Author Topic: Good wireless keyboard kit  (Read 4224 times)
Offline ShadowFlame
« on: Tue, 15 October 2019, 06:23:40 »
Are there any good Keyboard kits with the following features under $120AUD,
60-65% (65% prefered)
Includes case, stabs, plate and PCB
Wired and Bluetooth wireless
Hot-swappable
RGB is nice but not needed
I would like a split space bar but I know I wont be able to get one
The current one I'm looking at is the gk61 but it's not a 65%, if I can't find a 65% though I'll just go with it.
https://www.aliexpress.com/item/32942776819.html?spm=a2g0o.productlist.0.0.e9a04131JPxyLz&algo_pvid=4df407f4-cc09-41b1-b1cb-0aaba6bc2016&algo_expid=4df407f4-cc09-41b1-b1cb-0aaba6bc2016-1&btsid=aa129691-214f-44d2-be04-3602caffdba7&ws_ab_test=searchweb0_0,searchweb201602_9,searchweb201603_52
Offline FRANCO
Re: Good wireless keyboard kit
« Reply #1 on: Thu, 17 October 2019, 15:16:36 »
Offline ShadowFlame
« Reply #2 on: Fri, 18 October 2019, 18:23:23 »
Thanks, sadly I missed it though.
