Author Topic: [IC] SKB2 - steel, isolation top mount, powder coated / ETA set!  (Read 802565 times)
Offline PlastikSchnittstelle
Re: [IC] SKB2 - steel case, isolation top mount, powder coated or stainless
« Reply #800 on: Sat, 21 March 2020, 16:46:32 »
I will set up a discord once the gb goes live, about two weeks from now.
mentioned in the todo section  ;)
Offline Bl4ck
« Reply #801 on: Sat, 21 March 2020, 17:02:09 »
Oh... Ok!
Offline Bl4ck
« Reply #802 on: Sat, 21 March 2020, 18:44:00 »
Do you know if mill max sockets like 0305 would fit the case?
Edit: Wondering if I should get an extra PCB to have one hotswap and one not :)
« Last Edit: Sun, 22 March 2020, 16:18:50 by Bl4ck »
Offline konstantin
  • Formerly constexpr
« Reply #803 on: Sun, 22 March 2020, 13:50:50 »
Will YAS PCBs be available during the GB again?
« Reply #804 on: Mon, 23 March 2020, 07:51:41 »
Yes, about eight of those PCBs.
YAS option will only be available because I have those left from SKB1.
So YAS will only be a very small amount.
« Reply #805 on: Mon, 23 March 2020, 07:59:05 »
Yes, they fit. I have built one of the 60% prototypes with the "DZ60RGB V2 Hot Swap PCB" inside, there is enough clearance.
Offline Obstsalatjaa
« Reply #806 on: Mon, 23 March 2020, 08:15:33 »
Whats the price range ? Options
« Reply #807 on: Mon, 23 March 2020, 08:56:12 »
The price is TBD, like mentioned in the start post.
However, I did gave an estimate a few posts ago, here.
What do you mean by "Options"?
Offline Bl4ck
« Reply #808 on: Mon, 23 March 2020, 09:40:32 »
Oh, I see... if it can have kailh sockets it for sure can have mill max :)
« Reply #809 on: Mon, 23 March 2020, 09:45:10 »
Exactly, that's what I was thinking ;)
Offline Bl4ck
« Reply #810 on: Mon, 23 March 2020, 09:52:23 »
Quick question, what does early bird price include?
« Reply #811 on: Mon, 23 March 2020, 09:56:38 »
Quick answer: An SKB2 case of your choice.
Roughly of 20% advantage over normal price. So if your choice will be one of the bigger cases you might still have a small amount left to pay. Had mentioned it, but I don't know where :)
Offline teejstroyer
« Reply #812 on: Mon, 23 March 2020, 09:58:01 »
Yea, I’ll be completely honest, I just paid the invoice without knowing what I was getting. I’m just happy to be here.
« Reply #813 on: Mon, 23 March 2020, 09:59:31 »
 :thumb:
Offline Bl4ck
« Reply #814 on: Mon, 23 March 2020, 10:25:29 »
Case, but I'm assuming plate, and no PCB? or also comes with PCB
« Reply #815 on: Mon, 23 March 2020, 10:28:47 »
Case and plate. PCB will have to be added.
Offline Bl4ck
« Reply #816 on: Mon, 23 March 2020, 10:31:47 »
Ok I see
Offline darthcstis
« Reply #817 on: Mon, 23 March 2020, 14:49:28 »
I noticed you have a render for the lunar keys in your banner, any chance you have a better picture of it? i just bought that key cap set and i think this board is the perfect board for them. Thank you.
« Reply #818 on: Mon, 23 March 2020, 15:10:51 »
Yes, that's supposed to be lunar. I can make another rendering tomorrow.
Offline cadrev
« Reply #819 on: Mon, 23 March 2020, 15:21:35 »
Is it possible to have a rendering of GMK Nautilus with the yellow 75% case? I've been eye-ing this combo for a while now ever since seeing the RAMA M65 E-Yellow + GMK Nautilus combo. Looks like GMK Nautilus V2 GB should drop this april too so I guess that far off dream combo will come true  ;D
Offline donutsandhorses
« Reply #820 on: Mon, 23 March 2020, 16:19:45 »
I don't necessarily need a render (although it would be very appreciated), but what are your thoughts on grey vs. the Inox Nickel with SA Godspeed? I was hoping for naked Inox but the Nickel is still really interesting!
Offline nuno99costa
« Reply #821 on: Mon, 23 March 2020, 21:29:53 »
If we are requesting renders, I'd love to know how GMK Taro will look on the 95%  ;D
Offline ZG2047
« Reply #822 on: Tue, 24 March 2020, 02:23:44 »
Would be nice if you made a final pool on colors in order to help you make the final decision
Offline rinkaan
« Reply #823 on: Tue, 24 March 2020, 10:17:35 »
Nickel coated stainless will be one of the options?
Was actually deciding between nickel coated stainless and bead blasted stainless... Happy to get either... :) hope it is under 200 eurs with shipping and tax
Sent from my Redmi K20 Pro using Tapatalk
Offline Vigrith
« Reply #824 on: Tue, 24 March 2020, 13:01:43 »
You should definitely be good at under 200€, Plastik is in Germany so if you're in EU (which you probably are since you used euros) shipping will be reasonable and there'll be no additional VAT.
« Reply #825 on: Tue, 24 March 2020, 13:11:04 »
I think only the biggest version will land over 200€ - but that will be including PCB and shipping.
Bigger PCBs will of course be more expensive than smaller ones.
The 95% without PCB and shipping will be roughly 150€.
The 40% will be a little under 100€, the rest will fall inbetween.
« Last Edit: Tue, 24 March 2020, 13:15:39 by PlastikSchnittstelle »
Offline Vigrith
« Reply #826 on: Tue, 24 March 2020, 13:20:04 »
Yea I was generalising a bit, I know your prices aren't set yet even, main take away was that there'll be no extra tax at play since it's an EU based GB and shipping tends to be reasonable.
Offline About
« Reply #827 on: Tue, 24 March 2020, 15:35:59 »
Really liking the look of this board, but I have just one question.
Is it be possible to use a different PCB for the 65%? to add Hotswap for instance.
Sorry if this is a stupid question, I'm fairly new to the custom keyboard scene.
Offline nuno99costa
« Reply #828 on: Tue, 24 March 2020, 15:47:37 »
I think you can, just make sure the usb port is in the right place (although Plastik could confirm).
Also, you can use millmax sockets to get hotswap in the regular board
BTW, Plastik, which colors are 100% getting made? Saw on one of your posts that black might not make it and I'm not sure if any of the other colors will match with gmk taro.
Offline Bl4ck
« Reply #829 on: Tue, 24 March 2020, 15:59:11 »
Wait, black not being made? I really want it!
Offline konstantin
« Reply #830 on: Tue, 24 March 2020, 16:07:19 »
For what it's worth, I think black will match Taro the least. :)
Offline nuno99costa
« Reply #831 on: Tue, 24 March 2020, 16:08:11 »
Which color would match it better then :)
Sent from my GM1910 using Tapatalk
« Reply #832 on: Tue, 24 March 2020, 16:13:53 »
Not a stupid question at all. Quit a few would like to use a PCB of their choice. In terms of feature and quality, I don't see any reason not to go for the PCBs fom Maarten. If hotswap is important to you, no problem. As nuno99costa mentioned, just make sure the usb port is at the same position. Otherwise you don't need to care much. It's a top mount construction and mounting holes in the PCB are no concern, they are not used at all.
Colors:
beige, gray, black and yellow
Mentioned with RAL colors here.
There will soon be a vote regarding the three beige RAL options.
Mentioned here.
« Last Edit: Tue, 24 March 2020, 16:16:58 by PlastikSchnittstelle »
« Reply #833 on: Tue, 24 March 2020, 16:26:20 »
And sorry guys,
I didn't find the time to do more renderings today. Hopefully tomorrow.
BUT...
« Reply #834 on: Tue, 24 March 2020, 16:27:28 »
First Picture
Some of the pictures (photos) are ready! Just a few, more will be done tomorrow.
Here is just one:
Offline konstantin
« Reply #835 on: Tue, 24 March 2020, 16:42:15 »
First Picture
Here is just one:
Been waiting for this one. Gorgeous.
Offline cadrev
« Reply #836 on: Tue, 24 March 2020, 16:59:21 »
First Picture
Here is just one:
Oof this is super nice!  What keyset is this? Can't wait for the photos :D
« Reply #837 on: Tue, 24 March 2020, 17:32:38 »
That's GMK Serika by Zambumon.
More Photos tomorrrow :)
Offline rinkaan
« Reply #838 on: Tue, 24 March 2020, 18:25:22 »
Ahh I'm in Singapore... Which is why I factored in the tax... 7% tax with shipping (probably 30eurs at least) will quickly add up... Either way still more worth than expensive keycaps hahaha... (used eur since that currency of the country it is made in, deserves the respect :))
Offline ppnp253
« Reply #839 on: Tue, 24 March 2020, 18:47:30 »
Don't know if one was posted already, but is there a sound test? Or planning to have a sound test?
Offline CrazyAssMonkey
« Reply #840 on: Tue, 24 March 2020, 20:58:33 »
Oh man this looks awesome, any idea what the pricing may look like?
Offline pwade3
« Reply #841 on: Tue, 24 March 2020, 21:09:02 »
If you wanna get real wild, I bet yellow with taro could be interesting.
Otherwise, probably grey would be the safe bet.
Offline riterdando
« Reply #842 on: Wed, 25 March 2020, 04:08:59 »
Do I have to get an own Boardwalk PCB and Plate or will you offer this with the GB?
Gesendet von iPhone mit Tapatalk
Offline stoffelduss
« Reply #843 on: Wed, 25 March 2020, 06:26:23 »
Check reply #825
« Reply #844 on: Wed, 25 March 2020, 09:05:26 »
Check reply #825
Ahhh I totally missed that, I thought I read everything. Thanks for pointing it out.
Those are good looking prices.
Offline depletedvespene
    • Keyboard-related resources.
« Reply #845 on: Wed, 25 March 2020, 15:31:24 »
Okay, dumb question here: will we be able to order a specific form factor (say, TKL) and then ask for customized plates all in one go? (a clumsy git like me would really benefit from having the physical layout ready-made in the plate, so I won't end up soldering in the switches for the split spaces in the wrong order during the build, like... er... a friend... did).
Can we also order extra sets of nuts and bolts? I mean, if we can order extra plates and PCBs...
Looking forward to the GB!
« Reply #846 on: Wed, 25 March 2020, 16:14:01 »
SKB2 & GMK Taro
pwade3 offered me his GMK Taro color codes. I made some renders. Taro is very versatile. There are so many variations possible with the kits, really nice. I paired some with a gray and yellow SKB2:
« Reply #847 on: Wed, 25 March 2020, 16:36:40 »
Yes, see here.
« Reply #848 on: Wed, 25 March 2020, 16:41:06 »
The Boardwalk PCB is the only PCB that you would have to get elsewhere, MKULTRA, mentioned back here.
The plate will of course be included.
« Reply #849 on: Wed, 25 March 2020, 16:43:21 »
I'll help with custom plate files. Too early for that now though.
Extra nuts were already requested, I'll offer that.
« Last Edit: Wed, 25 March 2020, 16:49:38 by PlastikSchnittstelle »
