Author Topic: Broken Matias Mini Quiet Pro  (Read 1867 times)
Offline sandywind
« on: Wed, 30 October 2019, 06:57:42 »
Hi, my Mini Quiet Pro suddenly (literally) died.
Well, a few week ago Esc stopped registering except by applying a really disproportionate force, I thought that was due to a mechanical problem of that switch alone.
Now, no key works, I tried two computers and several USB cables.
Is anyone an expert in the hard ware of this particular keyboard? Is it feasible to repair it or should I simply put it in the drawer of historical/broken peripherals?
Corsair Vengeance K65 w/ SP DCS Twilight Keycaps | Poker II w/ Danger Zone keycaps | HHKB Pro 2 | Realforce 87UW55 | IBM PC BS 80's | OLKB Planck | IC WhiteFox | Varmilo VA87ML
Offline geewiz
Re: Broken Matias Mini Quiet Pro
« Reply #1 on: Wed, 30 October 2019, 07:08:54 »
I had the same issue with some keys not working on my new Matias Ergo only two weeks in. Contacted the vendor and their answer “just massage the keys a bit” annoyed me so much that I threw it into the attic and bought a Kinesis Freestyle Edge.
Turns out that these issues are quite common because QC on Matias switches is terrible. I might eventually buy a few replacement switches and take a soldering iron to the Ergo.
However, your whole keyboard stopping to work sounds like a different cause since all the switches failing at the same time seems pretty unlikely.
Offline sandywind
« Reply #2 on: Wed, 30 October 2019, 12:32:47 »
I also believe the problem with the switch was unrelated.
BTW which switches did you choose for your Kinesis?
Offline geewiz
« Reply #3 on: Wed, 30 October 2019, 13:49:01 »
MX Brown. Choice was very limited IIRC.
