Author Topic: [IC] GMK Sloth - GB starts next week!  (Read 232944 times)
Offline d00deitsnik
  • Grails: SA Olivia, 1800 w/ only Latriualum keycaps
Re: [IC] GMK Sloth
« Reply #50 on: Thu, 09 January 2020, 00:35:25 »
So any idea when this is going to make progress? This a really good set.
Yes, currently slotted for 2nd half of 2020.  ;)
Sweet!! This is the GMK highlight of the 2nd half of 2020 for me 🙌
Offline stevenT
Re: [IC] GMK Sloth
« Reply #51 on: Wed, 29 January 2020, 19:05:52 »
Let's make it happen
Offline fabijolo
  • I like expensive plastic.
Re: [IC] GMK Sloth
« Reply #52 on: Sat, 01 February 2020, 09:40:49 »
This set looks great, the only thing I would really love to have changed, is if the ESC Novelty would alsow be available with dark brown as its main colour
Offline //gainsborough
  • MATRIXの日常
Re: [IC] GMK Sloth
« Reply #53 on: Tue, 10 March 2020, 21:53:47 »
No Kristen Bell novelty?
=P
Offline driftingbunnies
Re: [IC] GMK Sloth
« Reply #54 on: Tue, 10 March 2020, 21:57:30 »
=P
Haha that's a great idea! I'm not sure how I would get that done though. Not sure her face would translate well  ;D
Re: [IC] GMK Sloth
« Reply #55 on: Wed, 25 March 2020, 09:36:11 »
Hey everyone! I'm looking at the kits again for sloth and based on the feedback in the IC form, I'm considering cutting the 40s kit. I've added split spacebars to the spacebars kit and added the extra B to the base kit. Please let me know what you guys think! If you're a 40% user, please voice your opinions so I can know if there's enough demand for it. Thanks!
238373-0
Offline konstantin
  • Formerly constexpr
Re: [IC] GMK Sloth
« Reply #56 on: Wed, 25 March 2020, 10:06:50 »
Base kit mostly looks good, but I'd replace the R3 #~, R4 \| ISO keys (partial and inconsistent ISO-UK coverage) with R3 \|, R4 <>, which are better for neutral ISO support (and also cover ISO-US fully). I also suggest changing the stepped Caps↲Lock legend to just Caps, since otherwise it's the only two-line legend in the set.
I would move the extra B to the spacebars kit. The reason being that most people who want to outfit their ergo board with proper keys/legends are probably going to end up buying the spacebars kit anyway. So, to me at least, the extra B and 2u/2.25u/2.75u spacebars kind of naturally go together.
Speaking of the spacebars kit, feel free to remove the 1.75u space since only about three 40% designs out there use it in total (and one of them actually requires two 1.75u's, so a single key doesn't do much).
« Last Edit: Wed, 25 March 2020, 10:16:00 by constexpr »
Re: [IC] GMK Sloth
« Reply #57 on: Wed, 25 March 2020, 10:10:19 »
Thanks for the feedback! I'll take out the 1.75u space. Since the Alice layout is getting more and more popular, is there are reason not to include the extra B key?
Offline konstantin
Re: [IC] GMK Sloth
« Reply #58 on: Wed, 25 March 2020, 10:18:17 »
You're welcome. Since it's just one key, it's your call. But since you'll be removing a key from the spacebars kit, effectively freeing up a spot, and also because of the reasons I gave above, I think it makes more sense to move the extra B to the spacebars kit.
I edited my post with a suggestion for the stepped Caps Lock legend in the meantime; check that out as well.
Offline depletedvespene
    • Keyboard-related resources.
Re: [IC] GMK Sloth
« Reply #59 on: Wed, 25 March 2020, 11:01:45 »
Came here to say this.
English (US), terminal style, seems to be the best all-around choice.
Re: [IC] GMK Sloth
« Reply #60 on: Wed, 25 March 2020, 15:35:18 »
I have no issue changing the ISO. It doesn't really affect me so I'll make this last change to it to include terminal style.
Re: [IC] GMK Sloth
« Reply #61 on: Sat, 28 March 2020, 22:56:34 »
<quote snipped>
Thanks for letting me know! Fortunately we're hoping to have the GB start before then :)
« Last Edit: Mon, 12 July 2021, 13:46:43 by HoffmanMyster »
Offline Karni
Re: [IC] GMK Sloth
« Reply #62 on: Sun, 29 March 2020, 00:40:05 »
i love the deskmat
Offline Scucka
Re: [IC] GMK Sloth
« Reply #63 on: Sun, 29 March 2020, 05:21:23 »
Colours are great! Good luck on this project  :thumb:
Offline bwolmarans
  • hello to you
Re: [IC] GMK Sloth
« Reply #64 on: Tue, 31 March 2020, 13:28:11 »
Reminds me of Olive but friendlier more interesting tones.
I'm in for sure. Wallet screaming, but in.
Best set for what's left for the rest of this year as far as I can see.
~it's time to fly~
Re: [IC] GMK Sloth
« Reply #65 on: Fri, 03 April 2020, 11:25:35 »
Appreciate it! Please let me know if there are any artisans any of you would like to see!
Offline KEYGEM
    • KEYGEM Online Shop
Re: [IC] GMK Sloth
« Reply #66 on: Fri, 03 April 2020, 14:19:30 »
I like the light colors you use. Really cute desk mat :)
Offline nasp
Re: [IC] GMK Sloth
« Reply #67 on: Fri, 03 April 2020, 16:05:14 »
If you'ree going to cut 40's, at least consider adding ortho support in base (4 keys) or adding ortho/staggered 40's support (6 keys).
Thanks DB!
Re: [IC] GMK Sloth
« Reply #68 on: Wed, 08 April 2020, 09:52:10 »
http://www.strawpoll.me/19724758
Please help me decide what colors I should use for the RAMA cap. Thanks everyone!
Re: [IC] GMK Sloth
« Reply #69 on: Sat, 11 April 2020, 09:26:47 »
Thanks DB!
Is it possible to include ortho support without using the Read/data/out/etc keys? If so, let me know and I can add those.
Offline Rumblehotep
Re: [IC] GMK Sloth - Help me decide on RAMA cap!
« Reply #70 on: Sat, 11 April 2020, 09:57:11 »
Laziest RAMA sloth cap possible would be just a brass Esc
« Reply #71 on: Sat, 11 April 2020, 10:00:14 »
I got a mockup of the brown with cream sloth. looks good  ;D
Offline DuellM
  • Keyboard Fatty
« Reply #72 on: Sun, 12 April 2020, 07:40:51 »
<quote snipped>
Ooh I like that!! The enter key can have the smiling sloth from the deskmat
« Last Edit: Mon, 12 July 2021, 13:46:50 by HoffmanMyster »
Offline Mcnos
    • GMK Fuyu
Re: [IC] GMK Sloth
« Reply #73 on: Sun, 12 April 2020, 07:44:00 »
Yes
« Reply #74 on: Sun, 12 April 2020, 09:27:17 »
<quote snipped>
The smiling sloth from the deskmat is already one of the novelties. There might be too many if it's an enter rama key as well. Personally I haven't talked to that many people who like those rama enter key so I don't really have plans to include one.
« Last Edit: Mon, 12 July 2021, 13:47:57 by HoffmanMyster »
Offline Kaptain Mike
  • discord: kaptainmike
« Reply #75 on: Mon, 13 April 2020, 00:00:27 »
Super excited for this!!!I'd love to see this on the Evolv 75 if possible. Good luck with this.
Offline Zenith10010
« Reply #76 on: Mon, 13 April 2020, 07:59:35 »
Love the theme. Any chance of a Canadian vendor?
Offline 28.8kbps
« Reply #77 on: Mon, 13 April 2020, 10:03:07 »
I really like the simplicity of this set! Any chance of UK modifiers for 2&3?
« Reply #78 on: Mon, 13 April 2020, 10:22:01 »
<quote snipped>
I like the walking sloth more, yes the smiling sloth would be too many if use in rama key. The long(?) arms are also essential to me so if the rama key could be longer then that would be perfect. Btw would it be strange to use brown key with grey infill for the rama?
I tried that and it does look a little strange. There's not quite enough contrast between the brown and the mod gray.
239824-0
« Last Edit: Mon, 29 November 2021, 15:47:14 by HoffmanMyster »
« Reply #79 on: Mon, 13 April 2020, 10:23:03 »
That would require `123 and the ISO keys to change correct?
Offline konstantin
« Reply #80 on: Mon, 13 April 2020, 21:05:09 »
2@ → 2"
3# → 3£
right Alt → Alt Gr (optional)
Offline Rumblehotep
« Reply #81 on: Tue, 14 April 2020, 03:13:12 »
Definitely brown & cream
I would be remiss not to mention in a thread of sloth afficionados my favorite children’s book about a piranha whose dream is to eat a sloth.
239862-0
Offline konstantin
« Reply #82 on: Tue, 14 April 2020, 05:42:54 »
Dang, even the colors match!
Offline kaspertypees
« Reply #83 on: Tue, 14 April 2020, 07:45:14 »
Yes, Finally a set which looks cute and matches everything that i own
 :thumb:
can't wait for this set to start its group buy / sale
« Reply #84 on: Tue, 14 April 2020, 11:59:20 »
Haha maybe i need to include that as one of the GB items...
Offline BigBabyJesus
« Reply #85 on: Tue, 14 April 2020, 12:05:24 »
First time I saw this set I thought "Eh" but now I love it!  :thumb:
« Reply #86 on: Tue, 14 April 2020, 13:35:39 »
Few updates after taking in all the feedback recently -
  • ISO - I'll stick to ANSI PC ISO. I'd like to reduce as much costs so that people can purchase base + novelties without paying too much
  • Novelties - I've added some new novelties since this is a large part of the set. New faces and some novelty arrows in the accent color
  • Renders - I've requested renders of the updated kits. These will be final unless there's an essential key that was missed
  • RAMA artisan - I've decided to do that brown cap with cream sloth. A mockup has been made and it looks great!
  • CAN Vendor - not sure about this one. I'm going to ask other vendors for advice
  • 40s - 40s kit will be included. It's roughly ~25% of the IC and I think it might be popular enough to meet MOQ with some extras. I've included the accent split bars there and put alpha split bars in the spacebars kit and moved the 'B' over
239906-0
Offline soran
  • what have I done
« Reply #87 on: Tue, 14 April 2020, 13:42:03 »
No alpha-coloured spacebars in the 40s kit? I would personally rather have a separate accent spacebar kit.
Offline konstantin
:thumb: for switching to Super.
How about Caps instead of Caps↲Lock for the stepped key? It would match Scroll and Num better.
I actually don't mind Caps Lock. Is there a set that has just Caps that you can show me? I'm sure there are but I can't think of one at the moment.
« Reply #90 on: Tue, 14 April 2020, 13:52:05 »
Are you saying there should be two spacebar kits? One alpha colored and one accent colored? I'm afraid it might be tougher to hit MOQ for both of them if I were to split them.
Offline konstantin
Yeah, Analog Dreams, Alter, Taro R2 come to mind.
Offline soran
  • what have I done
« Reply #92 on: Tue, 14 April 2020, 15:21:00 »
Looking at past sets, big portion of them had both colours of the bars in the 40s kit or in the spacebar kit. For example, people who want accent spacebars for Alice-like boards have to buy both kits anyway.
With 40s kit sales being around 10% of the base most of the time, I would say that it's save to assume, that it would hit moq with both colours included.
As for the separate accent spacebar kit, I guess Naut 2's spacebar kits has been stuck in mind for a while, sorry.
« Reply #93 on: Tue, 14 April 2020, 15:30:51 »
I guess the best way to just remove accented split spacebars all together. I don't think I can kit similar to Naut 2 since it's a much more established set.
239908-0
« Last Edit: Tue, 14 April 2020, 15:48:49 by driftingbunnies »
Offline soran
  • what have I done
Yep, that I could get behind
Offline Zenith10010
If your looking for a Canadian proxy (I hope you get one). Seems like most people are going with Deskhero.ca
Offline kbye
+1 for deskhero!
Updated renders of the kits to show the final kits.
Offline cemoon
Count me in for Lazy AF and Sloveties. Rama keycaps look sick too.
Offline ohyayitstrey
These are adorable.  I will at the very least be getting the mat
