - configurable with QMK/VIA
Parts included with the kit:
- Keyboard case: (Case, Weight, Accent)
- 1x FR4 Plate for alphanumeric cluster and 1x FR4 nav cluster
- 1.6mm Hotswap/Solder PCB; layout information will be shared later
- Daughterboard, Bridge, Flate flexible cable
- 1x O-ring (50a) for alphanumeric cluster and 1x O-ring (50a) nav cluster
- 4x Custom-designed rubber feet
- Plate support switch comb/fork
- Hand-carry keyboard bag
- Other accessories
5. Constructions
6. Layout
7. Pricing
We eager to make the unit price more affordable, pricing will be finalized near the GB stage
8. Media
We will be working with keyboard enthusiasts and influencers to give a preview of Obliviate, including build streams, typing tests, and overall impressions. A list of enthusiasts and influencers will be shared at a later time.
9. Manufacturer
We currently exploring another option to lower the unit price
10. FAQ
11. Keep in loop
Any feedback and questions are welcomed!
Interest check is still open to get a better insight on how much interest in this project and your region
Your inputs will be very valuable to determine price and vendor partners
Follow our instagram
Join our discord server
Check our web for other projects
« Last Edit: Fri, 24 May 2024, 23:00:08 by Anorexious »
Offline Anorexus
  • Designer
    • Anorexus Web
Re: [IC] ØBLIVIATE • FRL TKL O-Ring Mounted Keyboard
« Reply #1 on: Thu, 02 November 2023, 19:11:29 »
Design changelog
Prototype #1:
1. Based on the first design, the prototype consists sandblasted anodized aluminum 6063 monoblock case and nav blocker, powder coat brass weight, and stainless steel mirror polish accent
Prototype #2:
1. Add a curve on the front lips
2. Change surface treatment for accent and weight into sandblasted brass
3. Revert back weight design from prototype #1
« Last Edit: Thu, 16 November 2023, 23:21:06 by Anorexious »
Offline stotle.caps
« Reply #2 on: Sun, 05 November 2023, 01:14:29 »
pretty excited for this glwic
Offline noctoornal
« Reply #3 on: Tue, 14 November 2023, 17:34:30 »
filled out the IC form.
very nice design I like it and probably my first FRL TKL if I buy one.
GLWIC
Offline Thumb Key
« Reply #4 on: Wed, 15 November 2023, 04:35:51 »
I love this arc!
Offline Anorexus
  • Designer
    • Anorexus Web
« Reply #5 on: Fri, 17 November 2023, 00:50:29 »
Prototype #1 Photo
*prototype#1 based on older design, next prototype will have different accent and curvy lips
« Last Edit: Fri, 17 November 2023, 00:52:11 by Anorexious »
Offline ELE.WORKS
« Reply #6 on: Fri, 17 November 2023, 01:31:17 »
hey,bro. this's 70 is my style.very ok XD
Offline Anorexus
  • Designer
    • Anorexus Web
« Reply #7 on: Fri, 17 November 2023, 03:50:04 »
I love this arc!
GLWIC
Thank you!
Offline Anorexus
  • Designer
    • Anorexus Web
« Reply #8 on: Mon, 08 January 2024, 03:06:55 »
Update Prototype #2
Crescent
Offline nasikluban
« Reply #9 on: Fri, 12 January 2024, 22:59:13 »
These proto photo never miss, GLWIC!
Offline azhdar
  • Praise the AZERTY god
« Reply #10 on: Sat, 13 January 2024, 03:00:33 »
no iso ?
Azerty Propagandiste
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #11 on: Sat, 13 January 2024, 17:34:12 »
Update Prototype #2
Crescent
Is this the set design now? Personally I much prefer the original front with the straight cherry lip. Kinda a deal breaker for me TBH, but GLWIC!
Offline Anorexus
  • Designer
    • Anorexus Web
« Reply #12 on: Sun, 14 January 2024, 04:34:44 »
 :cool:
no iso ?
To keep it simple we are not offering ISO layout for now
Update Prototype #2
Crescent
Yes the design is finalized, we fully aware the design direction is not for everyone, thanks for good wishes  :thumb:
Offline Anorexus
  • Designer
    • Anorexus Web
« Reply #13 on: Mon, 20 May 2024, 21:58:54 »
Update Prototype #2
Another preview and exploded view
More photos >>>
« Last Edit: Mon, 20 May 2024, 22:09:33 by Anorexious »
Offline Anorexus
  • Designer
    • Anorexus Web
« Reply #14 on: Mon, 20 May 2024, 22:07:59 »
Quick build and typing test
