Author Topic: [IC] Hailey — SS 75%  (Read 52292 times)
Offline PheonixStarr
« on: Mon, 04 November 2019, 19:00:01 »
Hailey
A Stainless Steel 75%
On hold. Previously...
/) hi geekhack
Ever since I first heard the incredibly light, crisp clack of steel, I've been in love with the idea of a keyboard machined from stainless steel. After a storied, arduous development & 160 hours of renders, I'm finally ready to present Hailey, a stainless steel 75%. Its swooping lower assembly draws obvious inspiration from 159's illustrious Kepler keyboard, and a mirror-polished stainless steel finish adds an elegant touch to the piece. A delightful juxtaposition of gentle curves and hard angles, Hailey sits as a statement piece on your desktop, but still remains aesthetically neutral enough to fit most themes.
> DISCORD <
UPDATES
11/15/19 — On Renders & Prices...
yee yee renders
The price for the board has been finalized at $750... though I'm sure many of you might already know that after the recent events that transpired. The plate options are also solidified—carbon fiber, carbon fiber ISO, aluminum, brass, and POM. All are priced at $30 each. PCBs will go for $55 each. Note that the extra PCBs won't ship with a daughterboard, nor will I be carrying extras in stock at Keylace. Your Hailey kit will ship with two HERA-C boards by default.
11/11/19 — On ANSI & ISO...
Alright, so I finished the PCB. The board will support ISO (both enter and left shift). There's been a decent number of respondents on ISO options, so I will be offering a carbon fiber ISO-only plate.
11/7/19 — On Good News & Bad News...
Hey, I got some good news and some bad news. The good news is that Hailey will be priced at a much more reasonable number that is not $850. The bad news is that I have to remove the PVD option entirely.
The thing about PVD finishes is that QC'ing them is secretly the tenth circle of hell. I wouldn't be willing to accept even a tiny burr mark, and that's incredibly hard to guarantee on a workpiece of this size. I thought limiting it to ten-ish units would be feasible, but at that point we'd be paying almost twice the price just for a shiny butt. In conclusion—I can't go volume production because of QC, and I can't do limited production because of price. I've very sadly then struck PVD from the offering entirely. I promise I would really love to have it, but it's simply not the move.
Meanwhile, things developed with the Kagami finish. Turns out, my manufacturer isn't intending to polish the internals of the lower, which means the non-exposed faces will be left with a raw, machined finish. I must concede—it is very careless to sell a half-assed workpiece for a retail north of $700, but I honestly cannot devise any other solutions. I should clarify, though, that all external faces will be polished to a mirror standard, which means you won't see any of the raw texture unless you peer into the USB port.
The surfaces marked in blue, as well as the housing for the daughterboard, will be left with a raw machined finish.
This is a much cheaper alternative to polishing everything, which is both prohibitively expensive and minutely impossible in some corners.
Anecdotally, this also improves sound signature, but I'm not entirely sure how that works. Something to do with a diffuse surface vs glossy.
There is at least one more piece of good news. Engraving through CNC wasn't an option for the Kagami finish because it wouldn't be possible to polish the engraving. I realized, though, that I could just laser "Hailey" onto the rear! I've always wanted to do a laser engraving on a keyboard somewhere; I just haven't had the right keeb until now. Personally, I think the contrast of a mirrored surface against a matte engraving would look great. I'll have some renders up for that later.
Also, before I get any more questions—I am not serializing it. I'm not big on serialized boards, to be honest.
11/6/19 — On Colors and PVD...
Okay, I admittedly did not expect to update this quick, but that's my fault for pushing out a slightly rushed IC.
Big thanks to 159 as well as some others for warning me about the insane QC for PVD parts (and keyboards at large). After some deliberation, I've decided to limit the buy to 75 units of Hailey. As suggested by Rensuya, mirror-polished stainless steel will be made available as an option. Personally, I was rather surprised that this was a pretty well-received feature. In order to reduce the price tag (and also issues with polishing), I've very unfortunately decided to remove the engraving at the bottom of the board. It's on the bottom, anyway; you'll never see it. The mirror-polished Kagami finish will be priced lower than the PVD coating in a vain attempt to keep the quantity of that latter finish low. I should note, however, that there will be a limit of ten units for the PVD coating, for those who really want that shiny rose gold tone.
From lack of interest, I've dropped the Ano. "Nightingale Blue" upper and the PVD "Onyx Black" lower from the lineup. I've also modified the daughterboard cutout to keep things a little more sensical.
SPECIFICATIONS
    ‣  Aluminum 6063-T6 upper + beadblasted & anodized or electrophoretic coating finish
    ‣  Stainless steel 304L lower assembly + mirror-polished finish & a laser-engraved logotype.
           ‣  Personally, I find it quite convenient to be able to buff & polish away any scratches. This is something I do on watches and other stainless steel-made wear, so I imagine it won't be much different with a keyboard.
    ‣  Carbon fiber plate suspended in a full isolation mount, supported by custom-cut shock absorbent PORON strips.
           ‣  A brass & an aluminum plate will also be available for an added sum. It won't be much, though. And as per usual, the plate files will be made publicly available at the conclusion of the buy phase.
    ‣  An Alps EC11 rotary encoder with a click switch. Unlike the renders, knobs will be knurled on the sides. It is made of aluminum and available in silver and black.
           ‣  The encoder uses a standard 6mm D-shaped post, should you wish to use your own rotary knob.
    ‣  Custom "May" PCB; with an ARM STM32 chip, ESD & overcurrent protection, and the HERA-C daughterboard.
           ‣  Keylace will offer, for as cheap as possible, extra May PCBs & Hailey-type HERA-C daughterboards in case yours goes yoink. Each Hailey will ship with two HERA-Cs.
           ‣  Please note, also, that I design in the 19mm spacing.
    ‣  Two adhesive-backed silicone rubber feet, custom-cut
    ‣  5.5° typing angle
I'll be running Hailey as an FCFS GB through my site Keylace.co, which will soon be launching to carry Cygnus. Mid-December, three prototype units will be shown and sent out to streams.
SALES
Price — $750. Add plates for $30, add PCB for $55.
Quantity — I am still oscillating on this matter. Currently, the board has a 75 unit limit. At 100, the Cost of Goods for the board itself goes down, and if this is the case, I would very much like to use this extra overhead to focus on better presentation, packaging, and fine-tune the board at large (essentially, instead of reducing the price, I offer a better product than budget would've otherwise allowed).
Shipping — USPS.
Lead Time — Three months, give or take. I should note that the shipping phase won't take long, as I have about half a dozen people assigned to packaging & logistics.
IC FORM
RENDERS
Note: the renders are representative, and while I try to show what I want to sell, they are not 100% indicative of final colors, finishes, or other product options.
Please be aware that the ano. "Nightingale Blue" Upper & rose gold/black PVD Lowers are no longer offered. Additionally, contrary to renders, the stock knobs will be knurled on the sides. I'll have more renders posted soon to reflect the changes.
SPECIAL THANKS
...to 159 for providing early feedback, the Kepler TKL, & saving me from the sheer hell of QC'ing a hundred PVD parts;
...to Rensuya & senter for suggesting the Kagami mirror-polished stainless steel finish;
...to driftingbunnies for consultation on sale quantities and the "Hailey" engraving;
...to enome for reminding me to make a Discord server and being an excellent wall to which I could bounce ideas off, as well as an amazing source of support;
...to mrpetrov for also being an excellent wall;
...and to you for reading, especially if you left a comment :)
« Last Edit: Thu, 12 December 2019, 19:53:32 by PheonixStarr »
Offline mrpetrov
Re: [IC] Hailey — A Stainless Steel 75%
« Reply #1 on: Mon, 04 November 2019, 19:03:32 »
Very intrigued.
It’s like the love child of a Kepler and a Satisfaction75, which I mean as a massive compliment!
Planning a proto?
Also, I think I recall those long bumpon strips being a bit prone to peeling off over time, but I could be mistaken.
« Last Edit: Mon, 04 November 2019, 23:09:18 by mrpetrov »
Offline Monday.io
« Reply #2 on: Mon, 04 November 2019, 19:04:17 »
Id buy it 100%
Offline mydens
« Reply #3 on: Mon, 04 November 2019, 19:05:41 »
Why not stainless steel on top? its the best thing about the board and your hiding it.
Offline Steezus
  • Keeper of Facts
« Reply #4 on: Mon, 04 November 2019, 19:08:19 »
Very interesting board. I really enjoy the look and the rotary encoder. How much cheaper would it be to run with an aluminum lower assembly? It seems like a lot more machining is involved to produce the lower assembly. Other than added weight, I personally don't see a need to go with stainless steel given the added costs.
Offline chriszhu
  • (* ̄(エ) ̄*)''
« Reply #5 on: Mon, 04 November 2019, 19:11:01 »
Ohhhh, looks interesting!
Offline Quinella
« Reply #6 on: Mon, 04 November 2019, 19:14:40 »
Failed No Nut November to Hailey.
Offline Robosculpts
« Reply #7 on: Mon, 04 November 2019, 19:18:35 »
YES!!!!!! I was seriously thinking about the 7V but instead of a logo put a rotary encoder! I really like how it looks like it's floating from the side shot. I'm all in for this.
Offline 002 DC
« Reply #8 on: Mon, 04 November 2019, 19:25:47 »
 :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek:
when
Offline senter
« Reply #9 on: Mon, 04 November 2019, 19:27:16 »
I'm glad to see another stainless steel custom coming out. Why PVD finish on the steel tho?
PVD brass is commonly used in the community. Steel is almost the same heavy as brass and it looks exactly the same as well when both are PVDed.
It's would be a shame when you bring something new but it doesn't seem like so.
I agree with Norbauer's take on naked stainless steel. The look is unique and the maintainability is a great feature. You can read his full comments here
Offline NoxNoxNox
« Reply #10 on: Mon, 04 November 2019, 19:27:28 »
Oh this is up my alley.
Offline naked_and_jameson
« Reply #11 on: Mon, 04 November 2019, 19:28:39 »
I don't know if it's just me, but it seems like the IC form link isn't working.
Offline ilemondrop
« Reply #12 on: Mon, 04 November 2019, 19:31:48 »
This looks amazing, like probably one of the nicest boards I've seen during my 4 months in the hobby so far. I'm definitely in the wrong tax bracket for this board, I'd be open for a full body aluminum for the broke bois like me.
« Reply #13 on: Mon, 04 November 2019, 19:32:54 »
hi I fixed the ic form sorry for being DUMB
Offline zekkin
  • my entire life was unlimited zekk works
« Reply #14 on: Mon, 04 November 2019, 19:41:16 »
I do not think an unlimited buy for something involving something so painfully QC involved as PVD should be an unlimited group buy. I would recommend you set a hard limit to preserve the quality of the keyboard as well as your personal sanity.
Offline ptiede
« Reply #15 on: Mon, 04 November 2019, 19:46:29 »
I am definitely considering this. Although I do have a kepler on the way :p
Offline ab042896
« Reply #16 on: Mon, 04 November 2019, 20:35:15 »
POM plate sounds interesting. Also if going with PVD on the steel, why such limited choice on the colours?
Offline SlurmsMacKenzie
« Reply #17 on: Mon, 04 November 2019, 20:36:23 »
This looks like an awesome keyboard.  How might an all stainless steel base compare with an all brass like Kepler vs an aluminum base? I assume the sound and possibly the feel would be different, but anyway to describe the difference? Thanks
« Reply #18 on: Mon, 04 November 2019, 20:48:01 »
Planning a proto?
Oh, yeah, for sure. Three prototypes will be produced (two to be sold off at discount, by the way) and shown.
You may be right, yeah. I might have to cap Hailey to 50 units or less, considering the PVD. I heard it's pretty insane getting the coating flawless on workpieces like the lower.
PVD is expensive, bro
Hailey's SS lower is mostly an exercise in acoustics; the sound of brass is quite dark and dead, as brass isolates the sound signature to just the switches. Aluminum is pretty light and hollow in my opinion (although excellent case design can make it thocky). In any case, Hailey isn't looking for a thock as much as a super light, crisp "clack," if that makes any sense.
« Reply #19 on: Mon, 04 November 2019, 21:06:05 »
Planning a proto?
Sure, makes sense. I appreciate the reply.  I'm in the market for a 75%, will definitely keep an eye out for this one.  I love how you designed the cut out on side of the top half to allow the weight to peek out. Looks really nice.
Offline Robosculpts
« Reply #20 on: Mon, 04 November 2019, 21:07:09 »
Will there be any other options for the bottom piece other than PVD? I ask because I can guarantee I won't be one of the first 50.
Offline IOVERCALLHISTIOCYTES
« Reply #21 on: Mon, 04 November 2019, 21:13:42 »
Great board.
Is that GMK lux or a set of similar nature?
« Reply #22 on: Mon, 04 November 2019, 21:14:42 »
Considering the QC needed, I'm thinking of limiting the PVD and instead running Hailey with a mirror-polished SS304 lower, which seemed surprisingly popular when I asked around.
Offline Robosculpts
« Reply #23 on: Mon, 04 November 2019, 21:16:23 »
YES!!!! Thank you, kindly!
Offline Rensuya
  • Blue is my spirit animal
    • Link to the discord!
« Reply #24 on: Mon, 04 November 2019, 22:00:48 »
This board looks absolutely amazing, I cannot wait for updates!  :thumb:
Offline rondg
« Reply #25 on: Mon, 04 November 2019, 22:22:34 »
I know the whole theme of the board is it's made of stainless steel, but I hope you consider aluminum on succeeding runs. I am too poor for this :(
Good luck with this one!
Offline 002 DC
« Reply #26 on: Tue, 05 November 2019, 01:40:36 »
any discord servers for updates/bouncing ideas???
Offline Butterbeer
« Reply #27 on: Tue, 05 November 2019, 03:01:29 »
If steel is the big selling point then focus on the mirror option would be a good move. As much as I want that Rose Gold, seeing it on two different metals might not work.
I love the idea of a polished Stainless Steel Mirror bottom and if you could add a matching stainless steel top that would be awesome.
The Iron 65 Founders Edition offered a Stainless steel top shell, available in E-white or E-black. I think both would look great when paired with a stainless steel mirror bottom.
Offline Datastream
« Reply #28 on: Tue, 05 November 2019, 03:27:04 »
Very sexy looking board with every button in the right place but too expensive for my taste. Gonna be a pass from me.
Offline voxkey
« Reply #29 on: Tue, 05 November 2019, 07:45:06 »
Looking good!
Offline Obamas Mama
« Reply #30 on: Tue, 05 November 2019, 10:15:50 »
Might have to sell everything I own for this
Offline gasp
  • Formerly 'boop' (NTBCW Booper)
    • none
« Reply #31 on: Tue, 05 November 2019, 11:58:06 »
Absolutely love the look and idea of this board, in love with the potential pvd coated bottom. Price tag is for sure large, but I'm sure justified by the material used. I'll be keeping an eye on this for sure.
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
« Reply #32 on: Tue, 05 November 2019, 13:49:16 »
Does the knob got click action like analog sticks on a console controller?
Offline Genn
« Reply #33 on: Tue, 05 November 2019, 17:41:33 »
I love the overall design, but I can't get behind the idea of a rotary encoder simply because I feel a round cut clashes too much with the overall look of a keyboard. Any chance there could be a different top piece, without the rotary encoder?
Offline dumpling420
« Reply #34 on: Tue, 05 November 2019, 18:16:25 »
I really dig the board but like others have said I think it's way too expensive for me. I would honestly buy this if it was cheaper and made of aluminium, I don't really consider the material to be that big of a selling point, I think that the looks + the rotary encoder are enough to make this board stand out.
Offline breckstar
« Reply #35 on: Tue, 05 November 2019, 18:27:03 »
between this and cygnus is a toss up. i want both.
Offline hottrout
  • I'd Hit Dat Key
« Reply #36 on: Wed, 06 November 2019, 03:24:04 »
Nice board.  Love the rotary.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline Kevadu
« Reply #37 on: Wed, 06 November 2019, 16:04:42 »
I told myself I was going to stop buying keyboards...why did you have to make this beautiful thing?
Offline Vigrith
« Reply #38 on: Wed, 06 November 2019, 18:36:38 »
Lovely design, gonna cost way more than I feel comfortable paying for keyboards though - will be on the lookout for further iterations with alternate materials. Good luck!
« Reply #39 on: Wed, 06 November 2019, 22:34:11 »
ye
ye
... I hope you consider aluminum on succeeding runs.
... will be on the lookout for further iterations with alternate materials.
ye
Re: [IC] Hailey — SS 75% | PRICE DROP, NEW OFFERINGS, DISCORD SRVR.
« Reply #40 on: Thu, 07 November 2019, 00:26:47 »
I think it would be nice if there were some branding somewhere on the board, even if subtle or not immediately visible. Establish your brand!  My personal opinion is that it makes a difference, people pay a lot of money for labels on their clothes that no one can see also.
You mentioned that engraving will be difficult with the mirror polish, but what about something like the Keycult No. 2 stainless?  I'm not sure what method he used to put the logo on the bottom, maybe it's more practical?
Or maybe alternately (or in addition) you could offer an artisan encoder knob with your logo on it.
Edit: man, looking at the mirror finish on the Keycult No 2 stainless... It's gonna be beautiful on your board.
« Last Edit: Thu, 07 November 2019, 00:31:23 by SlurmsMacKenzie »
Offline enome
« Reply #41 on: Thu, 07 November 2019, 01:17:42 »
my heart fluttered by the pure awe of Hailey
i need to give this girl my number
my credit card number
Offline hottrout
  • I'd Hit Dat Key
« Reply #42 on: Thu, 07 November 2019, 05:18:29 »
Do you think ISO would be an option?
Systems -
  Keyboards -
Offline Robosculpts
« Reply #43 on: Thu, 07 November 2019, 06:59:15 »
I think the PVD black bottom is an excellent choice for the bottom color. Here's hoping that color will make a comeback.
Edit: A Skeletor purple E-coat top would be hella dope. just sayin'
« Last Edit: Thu, 07 November 2019, 08:40:54 by Robosculpts »
Offline Banzai
« Reply #44 on: Thu, 07 November 2019, 16:12:02 »
Ooof, I can make no guarantee I would buy it. But if you can keep the price in the $700 ballpark, I can't say for sure willpower will prevent me from owning this. I think you're building my dream board.
Offline ab042896
« Reply #45 on: Thu, 07 November 2019, 16:17:57 »
Do you have a rear facing render? The bottom looks nice, I'm curious to see how it looks from behind  ;)
Offline CF73
Re: [IC] Hailey — SS 75% | some good news, some bad news
« Reply #46 on: Fri, 08 November 2019, 01:51:46 »
can't wait for the typing sound test of the protos
Offline Iksion
« Reply #47 on: Fri, 08 November 2019, 13:04:28 »
Interested :thumb:
KBD75v1 | Kira | Melody96 | TX75v2 | TX-CP | hbcp | Keycult No.2 rev.1 | NK65 | Duck Octagon v3 | Percent Volt | TX65v2 | KY-01 | Sunsetter | Mr. Suit | J-01 | Dolphin 2021 | Phase One 65 | KBD8x Mark ii
Offline DukeEsquire
« Reply #48 on: Fri, 08 November 2019, 13:42:03 »
If the idea is that that stainless steel can be polished over time to maintain the look, does it makes sense to have laser engraving on the bottom? Wouldn't that make polishing difficult in the future?
Offline Araex
« Reply #49 on: Fri, 08 November 2019, 14:11:01 »
Finally someone is giving 75% the thicc bezel it deserves. Interested.
