Author Topic: [GB] Klippe S Mechanical Keyboard by Mekanisk  (Read 101179 times)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« on: Sat, 19 October 2019, 09:32:26 »
Price: $310
(This will be outdated pricing when the group buy starts, please check the website.)
Colors: Ultramarine, R1 Grey, Silver, E-white
Included
  • Klippe S mechanical keyboard top and bottom piece, CNCed in aluminium (Standard or Blocked Corners)
  • Carbon fiber isolation layer for the plate mounting
  • Aluminium Plate with either European, or American layout
  • High quality, VIA compatible, printed circuit board designed by Wilba
  • High quality packaging for storage, initial and future freight (I have made the packaging good so you can reuse it, so please do not throw it away.)
  • 4x stainless steel screws for the plate mounting, 6x stainless steel screws for the case mounting, rubber bumpons
Optional add-ons
  • High density precision cut EVA foam infill for the case (+$10)
  • Brass plate upgrade(+$15)
  • PC plate upgrade (+$10)
  • E-White coating(+$30)
If it is an upgrade or not, is just personal preference. Plate material pricing is based on cost of manufacturing.
Extra parts
  • Extra aluminum plate $25
  • Extra PC plate $35
  • Extra brass plate $40
  • Extra top standard $70
  • Extra top blocked corners $70
  • Extra PCB $60
  • Extra CF isolation layer $25
Not included, but needed to complete the kit: PCB mounted stabilisers, switches, keycaps
Design
Klippe means Cliff in Norwegian. Based on the Klippe T(tray) by Mekanisk, the Klippe S has some considereable upgrades. It is bottom mount, with an isolation layer. It is mounted in a way that makes the typing experience even and has a richer sound. There is now also an option for blocked corners. Klippe S is designed for a firm and even typing experience.
Low starting height: 18mm (lowest on any Mekanisk board)
8 degree typing angle
Isolation
Standard isolation in form of a carbon fiber layer for the mounting plate to rest on. This does help elimitinating the potential for pinging and metallic sounds from the keyboard(which can occour on 2-part keyboards). All in all, it is an affordable way to ensure that the keyboard sounds like you want it to, without costing you more than necessary. It's nothing magic.
Typing experience
Klippe S has a firm and even typing experience by default, this is due to the plate resting around the whole case. You can adjust flex by customizing the plate and isolation.
Weight
Klippe S has no weight, however it weighs around 1.3 kg.
How to buy
As many of you know, I do not start out a new design by selling a large amount of units, then make the kits more available later. Initially there was going to be a raffle, however there might be some kind of FCFS in addition, or maybe just that. We have a little more time to figure this one out.
First round will have approximately 50 units. The next rounds will have more, and might have a different pricing, design and options.
When
Pre-order November 2019, maybe december. Shipping early 2020 or earlier.
Where
Mekanisk.co
"Picture of Klippe S at the Oslo, Norway mechanical keyboard meetup"
Klippe S at the Oslo, Norway mechanical keyboard meetup, ultramarine color and GMK solarized dark
"Picture of the Klippe S prototype"
Picture of the Klippe S prototype in "blocked corners configuration"
Disclaimers:
Pricing is not 100% finished, there will be some minor updates.
Typing test by vegs:
« Last Edit: Thu, 05 December 2019, 03:26:51 by LeandreN »
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Re: Klippe S Mechanical Keyboard by Mekanisk
« Reply #1 on: Sat, 19 October 2019, 09:33:36 »
Reserverad
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
Re: [GB] Klippe S Mechanical Keyboard by Mekanisk
« Reply #2 on: Sat, 19 October 2019, 11:36:25 »
Approved! Lykke til  :thumb:
Offline bisoromi
  • Formerly Duwang
  • owo
« Reply #3 on: Sat, 19 October 2019, 11:37:42 »
glwgb
(credits to Kokaloo)
Offline jb1830
  • @jonboulton
    • 1upkeyboards.com
« Reply #4 on: Sat, 19 October 2019, 11:38:18 »
Hi. Yes. Thanks.
    IBM Model M            Fjell 002           Klippe            KC60           Planck
Offline jillsandwiched
« Reply #5 on: Sat, 19 October 2019, 11:43:10 »
Definitely looking forward to this one!
Offline juliandoucette
« Reply #6 on: Sat, 19 October 2019, 11:48:31 »
Looking forward to it.
Will you open source the plate files? If so, and I cut my own plate, will it be compatible with a boardwalk PCB?
Offline MacSurfy
  • Designer & 3D artist
« Reply #7 on: Sat, 19 October 2019, 11:55:25 »
Looking good. I'm probably in for one  :thumb:
Offline Nigolski
« Reply #8 on: Sat, 19 October 2019, 12:03:26 »
dang
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #9 on: Sat, 19 October 2019, 12:05:41 »
I will look at some options for that. I hope to make this possible for this round yes.
Offline Andrehey
« Reply #10 on: Sat, 19 October 2019, 12:34:18 »
Glorious norwegian craftmanship! Can't wait for feedback on the PC case  ;D
« Reply #11 on: Sat, 19 October 2019, 12:49:02 »
glwgb
first time in a while i am very interested in a 60
wish it came in black
Offline martensson
« Reply #12 on: Sat, 19 October 2019, 13:35:27 »
PC Fjell when?!  :)
Offline Kistler125
« Reply #13 on: Sat, 19 October 2019, 13:54:18 »
E white Fjell? :eek: :eek: :eek:
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #14 on: Sat, 19 October 2019, 14:16:25 »
glwgb
Thanks you for your interest.
Offline Mcnos
    • GMK Fuyu
« Reply #15 on: Sat, 19 October 2019, 14:51:01 »
nice,
Wish there were more details photos though so I can make a more informed decision.
Offline Ensaum
« Reply #16 on: Sat, 19 October 2019, 15:47:48 »
Any chance at a half plate since the included pcb has flex cuts in it?
« Reply #17 on: Sat, 19 October 2019, 16:03:47 »
yeah half plate polycarb would be sweet
Offline painstar
« Reply #18 on: Sat, 19 October 2019, 18:02:08 »
This will be my first custom keeb if I can snag one. Very excited. I really appreciate the reasonable price point.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #19 on: Sat, 19 October 2019, 18:40:14 »
Not this round, however if we have them in the future, they’ll be available for purchase standalone. It’s just some features and options we have to leave out, sadly.
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #20 on: Sat, 19 October 2019, 19:12:19 »
Wow, really liking the huge upgrades you done here while keeping the price reasonable, awesome work LeandreN! Might have to pick one up if I got the funds when this goes live. Nov. & Dec. are tough months to have the extra scratch in though.
Offline jinrawke
« Reply #21 on: Sat, 19 October 2019, 19:14:39 »
It's definitely refreshing to see the price this low while it's almost becoming the norm for keyboards to be in the 500+ range.
Offline olazy
« Reply #22 on: Sat, 19 October 2019, 19:40:14 »
any details on the pcb/layout? hot swap vs solderable? fixed layout or multi?
 :thumb:
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #23 on: Sun, 20 October 2019, 02:41:08 »
Thank you, I appericate the kind words.
Thank you! Yes, it is a tough month for many, with Christmas coming up. It will run again later :)
 :thumb:
The PCB layout is the standard WT60-D layout. No hot swap. It supports ISO/ANSI/TSANGAN/HHKB.
Offline _PixelNinja
  • C=Q/V=ε(A/t)
« Reply #24 on: Sun, 20 October 2019, 04:24:53 »
Any chance you would consider FR4 plates for future rounds ?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #25 on: Sun, 20 October 2019, 04:38:10 »
Maybe in future rounds, however we are already pushing the limits in terms of options for this round.
Offline DJSwayde
« Reply #26 on: Sun, 20 October 2019, 06:19:29 »
I second this, I want to make this into an Alps board if possible.
60%: CannonKeys Bakeneko60
BUILD 1: Black | FR4 plate | Cherry Vintage Blacks & Vintage Grey (TX 55g springs) | Cherry G80-3000LPCXY-2 keycaps
BUILD 2: Black | 1upkeyboards π60 (pi60) PCB | 1upkeyboards FR4 plate | Akko Rosewoods | HammerWorks CRP R6 Egyptian Alphas kit & CRP R7 kits (40%, 60%, Spacebars, Stepped Modifiers) keycaps
 | GEONWORKS Frog Mini
Silver | HHKB | 4pplet Steezy60 (Alps) PCB | Custom SS plate | Alps SKCL Yellows | Canon S-14 & S-16S keycaps
| GEONWORKS LAUNCHER60
Silver | Custom PCB | Custom SS plate | Alps SKCL Creams | C.Itoh CIT224F & IBM 5140 keycaps
| LSJ Ares
Silver | Custom PCB | Custom SS plate | Alps SKCL Browns & SKCL Amber | IBM Multistation 5556-CC1 (TW) & P70 (ANSI-US, 06-89) keycaps
 | LZ CLS h
Silver | Custom PCB | Custom SS plate | Alps SKCM Creams | MET Micro Officer 6000 (R315-00) & Zenith Data Systems TurbosPORT 386 keycaps
| MONOKEI Kei R1
Standard Red | Aluminum plate | Cherry Vintage Blacks & Vintage Grey (TX 55g springs) | Cherry G81-1291SAW & G81-3090SAQ (Schneider) keycaps
| SINGAKBD Unikorn R1
Black | Black aluminum plate | Cherry Retooled Blacks (TX 60g springs) | G80-3485LWNUS (Das Keyboard II) keycaps
| Wangus x KEZEWA Snake60 R2
Sage (re-anodized hot pink) | WKL | Custom PCB | Custom SS plate | NMB "Space Invader" (White one-eye linear [fourth generation]) | NMB RT-101 (NCD) keycaps
 | Weaston GSKT-00-Z
Silver | AEK HHKB | Aluminum plate | Alps SKCL Greens | Apple Extended Keyboard II (M3501, Taiwanese) & Standard Keyboard (M0116, US) keycaps
Pad: KBDFans KBDPAD MKII
Black | FR4 plate | Cherry Vintage Blacks (TX 60g springs) | Cherry G80-3485LWNUS (Das Keyboard II) keycaps
| KBDMania KMAC Pad
Titanium grey | Aluminum plate | Cherry Vintage Blacks (TX 60g springs) | Cherry G81-3090SAQ (Schneider) keycaps
| Leopold FC 210TP
White | Custom PCB | Custom SS plate | Alps SKCL Compact Greens & Alps SKCL Browns | C.Itoh CIT224F keycaps
| Momokai Aurora
Cherry Vintage Blacks (TX 55g springs) | Cherry G80-3000LPCXY-2 keycaps
Topre: PFU Ltd. HHKB Pro 1 (PD-KB300BN)
hasu Alt USB controller | Topre Realforce 91UDK-G (NG02B0) & Realforce 103UB (SE42B0) keycaps
| PFU Ltd. HHKB Pro 2 (PD-KB400B)
hasu Alt Bluetooth controller | Purple sliders | 35g domes | Stock & Topre Realforce Taiwanese kit (dark gray) keycaps
| PFU Ltd. HHKB Pro 2 Type-S (PD-KB400WS)
4pplet SHKB Lite controller | 25g domes | Topre Realforce 87UW55 (SE08T0), Realforce 91UW (NE0100), Realforce Taiwanese kit (white) keycaps
| Topre Realforce 23U (WC0100)
Cipulot EC23U PCB | Purple sliders | SS plate (modified to allow for 24U) | 25g domes | JUKI Celavi keycaps
 | Topre Realforce 87UW (SE08T0)
Purple sliders | 30g domes | Sony BKE-9400A, MKS-8050, PVE-500, stock keycaps
| Topre Realforce 91 (NE0100)
Cipulot RF R1 8-9Xu PCB | 30g domes | JUKI Celavi & Topre Realforce 108UG-HiPro (YK0100) keycaps
Other: Apple Desktop Bus Keyboard (C658-4081) (CA)
Alps SKCM Oranges & SKCL Lock Cream
| Apple M0110A (US)
Beige | Vortex ViBE (US) (case installed inside) | Custom PCB | Custom SS plate | Alps SKCM Blues | Hewlett Packard HP Portable Vectra CS (US) & R/332 Instrument Controller (US) keycaps
| KUL ES-87
Black | Keygeek Su Color V2s (45g) | MW Heresy (with Gluttony & Envy kits) keycaps
| Zuoya HE30
Black | Hotswap: Keytok Novas / Wooting Lekker Tikken Mediums | Ranked POM keycaps
Collection
Offline tentboy
« Reply #27 on: Sun, 20 October 2019, 07:57:52 »
v interested
Offline JJ
« Reply #28 on: Sun, 20 October 2019, 08:02:14 »
extremely interested
Sent from my SM-G9600 using Tapatalk
Offline macclack
  • The rhythm of the game
    • Macclack
« Reply #29 on: Sun, 20 October 2019, 10:36:29 »
Cool to see how the Klippe has evolved. I'm very tempted to get in on this.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #30 on: Sun, 20 October 2019, 15:43:18 »
Thank you for your continued support.
Offline pott
« Reply #31 on: Sun, 20 October 2019, 17:39:57 »
Very cool! Will this plate support a split backspace layout? (HHKB compatibility is mentioned, but not for the split backspace specifically.
« Reply #32 on: Sun, 20 October 2019, 17:44:48 »
you can see from the plate in the render that it is supported
Offline pott
« Reply #33 on: Sun, 20 October 2019, 18:04:23 »
Ooops. I see it now; indeed it does. Thanks!
Offline Lyle88
« Reply #34 on: Mon, 21 October 2019, 05:58:58 »
Is there enough space to fit a battery in the case behind the PCB?
Offline Grindbox
« Reply #35 on: Mon, 21 October 2019, 11:37:51 »
I'm in the same boardwalk boat!  If I could somehow get this case without the pcb and plate that would be preferable :)
Offline SaltyStorm
« Reply #36 on: Mon, 21 October 2019, 22:52:51 »
This looks really good, can't wait to buy it. I'm still relatively new to custom keyboards, and I was wondering if i would be able to buy it... well obviously I'm going to buy it, but I'm not sure if there is going to be the raffle thing or whatever.
Offline japanesehorrorwriter
« Reply #37 on: Mon, 21 October 2019, 23:04:53 »
Yup.
« Reply #38 on: Mon, 21 October 2019, 23:28:40 »
read the OP, this will be done raffle style
enter the raffle
if you don't win, spend the extra cash and get one on mm, or wait for the second round
leandren is meticulous (which is good, don't get me wrong) so the second round could be months away
up to you
Offline bananathock
« Reply #39 on: Tue, 22 October 2019, 05:21:11 »
egggssssoiiiiteeed! yes! klippe S!
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #40 on: Tue, 22 October 2019, 14:22:45 »
enter the raffle
up to you
Thanks puddsy. Means a lot !
« Reply #41 on: Tue, 22 October 2019, 19:57:36 »
enter the raffle
up to you
i do my best
i'm still debating going in for this, not sure what to sell to make room for it if i do, probably my mira
Offline despairsray
« Reply #42 on: Thu, 24 October 2019, 01:43:47 »
This looks great. Are the bezels on the case a little fatter on these compared to the Klippe T or are they identical? Def interested even though I ordered the T recently.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #43 on: Thu, 24 October 2019, 01:48:24 »
Yes, the bezels are larger. This is mainly due to the plate resting around the entirety of the case.
Offline bdegal
« Reply #44 on: Thu, 24 October 2019, 13:09:55 »
I really like the dark blue color in the first picture but I don't see this option on your site. Will this be an option?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #45 on: Thu, 24 October 2019, 13:11:26 »
Yes.
Offline p_blaze
« Reply #46 on: Thu, 31 October 2019, 22:20:11 »
awesome work as usual
hope there will be a WKL board from you someday for people like me who can't let go of their control keys
Offline fleeceman
« Reply #47 on: Mon, 04 November 2019, 17:10:16 »
Any typing tests?
Offline dwarflemur
« Reply #48 on: Mon, 04 November 2019, 18:30:46 »
just map control to the capslock key
Camp C225 | Norbatouch | ALF X2 + X3 | Orange TKL | CA66 | Leaf 60 | a bunch of others
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #49 on: Tue, 05 November 2019, 02:30:31 »
Any typing tests?
Not yet, as I don't have a good microphone which causes it to sound entirely different on video than in real life.
