Author Topic: [IC] Hammerhead, a 40% staggered PCB featuring AMJ40, JD40 and VCore compats  (Read 5302 times)
Offline Gondolindrim
    • My GitHub
Hammerhead Shark. The hammerhead sharks are a group of sharks in the family Sphyrnidae, so named for the unusual and distinctive structure of their heads, which are flattened and laterally extended into a "hammer" shape called a cephalofoil.
Hi there guys!
As I'm not a prominent community member, I first present myself. I'm Gondolindrim, a Brazilian mech enthusiast and PCB designer. Most of my PCB projects are open-source and can be found in the Acheron Project, which is the compendium of PCBs and documentations.
Following the success of the SharkPCB, I bring to you the Hammerhead, which is intended to be the natural following version of the SharkPCB. This PCB is actually the first one I have ever designed for the hobby, to replace the PCB of an old AMJ40 case I bought off of r/mm, so it is really close to my heart. An eventual GB is going to happen with Stenven Wood at Wood Cables, the same vendor that did the SharkPCB group buy.
The intention of this IC is to gather feedback on the present state of the PCB, how we intend to design and distribute it, the features required by the community, and how we can make this PCB the most inclusive possible.
The PCB
The PCB has some nice features to it, despite its simple nature:
  • USBC connector;
  • ESD protection on data lines;
  • TVS (Transient Voltage Suppression) on power lines, protecting the PCB from voltage spikes;
  • Full digital power rails isolation and filtering, stabilizing MCU voltage and avoiding power bugs;
  • Data lines differential pair impedance matching through differential-coupled ferrite core choke;
  • Cable shield discharge protection;
  • Overvoltage and overcurrent protection;
  • Current inrush protection from metallic cases;
  • ARM STM32F072 processor; all unused pins are broken out so that the user can expand the PCB in any way. I might switch it over to STM32F303 given the current state of QMK being, at least for now, aimed at supporting 303 before 072.
  • Compatibility with Vortex Core, JD40, AMJ40 and Shark cases.
As all the PCBs in my open-project Acheron, the Hammerhead is open-source. I You can access the files at the Github repository GitHub repository..
The PCB documentation will be found at the AcheronDocs page , where all documentation for the Acheron Project PCBs are. As of today the Hammerhead does not have a page, but I'll add it shortly once I prototype them.
The PCB is QMK compatible. VIA compatibility is not an option at this time as VIA is not accepting new boards right now, but in the future maybe they will open up again and, if they do, I will try to make it compatible.
Supported layouts
See the below image for the proposed layouts. These are subject to changes, specially after community feedback.
Preliminary PCB renders
Renders obtained through tracespace.io website. These renders are for visualization only and are prone to changes, specially after community feedback.
Intended feedback
I have received many queries from people wanting a PCB compatible to their Minivan keyboards, since Evan from TheVanKeyboards is sadly closing shop. The issue, however, is that the Minivan layout is very particular and a special PCB would have to be designed for that, since the majority of 40% staggered layouts use a 12U width configuration while MV uses 12.75 . I want to know if there is enough interest for a Minivan-compatible PCB.
Also I'd like your input on hotswap. I am not a huge fan, but I can definitely see why people like it.
Third, per-key LEDs; the Shark had so little LED users that honestly I feel it is a legitimate question if you guys want those per-key LEDs there. We can of course offer RGB underglow, as QMK is soon to support it in ARM processors soon.
Finally, layouts; the first ever 40% I used was a Vortex Core, and the AMJ layout did feel a little clumsy so I designed the PCB around variations of the VCore (6.25U spacebar, split shift and whatnot). Unfortunately there is not a big consensus on 40% staggered layout, as each board features its unique layout. I want to be as incluse here as possible, given also that the PCB is supposed to be compatible with VCore, JD40, AMJ40 and Shark cases. Please comment on what layouts you would like to see on this PCB and what am I missing.
Closing thoughts
I honestly need feedback from you guys as that's how I learn as a designer and make my PCBs better for the community.
I might do a prototype round for this PCB, which will probably be the same raffle style as the Doddle60 was. I won't be assembling these myself though -- Steven will probably want to hire a PCBA, which will considerably ramp proto prices up.
If you guys want to contact me directly, please do so over Discord. I love to chat and talk about stuff.
« Last Edit: Thu, 31 October 2019, 11:01:17 by Gondolindrim »
A pessimist will tell you the cup is half empty. An optimist will tell you the cup is half full. An engineer will tell you it's exactly twice the size it needs to be.
Offline fcoury
Gondogod, you're too good to be true. Instabuy for me!
    • My GitHub
Oh stop it you silly. Love you buddy.
Bromance aside, ideas? Feedback? Gib ideas plox
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
Nice, we could use a "general purpose" PCB along these lines.
We could also use a nice widely-available case... maybe someone like Worldspawn wants to whip up an acrylic case to go with it?
    • My GitHub
That would be amazing!
BTW: f*ck word. LaTeX all the way
Offline valkyr1e
For the right Shift split (the pink keys), would it be possible to have 1-1.25u option as well? (So this will align the right 2 bottom row keys). Currently, only 1.25-1u split is mentioned.
    • My GitHub
Suggestion added! Thank you. Never thought of that option!
Offline odd
Any future thoughts of maybe expanding this PCB to be a 45% PCB? There are plenty of JD40 compatible PCB's out in the wild but for some reason the JD45 has been completely ignored and I would live to have backup PCB's for those boards. I love your design BTW and will be sure to try and get a couple of these PCB's at some point.
