Author Topic: [IC]MAXKEY Virtual war  (Read 24674 times)
Offline hyperdolch
Re: [IC]MAXKEY Virtual war
« Reply #50 on: Fri, 18 October 2019, 08:13:58 »
Are there no 1.5U Ctrl, Alt yellow on gray?
Offline rockydbull
« Reply #51 on: Sat, 19 October 2019, 10:16:44 »
Yup those are missing and the spacebar kits are totally different. Nothing for uneven split space like 2.25/1,25/1.75
Offline GR1NN1NGC4T
« Reply #52 on: Sun, 20 October 2019, 14:11:23 »
I like the colours!
Is there going to be an international kit?
Offline BUGER
  • https://www.instagram.com/buger2501/
« Reply #53 on: Sun, 20 October 2019, 19:28:56 »
Group buying has started. Please check all the changes carefully. I hope most players will be satisfied.
https://geekhack.org/index.php?topic=102982.0
