Author Topic: [GB] BIOI G60BLE 60% PCB R2 (Extended to Oct 31st)  (Read 54314 times)
Offline Secret8znMan
Re: [GB] BIOI G60BLE 60% PCB R2 (Extended to Oct 31st)
« Reply #50 on: Sun, 09 August 2020, 09:39:15 »
What do I do with the orange LED? I got non hot swap version and I actually am not sure where and how I am suppose to solder it to. It's my first project like this, is there anybody here that can give me some advice?
Offline rooski15
« Reply #51 on: Sun, 09 August 2020, 09:48:01 »
There's a charging indicator pad you can solder it to.
See here:
https://scottywei.github.io/bioi-g60ble/
« Reply #52 on: Sun, 09 August 2020, 15:58:58 »
See here:
I've seen that picture, but I'm new to soldering. I know which side the contacts are, but which way should the hole in the tab face? Left or right?
Offline rooski15
« Reply #53 on: Sun, 09 August 2020, 16:30:47 »
See here:
I'd tack it on really light and test it. Then flip it if it doesn't work.
Offline andtar2
« Reply #54 on: Sun, 09 August 2020, 23:38:45 »
See here:
Check the BIOI G60BLE PCB Build Guide there are images showing LED polarites.
« Reply #55 on: Sun, 09 August 2020, 23:49:40 »
See here:
Thanks, this was exactly what I needed!
Offline Kuj0
« Reply #56 on: Sun, 04 October 2020, 15:54:41 »
Fingers crossed for a second round of this one. There are literally ZERO other options for hotswap bluetooth 60% PCBs from what I can find online.
Offline solomonshv
« Reply #57 on: Sun, 04 October 2020, 16:44:48 »
GK61XS is a 60% hotswap PCB with bluetooth: (4th option) https://www.aliexpress.com/item/32981170236.html
GK64XS is a 65% PCB that fits 60% cases, and is also hotswappable with bluetooth: (last option) https://www.aliexpress.com/item/4000993753892.html
do note that these don't use QMK or VIA. they are a trickier to program, but they do work. i have a polycarb KBD 5 degree board with the GK64SX that i use at work. setting up layers took a while to figure out, but once i got it set up it was fine.
Keebs::: Bok.CP - Antique Copper | Keycult No.2/65 Black/Brass | Keycult No.2 Rev 1 Grey/Brass | Jane V2 CE - Black/Multicolor | J-01 Rev1 - Blue | Haus - Silver | Kohaku - Red | OwLab Jelly Epoch - Ruby SE & Popcorn | KBD8X MKII WKL - Black PC | Ayleen WKL - Gin
Caps::: GMK Modo, GMK Jamon, GMK Olive, GMK Mizu, GMK Olivia++, GMK Bingsu, GMK Analog Dreams, GMK Botanical, GMK Moondust, GMK Taro R2, GMK Hennessey, GMK Serika R2, GMK Birch, GMK Tuzi, GMK Red Alert, GMK Zooted, GMK Hazakura, GMK Cyrillic Beige, GMK Lavender, GMK Daifuku, GMK November Fog, GMK Villanelle, GMK Blossom, DCS 9009 WYSE Alps
On order: GMK Tiramisu, GMK Maroon, GMK Bordeaux, GMK Taiga
