Author Topic: [IC] Aluminum Spacebars 6.25U/7U - Vote for your color!  (Read 44321 times)
Offline yui
Re: [IC] Aluminum Spacebars 6.25U/7U - Color Swatch update!
« Reply #50 on: Fri, 27 September 2019, 01:21:17 »
I got 2 questions, would you ship in the EU for a reasonable price and would it be possible to get a raw machined spacebar?
Offline deejasaurus
« Reply #51 on: Fri, 27 September 2019, 01:52:38 »
I'm down for a cyan 6.25u spacebar.
Offline lolafineday
« Reply #52 on: Fri, 27 September 2019, 12:38:37 »
Down for 2.75, and 2.25 navy blue spacebars
Sent from my SM-G975F using Tapatalk
Offline VictorMTB
  • MTBkeys
  • Designer at SilverTrunk Designs
« Reply #53 on: Fri, 27 September 2019, 15:14:16 »
you can absolutely order a raw polished aluminum or raw brass in the future! you'll just have to note that its very easy to scratch and also a fingerprint magnet.
That is if you don't anodize.
Offline ab042896
« Reply #54 on: Fri, 27 September 2019, 16:08:23 »
Is it possible to get a sound test with the one you've already made :cool:?
Offline LoneRegiment
« Reply #55 on: Fri, 27 September 2019, 17:20:21 »
I would be in if it were a Cherry profile spacebar, and I believe it would be more widely appealing.
Orange 12
« Last Edit: Thu, 10 October 2019, 08:41:31 by LoneRegiment »
Offline VictorMTB
  • MTBkeys
« Reply #56 on: Fri, 27 September 2019, 17:28:58 »
Havent had time to fix this post as we're pretty busy, but cherry in anodized or raw aluminum will be available!
yes sir as soon as we have a 6.25u made we shall do that and post.
Offline enome
« Reply #57 on: Sun, 29 September 2019, 06:45:49 »
ne BRASSSSSS avail?
Oh woops of course, But I'm not sure what we would charge for full brass? maybe a full brass bottom row kit?
Remember, everything is designed and manufactured in-house here in Richmond, BC. Canada.
OMG POGGGGGGERS
JUST TAKE MY MONEY
Offline iammeuru
« Reply #58 on: Mon, 30 September 2019, 19:39:00 »
If it's Cherry profile in 7u I'm 100% in. If it's anything else, I'm definitely not in.
Offline VictorMTB
  • MTBkeys
« Reply #59 on: Fri, 04 October 2019, 01:14:51 »
Sorry for the late reply guys, We have decided we are going ahead with this project and you should expect to see a group buy from us within a few weeks.
By popular demand we will be starting with 6.25u and 7u Cherry profile spacebars. This also goes for brass spacebars.
In the future we would like to machine many different sizes in aluminum and brass.. and different profiles too!
Now, I'll try to figure out how to make a poll for colors...
Shiny Natural Aluminum will always be available - we would just have to figure out what to coat it with.
Keep sending us your suggestions!
Offline VictorMTB
  • MTBkeys
Re: [IC] Aluminum Spacebars 6.25U/7U - Group buy coming soon!
« Reply #60 on: Fri, 04 October 2019, 01:18:42 »
I guess you're in!
« Last Edit: Fri, 04 October 2019, 01:22:42 by VictorMTB »
Offline alanskiii
Re: [IC] Aluminum Spacebars 6.25U/7U - GB coming soon!
« Reply #61 on: Fri, 04 October 2019, 02:08:01 »
Yesss Brass too! this will be the perfect touch for my build. Can’t wait!
Offline growler
« Reply #62 on: Fri, 04 October 2019, 02:21:02 »
Brass 6.25, sweet
growler
Don't just stare at it ...
Offline Techichi
« Reply #63 on: Fri, 04 October 2019, 09:47:32 »
Thinking about getting several brass space bars and having them plated. Rhodium, black rhodium, gold, platinum, nickel. You could do matte finishes, polished. Several possibilities.
Offline damsenviet
« Reply #64 on: Sun, 06 October 2019, 01:25:52 »
Would you offer a non-hollow version (or at least prototype and sound test it)? Some people like to stuff the inside of the spacebars with foam and the like, but it'd definitely be interesting to see a filled spacebar with just aluminum.
Offline wt1155
« Reply #65 on: Sun, 06 October 2019, 01:53:04 »
Any recommended spring weight for this spacebar ?
Offline VictorMTB
  • MTBkeys
Re: [IC] Aluminum Spacebars 6.25U/7U - Vote for your color!
« Reply #66 on: Tue, 08 October 2019, 10:48:20 »
Added numbers to the swatch so you can vote on what colors we'll go with!
First group buy will be 6.25u and 7u cherry profile space bars.
Offline Kerasan
« Reply #67 on: Tue, 08 October 2019, 22:49:55 »
which coating has the space bar in polished brass?
Color choise: rose gold, Gray, purple
Did you think about making anodizations like in the keyboard gb you designed?
Offline CF73
« Reply #68 on: Wed, 09 October 2019, 07:01:12 »
+1 for this, I'm assuming it'll also reduce the cost since less machining is required?
I'd be in for 6.25u alu in purple and white.
Offline KingOfMemes
« Reply #69 on: Wed, 09 October 2019, 08:17:24 »
A Non-hollow option would be tight. Would that cost more or less than a holo version? The obvious guess is more because more material, but I'm wondering if machining costs would be less since it would just be a flat cut along the bottom
Offline rockydbull
« Reply #70 on: Wed, 09 October 2019, 09:42:50 »
With the anode is there concern that constant touching will wear it away? Normally not something I am concerned about on a case, but the spacebar is touched so much. For the natural aluminum will there be any clear pvd or is it raw dog?
Offline CF73
« Reply #71 on: Wed, 09 October 2019, 23:59:48 »
I could be wrong, but the material cost would be the same considering that the piece of aluminum to be machined from is the same in size. Just extra machine work to trim down the interior of the keycap for hollow ones. (It'd be a different story for 3d printing since that's an additive process, where more material = higher cost).
Also, non-hollow caps may need some tweaks with switch/stab clearance around the mounting positions.  :rolleyes:
Offline ItszBrian
    • GMK Devoted
« Reply #72 on: Thu, 10 October 2019, 03:49:37 »
I really like 1 (cyan) ,4 (red) ,5 (purple), and 6 (pink). Although I might only get two colors if the group buy happens soon.
Offline Gondolindrim
    • My GitHub
« Reply #73 on: Mon, 14 October 2019, 19:11:08 »
I really like the blues and the golden keycaps.
A pessimist will tell you the cup is half empty. An optimist will tell you the cup is half full. An engineer will tell you it's exactly twice the size it needs to be.
Offline langstonhuge
« Reply #74 on: Mon, 14 October 2019, 19:16:46 »
I'm in for one in brass!
Offline Steezus
  • Keeper of Facts
« Reply #75 on: Mon, 14 October 2019, 19:48:51 »
I can definitely see myself grabbing a 7u in #1(cyan) and polished brass. :thumb:
Offline alanskiii
« Reply #76 on: Mon, 14 October 2019, 21:33:38 »
In for polished brass, but if I had to vote on colors I’m also interested in it’s 5, 6, and 8.
Offline RETURNISO
  • I do get excited about keyboard stuff..
« Reply #77 on: Tue, 15 October 2019, 07:44:36 »
i'll take a raw polished silver and black (7) :thumb:
Offline Kerasan
« Reply #78 on: Sat, 19 October 2019, 11:44:11 »
Any news?
Offline lolafineday
« Reply #79 on: Sat, 19 October 2019, 12:45:42 »
White, navy 2.25, 2.75, 7u
Offline noorejji
« Reply #80 on: Wed, 30 October 2019, 14:36:57 »
7, 8 and 14. 7u Topre with 6u centered spacing (read: Realforce 86U compatible).
« Last Edit: Wed, 30 October 2019, 14:52:29 by noorejji »
Offline Chris_der_Baer
« Reply #81 on: Thu, 07 November 2019, 10:05:43 »
Definetly in for a 6.25U in shiny aluminum shipped to EU. Cant wait for the GB
Offline nathanchere
« Reply #82 on: Thu, 07 November 2019, 17:10:41 »
Did this get shelved?
Offline VictorMTB
  • MTBkeys
« Reply #83 on: Thu, 07 November 2019, 17:30:14 »
No sir ! We're working overtime to get our honeyboard cases out first. We plan to hopefully start gb early december. We're really excited to start this project!
Any news?
Offline AdrianMan
« Reply #84 on: Fri, 08 November 2019, 12:21:28 »
6 u centered please!!!
Offline HOBI3CAT
  • FraktalKaps.com
    • Fraktal Kaps Website
« Reply #85 on: Mon, 11 November 2019, 09:18:23 »
Would definitely love a 6.25u naturally shiny aluminum to make molds with for casting ;) Polished metal gives the casted caps a super nice shiny finish. Waiting patiently!
Eat, Sleep, Resin, Repeat.
Offline alanskiii
« Reply #86 on: Sun, 29 December 2019, 04:57:58 »
Where’d this go? I got in on wkl board, need me some 7u bars :)
Offline Shutter_Shock
« Reply #87 on: Sun, 29 December 2019, 08:32:00 »
Also in for at least 1-2 6.25u cherry profile. Maybe a 7u as well. 1,7, and 11 are pretty good colors for me.
I agree that I wouldn't mind paying $40 instead of $30 if it means better finishing. Will the plain polished aluminum and brass be raw? It would be nice to see PVD coating on the polished ones.
Offline gamerman
« Reply #88 on: Sun, 29 December 2019, 18:34:10 »
I'm in for 3
Offline nathanchere
« Reply #89 on: Thu, 02 January 2020, 07:44:13 »
Any news?
Happy to hear that.  Both that it's still happening and the attitude of honoring prior commitments before starting new projects.
« Reply #90 on: Wed, 18 March 2020, 17:02:59 »
Any Updates in the Progress? Checking this thread weekly ^^ Hope the honeycombs are coming along fine
Offline alanskiii
« Reply #91 on: Wed, 18 March 2020, 17:04:28 »
I’m still down btw!
Offline subluxe
  • サブラックス
    • https://subluxe.ca/
« Reply #92 on: Thu, 19 March 2020, 13:06:20 »
I'm gonna safely assume this probably won't happen anymore :<
Offline Top Right Logo
« Reply #93 on: Thu, 19 March 2020, 14:07:23 »
Oh man, 15 would be perfect for my build. No way that gets through on votes though so not too devastated if it's shelved, but would be nice to see this project go through.
Offline Techichi
« Reply #94 on: Fri, 19 June 2020, 16:11:38 »
Is this still happening?
Offline syke
« Reply #95 on: Sat, 20 June 2020, 08:38:08 »
7u in Cherry is a must. wouldn't mind getting extras in 6u or 6.25u. Brass would be the icing on the cake.
Offline froueloop
« Reply #96 on: Sat, 20 June 2020, 20:49:51 »
6, the pink is so pretty
Offline dstaar
« Reply #97 on: Sat, 20 June 2020, 21:26:07 »
@VictorMTB, is this project still going on? thanks.
Offline KeebCalmAndCarryOn
« Reply #98 on: Thu, 02 July 2020, 07:54:44 »
Shiny natural aluminum, both sizes.  Also colors 6 and 10. Hope this project continues to move towards production.  Thank you.
Offline Anthixious
« Reply #99 on: Sat, 08 August 2020, 03:20:54 »
I'd love one space bar each of 13 and 14 if possible.
