Author Topic: [IC] SW (B)olch (Entering Production)  (Read 174841 times)
Offline Mcnos
    • GMK Fuyu
Re: [IC] GMK (B)olch
« Reply #100 on: Fri, 25 August 2023, 10:59:29 »
gonna be that guy and bump this...did this set die?
No, but I'm super late
Renaming the set to (B)olch. I will start a new IC once I have the kitting ready.
- Thanks Lightning
Offline FiEND
Re: [IC] GMK CYL (B)olch
« Reply #101 on: Sat, 26 August 2023, 12:35:53 »
clean & classy set. +1 for burgundy red alongside (or replacing) the blue.
Offline Dmitri
« Reply #102 on: Sat, 26 August 2023, 15:42:50 »
+1
Offline Mcnos
    • GMK Fuyu
« Reply #103 on: Sun, 27 August 2023, 09:46:38 »
I’m replacing the brown with a burgundy like red. Think it was mentioned
Edit: looks like I forgot to mention that part oops. The accents will be blue and red of a dark variant serparately to try and keep base moq low due to stock colors
« Last Edit: Sun, 27 August 2023, 09:56:40 by Mcnos »
Offline Mcnos
    • GMK Fuyu
Re: [IC] GMK CYL (B)olch - Currently Kitting
« Reply #104 on: Mon, 28 August 2023, 22:55:33 »
Blue Accent - Marinedunkelblau
Red Accent - Vogelkirschenrot
Legends will be changed to 2B for better contrast than GR9
« Last Edit: Mon, 28 August 2023, 23:47:06 by Mcnos »
Offline aicyborg
« Reply #105 on: Tue, 29 August 2023, 16:41:09 »
I'm guessing you're in the midst of overhauling kitting now but just for the record I'd love Nordeuk, or just UK support, if you could try it.
Offline Mcnos
    • GMK Fuyu
« Reply #106 on: Tue, 29 August 2023, 17:43:05 »
I’m doing barebones, but base will have UK/ISO support
Offline EdgeOfInfinity
Re: [IC] GMK CYL (B)olch (Kitting and verifying vendors)
« Reply #107 on: Thu, 31 August 2023, 14:40:19 »
this is.... actually fire!
i guess i'll never have enough gray/black sets
Offline pixelpusher
« Reply #108 on: Thu, 31 August 2023, 16:15:05 »
Will play well with Sky Modo too since the base colors are the same, right?
Might be a good time to pick up Sky Modo Accents
« Last Edit: Thu, 31 August 2023, 16:27:05 by pixelpusher »
Offline Mcnos
    • GMK Fuyu
« Reply #109 on: Thu, 31 August 2023, 18:31:48 »
I'm not 100% on the color on Sky Modo but if it's N9 it'll match, if it's CR it'll match as well.
« Last Edit: Thu, 31 August 2023, 18:34:09 by Mcnos »
Offline MoltenKhor
  • www.khor.store
    • Khor Store
« Reply #110 on: Mon, 04 September 2023, 09:48:04 »
you have my attention
Offline pixelpusher
« Reply #111 on: Mon, 04 September 2023, 14:53:56 »
Looks like it will match.  Sky Modo is TU2 legends  on CR mods and N9 Alphas.  I'll definitely pick up this set.  Very versatile.  I'm sure there are even more interesting mixes to be found as well.
Here's my photo of Sky Modo:
302373-0
Edited here to make the cyan legends gray:
302375-1
And here is a photo I took of N9(from Q:01) alphas and CR(from WoB) mods with white legends.
302383-2
Edited here to make the white legends gray. The gray legends of (B)olch will look quit nice, I think.
302385-3
Also shows how different those colors look depending on the light.  ;D
« Last Edit: Mon, 04 September 2023, 18:22:20 by pixelpusher »
Offline Mcnos
    • GMK Fuyu
« Reply #112 on: Tue, 05 September 2023, 11:08:05 »
The gray legends might be lighter since I changed it to 2B, GR9 might be a bit darker so I updated it to tackle the contrast challenge. Thanks for those "edits" as well. Good for those who want to see what i may look like irl.
Offline fuzzypanda24
« Reply #113 on: Thu, 28 September 2023, 23:57:20 »
Yes, more dark sets!!!  ;D
Offline Jecxz
« Reply #114 on: Tue, 03 October 2023, 19:48:27 »
consider my interest checked
Offline zacdxsvf
« Reply #115 on: Mon, 09 October 2023, 10:35:51 »
Interest checked!
Offline Thumb Key
« Reply #116 on: Mon, 09 October 2023, 11:19:27 »
It's so cool and fits all my black keyboards!
Offline atkins
« Reply #117 on: Tue, 17 October 2023, 02:29:38 »
EU - Prototypist
Are you aware that UK is not part of EU anymore and buying from Prototypist as a citizen of EU means very high shipping cost and import fees on top?
Offline aicyborg
« Reply #118 on: Tue, 17 October 2023, 07:55:33 »
EU - Prototypist
That bit could've just not been updated from 2019, and besides this forum has been endlessly whinging about most actual EU vendors for months now so they're probably an attractive option. At least ProtoTypist is reliable (and to the EU you won't pay import fees other than the sales tax you'd pay if you bought from any other). The only difference is around 10 Euro more in shipping. I've had stuff sent from PT to European friends and it wasn't difficult nor did it have hidden fees.
« Last Edit: Tue, 17 October 2023, 08:17:22 by aicyborg »
Offline Cringelord
  • Crack Connoisseur
« Reply #119 on: Fri, 20 October 2023, 01:38:38 »
I still want this. Also 2B accents maybe?
Offline diorite
« Reply #120 on: Sat, 21 October 2023, 06:53:49 »
can you ever have enough black and grey?
Offline diorite
« Reply #121 on: Sat, 21 October 2023, 06:59:52 »
Since the accents will be a separate kit I’d like to second the 2B accent suggestion, and maybe those could even be included in base?
Offline Akele
Re: [IC] DDolch
« Reply #122 on: Sat, 21 October 2023, 11:20:20 »
prays for international kit :)
Looks great!
I'd like to see an international kit too. I'll pray with you.
Offline Mcnos
    • GMK Fuyu
Re: [IC] SW (B)olch (In Production)
« Reply #123 on: Mon, 09 September 2024, 23:23:42 »
As title states
Were going into production soon. Unfortunately CYL is too costly as the hobby has died down and the time invested doesn't seem worth it as I find SW on par with GMK if not more to my liking.
If you have not heard of SW, it's an ABS/PBT blend, comes with best of both worlds from my understanding and I have been using them for months
After testing SW Keycaps with their SW Arctic run this was the summary I came to.
Looking to see vendor options, if you are a vendor and would like to order some for in stock, please reach out to me or YG from SwagKeys.
The accent kit and etc kits will be included with base. Do not have pricing yet but will come back to update with the samples in hand (This thread is just something I keep reviving every blue moon)
I will check on an international kit add-on. (I know some of you were asking, will check if its viable)
The RAL colors have been updated to use Pantones of similar depth. (Blue and Burgundy)
If there are any further questions I have not answered, feel free to PM or post a reply.
« Last Edit: Mon, 09 September 2024, 23:30:14 by Mcnos »
Offline //gainsborough
  • MATRIXの日常
Re: [IC] SW (B)olch (Entering Production)
« Reply #124 on: Tue, 10 September 2024, 00:00:43 »
Can confirm - SW keycaps are outstanding.
edit: also the packaging from SW is insanely high quality.  Here's the packaging for arctic
« Last Edit: Tue, 10 September 2024, 00:23:25 by //gainsborough »
Offline Mcnos
    • GMK Fuyu
« Reply #125 on: Sun, 03 May 2026, 20:50:32 »
I hadn't logged in a log time but heres samples.
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #128 on: Wed, 01 July 2026, 21:06:24 »
https://deltakeyco.com/products/swg-bolch?srsltid=AfmBOoow9xMv573psTHQV3HXd4ZlHuHR7B9plXleJlwQYJQ0_BvrOJFc
https://qwertyqop.com/products/swg-bolch?srsltid=AfmBOoosQDdxr54g2usm6QB94lPXR9Xfd3iwyGIow9JhVWIwg9fQ7Osy
https://swagkeys.com/products/swg-bolch
Is the the full vendor list or is there a US vendor?
Some vendors ran a GB in March. See KeycapLendar for the full vendor list including links.
US vendor was Bowl Keyboards.
Some vendors are currently taking pre-orders (for example Qwertyqop and DeltaKeyCo listed above), and production is estimated to finish in August.
See also info in Swagkeys' Roadmap.
« Last Edit: Wed, 01 July 2026, 21:49:31 by dvorcol »
Offline Mcnos
    • GMK Fuyu
« Reply #129 on: Mon, 05 October 2026, 22:41:05 »
People getting the set before I even got my hands on one 😭
